Official OPPO BDP-103D (Darbee Edition) Owner's Thread - Page 304 - AVS Forum | Home Theater Discussions And Reviews
 602Likes
post #9091 of 9107 Old 11-09-2016, 08:39 AM
srinivas1015's Avatar
Quoted: 118 Post(s)
Liked: 26
Is there any way to connect the Sony Playstation Gold wireless headset to the Oppo? It comes with a proprietary bluetooth dongle, which I'm not sure will work with the Oppo.
The headset does have a 3.5mm jack but I'd like a wireless solution for this. Is any adapter available? I'd like to avoid getting a new pair of headphones if possible.
srinivas1015 is online now
post #9092 of 9107 Old 11-09-2016, 08:56 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 929 Post(s)
Liked: 776
The only way you could really pull that off is to connect a headphone amp to the Oppo's analog outputs and then connect the headphones to the headphone output on that. Note that they wouldn't be wireless at that point. If you had a BDP-105 or BDP-105D, you could use an adapter plug to built in headphone preamp on that player. I don't have any recommendations for an inexpensive headphone amp - the Oppo HA-1 would work, but would be extreme overkill.
gsr is online now
post #9093 of 9107 Old 11-11-2016, 11:22 PM
bjhess's Avatar
Quoted: 24 Post(s)
Originally Posted by Bob Pariseau View Post
^ Try setting 3D Output FORCED instead of Auto. This produces 3D output (but only when you are playing 3D content) even if the display does not properly report it is 3D-capable.
Projectors are notorious for not properly reporting that they are 3D capable, which is why the FORCED choice was added.
2D content will still go to the projector as 2D.
--Bob
Thanks, that did it! I swear I had tried it, but I must have needed to "restart" the disc or somesuch. Thanks again!
Barry
bjhess is offline
post #9094 of 9107 Old 11-18-2016, 03:38 PM
ken6217's Avatar
Quoted: 37 Post(s)
I just purchased the 103D and have it running HDMI into my Marantz 8802A AVP. The Marantz is handling the audio / speaker configuration. How do I set the audio in the Oppo? I don't want to limit anything coming out of the OPPO.
Ken
ken6217 is offline
post #9095 of 9107 Old 11-18-2016, 03:51 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 1469 Post(s)
Liked: 1517
Ken
Set HDMI Audio BITSTREAM. Turn Secondary Audio OFF, and DTS Neo:6 Mode OFF. That's it. HDMI handles all the rest automatically.
In particular, none of the Speaker Configuration stuff in the OPPO applies to HDMI audio output. That's only for the Analog audio outs.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #9096 of 9107 Old 11-18-2016, 03:54 PM
tngiloy's Avatar
Quoted: 130 Post(s)
Liked: 92
Ken
From the manual:
HDMI Audio: Allows you to select the digital audio output format from the HDMI port. The
options are:
Auto (default) – The player checks with the device connecting to the HDMI output to
automatically determine which audio format to use.
LPCM – Digital audio output via HDMI will be in the multi-channel Linear PCM format. When
this option is selected, compressed audio bit streams will be decoded by the player. This
setting is recommended when connecting the HDMI output directly to a TV or to a receiver
without advanced audio decoding capabilities.
Bitstream – Digital audio output via HDMI will be in bitstream format. This option is
recommended when connecting the HDMI output to an A/V receiver or processor that
supports advanced audio decoding, such as Dolby TrueHD and DTS-HD Master Audio.
Off – No digital audio output via HDMI.
If your receiver can decode all the hi-Def audio codecs, then Bitstream would be your choice.
Also, don't worry about the "Audio Processing Setup" speaker configuration except for DRC. That section is for analog audio, not HDMI.
Tom
"When all else fails, read the manual."
tngiloy is offline
post #9097 of 9107 Old 11-19-2016, 04:10 PM
ken6217's Avatar
Quoted: 37 Post(s)
Got it. Thanks a lot!
ken6217 is offline
post #9098 of 9107 Old 11-25-2016, 01:41 PM
Cobra5wood's Avatar
I just acquired my first 4K TV(LG OLED65 B6). I need to verify how my 103D should be set up. I'm currently running a Directv HR24-100(set for "native output") into the rear HDMI input of the 103D and I'm running the HDMI #1 output to my Dennon X4200W. The current video settings for the 103D are output resolution=1080p, 1080p24 output=auto, and 4Kx2K output=auto(50/60hz) The current audio settings are HDMI Audio=Auto. I'm going to assume the ip scaling will be better in the LG than the Oppo. Do these settings seem OK without further revision?
Cobra5wood is online now
post #9099 of 9107 Old 11-25-2016, 04:54 PM
David Aiken's Avatar
Quoted: 218 Post(s)
Liked: 317
I've got a 105 and a 65" LG E6.
I do not reliably see a difference between sending Blu-ray at 1080p from the 105 and having the E6 upscale that to 4K or having the 105 upscale to 4K and passing that to the E6. When it comes to standard def sources from DVD and the like, I think the 105 does a marginally better job upscaling to 4K than outputting 1080p from the 105 and having the E6 upscale that to 4K. I would expect your results with the 103D and B6 to be similar.
I have the 105 set to upscale everything to 4K on the basis that it makes no difference with Blu-ray but it's slightly better with DVD and other standard def sources so I would suggest setting your output resolution to 4K.
David Aiken is offline
post #9100 of 9107 Old 11-26-2016, 10:23 AM
jasper08's Avatar
Have anyone try Spiderman 2(Sam Raimi version) with the Dolby Truhd track on the 103d? There are audio drop out in a few scene in these blu ray. More on the 2.1 version of the movie. Had latest firmware update on the 103d.
jasper08 is offline
post #9101 of 9107 Old 11-26-2016, 02:12 PM
Jk7.2's Avatar
Quoted: 106 Post(s)
Liked: 133
Quick question, if I run my 103d hdmi out into my avr (denon x4100) hdmi in am I loosing all the oppo's video processing to the avr's video processing? Should I be running an hdmi right from the oppo to my projector (epson 5030ub)? Sorry if this has been answered 1000 times, but please point me in the right direction! I finally switched my focus from bass to other things in the theater. Thanks
Jared
Jk7.2 is online now
post #9102 of 9107 Old 11-26-2016, 03:43 PM
Quoted: 218 Post(s)
Liked: 317
Jared
You should be able to configure the AVR's video settings so that it just passes through the video signal from all inputs without doing any processing at all. Provided you do that what you will see will be the 103D's processing unaltered.
You'll need to check your AVR's manual or look for an owners' thread on your AVR here for information on how to set your AVR up in that way.
post #9103 of 9107 Old 11-26-2016, 05:45 PM
Jk7.2's Avatar
Quoted: 106 Post(s)
Liked: 133
Jared
Thanks. I will look into that!
Jk7.2 is online now
post #9104 of 9107 Old 11-28-2016, 09:23 PM
kriktsemaj99's Avatar
Quoted: 634 Post(s)
Liked: 354
Forced subtitles in MKV
For the first time I just had a case of a forced subtitle track (Russian dialog in Captain America: Civil War) not playing automatically on the 103D (from a network drive). I made the MKV myself and that was the only subtitle track, set as default and set as forced. VLC shows the subtitles automatically when playing on a PC, but on the Oppo I had to explicitly enable them. I've made plenty of other MKVs the same way and the forced subtitles have always worked as intended.
Anyone else had subtitle issues with the latest public beta firmware?
kriktsemaj99 is offline
post #9105 of 9107 Old 11-29-2016, 08:29 AM
harrykeogh's Avatar
I hope the 203 does just as well as the 103D for blus. I was going to pick up another as a backup, then saw the price loons are asking for them.
harrykeogh is online now
post #9106 of 9107 Old Today, 07:12 AM
tang7969's Avatar
Quoted: 234 Post(s)
Liked: 150
I'm having problems with Vudu and Netflix. When I put either of them on I get the picture and no sound. I am running the 103 into a Marantz 7008. When I put in a bd I have picture and sound. Is anyone else having this problem? Can anyone suggest a fix? Thanks
SAMSUNG UN607150- OPPO BDP 103D- PSA 210T L/R -PHANTOM CENTER -ENERGY RC-10 SURROUNDS -PSA S3000i - MARANTZ SR7008 - APPLE TV -MONSTER POWER HTS2600MK -DIRECTV GENIE -HARMONY ELITE
BASEMENT SETUP- SAMSUNG UN466500- ENERGY 50'S L/R - DENON-AVR-3311CI- PS3 -APPLETV- MINI GENIE
tang7969 is online now
post #9107 of 9107 Old Today, 08:07 AM
Read the FAQ!
Liked: 1517
There's a fix for this problem in the current "Public Beta" firmware. Install this via USB stick. Details here:
http://www.oppodigital.com/blu-ray-b...-83-0918B.aspx
--Bob
Reply Blu-ray Players
Oppo , Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 103d Universal 3d Blu Ray Player Darbee Edition , Oppo Brand , Oppo Digital , Oppo Digital Inc
