Official OPPO BDP-103D (Darbee Edition) Owner's Thread - Page 301 - AVS Forum | Home Theater Discussions And Reviews
 621Likes
post #9001 of 9189 Old 09-27-2016, 07:13 PM
pappaduke's Avatar
Quoted: 137 Post(s)
Liked: 133
Originally Posted by Bob Pariseau View Post
Public Beta Firmware BDP10X-83-0918B Released for the OPPO 10x Players
http://www.oppodigital.com/blu-ray-b...-83-0918B.aspx
Release Notes:
This release is for the OPPO BDP-103, BDP-103D, BDP-105 and BDP-105D Blu-ray Disc players.
Special Notice:
Once this Public Beta firmware is installed on the player, you CAN revert back to the previous Official release via a USB thumb drive. There will be no issues upgrading to any future official or beta firmware release.
Comparing to the current Official release version BDP10X-83-0715, the major changes included in this version are:
1) Resolved a no audio issue with certain receivers when playing DD+ 5.1 content from Netflix and Vudu.
2) Resolved an issue where the player would automatically power off when receiving commands via a TCP connection.
3) General disc compatibility improvements based on recent and upcoming Blu-ray releases as well as user-submitted disc samples
All features and improvements of the previous firmware are also included in this version.
--Bob
Thanks Bob, I thought my player was working fine after the original update. When I went to watch Netflix tonight, no audio. I must have been using my ATV before so I didn't realize I had an issue. Your posted link saved the day. Thanks👍🏾
Yamaha 2010
Oppo 103D,ATV3,PS3, Samsung UN60ES7100F, Bluesound Vault 2 and Pulse Mini, Harmony One, Paradigm Monitor 9's, CC-390, 2ADP 390's/190's, 2 PDR 100's. B&W P5
Zone2-Paradigm SE-1's, Zone3-Paradigm-Stylus 370-SM
pappaduke is online now
post #9002 of 9189 Old 09-28-2016, 11:46 AM
Quoted: 176 Post(s)
Liked: 33
Originally Posted by SeeMoreDigital View Post
It can, but it's a 'known issue' that playback can be unstable.
Indeed, there are many posts within all of the BDP-10x player topics about this particular issue
No
It not play Dolby TrueHD audio tracks in MKV files Via USB
i try 12 movies with Dolby TrueHD audio tracks in MKV files Via USB
Zero successes !
It plays it low-quality of PCM !
OPPO sells some lies !
popyang45 is offline
post #9003 of 9189 Old 09-28-2016, 11:55 AM
rdgrimes's Avatar
Quoted: 1993 Post(s)
Liked: 1321
Lord give us patience.........
With current firmware DTHD in MKV works just fine IF : No other audio codecs are played after power-on (energy efficient standby).
There is no longer any forced decoding to PCM. If the playback fails you will likely just not get any audio bitstreamed at all.
I just re-tested this in firmware 0918B and its still true.
rdgrimes is offline
post #9004 of 9189 Old 09-29-2016, 06:32 PM
Smarty-pants's Avatar
Quoted: 747 Post(s)
Liked: 621
Since when is PCM low quality? Does Oppo even officially support THD via MKV?
If it's not officially supported, then if you can get it to work it's a free gift.
Smarty-pants is offline
post #9005 of 9189 Old 09-30-2016, 05:24 AM
Quoted: 176 Post(s)
Liked: 33
Question
no
With [I]current firmware Main Version BDP10X-83-0715
https://www.oppodigital.com/blu-ray-...-Firmware.aspx
via USB
again via USB
can't play Dolby TrueHD audio tracks in MKV via USB
output only LPCM or no voice !
I TRY firmware 0918B - NO Dolby TrueHD audio tracks in MKV via USB
http://www.oppodigital.com/blu-ray-b...spx#Thumbdrive
and LPCM is bad sound
post #9006 of 9189 Old 09-30-2016, 05:32 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1059 Post(s)
Liked: 987
Originally Posted by popyang45 View Post
no
is no firmware 0918B
where do you see firmware 0918B ?
BDP-103D Support Page
Note that if you don't have the USA version of the player, you need to get firmware updates from the distributor for where your player was purchased and the release dates are not the same as each distributor does their own verification and minor changes (switching the list of apps, local region codes, etc.).
gsr is offline
post #9007 of 9189 Old 09-30-2016, 05:49 AM
Quoted: 176 Post(s)
Liked: 33
and LPCM 7.1 is bad sound
Nor does it say that the Firmware Update fixes Dolby TrueHD audio tracks in MKV via USB !!!
post #9008 of 9189 Old 09-30-2016, 05:54 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2684 Post(s)
Liked: 1920
I have only one sample of such in my test suite, but it works for me. You might contact OPPO support with details of your problem file and offer to send them a sample.
If they can't help you then I doubt if we can.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
post #9009 of 9189 Old 09-30-2016, 06:03 AM
Quoted: 176 Post(s)
Liked: 33
-Bill
i do not know what's going on with you or if you tell the difference between PCM to DTS HD to Dolby TrueHD audio tracks in MKV via USB
i contact OPPO support NO TrueHD audio tracks in MKV via USB
post #9010 of 9189 Old 09-30-2016, 06:05 AM
wmcclain's Avatar
Liked: 1920
Are you asking for help from us here? What is it you want us to do for you?
-Bill
gsr likes this.
wmcclain is offline
post #9011 of 9189 Old 09-30-2016, 08:05 AM
Quoted: 176 Post(s)
Liked: 33
Exclamation
-Bill
answer the truth !
No lie !
you could do it ?
OPPO customer service explicitly says
OPPO 103D can't play TrueHD audio tracks in MKV via USB
why lie ? To sell devices ?
post #9012 of 9189 Old 09-30-2016, 08:17 AM
wmcclain's Avatar
Liked: 1920
answer the truth !
No lie !
you could do it ?
If I lied to you before, why would you believe me now?
Mediainfo shows this for my sample file:
Audio #2
Format : TrueHD
Codec ID : A_TRUEHD
Duration : 2 h 21 min
Bit rate mode : Variable
Maximum bit rate : 2 850 kb/s
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 kHz
For me, it plays from MKV on USB (and SMB).
For you: I don't think we can help you.
-Bill
wmcclain is offline
post #9013 of 9189 Old 09-30-2016, 12:48 PM
rdgrimes's Avatar
Liked: 1321
Its a big club with many well-respected members.
I was just playing an MKV of San Andreas via SMB and my AVR was happily displaying "Atmos". Maybe the poster is being confused by the player calling it "MLP" in MKV. But what do I know, I'm just lying.
gsr, rlb and sschen like this.
rdgrimes is offline
post #9014 of 9189 Old 10-01-2016, 07:38 AM
TomcatTLC's Avatar
Quoted: 133 Post(s)
Liked: 121
Hi fellow 103D Owners, I am looking for input re: P.Q. without having to read through the 9K+ thread posts. For those who have DirecTV, is there an noticable improved picture quality if the HDMI Handshake goes from the DirecTV Box HDMI Output into the 103D HDMI Input and then HDMI Output into either an AVR/Display (1080P) Source ? I am aware that this may/will depend on the quality of the Display's Upscaler but in general is there a picture quality improvement if the video signal goes to the 103D prior to reaching the Display ? I thank you in advance for any input on this matter.
TomcatTLC is offline
post #9015 of 9189 Old 10-01-2016, 08:47 AM
laserjock II's Avatar
Quoted: 703 Post(s)
Liked: 378
What size is your display?
laserjock II is offline
post #9016 of 9189 Old 10-01-2016, 09:15 AM
wcladley's Avatar
Quoted: 13 Post(s)
I am finding that, after the most recent Oppo firmware update for the BDP-103D, it will no longer connect to the Android Media Controller app. The app simply doesn't see the player. I've even tried manually entering the IP address from the player networking menu, and it is not working. Anyone else experience this and are there any workarounds?
wcladley is offline
post #9017 of 9189 Old 10-01-2016, 09:38 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2253 Post(s)
Liked: 2819
In Setup > Network Setup, confirm that My Network is ON, and then do a Connection Test. If that's good and the app still does not see the player, then call or email OPPO Tech Support for additional steps you can try.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is offline
post #9018 of 9189 Old 10-01-2016, 10:02 AM
Quoted: 703 Post(s)
Liked: 378
If you have a dual band router make sure both are on the same band.
I've had that as an issue also.
post #9019 of 9189 Old 10-01-2016, 10:28 AM
wcladley's Avatar
Quoted: 13 Post(s)
--Bob
Thanks Bob, confirmed that all of these settings are correct. I will contact Oppo post back once I have an answer.
wcladley is offline
post #9020 of 9189 Old 10-01-2016, 11:26 AM
TomcatTLC's Avatar
Quoted: 133 Post(s)
Liked: 121
... 75" (Mitsubishi LaserVue)
post #9021 of 9189 Old 10-01-2016, 11:41 AM
wmcclain's Avatar
Liked: 1920
It is working for me.
Firmware: 83-0918B, app: 4.0.1. (I see there is a 4.0.2 update; I should install that and try again).
-Bill
wmcclain is offline
post #9022 of 9189 Old 10-01-2016, 01:20 PM
Coyote Waits
htwaits's Avatar
Quoted: 919 Post(s)
Liked: 2030
Originally Posted by DeMornay View Post
Tom, thanks for your input.
I should have mentioned that I am located in Norway, Scandinavia, so ordering directly from Oppo is not an option.
If you add location to your AVS profile, you will get better quality responses. Note my location. It's close enough for me to walk to Oppo if I was just thirty years younger.
As they say in Real Estate, "Location, location, location!"
htwaits is offline
post #9023 of 9189 Old 10-01-2016, 02:54 PM
Quoted: 703 Post(s)
Liked: 378
I have an 80" LCD display and I initially set it up to go through the Oppo for the movie channels.
It worked ok but then for some reason I couldn't get the pay channels to pass through.
It wasn't worth it in the long run so I just watch BR's through the Oppo now.
post #9024 of 9189 Old 10-01-2016, 03:31 PM
TomcatTLC's Avatar
Quoted: 133 Post(s)
Liked: 121
Thank you for your input. When you say "it worked okay" was there a noticeable difference in the video quality when sending the video signal from the DirecTV box through the 103D and then to your Display/AVR or do you mean the signal handshake was okay in that it was working properly ? If there was no discernable difference in the video quality then I will not take the time to move equipment and cables around which with my setup would take some time and effort.
post #9025 of 9189 Old 10-01-2016, 04:11 PM
wcladley's Avatar
Quoted: 13 Post(s)
-Bill
Thanks Bill. I downloaded version 4.0.1 and it is working.
wcladley is offline
post #9026 of 9189 Old 10-01-2016, 04:38 PM
Quoted: 703 Post(s)
Liked: 378
If it's not too hard for you to try it, I might do that but what I meant is that it worked initially but I don't think I could tell much difference.
When I started having handshake type problems, it was only with the pay channels (HBO Cinemax, Showtime, etc)
I was going through a matrix switch and the receiver though so I'm not sure how much if anything it had to do with that.
*I have a unique situation in that I wanted to make it easy for family when I'm not around, so I use external self powered speakers for casual TV listening and run through the receiver for movies etc when I'm around.
post #9027 of 9189 Old 10-05-2016, 05:20 AM
docrog's Avatar
Quoted: 454 Post(s)
Liked: 77
Long time 103D owner, 1st post to this thread in a very long time. Suddenly (with no changes to my Oppo/AVR setup) I have no video output other than the Oppo logo, irrespective of which input I choose (Blu-Ray disc, HDMI in Front/Back) the display says "no signal and the "Home Menu" cannot be displayed. Audio is unaffected, regardless of input source. I've seen some vague reference to "power recycling", but cannot find it in the manual or Oppo FAQ. I could connect another TV to the "Diagnostic" port on the back (after removing existing HDMI cables), but I'm unsure what to do when I encounter the "Setup Menu". Any help would be greatly appreciated. Thanks!
docrog is offline
post #9028 of 9189 Old 10-05-2016, 05:48 AM
wmcclain's Avatar
Liked: 1920
What happens when you cycle through the output resolutions? Do any of them work?
-Bill
wmcclain is offline
post #9029 of 9189 Old 10-05-2016, 05:48 AM
Quoted: 703 Post(s)
Liked: 378
Just unplug it for a minute or so and plug it back in.
post #9030 of 9189 Old 10-05-2016, 07:30 AM
docrog's Avatar
Quoted: 454 Post(s)
Liked: 77
Thanks to those who contributed. Unplugging for an extended length of time and cycling through resolutions did not help. I eventually hauled out an old portable TV, unplugged the HDMI cable and connected the Oppo to the TV with an old time video cable. I was able to see the Home Screen and performed a reset to factory defaults (other than accounts such as Netflix & Vudu). The Oppo now works perfectly! It's likely to update to current firmware, so I hope that the video problem doesn't recur subsequently.
docrog is offline
Reply Blu-ray Players
Oppo , Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 103d Universal 3d Blu Ray Player Darbee Edition , Oppo Brand , Oppo Digital , Oppo Digital Inc
