Official OPPO BDP-103D (Darbee Edition) Owner's Thread - Page 283 - AVS Forum | Home Theater Discussions And Reviews
 624Likes
post #8461 of 9211 Old 03-03-2016, 07:40 AM
mogrub's Avatar
Quoted: 212 Post(s)
Liked: 180
For some reason, I had something knocking around in my memory that said there was a difference. I think I was just transposing the fact that the two HDMI outputs on the 103D are not treated the same. (i.e., HDMI output 1 applies both Darbee and the SI VRS chip, but HDMI output 2 applies neither.)
Every once in a while, quite inexplicably, things actually go according to plan.
mogrub is offline
post #8462 of 9211 Old 03-03-2016, 07:49 AM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3244
HDMI 1 signal passes thru the MT chip, the Darbee and the VRS. HDMI 2 is MT only. If using Source Direct or no other enhancements, I would assume they would both be the same.
gadgtfreek is offline
post #8463 of 9211 Old 03-03-2016, 07:50 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2854 Post(s)
Liked: 2115
HDMI inputs are the same. At least, I'm not recalling any difference...
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
post #8464 of 9211 Old 03-03-2016, 09:33 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2669 Post(s)
Liked: 3406
Originally Posted by mogrub View Post
Quick question. I've been through the manual and the FAQ's, and think I have my answer, but to confirm: am I correct that the two HDMI inputs on the 103D are processed identically?
You are correct. The two HDMI *Inputs* on the OPPO 10x family of players are processed identically, both for audio and video.
There are differences between the two HDMI *Outputs* of the players. And those differences between the two Outputs vary slightly between the Darbee and non-Darbee versions of the players.
(The capabilities of the Asynchronous USB DAC Input also vary between the 105 and 105D players.)
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
post #8465 of 9211 Old 03-03-2016, 09:37 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1098 Post(s)
Liked: 1076
^ Only the front input has the MHL feature. Other than that, the 2 inputs are the same.
gsr is offline
post #8466 of 9211 Old 03-03-2016, 09:58 AM
dcbii's Avatar
Quoted: 119 Post(s)
Liked: 53
Questions on output resolution 4K vs. Auto
I have a couple observations/questions on the output resolution setting on the BDP-103D.
1. I have a 4K TV that is 3D capable. If I set the BDP-103D output to forced 4K/2K, 3D (from a 3D disk) doesn't seem to work, but setting it back to auto allows 3D to work. (I would assume that's because 3D is already using 2x1080p, but that's not clear in the manual or FAQ).
2. If I set the output to auto and put in a DVD, even though both the AVR and TV are 4K-capable, the output from the 103D is 1080p at most. (I only get 576p from a PAL DVD, though I suspect that's because the TV doesn't negotiate being PAL-capable, even though it can play PAL material.) Any reason auto doesn't just upscale to 4K (at least for NTSC) since the TV supports it?
3. Finally, using forced 4K/2K output, PAL DVDs get converted to 4K/60 instead of 4K/50, even though the output is set to multi-system instead of NTSC. Any reason for this, or is this just expected behavior? My Denon X4200W converts 576p to 4K/50 if I do the conversion there.
I can have the Denon do most of these tasks, but I don't know if the conversion/scaling is considered better in the X4200W than in the Oppo. Certainly my old DV-983H and BDP-83 were very good at this, but maybe their processing has been surpassed. Is the 103D considered as good as the 83 for PAL playback?
Dave Barnhart
Oppo UDP-203, Oppo BDP-83, Denon X4200W, LG 55EF9500, all Monoprice Premium Certified HDMI cables
dcbii is offline
post #8467 of 9211 Old 03-03-2016, 10:00 AM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3244
Even the new UHD player does not output 3D in 2160p. because it is not able to. So that is normal.
I also noticed if you forced 2160p for say a 1080i signal, the output is 2160p ycbcr 4:2:0.
dcbii likes this.
post #8468 of 9211 Old 03-03-2016, 10:05 AM
dcbii's Avatar
Quoted: 119 Post(s)
Liked: 53
I figured. It's just a little inconvenient, since I can't leave the BDP-103D output set on 4K -- it has to be changed at least for 3D discs. I was kind of hoping it would just drop back for 3D playback (or that auto would go all the way up to 4K when it could).
And yes, I've also noticed the 4K-upconvert reducing the colorspace. If I output at 576p or 1080p, I get 4:4:4. Not that my eyes can actually see any difference there -- at least unless it was side by side, and maybe not even then!
Dave Barnhart
dcbii is offline
post #8469 of 9211 Old 03-03-2016, 10:08 AM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3244
I had the UHD player for a bit and it was forced to 2160p. I confirmed when I player a 1080p 3D disc, the display was only getting 1080p. PQ was good though.
dcbii likes this.
post #8470 of 9211 Old 03-03-2016, 11:34 AM
dcbii's Avatar
Quoted: 119 Post(s)
Liked: 53
I agree that 1080p 3D is good enough. And if I use the AVR to auto upconvert, it will upconvert 1080p 2D from the Oppo to 4K, and 1080p 3D from the Oppo it leaves alone. I guess I just need to be happy with using 4K upconvert on the AVR vs. the Oppo, unless I want to do a lot of extra setup for each disc.
Dave Barnhart
dcbii is offline
post #8471 of 9211 Old 03-03-2016, 04:09 PM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3244
Seems my 103D does a better job than the OLED with fine Chroma 1080p vs 2160p out (from Oppo).
Oppo set to 2160p resolution and Auto (50/60hz)
2160p
1080p (note 3rd square up right side)
Darbee on Luma Pattern (double images)
Darbee off
2160p
1080p (note dark edges)
Everything else is just anomalies from the iphone camera. I am going to send blu-rays out at 2160p/24 444 to my OLED and will prob run 1080i Dish thru the 103D and let VRS put out 2160p/60.
dcbii, ti-triodes and retro124 like this.
post #8472 of 9211 Old 03-04-2016, 07:52 AM
dcbii's Avatar
Quoted: 119 Post(s)
Liked: 53
Just did those same tests this morning, and I can duplicate your results, including the with/without Darbee on the one screen. So I will definitely set the Oppo to do the 4K output, rather than the Denon.
One other thing -- with all the screwing around with various settings on all the devices in the chain, I must have changed something important, because when I selected the 3D material on the S&M disc, with the Oppo still set to 4K/2K output, the 3D engaged properly! The TV showed 1080p, and the Oppo still showed 4K/2K output. I'm not sure what was different from what I had before, since I was changing too many settings on all 3 devices. Should have written it down. I also didn't try a regular 3D disc, but at this point in time, I don't have any reason to believe it wouldn't work. So my 3D issue with the 4K output appears to be no longer an issue. Glad I had to try a bunch of things while trying out what you posted! I really hate the lack of transparency in HDMI settings and how they interact (or at least my understanding of them) on various devices.
gadgtfreek likes this.
Dave Barnhart
dcbii is offline
post #8473 of 9211 Old 03-04-2016, 07:56 AM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3244
Thats odd. When I tried to force 3D conversion in the Oppo using some contrast and brightness patterns to check the 3D mode on the LG, it would not force until I changed the Oppo rez setting from 4Kx2K to 1080p.
I did some more reading today, it seems the VRS solution in this model is pretty good at scaling to 4K after the mediatek chip gets done with the signal. I guess in the long run it may be as good as your display but not better, but I'd also bet it would not be worse than a display. At least with the Oppo you know they pride themselves on accurate output.
Some people say the fine chroma rez is not a big deal, but if it passes one way and fails the other, I do not see why you wouldn't run it the way it passes.
post #8474 of 9211 Old 03-04-2016, 10:07 AM
dcbii's Avatar
Quoted: 119 Post(s)
Liked: 53
I didn't try that this morning, but the 3D "forced conversion" didn't work for me in 4K output mode when I previously tested it either. That wouldn't really bother me that much -- if I intended to use that mode a lot, I can change to auto output. I do want it to properly handle 3D discs, though. 3D disc mode needs to pass the wife/family factor (i.e. put in 3D disc, use glasses, it works).
Dave Barnhart
dcbii is offline
post #8475 of 9211 Old 03-08-2016, 08:35 AM
curlyjive's Avatar
Quoted: 512 Post(s)
Liked: 229
I had a really odd issue occur while watching Lincoln this weekend with my 103d and JVC R4910. after a bit of rewinding a fast forwarding, the motion looked like it was in 1.5X speed. Sort of like the soap opera effect if you have motion processing on, but I verified it is off on the PJ and I even cycled through all modes and back off. I powered cycled everything and even factory reset the oppo. I don't know for sure at what point it went away, but it did go back to normal. I could get it to occur again, seemingly if I tried to slow motion RR or FF for a bit. It would come back again.
Any thoughts?
curlyjive is online now
post #8476 of 9211 Old 03-11-2016, 07:10 AM
dcbii's Avatar
Quoted: 119 Post(s)
Liked: 53
Any thoughts?
Not sure what is happening, but I was unable to reproduce this with my Lincoln BD. I tried multiple FF/RW and slow FF/RW back and forth, and was unable to see what you are seeing. Not sure how many times this needs to be tried, but 5-10 minutes of attempts didn't do it. However, I'm not using a JVC R4910, so that is one obvious different factor.
Dave Barnhart
dcbii is offline
post #8477 of 9211 Old 03-11-2016, 08:16 AM
curlyjive's Avatar
Quoted: 512 Post(s)
Liked: 229
It was FF and RR at frame by frame speed that seemed to trigger it.
post #8478 of 9211 Old 03-11-2016, 08:23 AM
dcbii's Avatar
Quoted: 119 Post(s)
Liked: 53
Yes, that's what I meant by "slow FF/RW". That didn't seem to do it for me either.
Dave Barnhart
dcbii is offline
post #8479 of 9211 Old 03-12-2016, 04:57 PM
skinnydoggy's Avatar
Quoted: 45 Post(s)
Thumbs down
I am really disappointed in my Oppo. I used to think it was the greatest player in the world, but I am having second thoughts.
Has anyone else had issues with playing mkv files off th network? It plays fine, unless I fast forward and hit play. This causes it to freeze 100% of the time. Not good.
It's frozen up on me a few times during regular playback as well... I have the latest firmware, and its only a couple of years old.
skinnydoggy is offline
post #8480 of 9211 Old 03-12-2016, 05:22 PM
Quoted: 45 Post(s)
Well, now the mkv ended, and it froze to a black screen. Wow.
post #8481 of 9211 Old 03-12-2016, 07:32 PM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3244
I dunno, I put shiny round 2D and 3D discs in mine and they play.
Kazz063 likes this.
post #8482 of 9211 Old 03-12-2016, 07:45 PM
rdgrimes's Avatar
Quoted: 2145 Post(s)
Liked: 1460
That's a network issue. Although there are limits on how fast you can FF/RW over a network connection, freezing isn't a normal part of the process. If the player has a weakness, its that network bottlenecks can make it freeze.
skinnydoggy likes this.
rdgrimes is offline
post #8483 of 9211 Old 03-12-2016, 07:56 PM
Quoted: 45 Post(s)
I used to put shiny discs in mine too, until every video store within 100 miles closed.
post #8484 of 9211 Old 03-12-2016, 08:16 PM
laserjock II's Avatar
Quoted: 728 Post(s)
Liked: 397
+1
laserjock II is online now
post #8485 of 9211 Old 03-12-2016, 09:22 PM
ambesolman's Avatar
Quoted: 1083 Post(s)
Liked: 911
Perhaps one of these days somebody will invent a new way to get them, maybe even through the mail. Until then, looks like we're all SOL.
Sent using Tapatalk since the mobile version is still
rlb and Smarty-pants like this.
ambesolman is offline
post #8486 of 9211 Old 03-12-2016, 09:25 PM
Coyote Waits
htwaits's Avatar
Quoted: 928 Post(s)
Liked: 2053
Have you tried Amazon?
htwaits is online now
post #8487 of 9211 Old 03-12-2016, 09:40 PM
pappaduke's Avatar
Quoted: 147 Post(s)
Liked: 139
Netflix still has disc delivery.
pappaduke is offline
post #8488 of 9211 Old 03-12-2016, 09:56 PM
Quoted: 728 Post(s)
Liked: 397
Redbox pretty much everywhere, no?
post #8489 of 9211 Old 03-13-2016, 01:44 AM
SeeMoreDigital's Avatar
Quoted: 472 Post(s)
Liked: 198
I can't say I've encountered any problems myself.
Which network connection protocol are you using, SMB or UPnP?
What type of file storage device are you using?
Are you connecting through a network switch or through a router?
Which mkv file muxer did you use to create these .mkv contained files?
Cheers
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
I've been testing hardware media playback devices and software A/V encoders and decoders since 2001 | My Network Layout and A/V Gear
SeeMoreDigital is offline
post #8490 of 9211 Old 03-13-2016, 05:47 AM
Quoted: 45 Post(s)
Yes, Amazon is where I buy most of my BD's. I was a huge renter from my local store, but it could not survive. We (Canada) no longer have Redbox, our Netflix is inferior, and the exchange rate has driven prices on new releases over $30 per disc. Any streaming service is sub par. I really wish there was another way. Cable has become something for the rich and foolish, antenna does not give you the British stuff, and is almost unwatchable with so many commercials.
Reply Blu-ray Players
Oppo , Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 103d Universal 3d Blu Ray Player Darbee Edition , Oppo Brand , Oppo Digital , Oppo Digital Inc
