Official OPPO BDP-105D Owner's Thread - Page 23 - AVS Forum | Home Theater Discussions And Reviews
 248Likes
post #661 of 2094 Old 07-17-2014, 06:42 AM
Totallyconfused's Avatar
Quoted: 17 Post(s)
The 3 to 5 second audio mute when fast forwarding, reversing, or after a pause (or changing channels) is my main (actually only) dissatisfaction with my set-up. Since RichB is having the same problem and we are both using the 105D with analog outs to an A51, but different set-top sources, I'm inclined to believe the problem is with my Oppo settings rather than the very limited settings available with the Dish set-top, but I am sure I have tried every setting and combination of settings in the Oppo. RichB, I hope you solve your situation and share it with us. Thanks.
Totallyconfused is offline
post #662 of 2094 Old 07-17-2014, 07:03 AM
Oppo Beta Group
RichB's Avatar
Quoted: 1272 Post(s)
Liked: 873
I removed the Lumagen from the chain and there was no difference. I have not found any settings in the 105D that has any effect.
However, the Panasonic 65ZT60 definitely has slow HDMI handshaking.
It may be system specific so I recommend contacting Oppo support and see if they have any suggestions.
- Rich
Oppo UPD-205 | Sonica DAC | BDP-105D | HA-1 | PM-1 | Emotiva XMC-1 | ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG 65C7 | Lumagen 2020
RichB is online now
post #663 of 2094 Old 07-17-2014, 08:10 AM
acrafton's Avatar
Unable to connect BDP105 to Apps
I am unable to get my new Oppo 105 to connect to the iOS App on any of my devices. The oppo is on the network, I can see it from the app, but when I select it then it immediately say "connection failed". If I change the name of the Oppo the new name shows up in the app with the correct ip, etc but when I select it then it fails. .
Any ideas?
acrafton is offline
post #664 of 2094 Old 07-17-2014, 08:39 AM
edfowler's Avatar
Quoted: 169 Post(s)
Liked: 99
did you check to see if you have the latest version of the app? I have deleted and reinstalled the app before to get it to work. Have you turned off the oppo and restarted to try to connect again?
edfowler is online now
post #665 of 2094 Old 07-17-2014, 09:30 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 3787 Post(s)
Liked: 4927
Also, the latest iOS app requires the latest player firmware. Check Setup > Device Setup > Firmware Information. The "Main" firmware version number should end "0515".
If you are trying to use the app to Power On the player, additional requirements are:
1) Quick Start must be set
2) You must either be using Ethernet networking, or the Wifi dongle must be plugged into the USB 1 socket on the back of the player, and Wifi networking enabled.
--Bob
Bob Pariseau is online now
post #666 of 2094 Old 07-18-2014, 07:06 AM
ECS01's Avatar
Quoted: 38 Post(s)
Liked: 24
FWIW, and that might not be much, I also have a 50" Pioneer Kuro display (but use a Tivo Romio) and have also noted that the HDMI handshake is pretty slow... I suspect that the Kuro is starting to show it's age, relative to the HDMI in the TiVo and 105, but the picture is so good I'm willing to live with the slow handshake and resulting audio gap issues.
scirica likes this.
ECS01 is offline
post #667 of 2094 Old 07-18-2014, 08:34 PM
NextLevel217's Avatar
Quoted: 76 Post(s)
Liked: 34
Im curious as to how you guys have your 105d's hooked up? I was planning on running the oppo to the stereo outs on the yamaha and use the hdmi out strictly for blu ray. Is there a big difference between the hdmi and the analog outs? Thanks in advance guys
NextLevel217 is offline
post #668 of 2094 Old 07-19-2014, 10:43 AM
BillP's Avatar
Quoted: 277 Post(s)
Liked: 223
Yes there is. With analog outs, you're using the audio DACs of the Oppo. With HDMI, you're using the audio DACs of your AVR. Which is better depends on your AVR's DACs and implementation.
BillP is online now
post #669 of 2094 Old 07-19-2014, 11:40 AM
jabol's Avatar
Hi,
I own Oppo 105D which I bought 2 months ago. I recently started using navigation buttons on the front panel instead of the remote. However, I noticed that sometimes the buttons, when playing CD, are not responsive. I can see that they light up when I press them, but the player does not react. It happens from time to time. I do not have any issues when operating the player using the remote. Has anyone experienced it?
Thank you,
jabol
jabol is offline
post #670 of 2094 Old 07-22-2014, 05:48 AM
Super Moderator
teachsac's Avatar
Quoted: 859 Post(s)
Liked: 1397
Please take all audio theory discussion to the audio theory thread.
Thank you.
gsr and Links like this.
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #671 of 2094 Old 07-22-2014, 11:22 PM
jakenz's Avatar
One more 4k future proofing question... re the Oppo 105D's HDMI input
I've scanned the thread and as far as I can tell this specific question hasn't been asked and answered yet:
I understand the 105D's HDMI output is HDMI 1.4 compliant which means it can output 4k resolution content at 24 or 30 frames per second with 8 bit colour - as evidenced by the 105D's own 4k upscaling. Whereas (per the helpful link someone posted) 4k at higher frame rates such as 50 or 60fps or at 10-12 bit colour depth would require the greater bandwidth of HDMI 2.0.
So for argument's sake make a few assumptions re 4k in 2015:
- 2015 4k disc and/or streaming video formats are agreed supporting a range of bitrates and framerates
- current audio codecs e.g. LPCM remain for the time being
- 4k HDMI 2.0 capable source hardware becomes available, say disc players & video cards
- that as 4k content starts to arrive, that some of that 4k content - film in particular - is available in 8bit colour and at 24fps i.e. theoretically still within the HDMI 1.4 spec
My question is if given the above assumptions, and what you know of the 105D's hardware, in the scenario where you used some 2015 4k hardware to play 4k content at 24fps with 8 bit colour over HDMI would you expect the 105D ought to be able to successfully take (and process or passthrough) that signal via its HDMI input? My focus here is the possibility of continuing to use the 105D's terrific audio DACs with some 4k material even if only passing through the video.
Quite a few variables here so I suspect 'it depends' but I'd be interested in your thoughts.
jakenz is offline
post #672 of 2094 Old 07-23-2014, 04:27 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1285 Post(s)
Liked: 1347
The 10x platform won't accept 4K video input in any form, whether it be from optical disc, Internet streaming, locally attached storage, network playback, the HDMI inputs, etc. AFAIK, that's a hardware limitation, so don't expect it to change.
jakenz likes this.
gsr is online now
post #673 of 2094 Old 07-24-2014, 08:49 AM
mikeveredas's Avatar
I have a headache! (Oppo 105d connection plan)
In need of a new SACD player, so the 105D is on my radar. I want to take advantage of darbee. or at least give it a try, so I am trying to figure out how to connect it properly to take advantage of all the bells and whistles.
Currently I am connected by the following.
Xfinity, PS3 and Apple plugged into Marantz then single hdmi from marantz to TV.
The way I think I should connect if I get the 105d is
Xfinity, ps3, apple connected to marantz. Marantz to oppo, oppo to tv. Bam darbee is set and ready to roll. But wait...AUDIO. Do I connect analogs to marantz input? HDMI?
That is where I am stumped. I almost want to use 2 output sources, HDMI for movies and such and analogs for audio. Is that nuts?
And now you see why I have a headache. Seems like a lot of looping.
On a long enough time line the survival rate for everyone drops to zero
Samsung f8500 64", Marantz 7008 as pre/pro, Emotiva XPA-5 gen 2
Golden ear Triton 3, Axiom M22, M2, SVS PB12NSD(2), Definitive Technology Mythos 3
Oppo 105d, PS3, Xfinity X3 (beta)
mikeveredas is offline
post #674 of 2094 Old 07-24-2014, 10:11 AM
Read the FAQ!
Liked: 4927
^ If you connect HDMI output from the OPPO to a Marantz Input you will have an HDMI loop. Consider that when playing movies the Marantz will also be sending HDMI to the OPPO's input. And when playing your external sources, the Marantz will see HDMI input from the external source an also from the OPPO.
Now, that may or may not work depending upon details of how each source device executes the HDMI handshakes (handshakes are driven by the source device) and how the Marantz reacts to an HDMI handshake arriving on two separate inputs at the same time. You can try it of course, but you may have issues.
The alternative is to run multi-channel Analog to the Marantz for audio. The Marantz will only ever see HDMI input from the external sources, and the OPPO will only not be trying to send HDMI to the Marantz while also receiving HDMI from the Marantz.
Setting up Analog audio takes a bit of care to make sure speaker and sub levels are matched and that you don't have both the OPPO and the Marantz trying to process that audio (e.g., Crossover processing or speaker distance adjustments). But it does avoid loops.
On another note, if you use the PS3 for games there's an added complication, which is that the video processing in the OPPO may add undesired timing lag.
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
post #675 of 2094 Old 07-24-2014, 11:55 AM
This seems like more hassel than its worth. Mayby I'll just get a 103, standard, and use as a blu-ray/sacd and leave it as is...
post #676 of 2094 Old 07-24-2014, 12:31 PM
hernanu's Avatar
Quoted: 682 Post(s)
Liked: 1218
I've got a 103D, so take my comments from that perspective.
I have XFinity, and use HDMI exclusively.
I don't have a gaming system, so my connection is easy - the XFinity box to HDMI1 input and I'm done. It works great with the 103D and the Darbee function is an improvement.
As Bob mentioned, you may not want a gaming system processed by the 10XD due to latency issues, so that you may want direct to the Marantz.
So that leaves the Apple TV. That might benefit from the Oppo / Darbee processing, so you could connect it to the HDMI2 input.
Leaves you without a loop, then you could use the 103/105 (D) to your heart's content. Switching to a different input is easy, the analog connection is live, so if you wanted analog for music, you could do that as well.
Just my 2 cents.
hernanu is online now
post #677 of 2094 Old 07-26-2014, 10:02 PM
jake9's Avatar
Quoted: 20 Post(s)
Hi, guys. I currently looking to upgrade from my 103 to a 105 or 105D. The 105D is newer, I know, so perhaps it's more future-proof. But for the savings I'm thinking of going with the 105 since I'm mainly upgrading for the audio features of the 105, not for Darbee. Should I spend the extra money to get the "D" or is it mainly for videophiles, which I am not.
Thanks for any suggestions.
Oppo BDP-105D | Parasound Halo A 21 | Parasound Halo P 5 | Rega Planar 3 | Martin Logan Theos | Martin Logan Dynamo 1000
jake9 is offline
post #678 of 2094 Old 07-26-2014, 10:07 PM
edfowler's Avatar
Quoted: 169 Post(s)
Liked: 99
The other feature that the d offers over the 105 is an updated async usb input. The 105d will accept dsd from a computer thru the async usb port whereas the 105 will play dsd files, but only thru the regular usb inputs , ie. from an attached drive. I am trying to decide whether I want to upgrade my 105 to a 105d or just keep the 105 and get an HA-1 in addition
post #679 of 2094 Old 07-26-2014, 10:18 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
^ The 105/105D will play DSD files via network also (i.e. SMB, DLNA).
DanF8500 is offline
post #680 of 2094 Old 07-26-2014, 10:20 PM
edfowler's Avatar
Quoted: 169 Post(s)
Liked: 99
Does that mean that i can connect the 105 to my macbook via ethernet and use audirvana to play my dsd files?
post #681 of 2094 Old 07-26-2014, 10:32 PM
Smarty-pants's Avatar
Quoted: 751 Post(s)
Liked: 628
How is the BDP-105D different from the BDP-105?... the following list explains it.
The BDP-105D subtracts:
~the Marvell Qdeo video processor
...and adds:
~the Silicon Image VRS ClearView video processor.
(the VRS chip allows for a slightly better picture presentation do to some ever so slight undefeatable DNR in the QDEO chip.)
~the Darbee Visual Presence video processor.
~updated USB DAC interface to support DSD64 and DSD128
(the 105D can not play media files in DSD 128 -- i.e., on a directly attached USB hard drive or via the house network.
the new capability is limited to the Asynchronous USB Input only!)
~a newer firmware update for the USB DAC, can also allow acceptance of stereo LPCM at rates up to 384KHz 24-bit.
Rates above 192KHz are only available for output on the Analog outputs. (192KHz limit on the 105.)
~the ability to send DSD over HDMI on the HDMI-1 output.
(this was only possible on the HDMI-2 output of the BDP-105)
...and replaces:
~the remote with be a slightly new version with a Darbee button.
(otherwise the remote is identical to the BDP-105/103)
All other aspects and functions of the two models are identical.
jake9 likes this.
Smarty-pants is offline
post #682 of 2094 Old 07-26-2014, 10:36 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
^^ Ed, your 105 would be attached via ethernet to your home network (i.e. your router). Your Macbook would also be either hardwired to your router or communicate wirelessly (WiFi) to it. If you have all your audio media stored on your macbook hard drive, then you have a few different options to get your 105 to play those digital files via ethernet. You would either use the 105's onscreen browser to access your macbook's hard drive via SMB protocol, or via a DLNA server (running on your Macbook) you could 1. "Push" audio files to your 105 or 2. "Pull" audio files using your 105's onscreen browser from your DLNA media server. I don't know the full capabilities of audirvana, and whether it can be configured to be a DLNA server. But the SMB protocol allows your 105 to read digital media files from your home network storage device (i.e. macbook hd) without the use of a DLNA media server.
DanF8500 is offline
post #683 of 2094 Old 07-26-2014, 10:39 PM
edfowler's Avatar
Quoted: 169 Post(s)
Liked: 99
Sounds more complicated than just plugging a hdd into one of the usb ports. What advantage this?
post #684 of 2094 Old 07-26-2014, 10:50 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
^ The advantage of DLNA is that you don't need to be sitting in front of your tv and running the 105's onscreen browser to access and play your audio files. You can just leave your tv off and control all your music playback via a tablet device (iPad) or a smartphone (running iOS or Android) anywhere in your house through your home network. Accessing a large media database with hundreds of directories/sub directories can be very cumbersome using the 105's onscreen browser. The media software running on your tablet or smartphone is much more intuitive and will search for music files in your media catalog based on many different criteria (i.e. artist, genre, song, folder, just to name a few).
DanF8500 is offline
post #685 of 2094 Old 07-26-2014, 10:53 PM
edfowler's Avatar
Quoted: 169 Post(s)
Liked: 99
Is it that much better than using the oppo media app?
post #686 of 2094 Old 07-26-2014, 10:58 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
^ The Oppo media app can only read files from an attached usb hard drive or via a network drive (SMB protocol only). There's no intuitive searching for your audio files with this software like there is with a DLNA server running. The Oppo Media Control app only sees directory structures on your hard drive. So it's not much different than using your 105's onscreen browser, except that your tv can be turned off using the MediaControl app.
DanF8500 is offline
post #687 of 2094 Old 07-26-2014, 11:00 PM
edfowler's Avatar
Quoted: 169 Post(s)
Liked: 99
Is there a recommended DLNA program for Mac that has a trial?
post #688 of 2094 Old 07-26-2014, 11:05 PM
edfowler's Avatar
Quoted: 169 Post(s)
Liked: 99
Looks like there is plex. Sorry this is getting off topic. I will search the forums. Quick question though, looks like plex or a dlna server will not condition the music files like audirvana or jriver right? A dlna server will just present the file to the oppo right?
post #689 of 2094 Old 07-26-2014, 11:06 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
^ I'm a "Windows" and "iOS" user. I'm out of the loop for Mac audio software. Although I know that JRiver has a Mac version of its Media Center software, which has full DLNA capabilities. I'm sure there's a few more Mac-based DLNA media server software programs out there that I'm not aware of.
DanF8500 is offline
post #690 of 2094 Old 07-26-2014, 11:08 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
^^ DLNA media server software *CAN* transcode your digital audio files, *IF* you want it to. I prefer to send the original digital, lossless audio file to my 105 for playback.
DanF8500 is offline
Reply Blu-ray Players
Oppo Bdp 103d Universal 3d Blu Ray Player Darbee Edition , Oppo Digital Inc Bdp 105
