Official Sony BDP-S1200, BDP-S3200, BDP-S4200, BDP-S5200, BDP-S6200, and BDP-S7200 - Page 45 - AVS Forum | Home Theater Discussions And Reviews
 948Likes
post #1321 of 3717 Old 07-31-2014, 01:43 PM
HockeyoAJB's Avatar
Quoted: 975 Post(s)
Liked: 815
Originally Posted by Nickff View Post
This was all brought up before in this thread.
Probably so, but it's easy to miss something that is posted somewhere between pages 10 and 40 of a 45 page thread.
What would be helpful is if we added the 7200 to the first post in the thread. I would also consider redoing the first post such that it lists all of the features and specs for the lowest model (the 1200) and then for the next model up just say "everything the 1200 has plus...". Repeat as you go up the line all the way to the 7200, which would say "everything the 6200 has plus...". This way we can be more comprehensive in listing the features, while also making it easier to identify the differences between the models.
marctronixx and ToonMasterTim like this.
HockeyoAJB is offline
post #1322 of 3717 Old 07-31-2014, 01:45 PM
Nickff's Avatar
Quoted: 350 Post(s)
Liked: 221
Good idea.
marctronixx likes this.
Nickff is offline
post #1323 of 3717 Old 07-31-2014, 03:01 PM
skads_187's Avatar
Quoted: 150 Post(s)
Liked: 32
is the netflix interface the same on the 5200 and the 6200?
skads_187 is online now
post #1324 of 3717 Old 08-01-2014, 05:00 PM - Thread Starter
apw2607's Avatar
Quoted: 305 Post(s)
Liked: 339
Sure is.
marctronixx and skads_187 like this.
apw2607 is offline
post #1325 of 3717 Old 08-01-2014, 05:01 PM - Thread Starter
apw2607's Avatar
Quoted: 305 Post(s)
Liked: 339
Good idea.
If you PM me what you want I will cut and paste it into the first post.
apw2607 is offline
post #1326 of 3717 Old 08-01-2014, 05:04 PM - Thread Starter
apw2607's Avatar
Quoted: 305 Post(s)
Liked: 339
Originally Posted by Cortiz View Post
It's true that there's a lot of BD's that are region free, mostly Warner, Paramount and Universal, but there's also a lot of region B locked titles. Usually these comes from smaller companies, like Arrow in the UK. I have a few UK imports that are region Locked.
And of course the pesky 1080i/50 titles ;-)
apw2607 is offline
post #1327 of 3717 Old 08-01-2014, 10:29 PM
Cortiz's Avatar
Quoted: 83 Post(s)
Liked: 64
I hear you!...I also have a S6200 region free for those pesky titles and it work like a charm! (knock on wood!)
Cortiz is offline
post #1328 of 3717 Old 08-01-2014, 11:20 PM
tohoho's Avatar
I have a Sony BDP-S6200 (Japanese edition). I found a bug regarding to audio output as following.
If AV receiver's HDMI audio decode set to PCM, rather than Auto, then Dolby Digital 5.1ch audio is conveted to PCM 2ch audio. Even if AV receiver's HDMI audio decode set to PCM, DTS-HD Master Audio 5.1ch is converted properly to PCM 5.1ch.
I also have a OPPO BDP-103. In this player, both Dolby Digital 5.1ch audio and DTS-HD Master Audio 5.1ch are conveted properly to PCM 5.1ch audio, even if AV receiver's HDMI audio decode set to PCM.
Is there anyone who have same bug?
tohoho is offline
post #1329 of 3717 Old 08-02-2014, 04:52 AM
Super Moderator
teachsac's Avatar
Quoted: 861 Post(s)
Liked: 1397
Not a bug. The Sonys do not have internal decoders whereas the Oppos do. When set to PCM, DD and DTS are output as 2 channel PCM.
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #1330 of 3717 Old 08-02-2014, 08:45 AM
Cortiz's Avatar
Quoted: 83 Post(s)
Liked: 64
S~
Partially true. The Sony internally decodes True HD/Dolby but only 2 channels. However, it does fully internally decodes DTS and DTS HD Master as LCPM.
Cortiz is offline
post #1331 of 3717 Old 08-02-2014, 09:20 AM
Super Moderator
teachsac's Avatar
Quoted: 861 Post(s)
Liked: 1397
The 6200 and 7200 do. The 1200, 3200, and 5200 do not unless it was added at some point. His 6200 is decoding DTS-HD correctly and outputting DD as 2.0 PCM. No mention of receiver and whether or not it can decode lossless audio.
S~
teachsac is offline
post #1332 of 3717 Old 08-02-2014, 09:27 AM
Cortiz's Avatar
Quoted: 83 Post(s)
Liked: 64
S~
You are correct. I was referring to the S6200 and S7200.
Cortiz is offline
post #1333 of 3717 Old 08-02-2014, 10:49 AM
UHD Addict
aaronwt's Avatar
Quoted: 6416 Post(s)
Liked: 3965
Yes they are perfectly capable of decoding to multichannel PCM.Sony just didn't pay for the license to be able to do it.
Which is why I only bitstream from my Sony BD players. With my PS4 and XBOne I have them decode and send out multichannel PCM.
aaronwt is offline
post #1334 of 3717 Old 08-02-2014, 11:08 AM
tohoho's Avatar
So, why Sony make such strange specifications ?
tohoho is offline
post #1335 of 3717 Old 08-02-2014, 01:54 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 418
Your answer:
Foxbat121 is online now
post #1336 of 3717 Old 08-02-2014, 02:07 PM
Zaim's Avatar
Quoted: 51 Post(s)
We've being through this so many times I've lost count. The dual core processor makes little to no difference. It's just a bunch of marketing babble by Sony.
When the s790 was launched we saw only minor improvements in the xmb for navigation and a slight improvement with the lean back youtube interface.
I've certainly noticed a difference between the 6200 and the 4200, overall performance is a fair bit better, especially for DLNA in my case, the problem I mentioned with forward/rewind/pause/play is not an issue anymore, the player is way more responsive.
Zaim is offline
post #1337 of 3717 Old 08-02-2014, 02:55 PM
Nickff's Avatar
Quoted: 350 Post(s)
Liked: 221
For those interested, the 7200 is available via Sony's USA site.
Nickff is offline
post #1338 of 3717 Old 08-02-2014, 03:14 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 4065
Neat.
gadgtfreek is offline
post #1339 of 3717 Old 08-02-2014, 05:14 PM
UHD Addict
aaronwt's Avatar
Liked: 3965
Only $400!?!??
They list the 7200 at 5 lbs. And the 6200 at 2 lbs. They also list them has each having the same power consumption.
aaronwt is offline
post #1340 of 3717 Old 08-02-2014, 08:06 PM
cjpk248's Avatar
Quoted: 42 Post(s)
Liked: 24
Help!
I'm watching Alice in 3D and the color temp keeps changing on me randomly. I don't think it's any settings on my F8500 because I haven't had it happen with any other source.
What do I need to change on the 6200 settings?
Edit: only happens in 3D, need to check other BD's.
cjpk248 is offline
post #1341 of 3717 Old 08-02-2014, 09:30 PM
tohoho's Avatar
Did anyone confirmed above from authorized Sony people?
Need liscense to just decode PCM 5.1 from DD 5.1 ? I can't understand.
tohoho is offline
post #1342 of 3717 Old 08-02-2014, 11:39 PM
marctronixx's Avatar
Quoted: 24 Post(s)
Liked: 35
sounds right. the 7200 has a metal chassis. the 6200 is made of recycled plastics.
i posted a link from sonys site about the amount of recycled plastics in the 6200, so those numbers sound about right.
the 7200 feels just like the 790 did...
and yea the power consumption is the same because other than the the cover/chassis, its the same machine...
Only $400!?!??
marctronixx is offline
post #1343 of 3717 Old 08-03-2014, 05:01 AM
mdavej's Avatar
Quoted: 2277 Post(s)
Liked: 992
No need to confirm. It's well documented by Sony and proven by direct experience. Dolby makes it's money from licensing. Sony saves money by not paying for it. I think it's a smart thing to do since your AVR will decode anyway. Why pay for it twice?
We know they are capable since every other model until now would decode DD.
mdavej is online now
post #1344 of 3717 Old 08-03-2014, 06:09 AM
Nickff's Avatar
Quoted: 350 Post(s)
Liked: 221
Done.
Sony XBR-65A1E | Denon X6300H | Klipsch RF-7ii (x2), RC-64ii, RB-51ii (x4) | SVS PB12-Plus | Xbox One S | WDTV Live | Sony BDP-S6200 | Harmony 670
Nickff is offline
post #1345 of 3717 Old 08-03-2014, 07:10 AM
tohoho's Avatar
I don't think so. Specification is very strange such that can only decode DTS and DTS HD multi-channel to PCM multi-channel. Dolby's licensing is very expensive?
tohoho is offline
post #1346 of 3717 Old 08-03-2014, 09:03 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 418
Even if it is only $1 for each player, it can save Sony a few million dollars easily. This is the second year Sony did this. 2013 Sony players are the first to do this. Before that, old Sony players can full decode all audio tracks.
marctronixx and Zaim like this.
post #1347 of 3717 Old 08-03-2014, 01:02 PM
tohoho's Avatar
Thank you. I understand.
tohoho is offline
post #1348 of 3717 Old 08-03-2014, 08:20 PM
cjpk248's Avatar
Quoted: 42 Post(s)
Liked: 24
Originally Posted by cjpk248 View Post
Help!
Does this with Avatar is 3D too. I used another port on the TV with another cable. Towards the end of the movie it seemed to do it a lot less though. It's really weird and I'm pretty disappointed if this is some limitation with the 6200 not handling some sort of deep color or something else.
Anybody more technically savvy have a clue why I'm seeing this cool to warm switching in 3D?
cjpk248 is offline
post #1349 of 3717 Old 08-03-2014, 09:52 PM
UHD Addict
aaronwt's Avatar
Liked: 3965
I've never noticed this happening on my S6200 with the 3D titles I've watched. Does it only occur with certain titles?
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Sony UBP-X800--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #1350 of 3717 Old 08-03-2014, 11:34 PM
S_G7's Avatar
Quoted: 100 Post(s)
Liked: 37
Looks like the 7200 has dropped to $298 at Amazon.
marctronixx and sikclown like this.
S_G7 is offline
Reply Blu-ray Players
BDP-S6200 , bdps720 , sony bdp s7200 , Sony Blu Ray Disc Player Bdp S790
