USB bass management work around? - AVS Forum | Home Theater Discussions And Reviews
Old 10-07-2013, 10:08 AM - Thread Starter
huber13's Avatar
Does anybody have a work around to get bass management through USB audio in? I just found out that there is no bass management for that input and really makes the DSD decoding sound a little weak with no sub. I have B&W N803's and a Velodyne DD-12 sub they sound very good but not as good with out the sub, it takes a lot of the dynamic punch out of the sound. I'm using J River 19 on my PC and there is no way on their end to get the sub to work. My only thoughts are to get a sound card for the PC that has S/PDIF or Toslink outs. Anyone else try this and how does it sound?
Marantz AV8801, XPA-2 front, XPA-5 C-SL, SR, rear, OPPO BDP-105, B&W N803 mains, HTM2 center, LCR-6 S2 surrounds, DM 601 S2 Back, Velodyne Optimum 12 sub, Panasonic 60VT60, Directv HD HR-24, Panamax 5100. 3- dedicated 20 amp lines, Pro-Ject 2Experience TT, Ortofon Quintet Black, Musical Sourroundings Phonomena II + phono pre-amp.
huber13 is offline
Old 10-07-2013, 11:23 AM
Super Moderator
teachsac's Avatar
Quoted: 650 Post(s)
Liked: 950
Please use the thread for whichever player you have. Use the Post a Reply Button, not the start a new thread button.
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
Velodyne Eq Max 12 12 Subwoofer
