Official OPPO BDP-103D (Darbee Edition) Owner's Thread - Page 85 - AVS Forum | Home Theater Discussions And Reviews
 630Likes
post #2521 of 9252 Old 01-30-2014, 08:10 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 3811
For something with Native, use Native. For something without (Dish Network), Id recommend 1080i.
gadgtfreek is online now
post #2522 of 9252 Old 01-30-2014, 08:59 AM
vince325's Avatar
Quoted: 12 Post(s)
Hello all have the 103D and wonder if it will play back pal discs in a region 1 player. It looks like it might but want to check before I go and buy any.Thx
Thanks, Vince
Pioneer Kuro
Sony VPL-HW50
Marantz 8801
Oppo 103D
DirectV
XBOX 360
vince325 is offline
post #2523 of 9252 Old 01-30-2014, 09:32 AM
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
Thinking about buying a 103D and read on another thread that its possible to connect a cable box to the player? I'm curious to know how big of a difference it makes and if there's any lip sync issues? My configuration would be Cable box > Oppo 103D > Marantz HDMI receiver > Panny 60VT60 via ARC 2.
Panasonic P60VT60 Calibrated by Chad B
Marantz NR-1504
GoldenEar SuperSat 50s
SVS PC-2000
AppleTV 3
Sony PS4
mbroadus is offline
post #2524 of 9252 Old 01-30-2014, 09:39 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1207 Post(s)
Liked: 1249
Yes, as long as they are coded for the correct region for player or set as all region, they'll play fine. The player can either keep them in PAL format or convert them to NTSC depending on what your TV supports and how you have the video output settings configured on the Oppo.
gsr is online now
post #2525 of 9252 Old 01-30-2014, 09:51 AM
bob brennan's Avatar
Quoted: 105 Post(s)
Liked: 148
Set up that way, cable box is into the rear HDMI of the 103D - cable/103D/AVR/65ZT60 - no problems once you get the settings right in the 103D - all the processing of the signal is done in the 103D - box is native/direct - AVR through/direct to Panny 65ZT60
Panasonic TC-P65ZT60 - Oppo BDP-103D - Panasonic DMP-BDT220 - Toshiba HD-DVD-3A - OPPO DV-981HD - Harmony ONE
Onkyo TX-NR809 --- Definitive Technology - Studio Monitor 65 (2) - CS8040HD - Studio Monitor 45 (2) - Super Cube 6000
bob brennan is offline
post #2526 of 9252 Old 01-30-2014, 10:20 AM - Thread Starter
Neuromancer's Avatar
Quoted: 95 Post(s)
Liked: 360
Neuromancer is offline
post #2527 of 9252 Old 01-30-2014, 12:40 PM
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
Thanks...yes I currently have the cable box set on pass thru so that the panny does the signal processing and would keep the current configuration so that the 103D does the processing.
Marantz NR-1504
SVS PC-2000
AppleTV 3
Sony PS4
mbroadus is offline
post #2528 of 9252 Old 01-30-2014, 12:41 PM
Dougofthenorth's Avatar
Liked: 44
Fox/ESPN and several other stations transmit in 720P, most transmit in 1080i. It is usually recommended the the output from the cable box to the 103D should be set to native/direct or whatever sends the signal through unprocessed. The 103D should be set to output whatever the display capability of the HDTV/projector is which usually is 1080p.
-The 9242 allows only 3 levels 420p, 720p, 1080i
Originally Posted by WestCDA View Post
The Bell 9242 (a rebadged Dish receiver) can be set for an fixed HD output of either 720p or 1080i, which applies to all channels regardless of the source signal. As it's impractical to change this on the fly, I chose the 1080i setting and let the 103D deinterlace the signal. To me, this results in the best image.
Tx I will leave it at 1080i then
Dougofthenorth
www.turtleshelltortue.org RIP
Dougofthenorth is offline
post #2529 of 9252 Old 01-30-2014, 04:27 PM
conan48's Avatar
Quoted: 290 Post(s)
Liked: 349
If you set the Oppo to 4K upscale, does the darbee still function? I was told the darbee does not process 4K signals, so wouldn't that be a waste of money if you have a 4K tv and upscale everything to 4K from the Oppo?
conan48 is offline
post #2530 of 9252 Old 01-30-2014, 04:34 PM
garyokie51's Avatar
I have my Directv STB hooked up to my Oppo 103D. If I use the native setting and jump back and forth between a 720P and 1080i program it takes a couple seconds to sync. This is an issue when watching 2 sporting events at the same time. If I have the STB output 1080i there is no lag. Anyway to use native and eliminate the lag?
garyokie51 is offline
post #2531 of 9252 Old 01-30-2014, 04:38 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 3811
Nope, its the handshake and resolution change.
post #2532 of 9252 Old 01-30-2014, 05:03 PM
David Susilo's Avatar
Quoted: 622 Post(s)
Liked: 588
Th
The Darbee is applied before 4K upscaling. Also IF you use a Sony TV or projector, the Sony's internal scaler is leaps and bounds better than Oppo.
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED & WifiHifi Magazines
my (yet to be completed) BD list
my home theatre
David Susilo is offline
post #2533 of 9252 Old 01-30-2014, 05:07 PM
conan48's Avatar
Quoted: 290 Post(s)
Liked: 349
Originally Posted by David Susilo View Post
Th
I have a JVC, but it's funny they were saying in the Sony 4k thread that he Oppo was better at upcaling then the Sony built in one biggrin.gif
conan48 is offline
post #2534 of 9252 Old 01-30-2014, 05:43 PM
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
The same thing happens since my cable box is set to pass thru the signal so that it's processed by the Panasonic display. There's a lag when switching channels.
Marantz NR-1504
SVS PC-2000
AppleTV 3
Sony PS4
mbroadus is offline
post #2535 of 9252 Old 01-30-2014, 06:01 PM
Quoted: 622 Post(s)
Liked: 588
Too funny. They must have used "auto" setting instead of custom settings. I have daily access to multiple Sony displays and use the projector too, the upscaling on the Sony is closer to real 4K (A/B comparison with actual 4K movies of the same title and scenes) than the Oppo.
The Oppo can look "nicer" (sharper, more contrasty etc) but in terms of re-creating 4K, the Sony displays have the best upscaler.
my home theatre
post #2536 of 9252 Old 01-30-2014, 06:18 PM
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
I was told that the 103D processes audio, is this true?
Marantz NR-1504
SVS PC-2000
AppleTV 3
Sony PS4
mbroadus is offline
post #2537 of 9252 Old 01-30-2014, 06:25 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 3176 Post(s)
Liked: 2461
"Processes"? In what way?
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #2538 of 9252 Old 01-30-2014, 06:35 PM
pieandchips's Avatar
Liked: 175
Using the audio analogue preamp outputs, you can adjust levels and speaker types / audio delay etc.
HDMI audio no Sir.
pieandchips is offline
post #2539 of 9252 Old 01-31-2014, 05:34 AM
conan48's Avatar
Quoted: 290 Post(s)
Liked: 349
Do you have experience with the JVC eshift 3? I'm trying to get an idea if the Oppo 4K upscale does a better job then the JVC upscale to 4K,
conan48 is offline
post #2540 of 9252 Old 01-31-2014, 05:48 AM
Quoted: 622 Post(s)
Liked: 588
Unfortunately I'm still waiting for my X700 projector to arrive from JVC for long-term loaner (so I can do a very thorough feedback for their next year's model).
my home theatre
post #2541 of 9252 Old 01-31-2014, 07:50 AM
tlb48's Avatar
wouldn't direct AVR through refer to the audio not the video. would you loose mcacc or audyssey processing that way ? would you loose surround modes on the AVR ?
tlb48 is offline
post #2542 of 9252 Old 01-31-2014, 08:07 AM
Quoted: 105 Post(s)
Liked: 148
No - would have no effect on the audio portion of the signal - with many AVR's you can bring up the onscreen menu and set the "video" for direct or pass-through - Audio portion would have surround modes & audyseey intact
post #2543 of 9252 Old 01-31-2014, 08:58 AM
Kris Deering's Avatar
Quoted: 1985 Post(s)
Liked: 3115
I thought you got a X700 back in December?
From you in December:
"My apology for not catching your question I have the JVC X700 for review purpose the 4K upscaling inside the X700 is better than the 103D 4K upscaling.
My favourite setting is to set the 103D in hi-def mode at 35%, VRS at +1, output at 1080p 4:4:4 30-bit dithered into the X700 and let the projector do the upscaling under AUTO mode (under auto it uses 3 separate filters at 3 separate variable rate whereas if you use manual mode, the 3 filters will be running in tandem at the same rate on all three of them)
Now if you want a great upscaler, you'll need to get the Sony 4K projector the upscaler is freakishly amazing although the black level is nowhere as good as the X7oo."
My Home Theater
FS: 120" 16x9 Stewart Studiotek 100 screen material
Kris Deering is offline
post #2544 of 9252 Old 01-31-2014, 09:58 AM
Quoted: 622 Post(s)
Liked: 588
Kris, at that time the review unit was using the beta firmware (I didn't know at the time), just before CES they took it away from me to install the final firmware. Therefore my review at the time is considered moot.
my home theatre
post #2545 of 9252 Old 01-31-2014, 10:08 AM
conan48's Avatar
Quoted: 290 Post(s)
Liked: 349
Kris, at that time the review was using the beta firmware (I didn't know at the time), just before CES they took it away from me to install the final firmware. Therefore my review at the time is considered moot.
I don't think they would mess up the eshift 3 from prototype to final firmware. Usually, things only get better not worse......
I'm gonna wait then and see what you and the other experts on here think between the Oppo upscale vs. JVC eshift upscale.
conan48 is offline
post #2546 of 9252 Old 01-31-2014, 10:27 AM
Quoted: 622 Post(s)
Liked: 588
So true, but I just don't want to assume.
Kris Deering likes this.
my home theatre
post #2547 of 9252 Old 02-02-2014, 06:06 AM
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
I have an appointment to have my Panny 60VT60 calibrated on March 1 and thinking of buying a 103D but not sure if it will happen before or after the calibration. I currently have a PS3 for blu-ray but I'm more concerned how much of an impact the Darbee processor will have on calibration on the cable output since I'll have my SA 8300HD running thru it?
Marantz NR-1504
SVS PC-2000
AppleTV 3
Sony PS4
mbroadus is offline
post #2548 of 9252 Old 02-02-2014, 06:08 AM
wmcclain's Avatar
Liked: 2461
People say Darbee does not affect calibration, but I would ask the calibrator. Give him all the specifics and see what he says. Does he need all the final gear in place or not?
-Bill
post #2549 of 9252 Old 02-02-2014, 06:17 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 3811
IMO it does not. If you have the 103D by then, just have them run their signal generator thru the Oppo, thats what I do smile.gif
post #2550 of 9252 Old 02-02-2014, 07:25 AM
Liked: 175
-Bill
It's easy to disable Darbee. I always calibrate with it off, especially when working on sharpness.
I came from a PS3, and all I can say is, wow, I wouldn't have thought the 103D output to be superior but it totally is, with Darbee on or off, the clarity is fantastic. I never knew what I was missing.
Reply Blu-ray Players
Oppo , Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 103d Universal 3d Blu Ray Player Darbee Edition , Oppo Brand , Oppo Digital , Oppo Digital Inc
