Official Sony BDP-S1200, BDP-S3200, BDP-S4200, BDP-S5200, BDP-S6200, and BDP-S7200 - Page 31 - AVS Forum | Home Theater Discussions And Reviews
 948Likes
post #901 of 3715 Old 06-03-2014, 05:33 AM
Nickff's Avatar
Quoted: 329 Post(s)
Liked: 212
Originally Posted by tboe77 View Post
Thanks for the suggestions. I'm using all Monoprice HDMI cables with redmere. All 6' lengths.
I already had deep color disabled, from day 1.
Will try your suggestion re: Netflix authorization.
Try using an HDMI cable that does not use redmere.
http://www.avsforum.com/t/1417609/monoprice-redmere-hdmi-cables
It is my understanding that redmere is more for long HDMI runs.
Sony XBR-65A1E | Denon X6300H | Klipsch RF-7ii (x2), RC-64ii, RB-51ii (x4) | SVS PB12-Plus | Xbox One S | WDTV Live | Sony BDP-S6200 | Harmony 670
Nickff is offline
post #902 of 3715 Old 06-03-2014, 05:39 AM
Iain-'s Avatar
Quoted: 89 Post(s)
Liked: 58
BJC Tartan HDMI cables should sort it quite well:
http://www.bluejeanscable.com/store/hdmi-cables/hdmi-cable.htm
Iain- is offline
post #903 of 3715 Old 06-03-2014, 05:53 AM
UHD Addict
aaronwt's Avatar
Quoted: 5657 Post(s)
Liked: 3435
Just get some Monoprice non Redmere HDMI cables for those short six foot lengths. They don't cost very much and they work very well. I use a bunch of them with my devices that need short length HDMI cables. I have zero issues with using Deep Color.
I use Redmere HDMI cables for long lengths. They work very well for that.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Sony UBP-X800--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is online now
post #904 of 3715 Old 06-03-2014, 06:32 AM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3476
I have redmere running everything for space, some 3 feet, and do not have any problems with deep color, etc...
That is 3 different blu-ray players, two avr's and two dvr's.
Sure, redmere are for long runs, but if you have tight spaces they have a secondary use. Also less stress on the connections.
gadgtfreek is offline
post #905 of 3715 Old 06-03-2014, 10:14 AM
jurid001's Avatar
Quoted: 58 Post(s)
Interesting reaction on AUTO setting in video playback in s6200
Just got s6200 to complement my array of players. Played LE SAMURAI (Criterion) DVD (quite grainy but of very good quality for the period). Immediately noticed how bad picture looked on default setting, - over-smoothed and plasticky. Changed settings, got better picture, of course. I wonder if my unit is defective, or the default setting is SO bad. s6200 is supposed to be for videophiles, who would hate those settings. What's your impression of various video settings?
A2, A35, 150, 62fd, s790, s6500, 103D, WDTV LIVE, HTPC w/ HD-DVD/BD
jurid001 is offline
post #906 of 3715 Old 06-03-2014, 10:31 AM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3476
Use Direct.
post #907 of 3715 Old 06-03-2014, 10:48 AM
jurid001's Avatar
Quoted: 58 Post(s)
Why?
Sent from my SPH-L710 using Tapatalk
jurid001 is offline
post #908 of 3715 Old 06-03-2014, 12:06 PM
helvetica bold's Avatar
Quoted: 435 Post(s)
Liked: 263
yes, direct adds no additional processing. popped in the OG Transformers the other night, had no idea the bluray looked so good (sharp)! Im so use to the IQ of cable TV.
helvetica bold is offline
post #909 of 3715 Old 06-03-2014, 12:20 PM
jurid001's Avatar
Quoted: 58 Post(s)
Outputting without processing may defeat the purpose of s6200. Why buy s6200 then, you could get s1100 ?
jurid001 is offline
post #910 of 3715 Old 06-03-2014, 01:47 PM
marctronixx's Avatar
Quoted: 24 Post(s)
Liked: 35
Some users want the latest model and also the option to keep the signal as pure and untouched as possible, hence direct mode.
marctronixx is offline
post #911 of 3715 Old 06-03-2014, 02:03 PM
UHD Addict
aaronwt's Avatar
Liked: 3435
Plus everything below the 6200 only has one USB port.
post #912 of 3715 Old 06-03-2014, 02:16 PM
jurid001's Avatar
Quoted: 58 Post(s)
i don't think DIRECT in this case relates to direct more. It upconverts DVDs to 1080/24p in my case. Also in 48-bit;)
jurid001 is offline
post #913 of 3715 Old 06-03-2014, 05:34 PM
Cibo's Avatar
Quoted: 46 Post(s)
I just purchased the 6200. Can you guide me to the "direct" setting you are referring to?
Cibo is offline
post #914 of 3715 Old 06-03-2014, 05:50 PM
Cibo's Avatar
Quoted: 46 Post(s)
Sorry! Found it in the options menu. I should have looked more closely, but thank-you for catching this.
marctronixx likes this.
Cibo is offline
post #915 of 3715 Old 06-03-2014, 06:58 PM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3476
Yeah, goofy how that group of settings works.
post #916 of 3715 Old 06-04-2014, 06:18 AM
butch666's Avatar
Quoted: 39 Post(s)
Can anyone verify whether the S6200 will play MKV files with embedded subtitles over DLNA.
The S5100 cannot do this! (it will play the movie but not show the subtitles mad.gif)
butch666 is offline
post #917 of 3715 Old 06-04-2014, 07:19 AM
jurid001's Avatar
Quoted: 58 Post(s)
Forgot to mention that I also have a s5100. I must say I cannot get a better picture from s6200 than from s5100. Both are outputting DVDs at 1080/24p 48 bit color (s5100 on THEATRICAL setting). Anyone has experience playing with VIDEO SETTINGS and can shed some light on the problem?
jurid001 is offline
post #918 of 3715 Old 06-04-2014, 07:21 AM
Kisakuku's Avatar
Quoted: 24 Post(s)
Liked: 72
S5100 does it very well, the player is not your issue.
Kisakuku is offline
post #919 of 3715 Old 06-04-2014, 07:32 AM
butch666's Avatar
Quoted: 39 Post(s)
Are you really sure about that? I have tried several MKV files made by muxing in an srt file. All these play perfectly on my Panasonic VT60 through DLNA, but without the subtitles on my S5100....
But that's off topic since we're discussing the new product line here. Just wanted to hear if somebody had actually played any MKV's with embedded subtitles on the S6200. Because if this is the case I will most likely go and buy one ASAP...
butch666 is offline
post #920 of 3715 Old 06-04-2014, 07:37 AM
Kisakuku's Avatar
Quoted: 24 Post(s)
Liked: 72
I have been successfully playing MKVs with muxed in srt subs via DLNA on S580, S590, S5100 and S6200.
Kisakuku is offline
post #921 of 3715 Old 06-04-2014, 09:10 AM
neo_2009's Avatar
Quoted: 109 Post(s)
Liked: 63
When using an USB connection, the new models are able to play MKV with external subtitles ?
neo_2009 is offline
post #922 of 3715 Old 06-04-2014, 09:25 AM
bob_m10's Avatar
Quoted: 86 Post(s)
Is the Amazon app working with the newer players at this point? Thanks Bob
bob_m10 is offline
post #923 of 3715 Old 06-04-2014, 10:15 AM
UHD Addict
aaronwt's Avatar
Liked: 3435
The Amazon app has been working for a while on my 6200. Unless something changed recently,
bob_m10 likes this.
post #924 of 3715 Old 06-04-2014, 11:06 AM
bob_m10's Avatar
Quoted: 86 Post(s)
bob_m10 is offline
post #925 of 3715 Old 06-04-2014, 01:21 PM
Geir Henriksen's Avatar
HI, just got the s6200, and I think it is a big step up from my old ps3.
There is one thing i wonder about though, and that is how to output HD-sound (DTS-HD/True-Hd) from my ripped mkv files (On a cabled NAS) I see it on the display that is is outputting the HD sound, but it shows as only PCM on the receiver, but I would like the display on the receiver to light up with Dts-HD master and the like :o
When playing discs I get the receiver to light up with the full hd sound settings.
Any suggestions as to what settings I might have missed here?
Geir Henriksen is offline
post #926 of 3715 Old 06-04-2014, 02:42 PM
Kisakuku's Avatar
Quoted: 24 Post(s)
Liked: 72
Sony players haven't supported external subs for MKVs since S580.
neo_2009 likes this.
Kisakuku is offline
post #927 of 3715 Old 06-04-2014, 02:54 PM
Krayg's Avatar
Quoted: 13 Post(s)
I have the Sony BDP-S790, which seems to have the same Video Settings options available. These are displayed after choosing "Options" from the remote. When the Video Quality Mode of "Auto" is selected (as opposed to "Direct") I consistently get a better quality picture on DVDs (upconverted by the player to 1080/24p). It's subtle, but I definitely notice improved clarity without artifacts. But I can't see any difference between "Auto" and "Direct" when playing a Blu-ray, just with DVDs. I have no idea exactly what Auto is doing, and the manual gives no explanation.
Krayg is offline
post #928 of 3715 Old 06-04-2014, 03:23 PM
David Susilo's Avatar
Quoted: 619 Post(s)
Liked: 586
I can't seem to change the DNS number when using wireless connection, is this normal?
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED & WifiHifi Magazines
my (yet to be completed) BD list
my home theatre
David Susilo is offline
post #929 of 3715 Old 06-04-2014, 05:04 PM
raymondeast's Avatar
Quoted: 14 Post(s)
I have it hooked up wirless through wi fi and it is connected to the network I get 86%… but when I try to load internet videos nothing happens… also when I try tovuse screen mirroring my galaxy s3 says it is connected but it will not connect in the 6200..it just hangs there saying connecting… .it does that for 25 seconds then my galaxy automatically turns off the screen mirroring… it has the latest firmware update.
Any ideas.
raymondeast is offline
post #930 of 3715 Old 06-04-2014, 07:55 PM
crbaldwin's Avatar
Quoted: 77 Post(s)
Liked: 24
I don't suppose they made any DLNA operational improvements over my s590? Specifically I'm looking for thumbnails in the video lists, resume points saved through standby, and jumping to specific times in the video? Thanks.
crbaldwin is offline
Reply Blu-ray Players
BDP-S6200 , bdps720 , sony bdp s7200 , Sony Blu Ray Disc Player Bdp S790
