Official OPPO BDP-103D (Darbee Edition) Owner's Thread - Page 152 - AVS Forum | Home Theater Discussions And Reviews
 618Likes
post #4531 of 9179 Old 06-28-2014, 12:39 PM
bluer101's Avatar
Quoted: 327 Post(s)
Liked: 248
I have been using for years Netgear powerline hd adapters. They work perfect without running wires all over the house.
bluer101 is online now
post #4532 of 9179 Old 06-28-2014, 03:53 PM
David Susilo's Avatar
Quoted: 612 Post(s)
Liked: 579
I still can't get the crosstalk to disappear when watching 3D movies.
Using my PT-AE7000 set screen size to 140" and Pioneer BDP-62 3D set to "on" (there is no TV size adjustment on the BDP-62) there is hardly any crosstalk.
However when connected to Oppo BDP-103D the crosstalk is unbearable. I tried various the screen size setting on the player but the crosstalk remains insanely high.
Any help is appreciated. Thank you.
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED & WifiHifi Magazines
my (yet to be completed) BD list
my home theatre
David Susilo is offline
post #4533 of 9179 Old 06-28-2014, 04:44 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2127 Post(s)
Liked: 2689
^ The Screen Size setting has nothing to do with Crosstalk. You are talking about the image intended for one eye penetrating the shutter glasses and being viewed by the other eye. The player only sends out one image for each eye -- they aren't mixed. And there's no settings mistake you can make which will CAUSE them to be mixed.
Crosstalk is almost always due to a problem in the setup of the Display itself or its control of the shutter glasses.
However, if you feel you've exhausted all options in fixing the Display setup there are only a couple other things you can try.
1) Take the OPPO to a friend's house or store and connect it to a different 3D display and see if the same thing happens
2) Send the player to OPPO to be checked out.
When testing this, keep all Picture Adjustment settings in the OPPO at their factory default (0) values. You could also try setting 3D Output to FORCED in the OPPO in case your Display is having trouble recognizing the input as 3D video.
You could try re-installing the OPPO firmware, followed by a Reset Factory Defaults but I'd be surprised if that changed what you are seeing.
--Bob
David Susilo likes this.
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #4534 of 9179 Old 06-28-2014, 04:56 PM
Quoted: 612 Post(s)
Liked: 579
Thank you, Bob! I'll try everything you mentioned above.
my home theatre
post #4535 of 9179 Old 06-28-2014, 06:13 PM
Read the FAQ!
Liked: 2689
^ David, there's one other thing I'd like you to try. I'm assuming you are using the HDMI 1 output of the OPPO for video. (Double check that you haven't confused which OPPO socket you are plugged into for that cable.)
The default setting for HDMI Options > HDMI 1 Color Space is AUTO. Try changing that to YCbCr 4:4:4
If *THAT* cures your problem, go back to AUTO (which should make the problem come back) and see if you can find a status screen on your Display that says what format of video is coming into the Display. If it happens to be RGB instead of YCbCr, I think I may know what's going on here.
--Bob
post #4536 of 9179 Old 06-28-2014, 06:24 PM
Quoted: 612 Post(s)
Liked: 579
My output is at 4:4:4 30-bit dithered. The projector also sees the input accordingly. Weird
my home theatre
post #4537 of 9179 Old 06-28-2014, 06:32 PM
Read the FAQ!
Liked: 2689
^ Oh well. There's a bug with RGB Video Level and Source Direct on the 103D and 105D that I thought might be related to your problem (because 3D output is treated rather like Source Direct). But if the OPPO is already sending YCbCr 4:4:4 then that can't be it. Back to the suggestions in my prior post.
--Bob
post #4538 of 9179 Old 06-29-2014, 11:36 AM
hatlesschimp's Avatar
Quoted: 414 Post(s)
Liked: 403
I got a problem.
I put a blu-ray in the drive and I watched the movie then when I opened the draw there was no disc and the draw only opened half way then shut again. I cant get the disc out at all or the drive fully open????
hatlesschimp is online now
post #4539 of 9179 Old 06-29-2014, 12:17 PM
Smarty-pants's Avatar
Quoted: 711 Post(s)
Liked: 582
^ Is it a rental disc? It probably has some sticky residue on the top of the disc that is making it stick to the drive hardware.
With the tray closed, try lightly smacking the top of the player and see it the disc will nudge loose in the player.
Then open it and see if the disc will come out.
Smarty-pants is offline
post #4540 of 9179 Old 06-29-2014, 02:47 PM
TorTorden's Avatar
Quoted: 108 Post(s)
Liked: 149
Originally Posted by jedi29 View Post
Yes , all 4 ports are taken on my router !!
The wireless cards they put in non computer stuff isn`t that great , IMO !!
Later ,
G. 
Wifi cards aren't that great in computers either, they just have more raw porcessor power available for error correction and often older protocolls with more error correction implemented.
As for maxing out your ports on your router, or why they don't make routers with more ports is because its more flexible and cost saving to use switches for this task.
For most AV gear 100Mb/s switches are fine, but for wired desktops I would go with Gigabit/s.
For example probably any if these would work fine http://www.amazon.com/s/ref=nb_sb_no...twork%20switch
Should also be readily available in any store selling computer or networking gear as well.
TorTorden is offline
post #4541 of 9179 Old 06-30-2014, 03:34 PM
They_call_me_Roto's Avatar
Quoted: 252 Post(s)
Liked: 179
Oppo BDP-103D
Got one. Love it. Use this just for movies and the streaming services.
Packing a lot of sound into a small room.
268 square feet/2144 cubic feet
7.2 surround sound.
They_call_me_Roto is offline
post #4542 of 9179 Old 06-30-2014, 05:41 PM
elphillips's Avatar
Quoted: 259 Post(s)
Liked: 184
Old hookup question I'm sure. My 103D will have the video connected direct to the display. Which is the best, or preferred, audio connection to a pre/pro or receiver? HDMI or the set of analog connections?
elphillips is online now
post #4543 of 9179 Old 06-30-2014, 05:55 PM
Read the FAQ!
Liked: 2689
^ HDMI.
--Bob
post #4544 of 9179 Old 06-30-2014, 05:58 PM
elphillips's Avatar
Quoted: 259 Post(s)
Liked: 184
^ Thank you for your prompt reply and all of your help here on the forum.
post #4545 of 9179 Old 06-30-2014, 11:26 PM
rhale64L7's Avatar
Quoted: 823 Post(s)
Liked: 322
I have a quick question. Does the 103d playback both dsd formats like the 105d? Or is it limited like the 105? Thanx for any help
JVC RS4810 projector Stewart Cima 115" 2.35 screen, ATI 523 and 528 amps
7 mirror imaged 2 way DIY monitors. All matched to within 1db. All parts matched, 1 SVS SB16 ultra subwoofer
Emotiva XMC-1 processor Marantz UD5007 Bluray player
Furman sequencer ran off of a double 50amp breaker,Furman power conditioner
All in a dedicated 15x22x8 foot dedicated home theater.
rhale64L7 is online now
post #4546 of 9179 Old 06-30-2014, 11:40 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
^ Do you mean DSD64 and DSD128? If so, only the 105D supports those two DSD formats thru its usb dac input, which the 103D does not have.
DanF8500 is offline
post #4547 of 9179 Old 06-30-2014, 11:42 PM
rhale64L7's Avatar
Quoted: 823 Post(s)
Liked: 322
Yes thats what I was talking about. Thank you for the very quick reply. Even late like this. You folks simply amaze me.
post #4548 of 9179 Old 06-30-2014, 11:43 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
^West coaster...
DanF8500 is offline
post #4549 of 9179 Old 06-30-2014, 11:43 PM
rhale64L7's Avatar
Quoted: 823 Post(s)
Liked: 322
Now can I stream dsd through the 103d?
post #4550 of 9179 Old 06-30-2014, 11:44 PM
rhale64L7's Avatar
Quoted: 823 Post(s)
Liked: 322
Ahh that explains it.
post #4551 of 9179 Old 06-30-2014, 11:51 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
Yes, you can. Just like all the other 10x players. One cautionary feature was added to the latest firmware with regards to sacd/dsd playback for the 103/103D players. I will include it here for you.
"Added a safety feature for BDP-103/103D: the "SACD Output" format is set to "PCM" by default. The reason is that the digital-to-analog converter (DAC) used on these two models cannot adjust the volume for DSD signals, so the analog volume level could automatically switch back to 100 when a DSD stream is detected. This safety feature will force the DSD stream to be decoded as a PCM stream before sending it to the DAC, which can help control the volume when loading SACD disc(s)."
DanF8500 is offline
post #4552 of 9179 Old 06-30-2014, 11:52 PM
rhale64L7's Avatar
Quoted: 823 Post(s)
Liked: 322
Ok thank you again.
post #4553 of 9179 Old 06-30-2014, 11:56 PM
rhale64L7's Avatar
Quoted: 823 Post(s)
Liked: 322
One more question. Can I stream all forms of dsd on these oppo players? If not which ones can I stream?
post #4554 of 9179 Old 07-01-2014, 12:03 AM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
^ Forms of DSD? Again, do you mean dsd64/128? Only single rate dsd (stereo and multi-ch) is supported, and can be streamed only on the hdmi outputs.
DanF8500 is offline
post #4555 of 9179 Old 07-01-2014, 08:15 AM
rhale64L7's Avatar
Quoted: 823 Post(s)
Liked: 322
Yes again thats what I meant. So the only way to get double rate dsd is to get the 105d, regardless of the playback method.
post #4556 of 9179 Old 07-01-2014, 09:03 AM
Quoted: 711 Post(s)
Liked: 582
The HA-1 also supports DSD128 and DSD256 too.
A 103D + HA-1 combo would be a pretty sweet combo.
post #4557 of 9179 Old 07-01-2014, 11:16 AM
rdgrimes's Avatar
Quoted: 1888 Post(s)
Liked: 1217
I don't believe there's any way to output DSD128+ from the 103 models. So in that regard the DAC wouldn't be of any help.
rdgrimes is online now
post #4558 of 9179 Old 07-01-2014, 11:59 AM
rhale64L7's Avatar
Quoted: 823 Post(s)
Liked: 322
I would be running this all through a Krell Foundation which with the new upgrade does Multichannel Dsd128 . I was thinking of the HA-1 or the Marantz 11si with the 103d. I really wanted the Krell Connect but as of now it doesn't support dsd either.
post #4559 of 9179 Old 07-01-2014, 12:03 PM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1023 Post(s)
Liked: 936
The HA-1 will not output DSD in a digital form. It will accept DSD as an input, but all of it's outputs are analog.
gsr is offline
post #4560 of 9179 Old 07-01-2014, 12:07 PM
rdgrimes's Avatar
Liked: 1217
I hope you realize that the difference between these different flavors of DSD is comparable to the difference between you (in Ohio) hearing a gnat fart in California vs a gnat fart in Hawaii. Unless you've spent more on your speakers and hardware than most people spend on their houses, you can't hear it either way.
DanF8500 likes this.
Reply Blu-ray Players
Oppo , Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 103d Universal 3d Blu Ray Player Darbee Edition , Oppo Brand , Oppo Digital , Oppo Digital Inc
