Panasonic Player does not turn on - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-05-2013, 08:38 PM - Thread Starter
tguil's Avatar
I recently turned off my player while it was updating. It seemed to be hanging so I figured if I turned it off then on again it would be fine. Now, It doesn't respond to anything. Is there a way to do a factory reset of the machine or am I out of luck?
tguil is offline
post #2 of 3 Old 05-05-2013, 09:59 PM
Super Moderator
teachsac's Avatar
Quoted: 650 Post(s)
Liked: 950
Welcome to AVS. Please post in the thread for your player. Reset procedures are in the owner's manual in the troubleshooting section.
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #3 of 3 Old 05-06-2013, 09:39 AM
BillP's Avatar
Quoted: 258 Post(s)
Liked: 201
Unfortunately, that is a great way to brick your player. Check your manual to see how to do a factory reset. Also try contacting Panasonic customer service.
BillP is online now
Reply Blu-ray Players
Panasonic
