Official Sony BDP-S1200, BDP-S3200, BDP-S4200, BDP-S5200, BDP-S6200, and BDP-S7200 - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 947Likes
post #721 of 3697 Old 04-06-2014, 03:13 PM
Selvos's Avatar
Quick question:
Does the s5200 output multichannel audio over coax?
I'm looking at this and the 5100. Since I don't have a AVR with 3d passthrough I need to feed the video direct to the tv through HDMI, but I still want multichannel audio so the coaxial will have to provide that.
Although I don't know how often I'll use 3d, I just want the option without switching cables around everytime.
Selvos is offline
post #722 of 3697 Old 04-06-2014, 09:51 PM - Thread Starter
apw2607's Avatar
Quoted: 109 Post(s)
Liked: 219
Originally Posted by Selvos View Post
Quick question:
Yes but just lossy Dolby Digital and DTS bitstream
marctronixx likes this.
apw2607 is offline
post #723 of 3697 Old 04-07-2014, 11:11 AM
SeLfMaDe111985's Avatar
Liked: 99
Hey guys,
I just picked up the S6200. Great BDP, but one thing that annoys the heck out of me is when I turn my ZT60 on, the 6200 automatically turns on and my TV switches to that input. I couldn't find in the settings of the 6200 where to shut this off so maybe I have do something with the TV. Also my TV remote can control the 6200 which I do not like. I had a Samsung F7500...for a flagship model it was a little slow and also started making weird noises. Guess that's what happens when you buy a Samsung. Anyway saw great reviews for the 6200
SeLfMaDe111985 is offline
post #724 of 3697 Old 04-07-2014, 11:19 AM
Selden Ball's Avatar
Quoted: 3050 Post(s)
Liked: 1494
Originally Posted by SeLfMaDe111985 View Post
Hey guys,
To prevent one device from turning on others, you need to turn off the HDMI feature CEC "Consumer Electronics Control" in all of the devices. Different companies give it different names.
Selden
Selden Ball is online now
post #725 of 3697 Old 04-07-2014, 12:03 PM
Liked: 99
Is there a feature in the BDP that I can find
post #726 of 3697 Old 04-07-2014, 12:10 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
You have to turn it off on all the devices (BDP, AVR and TV).
On the Sony Player, it is called 'Control for HDMI'.
On Panasonic TV, it is called 'VIERA Link'
Foxbat121 is online now
post #727 of 3697 Old 04-07-2014, 01:19 PM
jdowney's Avatar
I have been having a problem with my S6200. When I go to turn the machine on (with my Harmony Remote) the BDP does not come on. The unit will also not come on with the Panasonic remote and will not come on if I use the on/off button on the machine and the DVD tray will not open. I have to unplug the machine at which point I get a "wait" signal and the machine turns off. It will then power on with the remotes and the machine appears to be working normally.. However, if I shut it off for any period of time, the same exact thing happens and I cannot get it to power back up until I unplug the machine.
This morning, at Sony technical support's request, I reset the factory defaults on the unit. The software is also up to date.
Sony now wants me to send the machine back to them.
Any ideas??
jdowney is offline
post #728 of 3697 Old 04-07-2014, 01:22 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
Sounds like a broken machine that locks up over the time.
post #729 of 3697 Old 04-07-2014, 03:01 PM
WingmanHD's Avatar
Any ideas??
Any chance you have the S6200 plugged into the your Receiver's switched AC output receptacle? I had my S5100 temporarily plugged into my receiver's switched AC output and it was not powering on properly.
WingmanHD is offline
post #730 of 3697 Old 04-08-2014, 04:44 PM
pharcycle's Avatar
sorry if this is a duplicate question but will these players bitstream / passthrough the HD audio formats over HDMI? They say they don't decode them but manual says they output Dolby Digital, LPCM and DTS for MPEG 2 (but not referring to the HD formats) so just want to check I'm not about to cripple my setup if I get one. John Lewis only lists the sound output as 'Dolby True HD (2ch)' and Sony's own website is decidedly coy about what it can do.
I'm probably just going for the more basic S4200 unless anyone has a better alternative?
I take it by decode the HD audio they are referring to the (lack of) ability to downsample the audio through the optical out at a lower bitrate?
Thanks and sorry my first post here is an annoying question!
pharcycle is offline
post #731 of 3697 Old 04-08-2014, 05:15 PM
von Levi's Avatar
Quoted: 26 Post(s)
Liked: 35
They do.
von Levi is offline
post #732 of 3697 Old 04-09-2014, 04:16 AM
Hatex's Avatar
Im looking at buying either the s5200 or s5100. Anyone whom tried them both and can tell if there are any changes in picture quality for normal bluray?
Where I live the s5200 is cheaper then the s5100, so thinking about grabing s5200 aslong there aren't any picture quality downsides compared to the s5100, despite what sony says..
Hatex is offline
post #733 of 3697 Old 04-09-2014, 06:20 AM
wonkycows's Avatar
I haven't compared the two models you speak of, but the s5200 is this years model and the 5100 is last years. I'd buy the latest tech if i were you. I don't believe there's a reason to buy the older model unless it was significantely cheaper.
wonkycows is offline
post #734 of 3697 Old 04-09-2014, 06:34 AM
UHD Addict
aaronwt's Avatar
Quoted: 5192 Post(s)
Liked: 3099
The S5200 did a way with the display and did away with one of the USB ports. So there is only a front USB port. So the USB stick you need for BD live would need to be in the front. This is the reason I went with the S6200. That seemed likemore of a successor to the S5100. The S5200 also has the newest apps. So if you can get the S5200 for less the the S5100. I would say that is your best bet. Unless the one USB port or no display is a deal killer.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is online now
post #735 of 3697 Old 04-09-2014, 09:18 AM
mzs22's Avatar
Quoted: 18 Post(s)
Tried to get online to watch netflix and got a SSL alarm message. Also a network error has occurred Anybody have this problem?.
mzs22 is offline
post #736 of 3697 Old 04-09-2014, 02:51 PM
Iain-'s Avatar
Quoted: 89 Post(s)
Liked: 58
How old is your gateway router?
When did you last update gateway firmware?
If it's old and slow, it could be time to upgrade to a faster and more secure one.
Iain- is offline
post #737 of 3697 Old 04-09-2014, 04:24 PM
mzs22's Avatar
Quoted: 18 Post(s)
My router is a netgear wndr 3300 not having a problem connecting on anything else.Firmware is up to date
mzs22 is offline
post #738 of 3697 Old 04-09-2014, 05:40 PM - Thread Starter
apw2607's Avatar
Quoted: 109 Post(s)
Liked: 219
The 5200 also supports IP noise reduction PRO if I'm not mistaken. This does improve marginal streaming video quality over regular IP noise reduction on the 5100.
Also the feature can be applied to any IP content now ... not just content that used the old Sony app framework ... like the old "amazon instant video" and "Crackle" apps.
apw2607 is offline
post #739 of 3697 Old 04-09-2014, 05:41 PM - Thread Starter
apw2607's Avatar
Quoted: 109 Post(s)
Liked: 219
Are you using the dedicated app ... or trying to view Netflix in the BDPs browser?
apw2607 is offline
post #740 of 3697 Old 04-09-2014, 05:49 PM
mzs22's Avatar
Quoted: 18 Post(s)
I am using the regular netflix app. I reset my router again and I can now get online. Not sure if it will stay working though.
mzs22 is offline
post #741 of 3697 Old 04-10-2014, 08:38 AM
terry2's Avatar
Quoted: 33 Post(s)
Liked: 25
Had same problem several times yesterday (Netflix and Amazon). According to a couple of post on the Sony forum the problem is the Sony servers (apparently you are routed thru them for the online apps). Don't know if that is the actual problem or not but makes sense.
terry2 is offline
post #742 of 3697 Old 04-10-2014, 11:12 AM
mzs22's Avatar
Quoted: 18 Post(s)
Happened again today,reset my router, and unplugged the machine and was able to get on netflix but when I tried amazon I got the "network error message" and could not get back on anything again.When I tried crackle I got the ssl alarm message but with other apps, "a network error has occurred".
mzs22 is offline
post #743 of 3697 Old 04-10-2014, 12:21 PM
Iain-'s Avatar
Quoted: 89 Post(s)
Liked: 58
Maybe it's time to have a go of one of these:
http://www.cisco.com/cisco/web/UK/solutions/small_business/products/routers_switches/small_business_routers/index.html
... specifically RV120 or RV180. You might like what you find there and here, as well.
http://www.smallnetbuilder.com/
Iain- is offline
post #744 of 3697 Old 04-10-2014, 10:53 PM
mzs22's Avatar
Quoted: 18 Post(s)
Went to Staples today and picked up Netgear Nighthawk AC1900 router,see if that helps
mzs22 is offline
post #745 of 3697 Old 04-10-2014, 10:57 PM
mzs22's Avatar
Quoted: 18 Post(s)
Also reset the dvd player.
mzs22 is offline
post #746 of 3697 Old 04-11-2014, 06:29 AM
chronoclast's Avatar
Quoted: 21 Post(s)
I've searched the thread and may have missed this but does the S6200 not remember resume points of BDs and DVDs? According to the manual it should but it always starts playback from the beginning. Is there a setting or something I'm missing?
Vizio M502i-B1, Ideal-Lume Bias Light, Chromapure, i1 Display 3 Pro, Harmony 700 Remote
Lumagen Radiance 2020, Oppo BDP-103, Marantz CD5004
Marantz SR7008, Polk Series II Monitor 70s Fronts, CS2 Center, 30s Surrounds, BIC America F12 Dual Subs
chronoclast is offline
post #747 of 3697 Old 04-11-2014, 06:55 AM
Iain-'s Avatar
Quoted: 89 Post(s)
Liked: 58
Also, don't forget to reboot the ISP broadband interface kit.
If none of that resolves the issue, contact your ISP as it could be a problem with them.
Good luck, mate.
Iain- is offline
post #748 of 3697 Old 04-11-2014, 06:58 AM
Iain-'s Avatar
Quoted: 89 Post(s)
Liked: 58
For BD, that's down to Java on individual titles. That's a problem I have as well, as it's a well-known BD issue.
DVD is quite stable for this issue as I've never had a resume point problem with that format.
Iain- is offline
post #749 of 3697 Old 04-11-2014, 07:32 AM
Muckle Dabuckle's Avatar
Excellent choice!  We got a free Motorola modem with ours and streaming on all of our devices has been amazing with those two devices.  With QOS enabled Netflix loads movies in less than 10 seconds in most cases and rarely buffers.   I've only had to unplug the Nighthawk once in the three months I've had it (with my old router I had to unplug it a couple times a month).
Muckle Dabuckle is offline
post #750 of 3697 Old 04-11-2014, 08:03 AM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 2968
Just wanted to drop back in and say I watched 3 new releases yesterday and the player is nice and fast with great PQ.
65E6P / 65EF9500 / DMP-UB900
AV7702II / Outlaw 7125
RF7II's / RC64II / Dual FV15HP's
gadgtfreek is online now
Reply Blu-ray Players
BDP-S6200 , bdps720 , sony bdp s7200 , Sony Blu Ray Disc Player Bdp S790
