Blu Ray settings - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 06-23-2013, 10:08 PM - Thread Starter
mcarciero's Avatar
Need opinion for best sound.
I have
Denon AVR 1613
5.1 surround speakers
Lg Blu ray player
HDMI connection
I was playing with the audio settings in the blu ray player and came across the following choices
HDMI ( PCM Stereo, PCM Multi-CH, DTS Re-encode, Primary Pass- Thru)
Digital Output ( PCM Stereo, DTS Re-Encode, Primary Pass- Thru)
Sampling Freq: (48 kHz, 96 KHz, 192KHZ)
Im trying to play Iron Man 2 on Blu Ray and I don't see DTS master , Dolby True HD, Dolby Digital
What settings should I use?
mcarciero is offline
post #2 of 9 Old 06-24-2013, 06:13 AM
Super Moderator
teachsac's Avatar
Quoted: 650 Post(s)
Liked: 954
You might try asking in the player thread. Bitstream (Primary Pass-Thru).
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #3 of 9 Old 06-24-2013, 12:40 PM - Thread Starter
mcarciero's Avatar
Originally Posted by teachsac View Post
You might try asking in the thread Bitstream (Primary Pass-Thru).
S~
I cant find that thread!
post #4 of 9 Old 06-24-2013, 03:14 PM
Super Moderator
teachsac's Avatar
Quoted: 650 Post(s)
Liked: 954
What player do you have. If you want you receiver to do the decoding, player should be set to pass-thru or bitstream. Secondary audio should be off.
S~
teachsac is offline
post #5 of 9 Old 06-24-2013, 08:27 PM - Thread Starter
mcarciero's Avatar
S~
I have an LG Blu-ray player.
I don't know if I want the receiver doing the decoding. Whats better?
post #6 of 9 Old 06-25-2013, 06:19 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
If you want to see the DTS-HD light turn on at your receiver, you need to let the receiver do the decoding. Either way is fine. There is no difference. But in order to let receiver decode, you must setup player to bitstream (which most don't out of box). As mentioned above, you need to select HDMI audio to primary passthrough and turn off secondary audio.
Foxbat121 is online now
post #7 of 9 Old 06-28-2013, 08:34 AM - Thread Starter
mcarciero's Avatar
How do I turn off secondary Audio?
These are the options my player has
post #8 of 9 Old 06-28-2013, 09:14 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
Sorry, I don't have LG player. You need to ask your question in LG player owner's thread.
post #9 of 9 Old 06-28-2013, 09:46 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
If memory serves, LG players don't have a secondary audio setting. Primary Pass-thru means secondary audio is turned off.
When you play a dts-MA or TrueHD track, what does your receiver report about the type of audio it is getting?
BIslander is offline
Reply Blu-ray Players
Denon Avr 1613 Receiver
