Any Advantage in Running HDMI Straight to Display Instead of through a Receiver? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-03-2013, 05:10 PM - Thread Starter
Tangled Cable's Avatar
Quoted: 115 Post(s)
Liked: 37
If I run the video signal from my blu ray player to a receiver and then to my display, aren't I running some risk of degrading or changing the signal in some way? Seems like the purest method would be to run it straight to the display, no?
Tangled Cable is offline
post #2 of 5 Old 10-03-2013, 05:39 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4780
The audio makes no difference to you? Or do you have dual hdmi outputs on your player? Personally I just use pass-through on my avr as far as video processing is concerned as my tv does a great job.
lovinthehd is offline
post #3 of 5 Old 10-03-2013, 06:04 PM - Thread Starter
Quoted: 115 Post(s)
Liked: 37
I would run separate HDMI audio and video cables to preserve HD audio.
Passthrough means the signal is untouched?
post #4 of 5 Old 10-03-2013, 06:24 PM
lovinthehd's Avatar
Liked: 4780
post #5 of 5 Old 10-03-2013, 07:15 PM
Super Moderator
teachsac's Avatar
Quoted: 815 Post(s)
Liked: 1337
Discussed many times over.
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
Closed Thread Blu-ray Players
