Official OPPO BDP-103D (Darbee Edition) Owner's Thread - Page 250 - AVS Forum | Home Theater Discussions And Reviews
 628Likes
post #7471 of 9227 Old 06-25-2015, 08:53 AM
AC2011's Avatar
Quoted: 108 Post(s)
Liked: 52
Originally Posted by 80sGuy View Post
You'd still have to open up the unit for connecting but no soldering required. Looks kind of tacky but whatever works. I'm sure there are other options if you want to get technical.
They actually say external USB connection recommended; but they will provide internal connection instructions on request.
I'm all for an external connection that is quick and painless; but interested if anybody has used these particular ones and had any problems.
Boston Acoustics Classic series L/C/R + front presence; Fluance XLBP Bipole surrounds; 2 x PSA XS15se
Yamaha RX-A3040; 3 x Emotiva XPA-100; Emotiva BAS-X A500
Oppo BDP-103D
AC2011 is offline
post #7472 of 9227 Old 06-25-2015, 11:52 AM
rlb
rlb's Avatar
Quoted: 1737 Post(s)
Liked: 1403
Originally Posted by gr8nrg View Post
I have asked this question in the Samsung JS9500 TV forum, but still pondering about the suggestion I got. Basically, the consensus was that I should set the output on Oppo NOT to 4K, but to 1080p and let Samsung do all of the upscaling to 4K thus letting Darbee effects pass on to TV before upscaling. I was told to NOT select 103d's output to 4K in order to avoid double upscaling by Oppo and then Samsung. Is it correct? Why would that be bad? I thought Oppo is supposed to have a great video chip, right? If I don't utilize it, why even bother with this unit if I could have bought a cheap $50 player and let TV do all the work? My receiver does audio processing, so it seems that OPPO is not doing ANYTHING if Darbee option is "off". I'm just not 100% sure about what my HDMI out settings should be for BEST picture. Even in the OPPO manual it recommends setting to HDMI output to match the TV set' resolution, which in my case is 4K A detailed explanation would be much appreciated! Thanks!
With last year's Samsung UHD processing, I subjectively (maybe by a little) preferred the 103D's upconversion to 2160P versus the Samsung processing.
Like you, I have the JS9500 and 103D. This year's processing on the JS9500 is significantly better than last year's. I compared results and in my opinion it isn't close. The Samsung is significantly better. If you feel bad about not using the OPPO, remember it was out around 16 months before the Samsung (i.e., Samsung a newer generation process). I even stopped using Darbee with the JS9500. However, the OPPO is still a great, player, even with "native or direct" output.
However, the final authority is your "eyes" and preferences. Experiment.
Samsung 65JS9500 and 65F9000 w/SEK-3500U, Denon AVR X3300 & Outlaw 755
Samsung K8500, OPPO 103-D, PS3, HR44, and Roku Ultra
rlb is offline
post #7473 of 9227 Old 06-25-2015, 01:33 PM
rdgrimes's Avatar
Quoted: 2179 Post(s)
Liked: 1513
Quite a few people are using the external kit and have reported no issues. Functionally they are the same as the internal mods.
rdgrimes is offline
post #7474 of 9227 Old 06-27-2015, 07:26 PM
bluewizard's Avatar
Quoted: 1760 Post(s)
Liked: 1050
Can someone give me a summary of the Oppo 103 and 105 Streaming capability?
I'm thinking of using this is a Music Only system. Pretty hard to find a Player and Streaming in separate units for that price.
Am I right in assuming there is a Smart Device App to control the Streaming, so I don't necessarily need to TV?
Oppo 103D and 105D as Audio Streamers???
Steve/bluewizard
bluewizard is offline
post #7475 of 9227 Old 06-28-2015, 01:35 PM
Quoted: 18 Post(s)
Liked: 5
Greetings all,
How do I get output sample rate information for FLAC playback?
My 103D is working well for the most part. I can play FLAC files from a USB stick or NAS just fine, kind of. I can get info for pretty much anything else.
The big issue is that the input at my receiver (Pioneer SC-77) is reporting a maximum sample rate of 48 kHz from the 103D (from USB or the hard drive). I'd like to be able to confirm this information at the 103D. FLAC on USB stick plugged into the receiver shows expected 96 kHz (input).
My connections are HDMI 1 out to F8500 TV, HDMI 2 out to the AVR. I've tried settings back and forth with Bitstream and LPCM, A/V Split and dual - and pretty much everything else - to see if I could get something to happen.
I did download a DSD sample track from the Oppo web site to experiment with. I worked fire. The input at the SC-77 reported the appropriate 2.8 MHz as did output at the 103D.
Any help would be greatly appreciated. This seems like it should be such a simple thing, probably is. I don't read many people having this kind of problem.
Thx
B
Billerator is offline
post #7476 of 9227 Old 06-28-2015, 11:36 PM
Quoted: 18 Post(s)
Liked: 5
OK.
After about a week and a half I got it fixed. The 103D was the culprit, not my receiver.
The solution was simple. A factory reset, 'Erase Settings' did the trick. The receiver reports the correct sample rate now. However, the Oppo still does not. I guess I can live with that.
Thx
B
post #7477 of 9227 Old 06-29-2015, 01:15 AM
SeeMoreDigital's Avatar
Quoted: 479 Post(s)
Liked: 200
Yes it would be handy if the Oppo BDP-10x range of players offered the ability to display information for 'audio only' files
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
I've been testing hardware media playback devices and software A/V encoders and decoders since 2001 | My Network Layout and A/V Gear
SeeMoreDigital is online now
post #7478 of 9227 Old 06-29-2015, 02:03 AM
bluewizard's Avatar
Liked: 1050
Some one gave me a link to this Oppo Q&A -
http://watershade.net/wmcclain/BDP-103-faq.html
Under - What are the specs of the digital inputs?
HDMI -
  • The inputs support stereo and 5.1 LPCM up to 192KHz, 7.1 LPCM up to 96KHz.
  • Lossy Dolby Digital and DTS up to 7.1.
  • Dolby Digital Plus up to 7.1.
  • They do not support input of DSD, Dolby TrueHD or DTS-HD MA.
What? How can that be? It doesn't support Dobly TrueHD or DTS-HD??? That can't be right?
Steve/bluewizard
post #7479 of 9227 Old 06-29-2015, 03:04 AM
bob brennan's Avatar
Quoted: 101 Post(s)
Liked: 136
HDMI -
Steve/bluewizard
Follow the link - via HDMI
https://www.oppodigital.com/blu-ray-...-Features.aspx
"The BDP-103D supports bit-stream output of Dolby TrueHD via its HDMI 1.4a output."
Panasonic TC-P65ZT60 - Oppo BDP-103D - Panasonic DMP-BDT220 - Toshiba HD-DVD-3A - OPPO DV-981HD - Harmony ONE
Onkyo TX-NR809 --- Definitive Technology - Studio Monitor 65 (2) - CS8040HD - Studio Monitor 45 (2) - Super Cube 6000
bob brennan is online now
post #7480 of 9227 Old 06-29-2015, 03:11 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2805 Post(s)
Liked: 3618
^ The lossless Bitstreams are supported for HDMI *OUTPUT*, not for input. However, the HDMI inputs do support high bit-rate LPCM -- up to 7.1 channels and up to 192KHz 24-bit -- if your content is already LPCM or if your Source device can decode the DTS-HD MA or TrueHD to LPCM to send to the OPPO.
--Bob
bluewizard likes this.
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #7481 of 9227 Old 06-29-2015, 05:51 PM
bluewizard's Avatar
Liked: 1050
Common Sense would tell us that a BLURAY player would support Dolby TrueHD and DTS-HD. Supporting HD audio is pretty much what it means to be a BluRay Player, though that's not the sum total of it.
Output -
- Analog Audio: 7.1ch, 5.1ch, stereo.
- Coaxial/Optical Audio: Dolby Digital, DTS, up to 2ch/192kHz PCM.
- HDMI Audio: Dolby Digital, Dolby Digital Plus, Dolby TrueHD, DTS, DTS-HD High Resolution and DTS-HD Master Audio, up to 7.1ch/192kHz PCM, up to 5.1ch DSD.
- HDMI Video: 480i/480p/576i/576p/720p/1080i/1080p/1080p24/4Kx2K, 3D frame-packing 720p/1080p24.
However, what does the FAQ link mean when it says -
They must mean something that is no evident to me.
Steve/bluewizard
post #7482 of 9227 Old 06-29-2015, 05:55 PM
Keenan's Avatar
Quoted: 2288 Post(s)
Liked: 2114
Output -
Steve/bluewizard
See the post right above yours.
Keenan is online now
post #7483 of 9227 Old 06-29-2015, 06:17 PM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1127 Post(s)
Liked: 1101
Output -
Steve/bluewizard
The lack of support for DSD, Dolby TrueHD, and DTS-HD MA on the BDP-10x players ONLY applies to the HDMI inputs on the player that can be used to send audio and video from other HDMI devices (such as a cable box, Apple TV, etc.) through the player. If you're playing a Bluray disc on the player, playing content from an attached USB storage device, playing content over your home network via SMB shares or DLNA, etc., then those audio formats are supported. This limitation is a hardware limitation of the HDMI input chipset that is in these players.
gsr is offline
post #7484 of 9227 Old 06-29-2015, 06:32 PM
bluewizard's Avatar
Liked: 1050
Thanks everyone! It is finally sinking in.
Still open to feedback on the Network Audio Streaming aspect. How well it works? How good is the App? And so on...? Any limitations?
Considering that a separate Streaming device increases the cost noticeably, it would be nice to have everything in one low cost box, and relative to what you get, even the Oppo 105 is a low cost box.
Keep in mind that while I may have video playback capability, I have no doubt the Oppo will be fine for that.
But if I want the Oppo to double as a pure Stereo audio playback device, I need a better sense of how well the Network Audio Streaming works.
Steve/bluewizard
post #7485 of 9227 Old 06-29-2015, 07:40 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
Steve/bluewizard
Network audio streaming (SMB or DLNA) is fantastic on the Oppo players. It's all I ever use to play back my audio files stored on my NAS. I don't use the Oppo's usb interfaces (Type A and B) or the hdmi inputs. You probably know everything I'm about to tell you (if not, then this applies to you), but for all the other Oppo owners who want to use network streaming on these players, it's well worth it. If you don't want to have your tv on for browsing your audio directories, you'll obviously need a media player/uPnP app (either iOS or Android based) or you'll need a home PC/laptop with uPnP media software installed (i.e. JRiver Media Center). For DLNA (to push audio files to the Oppo player), you'll need a DLNA media server. My NAS (Synology) has its own embedded media server for this. You can push any supported Oppo formats to the player. I'm not an Android guy. I use an iPad with either Oppo's MediaControlHD app, an app called Creation 5, or Synology's DS audio app. The Oppo Media Control app is, as you're aware, a free app. It's not super robust, but it gets the job done. I like the Creation 5 interface, and it does seem to be a little more stable of an app for audio playback. The list of uPnP media apps is extensive, so you'll have to find one that meets your standards. I actually prefer SMB to DLNA. It has been a more stable protocol for me when streaming my audio.
DanF8500 is offline
post #7486 of 9227 Old 06-29-2015, 08:35 PM
80sGuy's Avatar
Quoted: 185 Post(s)
Liked: 35
^^I use the USB to attach a portable drive full of rips since I don't have a NAS. Works great too, but yeah this is by far one of the best DLNA streaming devices for being a Blu-Ray player.
80sGuy is offline
post #7487 of 9227 Old 06-30-2015, 05:02 AM
bluewizard's Avatar
Liked: 1050
Originally Posted by DanF8500 View Post
Network audio streaming (SMB or DLNA) is fantastic on the Oppo players. ....
OK, thanks, that is helpful.
steve/bluewizard
post #7488 of 9227 Old 06-30-2015, 04:42 PM
Quoted: 18 Post(s)
Liked: 5
Greeting all,
Over the last week or so I'd been doing a lot of reading trying to resolve an issue I was having. The problem was resolved but I saw a discussion, unrelated to my problem, that sparked my interest. It was concerning USB thumb drive(s) for media file storage.
I have one PNY brand 64GB thumb drive(USB USB 2.0) I've been using primarily for music storage. I have had no problems with its function at all as far as I can tell. The biggest and may be the only problem is that my organization scheme is horrible. I have many folders set up as play lists. While this works, it results in many duplicate files. It isn't very efficient.
I'd like to get a couple more thumb drives and get them organized properly. How do you have your USB thumb drive(s) organized? What thumb drive and what size are you using for your media file storage? Multiple partitions? Is there any reason to go with a USB 3.0 over USB 2.0?
Thx
B
post #7489 of 9227 Old 06-30-2015, 10:14 PM
LePatron's Avatar
Liked: 0
oppo 103d vs nas
I would like to know if I would be losing any sound or picture quality downloading blu rays onto my qnap tvs871 vs. playing them on my oppo bdp 103d
LePatron is offline
post #7490 of 9227 Old 07-01-2015, 04:35 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2914 Post(s)
Liked: 2160
Welcome to AVSForum.
If you are talking about pirated material: forum policy forbids discussions of that.
For backups of your own discs, it depends on the method used. Backups without compression will have the same quality as the disc.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
post #7491 of 9227 Old 07-04-2015, 10:09 PM
Liked: 0
I recently bought this blu ray player but can't really tell a difference from Darbee and non Darbee. can anyone let me know if I need a quality HDMI cable or if anything I can do to improve
Simon Liu is offline
post #7492 of 9227 Old 07-05-2015, 05:10 AM
wmcclain's Avatar
Liked: 2160
New cable: no.
What Darbee settings are you using? What if you turn on the demo mode and turn the Darbee level setting up very high? Do you still not see a difference?
Have you read reviews of the Darbee effect or seen demos? You understand that it is a subtle effect when used properly?
-Bill
wmcclain is offline
post #7493 of 9227 Old 07-05-2015, 07:05 AM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 1101
^ Also make sure that you have the Oppo's HDMI1 output connected to the display. The Darbee processing isn't available on the HDMI2 output.
gsr is offline
post #7494 of 9227 Old 07-05-2015, 07:06 AM
wmcclain's Avatar
Liked: 2160
^And that you are using 1080p, not Source Direct.
-Bill
wmcclain is offline
post #7495 of 9227 Old 07-05-2015, 07:08 AM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3349
In Source Direct, with a blu-ray, is all that is allowed to happen the 4:2:0 to 4:4:4 conversion (or whatever setting you are using)?
gadgtfreek is online now
post #7496 of 9227 Old 07-05-2015, 07:14 AM
wmcclain's Avatar
Liked: 2160
As far as I know, yes. The player must do chroma upsampling (although 4:2:0 has been added to recent HDMI specs, so maybe we will have an even more raw Source Direct in the future. I don't know what population of existing displays supports it).
-Bill
gadgtfreek likes this.
wmcclain is offline
post #7497 of 9227 Old 07-05-2015, 10:16 AM
Liked: 0
Originally Posted by wmcclain View Post
New cable: no.
-Bill
I turned it up to 80 without even a subtle difference. I will check to see if I have it plugged in the right HDMI.
post #7498 of 9227 Old 07-05-2015, 10:25 AM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3349
In my experience anything over 40 HD, on and off, is pretty obvious.
post #7499 of 9227 Old 07-05-2015, 11:22 AM
Read the FAQ!
Liked: 3618
In Settings > Video Setup > Picture Adjustment > HDMI 1, or by using the on-screen Pop-up (Darbee button on the remote), enable the "Split Screen" demo mode for Darbee. While playing movie content you should now see a vertical, black line down the center of the screen. If you don't have that line then you are either using the wrong HDMI output or you have Source Direct selected.
With either the Split Screen or Sweep Screen demo modes engaged, the portion of the screen to the left of the divider line is the processed portion.
Crank Darbee up to a ridiculously high value (e.g., 100) and you should easily see the processing on the left side compared to the right. Pause the film and raise/lower the Darbee number and you should also easily see the change in processing.
--Bob
post #7500 of 9227 Old 07-07-2015, 10:24 AM
Liked: 1
Anyone using this with the LG 55EC9300 OLED?
Hi,
Is anyone using the OPPO 103d with Darbee activated with an LG 55EC9300 OLED TV? Just curious to see your opinion of an increase in PQ.
Vito
vito_f is offline
Reply Blu-ray Players
Oppo , Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 103d Universal 3d Blu Ray Player Darbee Edition , Oppo Brand , Oppo Digital , Oppo Digital Inc
