Official OPPO BDP-103D (Darbee Edition) Owner's Thread - Page 204 - AVS Forum
post #6091 of 6107 Old 12-26-2014, 11:54 AM
rdgrimes's Avatar
Quoted: 437 Post(s)
Liked: 267
Originally Posted by hernanu View Post
hmm... I guess the review site was wrong on the specs. Thanks for the correction.
I couldn't say if there are different versions of that disc floating around. But the Oppo can tell you what's playing via OSD.
Have you tried ripping those HR tracks and playing from USB? (I'll assume you know how)
rdgrimes is online now
post #6092 of 6107 Old 12-26-2014, 06:27 PM
miata's Avatar
Quoted: 25 Post(s)
Originally Posted by ray0414 View Post
what tv and avr do you have? so if we bypass the avr receiver we can get a better picture? on my new samsung 4k 8550 tv i have been using the oppo 4k upscale because its much better than the sammy 4k upscale. but by bypassing the avr, isnt there some sort of loss of sound decoding by the avr? is an optical cord needed or can HDMI cords be used instead?
I bought a Sony XBR-70x850B, but am currently using a loaner 86" while awaiting delivery of my 70". My AVR is a 7 year old Pioneer Elite VSX-92TXH,
Actually, all audio is send via HDMI2 out from the OPPO to the AVR and processed and output with my set-up. The Dish STB and Apple TV are fed directly to the AVR and pass HDMI video to the OPPO. The HD-DVD player is fed directly to the Oppo and passes audio to the AVR via HDMI OUT2. Blu-rays and other content from the Oppo also go to the AVR as well as ARC from the TV.
miata is offline
post #6093 of 6107 Old Yesterday, 05:09 AM
laserjock II's Avatar
Quoted: 105 Post(s)
Liked: 65
Originally Posted by rdgrimes View Post
I have a copy of that DVD-A. The stereo high-res tracks are 24/192, the 5.1 is 24/96. Could be that your AVR cannot accept 24/192. I have no issues playing that disc here, both type tracks play fine.
Hmmm, I'm using a Denon 4520. Assume that it will handle this 24/192 since it has 32/192 capability I believe.
laserjock II is online now
post #6094 of 6107 Old Yesterday, 11:35 AM
hernanu's Avatar
Quoted: 124 Post(s)
Liked: 266
Nope - don't have the disk, which is why I resorted to a review site. I've ripped DVD-A's to my NAS, but only the multichannel tracks.
hernanu is online now
post #6095 of 6107 Old Yesterday, 01:11 PM
rdgrimes's Avatar
Quoted: 437 Post(s)
Liked: 267
Well, there's no issue here with that disc, so the AVR is the main suspect. Try some 24/192 files on a USB drive and see what happens.
There's some free test files here: http://www.2l.no/ , on the page called "test bench" in the drop-down on the top.
FWIW, the AVR having a 32/192 DAC has no bearing on what it can handle for input. And again the Oppo can tell you what its sending on the OSD.
post #6096 of 6107 Old Yesterday, 02:35 PM
Quoted: 105 Post(s)
Liked: 65
What AVR/Processor are you using it with?
I'm not sure I care that much to listen to it in this 2 channel mode but assume I could use the analog inputs if I really wanted to otherwise.
I've been in touch with Oppo and they've offered to look into it if I send them the disc.
I'm not sure I would want to do that since that disc isn't available any longer and is at a premium price to replace.
Thanks for your input, I appreciate the responses.
post #6097 of 6107 Old Yesterday, 03:28 PM
rdgrimes's Avatar
Quoted: 437 Post(s)
Liked: 267
I use a Yamaha which accepts 24/192 on HDMI, as most should. Note that 24/192 can only be stereo, 5.1 is not possible.
Oppo support can only really tell you if the disc itself is faulty somehow, because it does work for others. I'd prefer it if you provide a detailed explanation of what exactly happens when you try to play the 2-ch tracks. What do you see on screen, what does the OSD say, and what does the front panel display say? Does the AVR indicate that it's receiving anything?
post #6098 of 6107 Old Yesterday, 10:23 PM
genegold's Avatar
Very good forum leafing through the knowledgeable comments. I've got a 103D on order, not shipped yet, to take a look vs. the 103 to use with a Samsung 46" F8000. Something said here, probably misunderstood, makes me want to double check about Darbee and audio while I still have the time. For audio, I use a PS Audio PerfectWave dac. Since it doesn't take HDMI, I plan to run a coax line instead. Darbee deals with video but does S/PDIF for audio have any effect on the ability to use it? Thanks,
genegold is online now
post #6099 of 6107 Old Yesterday, 11:12 PM
Smarty-pants's Avatar
Quoted: 247 Post(s)
Liked: 190
Originally Posted by genegold View Post
Very good forum leafing through the knowledgeable comments. I've got a 103D on order, not shipped yet, to take a look vs. the 103 to use with a Samsung 46" F8000. Something said here, probably misunderstood, makes me want to double check about Darbee and audio while I still have the time. For audio, I use a PS Audio PerfectWave dac. Since it doesn't take HDMI, I plan to run coax instead. Darbee deals with video but does a coax line for audio have any effect on the ability to use it? Thanks,
No, using coax for audio will not have any effect on the video portion of your playback material.
However, do realize that you will not be able to take full advantage of things like SACD and
lossless audio from Blu-ray by using coax.
For lossless audio (IE: DTS HD/MA, Dolby TrueHD, etc...), you will get a high bitrate core audio track over the coax output,
which should still sound pretty good, just not as good as a lossless audio track.
This scenario is true for all Blu-ray players, because the coax and/or optical outputs just don't have the capability of
handling the bandwidth that lossless audio is, thus the need for using HDMi or ANALOG audio to hear it.
~Dave
...Theater Room Setup...
JVC DLA-RS40-U... Oppo BDP-105D... Toshiba HD-XA2... Uverse VIP-2250... Roku Streaming Stick... Emotiva XPA-3... Onkyo TX-SR805
JBL LC2 (x3) ... JBL L820 (x6) ... SVS PB10-ISD (x2) ... SVS 20-39-PCI
Smarty-pants is offline
post #6100 of 6107 Old Yesterday, 11:29 PM
genegold's Avatar
Thanks. I don't have any SACD discs and Blu-ray makes up a fairly small part of what I play, so it won't be a big loss, and I had noticed the limitations you mention in the Oppo's specs. It'd be nice if Oppo added an I2S port, but from what I understand the cost of HDMI licensing is already substantial (it's why PS Audio dacs don't have HDMI, although they use the its physical format). More than audio, however, it's the value of $118 extra for Darbee on a 46" screen, an already very good one, that's been on my mind.
post #6101 of 6107 Old Yesterday, 11:39 PM
Quoted: 105 Post(s)
Liked: 65
How close are you sitting?
post #6102 of 6107 Old Yesterday, 11:47 PM
genegold's Avatar
8 feet
post #6103 of 6107 Old Today, 12:00 AM
Quoted: 105 Post(s)
Liked: 65
8 feet
Possibly an improvement if you have good eyesight.
Like most say, it will be a subtle improvement.
65" size and up will probably see a more noticeable improvement.
On my 2008 50" Panny plasma it was very subtle and now with my 80" I think I see more improvement.
I need to play with some settings to see how much more if any I can improve.
I'm still on about 35% on the HiDef setting.
post #6104 of 6107 Old Today, 12:19 AM
genegold's Avatar
Oh, I have good eyesight, the last time measured at 20-10 without my glasses. But subtle is subtle.
Other than DVDs, I watch a lot of movies, TV programs and occasionally a sporting event via a USB stick or HDD (plus listen to music of course). Typically 720p HD mkv files, with some avi and mp4.
post #6105 of 6107 Old Today, 06:58 AM
bluer101's Avatar
Quoted: 115 Post(s)
Liked: 100
Yep.
From 8 ft away on 46 inches is going to be tough, don't expect miracles.
One of the main reasons I bought mine was for my projector. Now that's where it shines.
bluer101 is online now
post #6106 of 6107 Old Today, 11:02 AM
planetbrian777's Avatar
OPPO 103D OEM Cable Issue
After receiving a new 103D and a Roku 3, I hooked it all up to my Marantz AV-8801. I hooked up the Roku to the HDMI 1 input of the 103D using the OPPO OEM cable and I noticed that the picture would go blank for 5-10 seconds after the picture was on for about 10 seconds and it would continually do this. The audio always stayed on though. The picture also looked grainy and was of general poor quality.
I re-connected the HDMI cable on the back of the OPPO and that seemed to fix it for a few minutes then the issue was back. I then swapped out the OPPO OEM HDMI cable and all is well now.....no more issues and the picture quality is outstanding. I imagine it has to do with the ferrite that is attached to the OEM cable. I learned a long time ago that ferrite is not your friend on audio and video cables. I once put them on speaker cables and the result was absolutely terrible sound. For me, I use ferrite on power cables only. When I unpackaged the OEM cable I immediately had reservations after seeing it had ferrite attached, but I tried it anyway.....now I know.
Anyone else have an issue like this?
planetbrian777 is online now
post #6107 of 6107 Old Today, 11:33 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 639 Post(s)
Liked: 1039
The ferrite choke on the cable does not affect the HDMI signals. It is interference protection. Do not fear it.
The cable OPPO ships with the player is a good one, but of course like any manufactured thing, some small fraction of them will be faulty. OPPO can send you a replacement cable under Warranty.
The fact that it worked (briefly) after you reseated the plug suggests that the mechanical fit between plug and socket was not correct -- or that the plug was being shifted in the socket by the weight of the cable, packaging kinks in the cable, or whatever.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
Reply Blu-ray Players
Oppo , Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 103d Universal 3d Blu Ray Player Darbee Edition , Oppo Brand , Oppo Digital , Oppo Digital Inc
Gear in this thread - 103d by PriceGrabber.com
