Official Sony BDP-S1200, BDP-S3200, BDP-S4200, BDP-S5200, BDP-S6200, and BDP-S7200 - Page 37 - AVS Forum | Home Theater Discussions And Reviews
 947Likes
post #1081 of 3697 Old 06-19-2014, 04:41 PM
Cortiz's Avatar
Quoted: 56 Post(s)
Liked: 45
According to the S7200 specs in the Sony UK website, it has high resolution audio which the S6200 does not have. So the players ARE different.
Cortiz is offline
post #1082 of 3697 Old 06-19-2014, 04:42 PM
Quoted: 860 Post(s)
Liked: 348
Originally Posted by David Susilo View Post
I thought Super Bit Mapping and the Sound Enhancer are nixed from the final product (of 6200). If they are both available in the 6200 then it's only cosmetics difference between the 7200 and 6200.
S6200 has option for "Digital Music Enhancer", but all I saw was an "SBM" option which is described as a "smoothing video graduation" over HDMI output (as if it has other types of output).
It's also a price difference.
JoeKustra is offline
post #1083 of 3697 Old 06-19-2014, 04:54 PM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 2969
SBM is in my menu, I know because I turned it off.
65E6P / 65EF9500 / DMP-UB900
AV7702II / Outlaw 7125
RF7II's / RC64II / Dual FV15HP's
gadgtfreek is offline
post #1084 of 3697 Old 06-19-2014, 05:54 PM
David Susilo's Avatar
Quoted: 612 Post(s)
Liked: 584
Thanks for the info . So SBM is in the 6200 but not DSEE (per Sony's "language", DME is different from DSEE)
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED & WifiHifi Magazines
my (yet to be completed) BD list
my home theatre
David Susilo is offline
post #1085 of 3697 Old 06-19-2014, 06:22 PM
Nickff's Avatar
Quoted: 277 Post(s)
Liked: 168
They both handle the same high-resolution audio formats...so what, exactly, is different?
marctronixx and steve1971 like this.
Nickff is offline
post #1086 of 3697 Old 06-19-2014, 06:37 PM
Quoted: 612 Post(s)
Liked: 584
DME enhances compressed music using re-equalization. DSEE uses "special algorithm" to upconvert anything including WAV to DSD.
my home theatre
post #1087 of 3697 Old 06-20-2014, 05:39 AM
Cortiz's Avatar
Quoted: 56 Post(s)
Liked: 45
Check out the sepcs here for the S7200: http://www.sony.co.uk/electronics/bl...specifications
Specs for the S6200: http://www.sony.co.uk/electronics/bl...yers/bdp-s6200
The players are definatley NOT the same. The S7200 has better audio specs. They may have the same guts for PQ but not not the same audio.
Cortiz is offline
post #1088 of 3697 Old 06-20-2014, 05:43 AM
Nickff's Avatar
Quoted: 277 Post(s)
Liked: 168
From the Sony UK site:
Hear the best sound with Digital Music Enhancer
Digital Music Enhancer combines three unique Sony audio technologies to give compressed content a richer sound. DSEE (Digital Sound Enhancement Engine) restores the subtle high frequency details that get lost in heavily-compressed digital files such as MP3s. Dynamic Recovery Range restores the contrast between soft and loud sounds – adding impact to dialogue, movies, and music. And Advanced Auto Volume automatically corrects the volume when changing between content formats.
It seems then that the 7200 has both DME and DSEE...likely to both be turned off by serious users (as many want the signal unmolested). I know I turned off DME on my 6200 as it affected the Netflix app.
That appears to be the first specific thing that is different between the two units.
David Susilo likes this.
Mathematics is the reason for the season.
Nickff is offline
post #1089 of 3697 Old 06-20-2014, 05:47 AM
Nickff's Avatar
Quoted: 277 Post(s)
Liked: 168
I have seen both those sites. As a matter of fact, I (earlier in the thread) posted a link to a Sony Asia page that listed a much more detailed list of specs...and, again, I see no difference in the audio formats handled by both units.
I want there to be a difference, so if you can point out something specific...I would love to hear it.
Nickff is offline
post #1090 of 3697 Old 06-20-2014, 05:55 AM - Thread Starter
apw2607's Avatar
Quoted: 110 Post(s)
Liked: 219
This all kind of reminds me when the US automotive manufacturers had their many different brands selling effectively the same car. For a company that's desperate to try and sell more to avoid posting more losses, perhaps Sony should simply offer just two players. Uber cheap and cheap. Price the 6200 at $79 MSRP and be done with it.
apw2607 is offline
post #1091 of 3697 Old 06-20-2014, 06:15 AM
Cortiz's Avatar
Quoted: 56 Post(s)
Liked: 45
Does the S6200 has this:
High-Resolution Audio – music as the artist intended
High-Resolution Audio works by converting analogue sound to digital at a higher and more precise rate than CDs. High-Resolution Audio can have a greater rate of 24bit/96kHz (compared to CD standard rate of 16bit/44.1kHz), capturing more of the details and subtleties in your music. The result is tracks exactly as they were recorded, with no compromise on sound.
Or
If it does, then they are the same.
Cortiz is offline
post #1092 of 3697 Old 06-20-2014, 06:20 AM
Nickff's Avatar
Quoted: 277 Post(s)
Liked: 168
^^^A few posts up, I mentioned that it does appear the 7200 offers both DME (available in the 6200) and DSEE (not available in the 6200)...so that is a difference. However I would be that many users will turn those features off, as audiophiles will likely want the audio signal untouched.
As far as the high-resolution audio description you give...it doesn't say anything specific. When I compared the audio formats that both units will play, there appears to be no difference...and that includes the high-resolution formats. I used the 6200's manual and this site to compare: http://www.sony-asia.com/product/bdp-s7200
Nickff is offline
post #1093 of 3697 Old 06-20-2014, 07:17 AM
krips's Avatar
Quoted: 140 Post(s)
Liked: 107
Regarding S6200 and S7200, my only concern was whether S7200 was capable of decoding Dolby TrueHD (5.1) vs (2.0). But that's not the case. Regarding PQ, I just got the Darbee darblet 5000 and it does some amazing job with the depth of PQ. Initially I was skeptical about getting the Darbee but experiencing the enhance PQ first hand is quite mesmerizing .
krips is offline
post #1094 of 3697 Old 06-20-2014, 08:28 AM
steve1971's Avatar
Quoted: 498 Post(s)
Liked: 431
About 2 weeks ago I talked with my Sony insider and she said the 7200 will not be offered in the U.S and the 6200 is it equivalent which means its pretty much the same model. This is one reason why I went with the 6200. So if people are waiting for Sony to bring the 7200 to the U.S your going to be waiting for a long time. One other thing I want to bring up is I am getting tired of people comparing the 6200 to the Oppo Blu ray players. Oppo is in a league of their own when it comes to Blu ray players and anyone who's smart enough knows that. They also charge a high price for their players which a guy like me who has a family and has priorities cant afford what they are asking for it. To me Sony is the next best thing and I feel the PQ of the 6200 comes very very close to the Oppo's. But to make comparisons just aint fair.
marctronixx and dandiego like this.
steve1971 is offline
post #1095 of 3697 Old 06-20-2014, 09:14 AM
Cortiz's Avatar
Quoted: 56 Post(s)
Liked: 45
I have never owned an Oppo so I can't personally comment on the PQ. However, most people, including professional reviewers, say that the as long as your BD player is outputting at 1080p 24p , there would not be any differences in PQ.
Cortiz is offline
post #1096 of 3697 Old 06-20-2014, 05:13 PM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 2969
Some of them have problems with cropping and colorspace, as seen with a test disc, but the recent sony's, pre 2013 Panny's, and Oppos pass with flying colors.
If you are just watching a blu-ray at 1080p/24, there is no need to huy an Oppo unless you want one.
Owner of 93, 103 and 103D.
post #1097 of 3697 Old 06-21-2014, 08:06 AM
Nickff's Avatar
Quoted: 277 Post(s)
Liked: 168
The Sony Asia site makes it seem like the 7200 will play 4k discs...not just upscale. Anyone else read it the same way? Are there any 4k movies to play?
"The Sony BDP-S7200 Blu-ray Disc™ Player
doesn't just play 4K resolution content, it also
upscales lower resolution content to near 4K
resolution."
Nickff is offline
post #1098 of 3697 Old 06-21-2014, 08:22 AM
steve1971's Avatar
Quoted: 498 Post(s)
Liked: 431
Agreed.
resolution."
Since it aint going to be released in the U.S and I don't plan on buying a 4K tv anytime soon or in the future I could care less. Plus there is no true 4K Blu ray disc's yet and it don't look as though there will be any anytime soon.
marctronixx likes this.
post #1099 of 3697 Old 06-21-2014, 09:02 AM
Vampidemic's Avatar
Quoted: 33 Post(s)
Liked: 48
resolution."
There is not a 4K disc standard. However, it might play 4K files from data discs, USB and/or network. Interestingly, the 6200 lists a resolution limit of 1920x1080 in the 'Playable types of files' section of the manual, but the 7200 manual omits that line.
Vampidemic is offline
post #1100 of 3697 Old 06-21-2014, 03:20 PM
UHD Addict
aaronwt's Avatar
Quoted: 5193 Post(s)
Liked: 3102
The S7200 needs to be able to decode H.265 if it's going to be playing 4K content. Isn't that what most 4K content will be encoded with?
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is offline
post #1101 of 3697 Old 06-21-2014, 04:11 PM
cminer72's Avatar
Quoted: 35 Post(s)
I'd be happy if the 6200 was a reliable player. First I had a skipping disc and crash incident where the player wouldn't even register a disc was inside without unplugging and restarting the unit. The disc was spotless as I'm OCD. Then netflix freezes, requiring an unplugging. Honestly, what I hate most is having to root around and find the cable to unplug. No holding down the power button like the 5100 or a cord that unplugs at the back of the unit like the 5200, either of which would make things tolerable.
cminer72 is offline
post #1102 of 3697 Old 06-21-2014, 04:49 PM
UHD Addict
aaronwt's Avatar
Liked: 3102
I would exchange it. I have two S6200s and neither of them behave that way. Mine have been very reliable.
aaronwt is offline
post #1103 of 3697 Old 06-21-2014, 05:14 PM
cminer72's Avatar
Quoted: 35 Post(s)
I've exchanged so many players over the last few years it's ridiculous. I'm positive the next one would flake too. My first Panny I bought years ago was rock solid. My Sony 570 was pretty reliable too. The 590, 790, 5100 and 6200 have all been much less reliable in my experience.
cminer72 is offline
post #1104 of 3697 Old 06-21-2014, 07:36 PM
Nickff's Avatar
Quoted: 277 Post(s)
Liked: 168
That would be frustrating. I had a 350 from its release until this year and it never had a hiccup. My 6200 has had zero issues so far also...fingers crossed.
Nickff is offline
post #1105 of 3697 Old 06-21-2014, 07:56 PM
cminer72's Avatar
Quoted: 35 Post(s)
Like I said. If you could reach behind the player to unplug it, it wouldn't be a big deal. A simple change from the way Sony has been building these things.
cminer72 is offline
post #1106 of 3697 Old 06-22-2014, 07:24 AM
UHD Addict
aaronwt's Avatar
Liked: 3102
I thought the power plug was permanently attached to these players? If I need to unlpug it I only need to get to the power strip it's attached to. ButI have not had nay issues that has required this.
aaronwt is offline
post #1107 of 3697 Old 06-22-2014, 09:12 AM
mdavej's Avatar
Quoted: 2126 Post(s)
Liked: 940
Why can't you just hold the power button down do several seconds? Accomplishes the same thing.
mdavej is offline
post #1108 of 3697 Old 06-22-2014, 12:45 PM
tboe77's Avatar
Quoted: 62 Post(s)
Liked: 136
Not always. My player froze up yesterday. Holding the power button did not work. Needed to cut power to the unit to get it to restart.
tboe77 is offline
post #1109 of 3697 Old 06-22-2014, 12:46 PM
Zaim's Avatar
Quoted: 29 Post(s)
I've had my 6200 for a month now and its been perfect. Same goes for my previous players (490, 4200)
I've got quick start on and haven't noticed any issue's with that either.
Zaim is offline
post #1110 of 3697 Old 06-22-2014, 04:05 PM
Nickff's Avatar
Quoted: 277 Post(s)
Liked: 168
Agreed.
Because I care about my fellow AVSers...
I think you meant that you could NOT care less.
Nickff is offline
Reply Blu-ray Players
BDP-S6200 , bdps720 , sony bdp s7200 , Sony Blu Ray Disc Player Bdp S790
