Official OPPO BDP-103D (Darbee Edition) Owner's Thread - Page 300 - AVS Forum | Home Theater Discussions And Reviews
 584Likes
post #8971 of 8991 Old 09-19-2016, 06:48 PM
asere's Avatar
Quoted: 1088 Post(s)
Liked: 201
Guys here is the fix for the Netflix/Vudu no audio signal from the desk of Oppo.
Basically copy and paste and transfer to a usb stick, load the stick on he Oppo player and should automatically update.
I already this this and YES it's fixed. Read below from Oppo:
We have developed a firmware for the BDP-10xD series of players were audio from Netflix and VUDU would not come through when using a single HDMI cable to particular receivers. You can upgrade the firmware of the player by downloading the 83-0918B BDP10x.BIN file (http://download.oppodigital.com/BDP0...ion/BDP10X.bin) and transferring it to a FAT32 formatted USB drive. The player should prompt you to upgrade, and if not, then go into Device Setup and Firmware Upgrade then VIA USB. Follow the onscreen prompts to upgrade the firmware of the player.
If you find, for whatever reason, that you need to use the current Official Firmware, then you can do so by downloading its BIN file (http://download.oppodigital.com/BDP1...715/BDP10X.bin) and replacing the BDP10x.BIN on your flashdrive. Then go into Device Setup and Firmware Upgrade then Via USB.
Sent from my SM-G900P using Tapatalk
asere is online now
post #8972 of 8991 Old 09-19-2016, 07:26 PM
Liked: 2
Thanks, just installed the update on my bdp103d and it fixed the no sound issue for VUDU and Netflix
john fusco and asere like this.
kyrunner7 is offline
post #8973 of 8991 Old 09-19-2016, 08:12 PM
asere's Avatar
Liked: 201
Cool, glad to hear that
asere is online now
post #8974 of 8991 Old 09-20-2016, 03:31 PM
tbase1's Avatar
Quoted: 38 Post(s)
Liked: 59
What integrated amp would you guys use with a BDP-93 or BDP-103D for music only? ( solid state or tube ) I'm running 4ohm system audio sa1750 speakers.
tony4k
tbase1 is offline
post #8975 of 8991 Old 09-21-2016, 10:25 AM
paligap's Avatar
Quoted: 53 Post(s)
Liked: 27
These might be stupid questions, but I'll ask anyway. I just bought a Sony 75-940D (previously had a 1080p plasma set).
I know the 103D can't accept any 4K input, but should I set the Output Resolution and the 4Kx2K Output to Auto? I presume the Oppo will detect the 4K capability of the Sony and upscale as appropriate. Is there any benefit to doing that as opposed to letting the Sony upscale everything?
If I do make those settings, will the Netflix app on the Oppo output 4K material to the Sony? What about HDR?
Sony XBR-75X940D
Oppo BDP-103D
Denon 4520
Custom UFW-15 (2)
Rocket RS850 (2), Rocket Bigfoot Center, Rocket RSS300 (2), Rocket RS250MKII (4)
paligap is offline
post #8976 of 8991 Old 09-21-2016, 10:52 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 1386 Post(s)
Liked: 1411
^ The Netflix app in the 10x players streams up to 1080p content, and without HDR. It would have to be that way as the 10x players can not play *ANY* content which is already 4K.
As for setting the player to deliver upscaled 4K to your 4K-capable display, it's hard to predict which will be better. The best advice is to just try both ways and see which one you like. If you can't tell a difference, stick with 1080p output as that is less likely to produce random HDMI handshake problems.
It's not just a matter of whether the player or the display does a better job of upscaling. The processing path in the display for 1080p and 4K is almost certainly different.
Since MOST content fed into the display will be 1080p, the display may have been optimized to handle 1080p best, for example. Also, processing 4K input takes more processing power. Again, the answer here is to just try it both ways and see which you like.
--Bob
paligap likes this.
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
post #8977 of 8991 Old 09-21-2016, 01:38 PM
David Aiken's Avatar
Quoted: 96 Post(s)
Liked: 87
To add to Bob's comment about Netflix:
There is what I'll call a "handshake" between the Netflix app on whatever device you're using and the Netflix server so the server is aware of what kind of content the app can handle. The content listings you will see will only list those versions of a program that your subscription allows and that the app on your device can handle. I've got an LG E6 OLED, a Samsung UHD player, and an Oppo 105. All have Netflix apps and my subscription includes 4K content. The Oppo can't handle UHD so I only get listings showing HD and SD offerings when I use the Oppo's app. The Samsung can handle UHD and the HDR10 version of high dynamic range so it lists the highest resolution of what versions are available and shows the HDR10 flag if the program is available in HDR10 but never shows a Dolby Vision flag. The LG app shows the highest resolution available and sill show Dolby Vision flags as well as HDR10 flags. Of course, if your subscription does not include 4K you will never be shown the 4K versions.
Since your Oppo can't process 4K material, you will need to use the Netflix app on the Sony TV and pass the audio from the TV to your system via ARC or digital output (usually optical). Use bitstream output for the audio because if you use LPCM output some displays down mix the output to stereo so you will lose multichannel audio. Bitstream output should preserve multichannel audio if the program has it.
Apart from upgrading your Netflix subscription to include 4K if you need to, using the TV's netflix app, and getting the audio to your system there is only one other thing to consider. That's your internet connection. Netflix say that HD requires a 5 mbps download speed connection and UHD requires a 25 mbps download speed connection. Check what speeds you can get from your ISP. Using a speed test app, my download speed clocks in around the 22-23 mbps rate and I can stream 4K material without any problems but if your connection speed is much lower than that you may have to pay for a higher speed connection in order to be able to stream 4K material successfully. I wasn't certain whether I could get by with my connection or if I needed to be able to get a minimum of 25 mbps so I tried it and haven't had any problems so if your download speed is not too far below 25 mbps then I'd try it and see what happens but if your download speed is too low then you will need a faster connection as well.
paligap likes this.
David Aiken is online now
post #8978 of 8991 Old 09-21-2016, 02:05 PM
paligap's Avatar
Quoted: 53 Post(s)
Liked: 27
Thanks, Bob and David. I suspected much of the info you provided. I just got the TV, and I'm still in a free month of Netflix. I was pretty sure I'd have to use the apps on the TV to get 4K and HDR10. My internet connection is 100 mbps, so I should be okay. I tested the ARC feature the other night, and it has some side effects, so I might have to enable it on an as-needed basis.
Sony XBR-75X940D
Oppo BDP-103D
Denon 4520
Custom UFW-15 (2)
paligap is offline
post #8979 of 8991 Old 09-21-2016, 05:05 PM
nathan_h's Avatar
Quoted: 736 Post(s)
Liked: 378
So excited about the new UHD player that I have listed my 103D and Region Free kit in the Classifieds.
I'll never abandon Oppo, but I feel at this point like we are growing up together....
____________________
Current theater & gear: "Nathan's Theater in Search of....".
nathan_h is online now
post #8980 of 8991 Old 09-21-2016, 06:02 PM
tngiloy's Avatar
Quoted: 118 Post(s)
Liked: 87
I started with the 80, then the 83 ( a breakthrough product on so many levels), then the 93, then the 103, then the 103D. I think I know what you mean.
But personally, although I may be growing older, I never plan to grow up.
But one feature I would like on the new Oppo 203 would be Amazon Video. As an Amazon Prime member this would be great. Don't know why it hasn't happened already.
Tom
"When all else fails, read the manual."
tngiloy is offline
post #8981 of 8991 Old 09-21-2016, 06:13 PM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 839 Post(s)
Liked: 652
Basically because Amazon isn't interested. It takes two to tango...
gsr is online now
post #8982 of 8991 Old 09-21-2016, 06:25 PM
nathan_h's Avatar
Quoted: 736 Post(s)
Liked: 378
That's unfortunate. I too would love to see it.
post #8983 of 8991 Old 09-21-2016, 06:34 PM
jedi29's Avatar
Quoted: 75 Post(s)
Liked: 57
It`s like "Apple TV" , no AIV either , and again both parties are fine with that.
Amazon sells there "Fire-Stick" , and not all "Smart TV`s" will have AIV either , the new "Andriod-TV`s" kind of have to. Other will make you wait ( think Vizio ).
Later
Me 
jedi29 is offline
post #8984 of 8991 Old 09-22-2016, 06:53 AM
tngiloy's Avatar
Quoted: 118 Post(s)
Liked: 87
Has Oppo asked Amazon if they can have the next dance??
tngiloy is offline
post #8985 of 8991 Old 09-22-2016, 08:38 AM
hernanu's Avatar
Quoted: 517 Post(s)
Liked: 927
I believe they have, but Amazon would rather dance by itself while Oppo leans against the wall holding its tiny beaded pocketbook.
Sad.
hernanu is offline
post #8986 of 8991 Old Today, 10:39 AM
Liked: 0
MKV file support with DTS HD Master Audio and Dolby TrueHD (USB or network)
Hi,
I ask if the oppo BDP-103D support MKV file with DTS HD Master and Dolby True HD.
My current Marantz UD5005, is not bad but don't support audio of this type with MKV files.
thank you !
alex5671 is online now
post #8987 of 8991 Old Today, 10:43 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 1965 Post(s)
Liked: 887
Originally Posted by alex5671 View Post
Hi,
thank you !
Welcome to AVSForum.
Yes, both.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #8988 of 8991 Old Today, 10:52 AM
Liked: 0
Yes, both.
-Bill
Thank you !!
Do you know if support USB devices more then 2 TB ? ( I like to purchase a 4 TB hardisk)
post #8989 of 8991 Old Today, 11:14 AM
wmcclain's Avatar
Liked: 887
Thank you !!
Yes, it supports GPT partitioning, which is what you need to go larger than 2TB.
See the FAQ in my signature for more.
-Bill
post #8990 of 8991 Old Today, 01:57 PM
80sGuy's Avatar
Quoted: 173 Post(s)
Liked: 31
Sad.
'F' Amazon! That's all I have to say and they've got their minions reading this. I know because Jeff Bozo wants everything for himself, basically tries to kill off everyone and then have it all under Amazon (remember the bookstores?). That said, I'm not sure if you guys recall this when the latest Apple TV released, Amazon basically banned it from selling on their portal. So obvious ain't it.
Back to subject regarding OPPO supports MKV with True-HD; the answer is YES!
80sGuy is online now
post #8991 of 8991 Old Today, 02:23 PM
srinivas1015's Avatar
Quoted: 38 Post(s)
John Archer (from Forbes) says that the review units might be out in October, and a public release in November.
https://twitter.com/BigJohnnyArcher/...97226968883200
srinivas1015 is online now
Reply Blu-ray Players
Oppo , Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 103d Universal 3d Blu Ray Player Darbee Edition , Oppo Brand , Oppo Digital , Oppo Digital Inc
