Playing music files from external hard drive on OPPO 93 - AVS Forum | Home Theater Discussions And Reviews
Old 05-04-2013, 04:06 PM - Thread Starter
atomicthunk's Avatar
I have been trying to play music files using the USB input. The only problem I am having is that every now and then, the music pauses( less than a half second) and it almost sounds like a skip on a cd. I know the source files are good. Is there a limit to size of hard drive that can be used? The drive I am using is 200GB IDE drive in an external case. Would this work better with a faster SATA drive? The files I am playing are in folders with the album name and the songs are in the FLAC format. Has anyone had the same issue and if so were you able to find a solution? t. Any other other ideas? Thanks.
atomicthunk is offline
Old 05-05-2013, 06:28 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2701 Post(s)
Liked: 1925
Welcome to AVSForum.
Please post this sort of question in the BDP-93 owners thread: http://www.avsforum.com/t/1291855/official-oppo-bdp-93-owners-thread
Maximum HD size on the -93 is 2TB. USB is fast enough.
Have you tried different devices? As a test, I would try a thumb drive, which are usually trouble free (although they do fail from time to time).
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
Oppo Bdp 93 Blu Ray Player
