Official Sony BDP-S1200, BDP-S3200, BDP-S4200, BDP-S5200, BDP-S6200, and BDP-S7200 - Page 43 - AVS Forum | Home Theater Discussions And Reviews
 947Likes
Old 07-23-2014, 10:01 PM
HD KOOL-AID's Avatar
Quoted: 44 Post(s)
Liked: 26
Question on the quick start feature on the 6200. Does the player keep the blu-ray spinning slightly when powered down/off?
HD KOOL-AID is online now
Old 07-23-2014, 10:26 PM
UHD Addict
aaronwt's Avatar
Quoted: 5194 Post(s)
Liked: 3102
Neither of my S6200s do.
marctronixx likes this.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is offline
Old 07-23-2014, 11:01 PM
Quoted: 44 Post(s)
Liked: 26
Just wondering since I leave blu-rays in the drive and it was making a faint ticking/knocking noise like it was spinning slowly. When I powered up my 6200 this morning with the bluray in it started buzzing all loud until I ejected it. But played movie normally when I put the drive in again. I turned off the quick start function on mine hope my drive dont go out on me. Thanks.
Old 07-23-2014, 11:46 PM
marctronixx's Avatar
Quoted: 24 Post(s)
Liked: 35
it may spin up once powered on with disc inserted, but will stop down after several seconds.
if you are concerned, remove any discs and shut off quick start.
marctronixx is offline
Old 07-24-2014, 07:05 AM
steve1971's Avatar
Quoted: 498 Post(s)
Liked: 432
Had my 6200 now for a few weeks and zero issues. Plays everything I throw at it and streams flawlessly. This player is going down as one of the best Blu ray players I have yet to own.
steve1971 is offline
Old 07-24-2014, 07:47 AM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 2979
I agree. 1200 and 6200 are great so far, granted Ive only used the 1200 as a streamer at night, but it does a great job.
65E6P / 65EF9500 / DMP-UB900
AV7702II / Outlaw 7125
RF7II's / RC64II / Dual FV15HP's
gadgtfreek is offline
Old 07-24-2014, 08:17 AM
hmunster2's Avatar
Quoted: 92 Post(s)
Liked: 32
5200 v 6200
Looking for a new 3D blu ray player-other than 4K upconversion, is there any significant differences between the 5200 and 6200. I send the audio to my AVR for decoding, so that is not an issue- but what about the picture quality (I assume that they should be the same??)? Was almost thinking of going with Oppo, but then reason set in-it is digital, so picture quality can't really be any better (without Darbee version), right?
hmunster2 is offline
Old 07-24-2014, 08:56 AM
UHD Addict
aaronwt's Avatar
Liked: 3102
The 6200 has a dual core CPU, a front display, and two USB ports.(I use the back USB port for a flash drive for BD Live)
The 5200 has a single core CPU, no display, and only one USB port.
There might be other differences but those are the three reasons I went with the S6200 when I upgraded my S5100s. The S6200 seemed like the real sucessor to the S5100.
marctronixx and skads_187 like this.
aaronwt is offline
Old 07-24-2014, 02:37 PM
Alex F.'s Avatar
Quoted: 448 Post(s)
Liked: 224
In my experience, not right. We have different Blu-ray players in use in several rooms. For consistency, each new purchase was tested on the same Panasonic plasma television. Our Sony 5100, Panasonic 320, and Panasonic 220, for example, deliver a better overall picture than the Oppo BDP-83. The Sony and Panasonics provide better sharpness on Blu-ray discs and better upscaling on regular DVDs. A Sony 590 (two years old) has a grainy structure that the Sony 5100 does not have. Our Sony 390's picture looks identical to our 590. The Panasonic 320 and 220 share the same video performance among themselves as well. The color rendition is a bit warmer on all the Sonys compared with the Panasonics.
So, no, not all players have the same picture quality simply because they are digital. Within a given brand of the same model year, though, I've found models close in price tend to have the same picture quality since they usually share the same basic video circuitry. Other features are what typically cause price differences.
Alex F. is offline
Old 07-24-2014, 05:19 PM
Nickff's Avatar
Quoted: 277 Post(s)
Liked: 169
^^^What was the comparison like with all post-processing turned off on all the players?
Nickff is offline
Old 07-24-2014, 05:42 PM
Alex F.'s Avatar
Quoted: 448 Post(s)
Liked: 224
All post-processing was turned off. It is, of course, the only way to properly compare the baseline performance of players.
Alex F. is offline
Old 07-25-2014, 03:41 AM
Liked: 1
Question BDP-S1200 setting questions
Hi,
I have a Sony BDP-S1200 blu-ray player and was wondering what "BD-ROM 24p Output" and "DVD-ROM 24p Output" setting under the "Screen Settings" menu is and what the best setting is (AUTO, ON, OFF)
Artoo Smith is offline
Old 07-25-2014, 06:36 AM
Nickff's Avatar
Quoted: 277 Post(s)
Liked: 169
Originally Posted by Artoo Smith View Post
Hi,
If your display accepts 24fps material, then choose AUTO.
Nickff is offline
Old 07-25-2014, 07:27 AM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 2979
BD Rom 24p On
DVD Rom 4p Off
For me DVD 24p can be an issue at times so I just stopped using it.
Old 07-25-2014, 08:40 AM
AC2011's Avatar
Quoted: 108 Post(s)
Liked: 52
I have a BDP-S5100 in my main setup. My TV is not 4K, and I don't expect to upgrade that set for at least 3-5 years. If I don't have the ability to see 4K, is there any reason(s) for an upgrade to the 6200? (Other than the 2sec faster loading speed)
Or to the 7200 (although I can't see that it is actually available in Canada).
I presume, when running everything through an AVR, that the PQ of the 6200 is not likely to be substantially different from the Oppo 103?
Boston Acoustics Classic series L/C/R + front presence; Fluance XLBP Bipole surrounds; 2 x PSA XS15se
Yamaha RX-A3040; 3 x Emotiva XPA-100; Emotiva BAS-X A500
Oppo BDP-103D
AC2011 is offline
Old 07-25-2014, 08:57 AM
UHD Addict
aaronwt's Avatar
Liked: 3102
The S6200 also has updated Netflix and Amazon apps. So if you use those apps that is another reason to upgrade.
aaronwt is offline
Old 07-25-2014, 08:58 AM
Nickff's Avatar
Quoted: 277 Post(s)
Liked: 169
Post 1269 might help with part of your question. :-)
Nickff is offline
Old 07-25-2014, 09:07 AM
AC2011's Avatar
Quoted: 108 Post(s)
Liked: 52
I do use Netflix, never used Amazon - note, I am in Canada, but I use a service which gives me a US IP address, so even though I buy the Cdn model, I believe I end up getting the US Apps.
How, exactly, is the Netflix app upgraded? (One thing I hate about my current 5100 is that almost every time I click on the Netflix app icon on screen or use the Netflix button on the remote, I get this screen saying "updating network content". Sometimes it takes FOREVER to update.)
Thanks, saw that. My 5100 has a front display, and I don't use USB ports or BD Live.
Oppo BDP-103D
AC2011 is offline
Old 07-25-2014, 11:18 AM
UHD Addict
aaronwt's Avatar
Liked: 3102
The S6200 still does that crap where it shows updating content. The Netflix client on the S620 is the most current one. It shows background art and there are many other things that make it look better than the previous version. Not sure if there are any performance improvements though
aaronwt is offline
Old 07-27-2014, 06:13 AM
RWetmore's Avatar
Quoted: 360 Post(s)
Liked: 198
The S7200 doesn't even have dual HDMI?
RWetmore is offline
Old 07-27-2014, 06:17 AM
Nickff's Avatar
Quoted: 277 Post(s)
Liked: 169
As of now, the only known difference between the 6200 and 7200 is the case. Some are holding out hope the internals are "better".
Nickff is offline
Old 07-27-2014, 06:22 AM
RWetmore's Avatar
Quoted: 360 Post(s)
Liked: 198
Boy, what a disappointment. I can't believe it doesn't offer dual HDMI. The only good thing I guess is it makes the S6200 that much more of a good value, as it's about $250 less!
RWetmore is offline
Old 07-27-2014, 10:40 AM
EManT2200's Avatar
Quoted: 35 Post(s)
Bdp-s7200
Hoping to find a review about this BDP-S7200 soon. I have the BDP-S790, before I purchased this one, I had read a couple of professional reviews that said it came very close to Oppo's picture and audio quality. I have to admit, the S790 does produce a beautiful picture. Anyway, hoping that there may be improvements here to bring the S7200 even closer to the Oppo's quality, but, of course about $100.00 cheaper than the Oppo.
EManT2200 is offline
Old 07-27-2014, 04:16 PM
steve1971's Avatar
Quoted: 498 Post(s)
Liked: 432
Sorry but the 6200 and the 7200 are the exact same except for the out side appearance. As far as matching Oppo's pic and audio quality they come very very close.
Old 07-27-2014, 04:31 PM
Quoted: 24 Post(s)
Liked: 35
no. i have the unit in my home as we speak.
Old 07-27-2014, 04:33 PM
Quoted: 24 Post(s)
Liked: 35
agree 100%. you are just paying for aesthetics, nothing more...
steve1971 likes this.
Old 07-27-2014, 04:42 PM
tboe77's Avatar
Quoted: 62 Post(s)
Liked: 136
Agreed. Which is why anyone seriously considering the 7200 might as well just spend the extra $100 and get an Oppo. That way, you're at least getting something more than looks for the premium you're paying over the cost of the 6200.
marctronixx and steve1971 like this.
tboe77 is offline
Old 07-27-2014, 05:01 PM
UHD Addict
aaronwt's Avatar
Liked: 3102
Not sure about audio quality since the Sony players don't decode all formats to multi-channel pCM. But if bitstreaming the audio should be identical.
I still think a stand alone Darblet with the SOny makes more sense than the Oppo. I know in my setup the Oppo would make no sense. I already have a video processor that all my devices go through. The Darblet is at the very end of the video chain, right before the TV.
aaronwt is offline
Old 07-28-2014, 08:23 AM
steve1971's Avatar
Quoted: 498 Post(s)
Liked: 432
I have to give one of these Darblet's a try. I hear so many good things about them so why not?
Old 07-28-2014, 08:29 AM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 2979
I tried it. It defintely has an effect, one that I decided I did not like.
The good, it can enhance the sharpness of blu-ray (if you feel you need it), owners will tell you the better the source the better it works.
The bad, on some like Dish/Directv with some compression artifacts, the Darblet can make things look worse. I would see added artifacts in compression noise with it on, so I felt no need to keep it for that $$$ just for blu-ray.
I later had the 103D, and came to the same conclusion, so i left it off.
BDP-S6200 , bdps720 , sony bdp s7200 , Sony Blu Ray Disc Player Bdp S790
