Official OPPO BDP-103D (Darbee Edition) Owner's Thread - Page 179 - AVS Forum
post #5341 of 5361 Old 09-26-2014, 09:04 AM
sakgoz79's Avatar
Originally Posted by Bob Pariseau View Post
SAKGOZ79,
The folks who run AVS ask that discussion of hacked firmware be taken someplace else. Discussion of Region Free hardware mods -- and the SuperDisc, free software mod for SD-DVD (only) Region Free, is allowed.
For SuperDisc see the FAQ -- link available at the top of the first post of the BDP-103 owner's thread.
--Bob
Ok I got it sorry for confusion I was just wondering
sakgoz79 is offline
post #5342 of 5361 Old 09-29-2014, 06:18 AM
lasab's Avatar
Liked: 7
Does the US version of the 103d have the BBC Sport app?
When I access "choose sport" all the sports come up with error HODGE.
The replays in the area to the left work fine.
lasab is offline
post #5343 of 5361 Old 09-29-2014, 06:42 AM
asere's Avatar
Quoted: 37 Post(s)
Well the Oppo arrived on Saturday and of course I could not wait to set it up so I did just that. The unit out of the box was very impressive inside a black bag and solid as can be upon taking it out. Set up was quite easy basically just like my old bluray player.
I experimented with Darbee and found the best setting for my 50" plasma to be High Def with levels set to 100%. I tried the 35-50 % and even 75% but at that setting I could not tell much difference before and after.
Once set at 100 I could clearly see a difference. The faces had more details and the dark scenes lit up without taking away from black levels.
Overall I am happy with the unit.
asere is online now
post #5344 of 5361 Old 09-29-2014, 07:12 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 361 Post(s)
Liked: 880
^ You can flip between Darbee Hi-def and Off using the Darbee button and the Arrow buttons on the remote to more easily spot what a given percentage level is doing. Or you could activate either of the Darbee "demo" modes. The portion of the screen to the left of the demo divider line is the processed portion.
Ideally you don't want to set Darbee so high that the processing becomes obvious without such direct comparison. It should be subtle.
--Bob
Bob Pariseau is online now
post #5345 of 5361 Old 09-29-2014, 07:16 AM
asere's Avatar
Quoted: 37 Post(s)
--Bob
Thank you. I did use the on/off and screen split feature but and at 50% I could tell a slight difference from up close but once I moved to my sitting area which is like 13ft the effects would disapear therefore I set it to 100%. At that level I can see a nice picture without artifacts.
asere is online now
post #5346 of 5361 Old 09-29-2014, 09:28 AM
sworth's Avatar
My region free modded 103D was exactly like that when it arrived. I had to turn it up to 100 to see the Darbee effect. But I did a restore factory presets and all of the image processing settings became twice as powerful. I think when they update the firmware, they don't always hit reset and things don't work right at first.
Also, make sure you are using HDMI 1 out. That is the one on the RIGHT, not the left as you would expect. I don't know why 2 comes before 1 on the Oppo, but it does. Darbee won't work at all on HDMI 2.
sworth is online now
post #5347 of 5361 Old 09-29-2014, 09:32 AM
asere's Avatar
Quoted: 37 Post(s)
If I hit reset will it still keep the most current firmware? Yes I do have it connceted to HDMI 1.
Are you telling me 100 % is too high regardless of tv and seating distance?
asere is online now
post #5348 of 5361 Old 09-29-2014, 09:53 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 105 Post(s)
Liked: 174
Setting Darbee to 100% is sort of like turning the contrast and brightness controls all the way up on your TV. So yes, 100% is not recommended by most people and as Bob says, Darbee should be a subtle effect.
When you select the reset, it keeps the current firmware. It just resets all the settings in the menu to their default values and has been known to resolve some mysterious issues.
gsr is online now
post #5349 of 5361 Old 09-29-2014, 10:25 AM
asere's Avatar
Quoted: 37 Post(s)
Thank you I shall try the reset and change Darbee to just a subtle effect.
asere is online now
post #5350 of 5361 Old 09-29-2014, 11:07 AM
Gecko85's Avatar
Quoted: 122 Post(s)
Liked: 80
Use the split-screen to get the setting that looks best to you, in your setting, at your viewing distance. Everyone will be different. For me, 55% was perfect.
asere likes this.
Panasonic TC-P60ST60, Pioneer SC-1523-K, Oppo BDP-103D, Pioneer PL-550 + Cambridge Audio Azur 640P, B&W CM1 (fronts), B&W CM Centre, Athena Point 5 Mk II (rears), Hsu VTF-2
Sony 34XBR960, Onkyo TX-NR414, Sony PS3, Athena Point 5 Mk II (center and fronts), Wharfedale WH-2 (rears), Polk PSW10
Gecko85 is online now
post #5351 of 5361 Old 09-29-2014, 06:47 PM
asere's Avatar
Quoted: 37 Post(s)
I went ahead and changed it to 55 instead of 100. At 55 I can see just a subtle change.
asere is online now
post #5352 of 5361 Old 09-29-2014, 11:47 PM
sworth's Avatar
Resetting it will only clear out your settings, not the firmware. 100% is normally too high, yes. I would recommend doing a restore to factory presets.
post #5353 of 5361 Old Yesterday, 05:24 AM
asere's Avatar
Quoted: 37 Post(s)
On the Menu it asks to reset the settings and reset settings with all apps. Which one do I do?
asere is online now
post #5354 of 5361 Old Yesterday, 07:52 AM
Read the FAQ!
Quoted: 361 Post(s)
Liked: 880
Reset Settings and Applications will also discard the login credentials for the Internet apps -- for example if you are going to sell the player. You would have to log in again for each app you use.
The Reset Settings which preserves the Applications stuff is the normal one to use.
--Bob
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
. -- Need personal consultation/training?
post #5355 of 5361 Old Yesterday, 01:04 PM
asere's Avatar
Quoted: 37 Post(s)
How should the Oppo be connected? Right now I have it the tv hdmi to the avr and Oppo hdmi 1 to the receiver however, reading the Oppo manual they recommend
Split A/V
(recommended) Use HDMI 1 OUT as the dedicated video output port and
HDMI 2 OUT
as the dedicated audio output port. This setting will ensure the best possible
picture quality and the highest possible audio resolution.
Is this how most users have it?
asere is online now
post #5356 of 5361 Old Yesterday, 01:45 PM
bob brennan's Avatar
Quoted: 30 Post(s)
Liked: 101
Split A/V
HDMI 2 OUT
That will work fine assuming the AVR has the ability to pass the signal through (direct) allowing the OPPO to handle all the processing. This way you only need 1 HDMI cable from OPPO (see page 11 manual) - You can use the split A/V system if you want to use 2 HDMI from the OPPO as noted above.
BUT without a connection from the HDTV to AVR you might not be able to use the the Internet features of the HDTV - I had used the OPPO/AVR/HDTV system for some time but recently changed to use both OPPO HDMI out but maintaining the AVR/HDTV HDMI connection. I did not see any improvement in the video by going to the dual output system.
Panasonic TC-P65ZT60 - Oppo BDP-103D - Panasonic DMP-BDT220 - Toshiba HD-DVD-3A - OPPO DV-981HD - Harmony 880
Onkyo TX-NR809 --- Definitive Technology - Studio Monitor 65 (2) - CS8040HD - Studio Monitor 45 (2) - Super Cube 6000
bob brennan is online now
post #5357 of 5361 Old Yesterday, 01:50 PM
asere's Avatar
Quoted: 37 Post(s)
Thank you, the other issue with split would be in order to watch tv the Oppo would need to be ON all the time.
asere is online now
post #5358 of 5361 Old Yesterday, 01:55 PM
Logibaird's Avatar
Liked: 2
--Bob
The best option is off, the processing is not needed with Blu Ray, however if you like this sort if gizmo go with it.
Logibaird is offline
post #5359 of 5361 Old Yesterday, 02:15 PM
rlb
rlb's Avatar
Quoted: 169 Post(s)
Liked: 104
I presume you know that you are on an "owner's thread" for the 103D which was probably bought for it's Darbee capability (otherwise you would buy the 103 for $100 less). So I would expect most of the posters on this thread would "like this sort of gizmo".
Smarty-pants and asere like this.
rlb is offline
post #5360 of 5361 Old Yesterday, 02:17 PM
Quoted: 30 Post(s)
Liked: 101
The whole purpose of the 103D is the Darbee - if not interested in this "gizmo" you should buy the 103 and save a $100.00
post #5361 of 5361 Old Today, 09:08 AM
mogrub's Avatar
Quoted: 72 Post(s)
Liked: 95
I like gizmos. And this 103D doohickey here is a particularly appealing gizmo.
Every once in a while, quite inexplicably, things actually go according to plan.
mogrub is offline
Reply Blu-ray Players
Oppo , Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 103d Universal 3d Blu Ray Player Darbee Edition , Oppo Brand , Oppo Digital , Oppo Digital Inc
Gear in this thread - 103d by PriceGrabber.com
