Official Sony BDP-S1200, BDP-S3200, BDP-S4200, BDP-S5200, BDP-S6200, and BDP-S7200 - Page 51 - AVS Forum | Home Theater Discussions And Reviews
 947Likes
Old 08-21-2014, 06:18 AM
HockeyoAJB's Avatar
Quoted: 974 Post(s)
Liked: 808
Originally Posted by helvetica bold View Post
I own the 6200 and I picked up a copy of Amazing Spider Man 2. On the box it states DTS HD MA but there is no option in the menu. I can only output Dolby Digital 5.1 on the 2D disk. What gives - am I missing something? Did anyone here pick up the BluRay?
I do not have a copy to check. You mentioned "2D disk". Did you buy the 3D combo pack? Is it possible that only the 3D disc contains the DTS-HD Master Audio soundtrack?
HockeyoAJB is offline
Old 08-21-2014, 07:25 AM
Liked: 7
Hi guys,
I got the 7200 from amazon to upgrade from a 3200 which played USB files perfectly. Now, despite the great looks and the zippy performance of the 7200, it's got a strange issue. Despite setting the screen aspect to Normal (not Full), videos will 'sometimes' become stretched to fill the 16:9 display. I say sometimes because when I first switch on the player videos play in their correct aspect ratio. But after a while, and for some strange reason, I go to play files and they stretch out. This applies to both 4:3 and other wider aspects. Files are on a USB drive. Does not occur with YouTube vids. The only fix I've found is to restart the player. This fixes the issue temporarily. I checked my Toshiba HDTV to make sure aspect ratio is also set to native. Never had such problems with the 3200.
So do you guys know what's happening here? Is this a defective player? The only difference in the setup is that I'm using a different HDMI port. I'll try the same port I used for the 3200 and see what happens today.
Haisook is offline
Old 08-21-2014, 07:27 AM
UHD Addict
aaronwt's Avatar
Quoted: 5203 Post(s)
Liked: 3111
I had the rental earlier this week. I remember it playing back in 5.1 DTS-HD MA. DO you have the audio restorer turned on? That would decode everything and re-encode it to DD.
marctronixx likes this.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is offline
Old 08-21-2014, 07:52 AM
helvetica bold's Avatar
Quoted: 388 Post(s)
Liked: 242
I do have BD Audio Mix set to off. I'll try it with it on. Also what should "downmix" set to, surround or stereo?
helvetica bold is offline
Old 08-21-2014, 08:15 AM
HockeyoAJB's Avatar
Quoted: 974 Post(s)
Liked: 808
You want BD Audio Mix to be "off". This prevents the player from mixing the UI sound effects with the movie audio. If you mix them then the player will downmix the audio.
Make sure the player is set to bitstream the audio, not decode it, though this would normally lead to stereo audio not Dolby 5.1 as opposed to DTS-HD MA.
Also, in your AVR's settings, make sure that the HDMI audio output is set to "Amp" and not "TV+Amp". If it is set to "TV+Amp" then your TV's audio capabilities come into play. Most likely the TV can't decode DTS-HD MA, so it would force the source device to output something that it can handle. If you use the "Amp" setting then the TV's audio capabilities have no impact on what is played.
If you've checked all of the above and still haven't resolved the issue, try swapping out the HDMI cable connecting your player to your AVR. It is unlikely that this is the cause, but it is possible that the HDMI cable is either incapable of carrying HD audio or is incorrectly relaying the EDID of your receiver to the player.
Old 08-21-2014, 09:31 AM
Quoted: 388 Post(s)
Liked: 242
My 6200 is connected to the Sony 1040 receiver so my entire pipeline is new-ish Sony products. Its weird that I can't get DTS MA. Anyway thanks for all of the advice.
I'll double check the Amp setting on my AVR.
Old 08-21-2014, 12:39 PM
Iain-'s Avatar
Quoted: 89 Post(s)
Liked: 58
Originally Posted by Iain- View Post
http://www.mrmdvd.com/catalog/produc...oducts_id=1642
http://www.mrmdvd.com/catalog/produc...oducts_id=1604
http://www.tps.uk.com/?tab_name=SONY...&choice_id=209
Don't forget North American mains are different from UK or Aussie mains (120 VAC/60 hz. v 230 VAC/50 hz.). These players are UK spec and won't need mains voltage converter. Only thing you will need is a mains plug adaptor to connect to mains.
Also before ordering, enquire to be sure that any future OEM firmware upgrades won't disable the multi-region features.
Originally Posted by Jamo8 View Post
Thanks for the info mate. I didn't realize that the sony blu ray is only 120vac I thought it is multivoltage. My sony projector is multivoltage.
Hmmm... it is slightly expensive in UK.
You get what you pay for.
BD multi-region modifications can be either of two types:
  • Firmware hacks
  • Permanent hardware modifications
With the former, you can't upgrade the player firmware without disabling the multi-region modification. With the latter, the multi-region feature will never be disabled after normal firmware update.
Multiregion Magic use an ICOS multi-region modification of the latter category. Quite stable, but obviously more expensive as the modification is quite involved.
You should peruse this thread:
http://forum.blu-ray.com/showthread.php?t=245235
Jamo8 likes this.
Iain- is offline
Old 08-21-2014, 08:34 PM
Jamo8's Avatar
Quoted: 17 Post(s)
  • Firmware hacks
Thanks again bud, you have been very helpful. Out of interest , what bluray player do you own ?
Jamo8 is offline
Old 08-21-2014, 09:38 PM - Thread Starter
apw2607's Avatar
Quoted: 114 Post(s)
Liked: 220
Originally Posted by Haisook View Post
Hi guys,
Hmm. I recall a issue with the original firmware on the bdp-s390/590 that exhibited this behavior. Is it the same file that suddenly becomes stretched after a period of time?
Have you tried playing from a DLNA Server instead.
If you can replicate the issue in a consistent way, you may want to let sony know on the sony forums, they fixed this once before so I am imagine they can do it again.
marctronixx and Haisook like this.
apw2607 is online now
Old 08-22-2014, 07:31 AM
Liked: 7
Yep, the same files that were playing normally before will stretch out. And this applies to many types of files; mkv, mp4, avi. I no longer use DLNA to play videos as I found out that direct play from USB gives more consistent playback and no transcoding is needed (especially with subtitles on).
I tried to use a different HDMI port thinking it could be related to a defective port? , I also disabled both 3D and 4K output from the player settings. Didn't notice any stretching yesterday, but I didn't use the player long enough.
I think I will go ahead and report that because I'm quite sure it's a software bug. It's strange, though, that not many people have this issue.
Haisook is offline
Old 08-22-2014, 05:41 PM
Liked: 7
Well, I had the same issue again today (using a different HDMI port, 3D/4K off). I will go ahead and report this now. I just wonder if Sony will release a software update just for my sake!
Haisook is offline
Old 08-22-2014, 06:11 PM
marctronixx's Avatar
Quoted: 24 Post(s)
Liked: 35
uhhh.. no they wont.
JoeKustra likes this.
marctronixx is offline
Old 08-22-2014, 06:18 PM
Liked: 7
In this case, I will have to return this player and keep the 3200... my main use is playing video off USB and the 3200 did that too well, so I thought the 7200 would be a perfect player with the extra speed and all.
Haisook is offline
Old 08-22-2014, 06:20 PM
Quoted: 24 Post(s)
Liked: 35
welp, one must do what one must do...
Old 08-22-2014, 06:23 PM
Liked: 7
Has anyone noticed this issue with the 6200?
Haisook is offline
Old 08-22-2014, 06:28 PM
Nickff's Avatar
Quoted: 277 Post(s)
Liked: 169
Another option is to buy an actual device designed for playing many types of media (KDlinks, WD TV, etc.) and just buy a lower-end blu-ray player for shiny discs. A WD TV Live and a Sony S1200 might be cheaper than a 7200.
Mathematics is the reason for the season.
Nickff is offline
Old 08-22-2014, 06:33 PM
Liked: 7
I wanted one player to play them all! (in case I need to play a bluray or dvd as well..)
Haisook is offline
Old 08-22-2014, 06:37 PM
Liked: 7
I am currently chatting with a Sony representative online via their Chat support. I will let you know what's going on.
Haisook is offline
Old 08-22-2014, 07:09 PM
Liked: 7
OK, the guy told me to reset the player to factory default. I did that. I will see what happens. What's strange to me is that now whether the Screen Aspect setting is set to "Normal" or "Full", files play in their correct aspect ratio; they don't stretch. I asked him if he had an explanation for that, he said this setting might not affect files on USB. Anyway, let's hope things remain the way they are and videos do not begin stretching out!
Haisook is offline
Old 08-23-2014, 04:43 AM
Zaim's Avatar
Quoted: 29 Post(s)
Nope, all fine for me
marctronixx and steve1971 like this.
Zaim is offline
Old 08-23-2014, 07:36 AM
Iain-'s Avatar
Quoted: 89 Post(s)
Liked: 58
Current players are BDP-S770 and BDP-S790.
The BDP-S7200 will join them soon, as well.
Iain- is offline
Old 08-23-2014, 09:02 AM
Liked: 7
Videos stretched out again! It looks like on the 7200, the screen aspect setting (Full or Normal) does not really affect USB videos. It has a mind of its own when playing such files and will tend to stretch out the videos after some time. In my case, it often happens after watching Netflix or YouTube for a while. I've left a message on the Sony Community (which appears to be deserted by the way), sent them an email, and I am currently chatting with one of their representatives via their online chat system.
In the meantime, does anybody have a clue about this issue while the mighty Sony figure out what's wrong with their top of the line bluray player?
Haisook is offline
Old 08-23-2014, 09:10 AM
steve1971's Avatar
Quoted: 498 Post(s)
Liked: 434
I haven't had any issues with my 6200. Plays everything I throw at it flawlessly and streams very well. Come October though I will be replacing it with an Oppo thanks to my wife!
steve1971 is offline
Old 08-23-2014, 09:49 AM
Iain-'s Avatar
Quoted: 89 Post(s)
Liked: 58
I'm not an early adopter.
It's precisely for reasons such as the above that I prefer to wait until new models have been out for at least 6-9 months and major problems have been sorted before I purchase one.
BTW, I would never buy a BDP from the company that steve1971 describes above.
Iain- is offline
Old 08-23-2014, 09:52 AM
Iain-'s Avatar
Quoted: 89 Post(s)
Liked: 58
Originally Posted by steve1971 View Post
I haven't had any issues with my 6200. Plays everything I throw at it flawlessly and streams very well. Come October though I will be replacing it with an Oopps thanks to my wife!
Why?
Do you simply want to be a part of the cult?
Iain- is offline
Old 08-23-2014, 09:55 AM
Cortiz's Avatar
Quoted: 56 Post(s)
Liked: 45
I still have my S770 even though i moved on with the S790 and now the S7200. There's something about the S770 that love so much! It's been my favorite Sony player so far.
Cortiz is offline
Old 08-23-2014, 09:57 AM
KonaBound2010's Avatar
Quoted: 18 Post(s)
About to pull the trigger on the 6200. Amazon has it on sale for $141 with free shipping.
Anyone seen it any cheaper anywhere new?
KonaBound2010 is offline
Old 08-23-2014, 10:01 AM
Cortiz's Avatar
Quoted: 56 Post(s)
Liked: 45
Audio Question
I know the S6200 and S7200 will only decode 2CH for True HD. But how about Dolby Digital? Does these players fully decodes Dolby Digital or do they decode only 2CH as well? I have a an old Sony soundbar that that does not decode any of the HD Codecs so I have to relay on the player to internally decode these as LCPM. My S7200 fully decodes HD Master Audio as LCPM and sounds really nice but for True HD, I'm only getting DD. Does this means it's decoding DD as 2 CH only or Multi?
Cortiz is offline
Old 08-23-2014, 10:05 AM
Liked: 7
But it's pretty much the same as 6200 in terms of software I assumed. Even on netflix the model is displayed as 6200.
Haisook is offline
Old 08-23-2014, 10:23 AM
steve1971's Avatar
Quoted: 498 Post(s)
Liked: 434
So I take it you would never buy an Oppo Blu ray player? Why?
Why?
Part of a cult? I don't see buying an Oppo Blu ray player as being part of a cult I see it as owning one of the best Blu ray players ever made. Yes they are expensive but you get top notch quality and the best customer service support help around. I have wanted an Oppo for 2 plus years but have never had the means to buy one. Well come October that changes. My 6200 will go to my daughter.
BDP-S6200 , bdps720 , sony bdp s7200 , Sony Blu Ray Disc Player Bdp S790
