DTS Master Audio decoding problem? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-16-2013, 01:27 PM - Thread Starter
slumkid's Avatar
Hi All -
Haven't used my Oppo to play discs for a few months. I just put in the new Tommy Blu-Ray disc, and was very disappointed that there was no sound from the rear speakers when I selected the DTS Master HD audio track.
I noticed that the Oppo was reporting the disc properly as DTS audio when I selected that sound track, but my Sony ES receiver is just seeing PCM stereo, no matter which sound mode I select on the Oppo. I checked a couple of other DTS discs that i know USED to work fine, but they will not play properly either. Dolby Digital 5.1 surround works fine, but no DTS Master HD. All of the settings look fine to me on the Oppo - audio output is set to bitstream.
I tried re-seating the HDMI cables and powering everything down and back up with no luck. Obviously, I have to determine if the issue is with my Oppo or my Sony receiver. I'm not sure where I am going to get another blu-ray player I can try.
In the meantime, has anyone heard of this issue with the Oppo, or have any other settings / suggestions I could try?
Tom
Better Things
slumkid is offline
post #2 of 2 Old 11-16-2013, 01:56 PM
Super Moderator
teachsac's Avatar
Quoted: 650 Post(s)
Liked: 949
Please post in the appropriate Oppo thread.
S~
slumkid likes this.
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
Closed Thread Blu-ray Players
Sony Str Da5500es Es Series Network A V Receiver
