Official OPPO BDP-103D (Darbee Edition) Owner's Thread - Page 308 - AVS Forum | Home Theater Discussions And Reviews
 629Likes
post #9211 of 9238 Old 03-27-2017, 04:47 AM
bob brennan's Avatar
Quoted: 101 Post(s)
Liked: 136
Originally Posted by wmcclain View Post
When you are running beta firmware it checks the beta servers; production firmware checks the production servers.
At least: that was the rule at one time. Did it become more complicated? I forget.
-Bill
Thank you!! Appears that is still the rule - when I download new firmware to flash drive - installed with no problem at all!
Panasonic TC-P65ZT60 - Oppo BDP-103D - Panasonic DMP-BDT220 - Toshiba HD-DVD-3A - OPPO DV-981HD - Harmony ONE
Onkyo TX-NR809 --- Definitive Technology - Studio Monitor 65 (2) - CS8040HD - Studio Monitor 45 (2) - Super Cube 6000
bob brennan is offline
post #9212 of 9238 Old 04-12-2017, 05:00 AM
justinbleu's Avatar
I just got my Oppo BDP-103D and have read up until page 14 of this thread. I do need some help. I would like to stream movies from my pc to the oppo. The Oppo is wired via ethernet and connected to the internet I can watch netflix but I cant see my pc or any files. What must I do on the computers end so that it can communicate with the Oppo?
I have been watching movies on my TV from my PC via HDMI using MPC-HC and Madvr. Is there anyway I can do this wirelessly through the Oppo.
justinbleu is offline
post #9213 of 9238 Old 04-12-2017, 05:38 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 3101 Post(s)
Liked: 2374
You'll need to run an SMB or DLNA server on your pc. What sort of system do you have? Windows has SMB built-in, although getting the security for sharing is sometimes a chore. We usually recommend using non-MS DLNA servers.
-Bill
justinbleu likes this.
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #9214 of 9238 Old 04-12-2017, 07:42 AM
SixSpeedRon's Avatar
Enable sharing on your PC and have the PC and Oppo connected to your home network. When the Oppo needs a password, use your Microsoft account PW. Your content can be accessed through the Network logo on the Oppo main screen.
SixSpeedRon is offline
post #9215 of 9238 Old 04-13-2017, 11:43 AM
justinbleu's Avatar
I have windows 10. I found a way to access my files by going to Control Panel - Network and Sharing Center - Media Streaming options.
Using this method I can only access certain files. For instance a music FLAC will not show up on the Oppo but if I put that same file on a thumb drive it can see it and play it. There are also other videos that will not show up on the Oppo, while others will show up but the format is not supported.
This is a start in the right direction and thanks for your help.
post #9216 of 9238 Old 04-13-2017, 11:47 AM
justinbleu's Avatar
Thanks for your reply what DLNA or SMB are you using to access your media. I have PowerDVD which works but I run into the same problem as stated above that only certain files are available on the Oppo.
Is there a way to play media from my laptop and just have it stream to the Oppo. In other words can I play a movie / music on my pc and have the oppo mirror it. There are certain codecs that the Oppo just cant read and so I would like to have an alternative way to play movies when this situation arises. Thank you.
post #9217 of 9238 Old 04-13-2017, 01:57 PM
Although another DLNA device (USB on router) appears in my list of network devices on the Oppo, I am able to play FLAC files through the Oppo from a storage drive on my Windows 10 HTPC. Normally for music, I just use Kodi to play from the HTPC, as Kodi's GUI is better and video is not an issue.
To stream movies directly from your laptop, you could plug it into the Oppo through an HDMI input or use a wireless HDMI transmitter if you don't want a cable crossing your room. You could also put movies on a USB drive and plug it into the USB on the Oppo. This should give better quality, as you are not processing video twice.
post #9218 of 9238 Old 04-13-2017, 04:49 PM
fourbigkids's Avatar
Hi all.
I am playing around with the Oppo 103D as a preamp as we have downsized and need to scale back the HT gear (going from 5.1 to 2.1 and losing a Denon processor). I am looking for the Oppo to process and downmix the audio on video files with the whole range of audio surround sound formats to 2.1.
I have a HTPC which is connected to three 'audio devices', the Oppo (by HDMI - as a cloned display), a Panasonic Display (by HDMI - as a cloned display) and a Chord DAC (by USB). Now when I had a Denon 3808c in the system I was able to set up a heirarchy of sorts. The display would always be on and appear as a device in the HTPC's audio device window. If the Denon and the Chord were off at the time they would not show in the the Audio Device list. If the Denon was on, it would be the default device, unless the Chord was on, and it would be the default device. The other would not appear in the list as it would be off.
The problem I am having is that even though the Oppo is off, it remains as a device in the Audio device list. I have attached a photo. The Oppo is powered down. Now this presents problems whenever you want the Panny to be the 'default' device. If the Oppo doesn't drop off the list like the Denon, then you have to manually select the display as the audio device. And that, let me tell you, is a pain for my wife, which makes it a pain for me. Does anyone know why the Oppo remains an active device on the HTPC and whether it can be prevented?
I have spoken to Oppo Australia and they thought it might have something to do with HDMI CEC and the energy saver mode on standby. I checked though and both are set as was recommended, ie. off and 'energy efficient'.
Appreciate your advice.
Regards
Allan
Panasonic TH-P60ST60A screen, Oppo BDP-103D Blu-Ray, HTPC/AudioPC based on Antec ISK110-VESA, Qnap TS-639 Pro, Chord QuteEx Dac, Musical Fidelity A5 Integrated amp powering the mains, Denon AVR-3808 for everything else, GoldenEar Triton Ones for Mains (and performing sub duties), Duntech Onyx Centre and Duntech Pearl Rears.
fourbigkids is offline
post #9219 of 9238 Old 04-13-2017, 08:06 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 3360 Post(s)
Liked: 4307
^ I presume you have HDMI output from the OPPO going to the Display.
Try physically disconnecting that HDMI from the OPPO to the Display and see if your problem goes away -- i.e., if the OPPO drops off the list when it is OFF (Energy Efficient).
If so, check for both ARC (Audio Return Channel) and HDMI CEC in the *DISPLAY*. I.e., the *DISPLAY* may be publishing that the OPPO is on the HDMI chain even while the OPPO is "Off".
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #9220 of 9238 Old 04-13-2017, 10:47 PM
Thanks for responding Bob.
I disconnected the display from the Oppo. No change, the Oppo still appears as a device on the HTPC. I see that ARC is only available on the HDMI input to the display to which the HTPC is attached. So I also changed it to a non-ARC input. It made no difference. The Oppo remains in the list of audio devices whether on or in Standby.
On further testing, it also remains as a device even when turning the Oppo off at the wall and restarting the HTPC! The only way that I can get it to drop off the list is to disconnect the HDMI between the Oppo and the HTPC.
This is very peculiar behaviour. I am starting to think it may be a computer issue rather than the Oppo, although it doesn't happen with other devices when they are turned off (the DAC and the Denon processor). They drop off the list.
Allan
post #9221 of 9238 Old 04-14-2017, 04:10 PM
wxman's Avatar
Quoted: 4015 Post(s)
Liked: 2826
I was having some issues with my 103D on my LG E6. At times, I saw pulsating in near black scenes with some blu ray movies. Watched Free State of Jones last night on my 103D, and in some of the outdoor night scenes, the near blacks would pulsate. First I thought it was the darbee effect, but after I turned it off, it still pulsated. Tested the same scenes on my 203, and no pulsating.
LG 65E6P FW 04.31.00
LG 65EF9500
wxman is online now
post #9222 of 9238 Old 04-19-2017, 06:13 PM
Quoted: 51 Post(s)
Question
Can the 2d to 3d feature produce more than a 3d 720p image from a 1080p source ?
a) from a dvd upscaled to 1080p with forced 1080p24
b) from a Br with resolution automatic| 1080p24 automatic
c) from any source at 1080p thru hdmi in
Until now i could only get a 720p 3d from all these never a 1080p 24*
*the resolution for 3d 1080p it's not exacly 24
Nando64 is offline
post #9223 of 9238 Old 04-19-2017, 07:10 PM
Quoted: 51 Post(s)
Question
Originally Posted by Bob Pariseau View Post
Yes, yes, yes, and yes. Of course don't expect it to look as good as content created in 3D.
--Bob
Can it produce more than a 720p 3d image (1080 24p?) from a 1080p source?
I was't able to get more than 720p 3d from a 1080p source
(upscaled dvd or tv thru hdmi in) or from BR sources ( those are 1080 24p) setings are: output resolution automatic \108024p automatic|forced
Nando64 is offline
post #9224 of 9238 Old 04-19-2017, 07:23 PM
Read the FAQ!
Liked: 4307
Sure! Set your output resolution to 1080p. You'll get (3D)1080p/24
--Bob
Nando64 likes this.
post #9225 of 9238 Old 04-20-2017, 05:59 AM
Quoted: 51 Post(s)
Unhappy
--Bob
Tanks for reply
Still
a) if source is dvd with setings\ Output res 1080p & 108024 forced on or automatic on result always 720p 3d
b) tv thru hdmi in at 1080p or 1080i with same output resolu setings
above \ same results
c) standard br with
a) output resol - source direct & 108024p automatic or forced
\ same result
b) output resolution set to 1080p with 1080 24 \automatic\ forced & off \ always same output 3d 720p
So at least the br schoud work - I think i've tried all possible combinations now
Nando64 is offline
post #9226 of 9238 Old 04-20-2017, 06:02 AM
Read the FAQ!
Liked: 4307
It sounds like your AVR or display is blocking 3D at 1080p. The OPPO can output that but only if the receiving gear says it can accept it.
--Bob
post #9227 of 9238 Old 04-21-2017, 12:43 PM
Quoted: 51 Post(s)
Arrow
--Bob
Don't think so 'cos
a) regular 3d br play fine at 1080 24p
b) it's a 4k hdr tv with 3d
tanks anyway
Edit\23\4\217
I guess i found a kind of reason for that:- in
How to create 3D frame sequential video?
"frame sequential is not a HDMI 1.4a 3D display format it is format for outputing 3D 720p video content developed years ago by Nvidia for 3D games to 3D capable displays. that can refresh at 120fps(60fps per eye) and which used Active Shutter Glases.
It is no a format for comnpressing video for transmisson or storage such as MPEG2 or H.264 for HD or MVC for 3D."
So maybe my 103&105 are outputing this frame sequential format
edit\4\5\2017- well it seems this's the reason
sources at 1080p 24 will give 1080p24 (23.976)
other 720p
http://www.samsung.com/us/support/answer/ANS00023044/
Nando64 is offline
post #9228 of 9238 Old 06-15-2017, 02:06 AM
rickardl's Avatar
Quoted: 119 Post(s)
Liked: 95
When I play a DVD, such as R1 NTSC, and I have selected the player to output 1080p, will the player also convert the colorspace (gamut) from SD colorspace SMPTE-C/NTSC to the HD Rec. 709 colorspace?
Or will it just do the upscaling of the resolution?
rickardl is offline
post #9229 of 9238 Old 06-15-2017, 04:05 AM
Read the FAQ!
Liked: 4307
^ You'll get Bt.709 with output 720p or higher. You'll get BT.601 with output below 720p. All automatic.
--Bob
rlb likes this.
post #9230 of 9238 Old 06-20-2017, 02:07 AM
danishdrummer's Avatar
MKV/3D on BDP-103 Darbee?
I've been trawling the web for an answer, but I have been unable to find it.
I have ripped some of my discs, including 3D ones to MKV to save shelf space. But it seems that the player is unable to play 3D mkv's? I found this info on Oppo's official site "press the 3D button on the remote once to turn on the "2D->3D" conversion then press the 3D button again to display the "3D Setting" menu. Select "Side-by-Side" or "Top-Bottom" to match the source to convert the image to 3D press the 3D button on the remote once to turn on the "2D->3D" conversion then press the 3D button again to display the "3D Setting" menu. Select "Side-by-Side" or "Top-Bottom" to match the source to convert the image to 3D".
However, as I own the Darbee edition, there is no 3D button on the remote, but instead the dimmer button is in the 3D buttons place with the Darbee button below. Is there no way to turn on the above setting without having a 3D button on the remote? It cannot be done manually in the settings menu, it seems. Maybe the feature has been removed again?
Help would be much appreciated!
danishdrummer is offline
post #9231 of 9238 Old 06-20-2017, 05:22 AM
wmcclain's Avatar
Liked: 2374
Is 3D in the Options popup menu? Just above the RED button on the remote.
Note that the player supports the side-by-side and top-bottom formats, but not the native MVC 3D format.
-Bill
post #9232 of 9238 Old 06-20-2017, 01:45 PM
-Bill
Thanks, Bill – yes it is! Along with advanced subtitles settings (also zoom settings, but at least the zoom button is still on the remote). Problem solved. It's a bit odd that this is not mentioned in the manual. It only mentions subtitle and picture adjustment + zoom and angle (page 29). But thanks again!
post #9233 of 9238 Old 06-23-2017, 03:32 PM
ti-triodes's Avatar
Quoted: 317 Post(s)
Liked: 444
Have there been any reports of the 103D (or 103) emitting a strong plastic smell after playing a disc for a while?
I sent my 103D back to OPPO after it started stinking fairly badly. It didn't matter what kind of disc I played. They found nothing wrong but changed the loader. It was fine for a while, but has started smelling again. I thought I'd check with you guys before contacting OPPO again while still under the repair warranty.
Any one else report this over the years?
ti-triodes is offline
post #9234 of 9238 Old 06-23-2017, 05:28 PM
JazzGuyy's Avatar
Quoted: 316 Post(s)
Liked: 314
Is the location of the player well ventilated with plenty of clearance around the player for air flow? Sounds like an overheating problem to me.
JazzGuyy is online now
post #9235 of 9238 Old Yesterday, 02:45 PM
ti-triodes's Avatar
Quoted: 317 Post(s)
Liked: 444
It's in an open rack with lots of air. Agreed it sounds like something is overheating. I'll probably open the cover and do a touch test after unplugging it and letting the caps discharge.
post #9236 of 9238 Old Yesterday, 03:59 PM
Read the FAQ!
Liked: 4307
Take the player to another room, attach ONLY the power cable, and play something like a CD on Repeat All for a few hours. Any odor? (There will of course be no audio or video output since nothing else is cabled.)
I'm guessing the answer will be no.
Assuming it passes that test, and given that OPPO stated they found no problems, the most likely explanations are:
1) The odor is coming from something else in your setup. Not the OPPO. OR,
2) Something you have connected to the OPPO is faulty and is causing excessive draw against the power supply in the OPPO. Thus excessive heat.
I'm betting (2) will be the case.
There are several possibilities here:
1) You have a shorted cable attached to the OPPO.
2) You have a shorted device at the other end of some cable.
3) You are trying to draw too much power from the USB sockets by attaching USB drives that need a lot of juice and are not connected to external power.
4) You have a mistake in your cabling which is causing unintended power flow. As just an example of this, suppose you have two devices that want to share the Subwoofer. One common mistake is to wire both of them to the Subwoofer by using a Y-adapter at the Subwoofer so that the output signal from both devices can reach the single input of the Subwoofer. The PROBLEM with this is that those two outputs are not just connected to the Subwoofer, they are connected TO EACH OTHER. Which means you have the output of one device forcing voltage BACK INTO the output of the other device (and vice versa).
I used that last paragraph as just an example of the type of wiring mistakes we've had posted here. What you should do in YOUR case is carefully re-think your wiring looking for silly mistakes like this.
Here's another possibility: You have one heck of a Ground Loop current flowing. A Ground Loop is garbage current that flows along the cable shields of the cables connecting your devices trying to find a path back to Ground. The devices in the path don't even need to be turned on.
These days the most common source of such Ground Loop garbage current is the feed wire coming into your house for cable or satellite TV. I.e., that wire is not properly Grounded where it enters your house.
Another possibility is that you have a faulty device which is leaking wall power to its chassis -- and thus to the shields of the cables. This is actually a dangerous situation. The usual suspects here would be power amps.
The OPPO has a 3-prong power plug, which is a typical path for such Ground Loop garbage current to flow. So the garbage current may be flowing around the chassis shield of the OPPO to Ground through that 3rd prong.
A Ground Loop would typically have other symptoms, such as Hum from your Subwoofer, or horizontal interference lines appearing on your TV screen. If you have either of those symptoms, then you may have a severe or even dangerous Ground Loop that needs to be fixed. I say severe because it is highly unusual for enough current to flow in a Ground Loop to heat things up. Start by disconnecting your TV feed where it comes out of the wall in your viewing room, and also unplug your amps. Run the OPPO for a while and see if the odor is gone.
--Bob
post #9237 of 9238 Old Yesterday, 08:10 PM
rdgrimes's Avatar
Quoted: 2272 Post(s)
Liked: 1623
There's a CPU cooler on the SOC chipset. Check to see if that's loose. That would account for all your symptoms. I think they use a sticky pad for thermal paste.
rdgrimes is online now
post #9238 of 9238 Old Today, 02:48 PM
ti-triodes's Avatar
Quoted: 317 Post(s)
Liked: 444
--Bob
Thanks Bob. There's about 30 hours on it since I got it back and it was checked in 2 locations. Then it was plugged directly into my E6 since I'm planning to sell it. No other grounding other problems in the house.
Thanks so much. I'll check this out.
Reply Blu-ray Players
Oppo , Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 103d Universal 3d Blu Ray Player Darbee Edition , Oppo Brand , Oppo Digital , Oppo Digital Inc
