Can't enter letters on Panasonic DMP-210 - AVS | Home Theater Discussions And Reviews
post #1 of 3 Old 06-20-2013, 11:25 AM - Thread Starter
kazuba's Avatar
I'm trying to log into Netflix on my Panny DMP-210, but the remote will only let me enter numbers. For example, the "2" key also has "a, b, c" on it. On most keypads, to enter "b" you would should just hit the "2" key three times, but the only thing it will do is enter "2" three separate times. Couldn't find anything in the manual. What am I doing wrong? Thanks.
kazuba is offline
post #2 of 3 Old 06-20-2013, 12:38 PM - Thread Starter
kazuba's Avatar
Found a post that says to hit 'OK' when you're in the window to enter your e-mail address. Should bring up a virtual keyboard. I'll give it a try.
kazuba is offline
post #3 of 3 Old 06-22-2013, 05:34 PM
craftydevil's Avatar
Having the exact same problem. Hitting OK in the email box worked! Virtual keyboard popped up. thanks!
craftydevil is offline
Reply Blu-ray Players
Panasonic 3d Blu Ray Player Dmp Bdt210
Gear in this thread - Bdt210 by PriceGrabber.com
