One-and-Only PS4 as Blu-Ray Player Thread - Page 6 - AVS Forum
 5Likes
post #151 of 179 Old 05-20-2014, 05:33 PM
AncientAlien's Avatar
Never used my PS4 for Blu-Ray until the other day. I have always used my Panasonic BDT-230. Recently I've noticed some strange artifacts on images and credits on the BDT-230 with DVDs and Blu-Ray but movie was fine. Sound from a few Blu-Ray titles was lacking in overall "punchiness" as well. Star Trek into darkness was terrible sounding, as far as loudness and punch goes so I put it in the PS4. I usually set to bitstream so I can see the logo/icon of DTS-MA/DDTrue HD on my receiver.
On the PS4 Star Trek definitely sounded more full and punchy vs. my standalone player. Once I set to PCM I was amazed at the difference in output and overall clarity. PCM sounded better. Star Trek is DD true hd. I then put in thor 2 which has dts ma track and pcm sounded inferior. Any insight? Also, the artifacts were gone on the ps4.
AncientAlien is offline
post #152 of 179 Old 05-20-2014, 08:15 PM
helvetica bold's Avatar
Quoted: 39 Post(s)
Liked: 59
Anyone have the Sony 6200 BluRay player? If so how much better is it than the PS4 or PS3 as a player?
bth24 likes this.
helvetica bold is online now
post #153 of 179 Old 05-21-2014, 04:43 AM
mdavej's Avatar
Quoted: 213 Post(s)
Liked: 321
You can use a remote, play 3D, and it's cheap, quiet and efficient.
mdavej is offline
post #154 of 179 Old 05-21-2014, 12:13 PM
Quoted: 39 Post(s)
Liked: 59
Thats great but is the image quality better?
post #155 of 179 Old 05-21-2014, 01:44 PM
mdavej's Avatar
Quoted: 213 Post(s)
Liked: 321
Probably not. All Sony's have sub-par upconversion IMO. Unless you like artificial enhancement, you're not going to see any difference in BD.
mdavej is offline
post #156 of 179 Old 05-22-2014, 03:30 PM
saprano's Avatar
Quoted: 95 Post(s)
Liked: 248
Well it does have an 8 core processor to its advantage. Just like the PS3.
home theater addict
saprano is offline
post #157 of 179 Old 05-24-2014, 10:01 PM
Had this issue a while back, (PS4 Shutting off).
I was watching T2:Skynet Edition Blu-Ray and after about 10 minutes the PS4 shut off. Actually took a while to turn back on. Went through the reboot and started where I left off. After about 10 minutes, it shut off again. I had to unplug to get it to turn back on. What's happening here? Could this be the auto shut off? I haven't watched a blu ray before tonight. It did also happen before on a game. I complain for a replacement will it be new or refurbished?
post #158 of 179 Old 05-25-2014, 04:45 PM
Quoted: 39 Post(s)
Liked: 59
I finally picked up the Sony 6200 BluRay player. First impressions it does seem better the the Ps4. I watched Star Trek into darkness in 3D and was blown away. Colors looked amazing due to the higher bit depth and overall the PQ looked flawless.
post #159 of 179 Old 05-26-2014, 06:15 AM
saprano's Avatar
Quoted: 95 Post(s)
Liked: 248
Make sure noise reduction is turned off in the PS4.
home theater addict
saprano is offline
post #160 of 179 Old 06-07-2014, 09:08 AM
PlasmaPZ80U's Avatar
Quoted: 79 Post(s)
Liked: 197
I noticed Netflix now always outputs 5.1 audio as PCM 5.1 and not DD+ 5.1 (regardless of whether the audio priority is Linear PCM, Bitstream (DD), or Bitstream (DTS)). I think the latest update did this. However, it does seems PCM 5.1 is working right now.
PlasmaPZ80U is online now
post #161 of 179 Old 06-07-2014, 05:02 PM
roadwarrior980's Avatar
The app recently updated and at first mine did this too.
What I did was go to the main menu and manually close the app (hover over it then select menu on the remote).
When you restart it it should allow DD + 5.1.
Mine had this issue and I thought it was a netflix network issue. I guess they and fios are not on good terms
"To sin by silence when we should protest makes cowards out of men."
Operation Iraqi Freedom Campaign Veteran, 06-08.
Operation Iraqi Freedom Campaign Veteran, 09-10.
Operation Enduring Freedom Campaign Veteran, 12-13.
roadwarrior980 is offline
post #162 of 179 Old 06-08-2014, 05:32 PM
MagnoliaMOE's Avatar
I just checked the Netflix app on the PS4 and I had to change the priority to Dolby Digital in the menu in order to Dolby Digital Plus bitstreamed to the AV-8801. I closed out the app and restarted too.
MagMo
Elite 70" (PRO70X5FD), Oppo BDP-105, Marantz AV-8801, Marantz MM-7055, PS4, PS3 (Fatty SACD), MartinLogan Theos, MartinLogan Stage, MartinLogan Montage, MartinLogan Descent-i
MagnoliaMOE is offline
post #163 of 179 Old 06-08-2014, 07:47 PM
ScratchFury's Avatar
I was helping a friend calibrate his Sony 65W850A with the Disney WOW Blu-ray and found the PS4 wouldn't produce the correct Ideal White and had a delay in audio sync when compared with a PS3. I'm going to see if he'll let me borrow his PS4 to test it on my TV to see if it's a specific interaction or if the PS4 has an issue. Anyone else seen this?
ScratchFury is offline
post #164 of 179 Old 06-09-2014, 12:35 PM
Quoted: 79 Post(s)
Liked: 197
I did both suggestions and it worked. Not sure whether the audio priority setting was the reason though.
post #165 of 179 Old 06-09-2014, 12:39 PM
Quoted: 79 Post(s)
Liked: 197
don't know about audio sync but my Samsung PN51F5300 Plasma TV calibrates identically on both my PS3 and PS4. Including passing WTW and BTB and outputting video levels
I use YCbCr on the PS3 (not RGB) for DVDs/BDs and YCbCr is the only kind of output on the PS4 for DVDs/BDs (you can't output RGB while playing DVDs/BDs). Of course, PS4 game discs don't count when I say DVDs/BDs.
post #166 of 179 Old 07-05-2014, 06:31 PM
porks27's Avatar
i also have a sony 65w850a and had audio synch troubles with my ps4 and ps3.
I turned off the "output at 1080p/24Hz" setting on both ps3 and ps4 and that seemed to fix the audio synch issues.
Not sure why it wasnt working still need to sort it out. Supposedly my yamaha amp and tv should accept the 24hz signal.
porks27 is offline
post #167 of 179 Old 07-05-2014, 08:02 PM
aftcomet's Avatar
Quoted: 40 Post(s)
My fiancé has a Netflix account and since she's overseas she's letting me use it here.
A little off topic but this statement just sounds weird. Maybe I'm too young but I would expect someone's fiance to let their S.O. use their $7.99 Netflix account ANY time.
aftcomet is offline
post #168 of 179 Old 07-06-2014, 10:53 AM
Yea, it's probably just you being too young and it sounding weird
post #169 of 179 Old 07-24-2014, 01:26 AM
rupedogg24's Avatar
PS4 finally gets 3d blu-ray support next week!
I watch a lot of 3d with my family and this is the update I've been waiting for. Already love the PS4 bluray performance and can't wait to see how it handles 3D.
http://www.psu.com/a024092/PS4-syste...lu-Ray-support
Samsung 64' F8500
Onkyo NR809 (Main)
PS4
Samsung BD5900
7.2 System with Cambridge Soundworks MC300IW (left, center,right)/Monoprice 8inch in-wall speakers(wides), JBL AESS5-WH (surround)
Cambridge Soundworks Base Cube 15' Sub
Bic 12' Subwoofer
rupedogg24 is online now
post #170 of 179 Old 07-24-2014, 01:55 AM
HD KOOL-AID's Avatar
That's good news was waiting for 3d support myself. Sony does not want Microsoft to beat them on the 3d support great for PS4 owners.
HD KOOL-AID is online now
post #171 of 179 Old 07-24-2014, 02:18 AM
theskins44's Avatar
NICE,can't wait to compare it to 3d on ps3....I been thinking of trying a new 3d player to compare to the ps3. I already have ps4
theskins44 is offline
post #172 of 179 Old 07-24-2014, 02:24 AM
theskins44's Avatar
I should add,I didn't see any difference in PQ between ps3 and ps4 in 2d bluray
post #173 of 179 Old 07-30-2014, 08:34 PM
Thumbs up
The 3d support update is up. 1.75 194 MB
post #174 of 179 Old 07-30-2014, 08:47 PM
Having some Netflix issues with ps4. Dolby digital plus movie says pcm on my receiver. Had to delete and re-install twice to fix it but now everything is is pcm and no dd+.
post #175 of 179 Old 07-31-2014, 07:14 AM
rupedogg24's Avatar
Has anyone noticed a noticeable lag in video and audio lip sync after firmware 1.75? I tested Into the darkness last night and found that the video was lagging behind the sound no matter what I did. I tested several other discs and the results were the same. In my standalone BD player no lag whatsoever.
Samsung 64' F8500
Onkyo NR809 (Main)
PS4
Samsung BD5900
Bic 12' Subwoofer
post #176 of 179 Old 08-01-2014, 07:42 AM
CheYC's Avatar
Quoted: 12 Post(s)
Liked: 50
Any word on the performance of 3D? Vs. PS3 or other standalones?
CheYC is online now
post #177 of 179 Old 08-02-2014, 11:07 AM
gadgtfreek's Avatar
Quoted: 78 Post(s)
Liked: 306
IIRC, apps like Vudu on the PS3 actually output RGB because Sony treated apps as games. Does the PS4 still output RGB on this type of stuff?
65" VT50 / BDT460
X4000 / Outlaw Model 7125
Klipsch RF82 II and RC62 II / Hsu VTF-15H (2)
Directv HR44-200 / HR24-500
gadgtfreek is online now
post #178 of 179 Old 08-02-2014, 11:12 AM
gadgtfreek's Avatar
Quoted: 78 Post(s)
Liked: 306
Nevermind, found a post from april that confirms the app are still RGB.
65" VT50 / BDT460
post #179 of 179 Old 08-09-2014, 05:20 PM
Abupa's Avatar
Ps4 audio quality?
Hello,
My setup: cm1's stereo (later cm9) classe cap 151 and ps4.
When watching movies and series on dvd, the sound is good, detailled.
But how does this compare to something like the Marantz ud7007? When watching series, the sound tends to be a bit thin, and not 100% harmonic. I'd like a bit warmer sound for instance and more harmonic.
Does an upgrade like this help take off the edge?
Abupa is online now
Reply Blu-ray Players
Playstation 4 Console
User Tag List
