Official Sony BDP-S1200, BDP-S3200, BDP-S4200, BDP-S5200, BDP-S6200, and BDP-S7200 - Page 67 - AVS Forum | Home Theater Discussions And Reviews
 947Likes
post #1981 of 3702 Old 11-15-2014, 11:21 PM - Thread Starter
apw2607's Avatar
Quoted: 116 Post(s)
Liked: 222
Originally Posted by mdavej View Post
It can, but not well. It often doesn't work. You should get a different device for that.
Quite honestly many devices struggle with pause of files from a dlna server for any length of time.
FF/REW works fine for m2ts. MKVs can be problematic however there are fixes. Read through the s790 thread,
apw2607 is online now
post #1982 of 3702 Old 11-16-2014, 01:42 AM
Muyfa666's Avatar
Quoted: 27 Post(s)
Originally Posted by Vampidemic View Post
Originally Posted by Muyfa666 View Post
The DTS decoding to multi channel PCM sounds quite nice, but what does the last sentence mean? That the same is not true for a standard Dolby Digital 5.1 track? No multi channel decoding? Only stereo?
Correct. You'll need a receiver to decode with these players.
So I might as well bitstream all formats from a 5200 and get the same result?
Muyfa666 is offline
post #1983 of 3702 Old 11-16-2014, 10:40 AM
mdavej's Avatar
Quoted: 2129 Post(s)
Liked: 940
You have no choice in the matter. It's all bitstream or all PCM. In any case, the result is not the same. With bitstream you'll get full 7.1 on all HD codecs. With PCM, most will be mixed down to 2 channel. Is your AVR not capable of decoding HD formats?
mdavej is online now
post #1984 of 3702 Old 11-16-2014, 03:25 PM
Muyfa666's Avatar
Quoted: 27 Post(s)
I have a soundbar, but I think it should work. I'm getting a better AVR next year anyway. I think the 5200 will do, but if I can raise some extra cash I may go for the 6200...
Muyfa666 is offline
post #1985 of 3702 Old 11-17-2014, 11:34 AM
steve1971's Avatar
Quoted: 498 Post(s)
Liked: 434
***Update*** Well got the firmware update from Sony today and installed it via a thumb drive and presto....issue solved! The streaming capability of my 6200 is up and running and its connected via built in wifi which means its now connected to my wifi network with no issues. Thank god is all I can say.
marctronixx likes this.
steve1971 is offline
post #1986 of 3702 Old 11-19-2014, 04:08 AM
hsinnott's Avatar
Quoted: 45 Post(s)
Liked: 54
A review has appeared in the Xmas 2014 edition of the UK's 'Home Cinema Choice' magazine...review starts off with headline "Step-down sibling" then states the following...
-"front and rear USB ports able to play downsampled hi-res FLAC and ALAC, but if you want proper hi-res audio playback you need the top end 7200 model. That deck also spins SACDs, and has a more grown up design."
-"the 6200 streams everything except MKV and FLAC"
-"the 6200 definitely deserves a place on the shopping list of budget BD buyers. But the missing web aps and plasticky build quality count against it"
Overall the article had a very "meh" feeling to it...Price quoted is 170 UK pounds...hardly a "Budget BD" player and it gets 4 out of 5 stars.
hsinnott is offline
post #1987 of 3702 Old 11-19-2014, 05:45 AM
Quoted: 866 Post(s)
Liked: 349
Since my S6200 does "spin SACDs" and have "web apps", I wonder if the US version is different than the UK version. Or....
JoeKustra is offline
post #1988 of 3702 Old 11-19-2014, 08:12 AM
steve1971's Avatar
Quoted: 498 Post(s)
Liked: 434
How the hell can that magazine call it a Step Down sibling to the 7200 when its practically the same player? A budget blu ray player? I think the price and features say otherwise. The magazine obviously has a bias favoring the 7200.
post #1989 of 3702 Old 11-19-2014, 08:31 AM
HockeyoAJB's Avatar
Quoted: 974 Post(s)
Liked: 808
My understanding is that the US and UK versions of the 7200 are the same, but the U.S. and UK versions of the 6200 are different. Multiple sources seem to suggest that the US version of the 6200 is identical to the US/UK versions of the 7200, minus the case. But, the UK version of the 6200 supposedly lacks support for SACD, and streaming of FLAC files.
HockeyoAJB is offline
post #1990 of 3702 Old 11-19-2014, 08:50 AM
hsinnott's Avatar
Quoted: 45 Post(s)
Liked: 54
I checked the UK and Ireland Sony websites and the picture of the player on both sites has the SACD logo on the top of the unit.
hsinnott is offline
post #1991 of 3702 Old 11-19-2014, 08:54 AM
hsinnott's Avatar
Quoted: 45 Post(s)
Liked: 54
I think they just don't dig the design or plastic finish of the unit. Personally I like it. Plastic does not necessarily mean cheaper imo. I think the player looks quite striking. And I couldn't be happier with the players performance so far after 1 week of heavy use.
marctronixx and steve1971 like this.
hsinnott is offline
post #1992 of 3702 Old 11-19-2014, 08:58 AM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3043
People have to realize the web reviewers are like bloggers, in where they actually think they have some validity and do good testing when they do not. Even if they are related to a magazine.
65E6P / 65EF9500 / DMP-UB900
AV7702II / Outlaw 7125
RF7II's / RC64II / Dual FV15HP's
gadgtfreek is offline
post #1993 of 3702 Old 11-19-2014, 09:05 AM
hsinnott's Avatar
Quoted: 45 Post(s)
Liked: 54
Absolutely, thank goodness for these forums. I used to subscribe to many magazines in the early days of DVD and reviews then seemed a lot more professional and honest. Nowadays I think a lot of reviewer's are either not qualified for the job or are receiving bribes from manufacturer's.
hsinnott is offline
post #1994 of 3702 Old 11-19-2014, 09:07 AM
hsinnott's Avatar
Quoted: 45 Post(s)
Liked: 54
Check out this in depth review of the BDP-S790. They use YCbCr 4:4:4 and utilized Direct mode for the image....what are you guys using on the BDP-S6200....
http://www.hometheaterhifi.com/blu-r...-3-in-use.html
and a review of the BDP-S5100...
http://www.hometheaterhifi.com/blu-r...ay-player.html
hsinnott is offline
post #1995 of 3702 Old 11-19-2014, 09:20 AM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3043
I use Direct Mode/Standard on any recent Sony, because they are modes that do not seem to do any mucking with the image.
YCBCR 422/444 vs RGB 444 depends some on the display too.
Spears and munsil helps with this and is a good disc. For my VT50/7200/6200 I run 1080p/24 out, ycbcr 444, superbitmapping OFF and pic mode Direct.
hsinnott and marctronixx like this.
post #1996 of 3702 Old 11-20-2014, 01:40 AM
Hans Gruber's Avatar
Quoted: 49 Post(s)
4:4:4 or 4:2:2 which is best to use. My 5200 has the option for 4:4:4
Hans Gruber is offline
post #1997 of 3702 Old 11-20-2014, 05:54 AM
Quoted: 253 Post(s)
Liked: 71
On my 7200 I set it to Auto because my display can handle it--Sony 65 inch 4K 850A model...I am not sure the settings on the 5200 tho
aflorida is online now
post #1998 of 3702 Old 11-20-2014, 06:00 AM
mdavej's Avatar
Liked: 940
Discs are authored in 4:2:2. Anything else is being artificially rendered. Probably makes no visual difference. I also use Auto.
post #1999 of 3702 Old 11-20-2014, 06:51 AM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3043
True, but some displays show more banding with 422 vs 444. That is why people must test, not make blanket assumptions for multiple electronic chains.
Bob, in the Oppo threads turned me onto the Ratatouille disc as a good test for color banding.
post #2000 of 3702 Old 11-20-2014, 06:52 AM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3043
Auto is almost always going to send ycbcr 444.
post #2001 of 3702 Old 11-20-2014, 07:21 AM
Quoted: 253 Post(s)
Liked: 71
Setting it to Auto (since my display the Sony 4K 65 inch 850A can handle it)
depending on the disc my TV's On screen display shows the resolution (either 1080p...or 1080/24...or 3840 x 2160 for 4K) AND shows the Deep Color Bit Rate either 10 bit or 12 bit or 16 bit is displayed.
Usually it displays 12 bit...but I am wondering with Blu Rays that are Mastered in 4K with (whats called)Expanded Color will it display more than 12 Bit...maybe display 16 Bit.
Anyone know?
post #2002 of 3702 Old 11-20-2014, 06:23 PM
Iamjcl's Avatar
Quoted: 62 Post(s)
Since BD playback PQ and SQ seem to be comparable between the Panasonics and the Sonys, has anybody compared Vudu streaming PQ (and SQ) between the 2 brands?
I've got a Panasonic 330 I think in one room and while BD playback seems exclellent, streaming 1080p (HDX from Vudu) never looks very good. I realize its not going to be BD,
but curious if anyone has directly compared the 2 players in this respect. Maybe the Rokus are better at this than the disc players? I've got a newer one of those but its on a smaller TV - perhaps I should give it a try as well.
We've probably watched streaming movies considerably more than BD in the last year or so, and I had assumed PQ was probably the same?
Iamjcl is offline
post #2003 of 3702 Old 11-21-2014, 06:52 AM
ToonMasterTim's Avatar
Quoted: 114 Post(s)
Liked: 78
Perhaps the older versions of the apps don't support the higher bit rates for streaming? That is the case with some older hardware running older versions of Netflix apps, perhaps it applies to other service apps as well? As you probably know, BD players and smart TVs won't get the latest app updates. For instance, my 2013 Panasonic BDT230 isn't running the latest Netflix UI that you see on Roku, PS3, 2014 smart TVs, etc. but it works just fine. PQ is excellent. Some older apps may support only 720p or lower bit rates, which could explain the difference in PQ you see. You can play one of the example shorts that displays the bit rate to see if this is indeed the issue. Roku, AppleTV, and other streamers are often better as streaming devices since they typically receive updates over a longer period of time than BD players or smart TVs. A Roku Stick, Fire TV stick, or Chromecast is a cheap means of adding a streamer to your system for less than $50.
ToonMasterTim is offline
post #2004 of 3702 Old 11-21-2014, 07:06 AM
Iamjcl's Avatar
Quoted: 62 Post(s)
Good points - Thanks. I just checked and the BD player I'm using down there is a BDT-110, so maybe older than I thought, but I still think 2012 or newer.
Resolution is good - mostly just that dark(er) scenes look terrible. Fades etc... are very banded. That type of thing. A bright, somewhat static image can look very good.
I really haven't watched much NetFlix on that (projector) setup - almost always Vudu or DirecTV (which doesn't look very good either, but I don't watch it very much. It's not the Genie DVR, but the one that came before) as I understood that Vudu SHOULD have about the best streaming quality with their HDX files.
I may just move one of my Roku boxes temporarily to test it out.
I'd be happy to get another BD player if it would be an improvement for streaming (doubt it would improve discs, but I'm happy with that though) but don't want to add to the collection if it won't matter.
Iamjcl is offline
post #2005 of 3702 Old 11-21-2014, 09:45 AM
RWetmore's Avatar
Quoted: 362 Post(s)
Liked: 199
Actually what comes off the disc is 4:2:0.
RWetmore is online now
post #2006 of 3702 Old 11-21-2014, 11:01 AM
Muyfa666's Avatar
Quoted: 27 Post(s)
Just read that the US and UK 6200 may differ. Can anyone confirm that? Need to know if one is inferior if I'm gonna get one...
Muyfa666 is offline
post #2007 of 3702 Old 11-21-2014, 02:07 PM
hsinnott's Avatar
Quoted: 45 Post(s)
Liked: 54
Here is a thread dedicated to UK model on UK AVForums...
https://www.avforums.com/threads/son...hread.1860739/
hsinnott is offline
post #2008 of 3702 Old 11-22-2014, 08:41 AM
Liked: 1
Jump to positions un files in BD or DLNA
Hello everybody
I bought a Bdp 4200 some days ago and can still not find a way to jump to specific time locations in the MKV I want to play, either with MKV burnt on BD or when accessing them thru DLNA playback....
is there something I missed ? Is this impossible ?
Thank you !
micool121 is offline
post #2009 of 3702 Old 11-22-2014, 08:51 AM
Quoted: 253 Post(s)
Liked: 71
Am I crazy?
I owned the 6200....had problems with it (freezing issues as I and others have reported)..exchanged for the 7200 (all is well with this model)...now deciding to exhange for an Oppo. Am I crazy? Need your opinions before I make the plunge.
My home theatre consists of :
Sony 65 inch XBR 4K 850A display...Sony's new 4K media player the FMPX10 so I can get actual 4K content(movies in 4K/Netflix in 4K,etc)...Lexicon MC12 processor/pre-amp....Sunfire Signature 500 watt 5 channel amp...Aerial Acoustics speakers (Front L/R...Center...Surrounds L/R)..Velodyne Sub...all cables are : Monster/Audio Quest/MIT).
post #2010 of 3702 Old 11-22-2014, 09:34 AM
madmartigan10's Avatar
Hey I just rented 22 jump street from the sony entertainment movie section on my sony bdp 5200 and it was showing 2 channel PCM on my yamaha rx-a840 reciever.
Just wondering if my setup is not configured right or sony online movies just do not have surround sound. I also watched avengers 3d and star wars last night and they played fine in 7.1 and 6.1 hd dts master audio respectively.
madmartigan10 is offline
Reply Blu-ray Players
BDP-S6200 , bdps720 , sony bdp s7200 , Sony Blu Ray Disc Player Bdp S790
