OPPO BDP-105 & 105D as a pre/pro - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #1 of 38 Old 03-09-2014, 09:28 PM - Thread Starter
wse
wse's Avatar
Quoted: 1965 Post(s)
Liked: 739
Tell us what do you like and dislike about using the 105 or 105D as a pre/ pro? In addition tell us what improvement you would like to see so the OPPO Replace your AVR wink.gif
wse is offline
post #2 of 38 Old 03-11-2014, 12:08 PM
OmarF's Avatar
Quoted: 22 Post(s)
Liked: 84
Here's my experiences on this.
My thought initially was just like most of ours would be: The shorter the signal path, the less sound degradation, the better. Running straight from the source would bypass a whole other piece of equipment, and provided the volume control on the OPPO is mostly lossless, we can only gain signal integrity.
So, I tried it running straight from the OPPO to my amp (Ayre V-5xe, bypassing my K-5xe MP preamp) and the music sounded very sweet and airy, with beautiful sound staging. Problem was, I seemed to be missing low end punch, and highs lost crispness. What was wrong? Why was I losing sonic power?
Spoke with my dealer and he explained that players are not designed to put out enough power to drive an amplifier. They're designed to be fed into a preamp, and the preamp has much more power at its output stage than a player does, and thus is able to drive an amplifier to a superior dynamic range. Dynamic range being exactly what I was missing.
Discussed it with a friend of mine who's a sound engineer, and he explained that one of the differences between pro gear and home gear is that pro amps have a very high input impedance, whereas home amps have a very low input impedance. When an amp has very low input impedance, essentially, the flood gates are wide open and the amp is sucking all the juice out of your input device--hence why home preamps have very high output voltages, it's in order to drive an amp that would have low input impedance.
So unfortunately, yet again theory (or hope) does not always match up to reality, in terms of using a direct path from player to amp. One could still very effectively hook up their OPPO straight into an amp, it just has to have a high input impedance. That would be lovely to hear, and I can't see why a pro amp, or even home amp with high input impedance, wouldn't play just fine with the OPPO by themselves.
Hope this helps,
Omar
ellisr63 likes this.
OmarF is offline
post #3 of 38 Old 03-11-2014, 12:45 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 2248 Post(s)
Liked: 2818
^ Check out this white paper (PDF file) posted by OPPO UK. They recommend you use an amp with an input impedance of 47K ohms or greater, which is actually not that unusual for home theater amps:
http://www.oppo-bluray.co.uk/UserFiles/Docs/PDF/BDP-105EU%20Direct%20Power%20Amplifier%20Connection%20V2.pdf
--Bob
Anthem D2/D2v/AVM50/AVM50v/ARC1 tweaking guide. -- Need personal consultation/training? PM me!
Bob Pariseau is online now
post #4 of 38 Old 03-11-2014, 02:44 PM - Thread Starter
wse
wse's Avatar
Liked: 739
Looks like I should be good
CA-M600   600W MonAural Amplifier
Click to enlarge
All tests un-weighted and 500kHz measurement bandwidth (except SNR)
Frequency response
1 Hz - 100 kHz, -3dB
Output power
600W rms into 8Ω (27.8 dBW)
1200W rms into 4Ω (27.8 dBW)
Harmonic Distortion
<0.002% at 1 kHz balanced
<0.004% at 1 kHz single ended
Peak Output Voltage
226V peak to peak, 80V rms no load
206V peak to peak, 73V rms into 8Ω
Input Impedance
50kΩ balanced / single ended
Voltage gain
29dB balanced / single ended
Input level at clipping
2.86V rms balanced / single ended
Intermodulation Distortion
>100dB below fundamental into 8Ω balanced / single ended
>90dB below fundamental into 4Ω balanced / single ended
Signal to Noise Ratio
-120dB at peak output into 8Ω
Measurement Bandwidth: 22 kHz
Output impedance
0.03Ω @ 1 kHz
Standby power consumption
< 1W
Rated power consumption
440W @ 1/8th power into 8Ω
Width
17.5” (444mm)
Depth
17.52” (445mm)
Height
8.78” (223mm)
Gross weight
100 lb (45.4 kg)
Net weight
88 lb (39.9 kg)
Mains voltage
Specified on rear panel
wse is offline
post #5 of 38 Old 03-11-2014, 02:46 PM - Thread Starter
wse
wse's Avatar
Liked: 739
And also
CA-5200 - POWER AMPLIFIER
The CA-5200 is a 5 x 200W model, based on the same channels used in the CA-2200. Power supply components are large enough to allow for the greater power demands of five channels without sacrificing performance. Design features include balanced circuitry, overbuilt power supplies and oversized output stages to ensure the highest performance at every output level, with any loudspeaker.
models
(balanced inputs)
CA-5200
voltage gain 29.1dB
bandwidth
phase
155kHz (-3dB)
22kHz (-0.1dB)
< -10° (22kHz)
sensitivity 1.4Vrms
power/channel (continuous)
(120VAC line, 1kHz signal regulated to 1% THD + noise into resistive load, all channels driven)
load (resistive)
200W
370W
THD + noise (unweighted, 10Hz - 500kHz bandwidth, 1Vrms/1kHz input)
load (resistive)
none 0.002%
0.003%
0.005%
noise FFT noise floor peaks all below –95dBV
(with terminated inputs)
S/N ratio (relative to 1kHz sine wave full level output into 8Ω) 108dB
height
depth
(excluding
connectors)
width
gross
weight
net
weight
8.75” (222 mm) 21.0” (534 mm) 17.5” (445 mm) 133 lbs (60 kg) 121 lbs (55 kg)
idle power consumption 348W
rated power consumption 1056W
wse is offline
post #6 of 38 Old 03-11-2014, 05:24 PM
RouslanB's Avatar
I had my 105 hooked up to Emotiva XPA-2. Low-end punch was very present and tight - I had to remove paintings from the walls (at Oppo's volume of 100%).
I was using Oppo's XLR outs and silver cables.
Now I am planning to switch to NCore monoblocks as soon as I assemble them - I am curios how they would sound with a straight connection to Oppo .
RouslanB is offline
post #7 of 38 Old 03-11-2014, 06:47 PM - Thread Starter
wse
wse's Avatar
Liked: 739
Originally Posted by RouslanB View PostI had my 105 hooked up to Emotiva XPA-2. Low-end punch was very present and tight - I had to remove paintings from the walls (at Oppo's volume of 100%).
What do you mean you had to remove paintings from the wall?  WAS IT TO LOUD?
I was using Oppo's XLR outs and silver cables.  Now I am planning to switch to NCore monoblocks as soon as I assemble them - I am curios how they would sound with a straight connection to Oppo .
wse is offline
post #8 of 38 Old 03-11-2014, 09:12 PM
OmarF's Avatar
Quoted: 22 Post(s)
Liked: 84
--Bob
Thanks for the info!
It was actually my 95 that I tried hooking straight up, I figured the 105 would be the same.
I tried hooking my 105D straight up today, and it sounds very good, ESP. with asynch DAC and Audirvana direct/integer/upsampling.
Omar
OmarF is offline
post #9 of 38 Old 03-12-2014, 12:40 AM
RouslanB's Avatar
It was VERY LOUD at 100 - to the point pictures on the wall started to vibrate.
Speakers were on spiked platforms with vibro-contol (Vibro-pods).
RouslanB is offline
post #10 of 38 Old 03-14-2014, 04:00 PM
audiman's Avatar
Quoted: 13 Post(s)
Liked: 26
bggest problem is the inability to use the trims in dsd mode. it,s great in stereo to my mac amps to n802, but the balance is off in mch.
audiman is offline
post #11 of 38 Old 03-14-2014, 04:18 PM - Thread Starter
wse
wse's Avatar
Liked: 739
OPPO BDP-105 rocks as a pre/pro I wish they would include additional functionality such as automated EQ
linger63 likes this.
wse is offline
post #12 of 38 Old 03-14-2014, 11:40 PM
OmarF's Avatar
Quoted: 22 Post(s)
Liked: 84
I had this problem, then just switched to PCM output. All trims working. Did not notice any loss of resolution, but didn't a/b very much yet. ***NOTE: DSD output is about 6-7 dB louder than PCM. With PCM output, your sound levels will be the same as with all your other multichannel music.
Omar
OmarF is offline
post #13 of 38 Old 03-15-2014, 08:58 AM - Thread Starter
wse
wse's Avatar
Liked: 739
Omar
wse is offline
post #14 of 38 Old 03-15-2014, 10:37 AM
audiman's Avatar
Quoted: 13 Post(s)
Liked: 26
Omar
Tried it a lot and i like the DSD direct mode better.
audiman is offline
post #15 of 38 Old 03-15-2014, 11:20 AM - Thread Starter
wse
wse's Avatar
Liked: 739
Yes the DSD mode sound fuller to me as well especially straight to the amps biggrin.gif
I finally realized what I was missing with the SSP-800 which unfortunately does not support DSD rolleyes.gif
wse is offline
post #16 of 38 Old 03-15-2014, 03:23 PM
SubObjective99's Avatar
wse,
http://www.avsforum.com/t/1511029/my-humble-set-up
Very nice components. I'm jealous.
Derogatory terms like "analog bigot", "digiphobe", "internet eggspurts" have nothing to do with electrical engineering.
SubObjective99 is offline
post #17 of 38 Old 03-15-2014, 05:28 PM - Thread Starter
wse
wse's Avatar
Liked: 739
Originally Posted by SubObjective99 View Post
wse,
Thank you, it took me a long time and a few sacrifices to get there wink.gif
wse is offline
post #18 of 38 Old 03-15-2014, 07:39 PM
^ I just love your speakers and your Classe gear. I have the Classe CA-200 power amp and the CP-50 pre-amp from the 90's and also the B&W 801 Matrix Series III speakers also from the 90's. I still love them all. I guess I'm just an old-school 2-channel man. smile.gif
post #19 of 38 Old 03-15-2014, 08:13 PM - Thread Starter
wse
wse's Avatar
Liked: 739
Thank you I intend to keep that rig until it goes bust so 15 years would be great biggrin.gif
wse is offline
post #20 of 38 Old 03-17-2014, 05:33 PM
Namikis's Avatar
I swapped out the receiver for the Oppo 105 as a test, to see if I could stand using it as a pre-processor. My conclusions:
1. It can, in theory, replace a receiver, and it sounds good. Not sure it sounds better than with the receiver in the path though.
2. If you had level of complexity in your home theater setup, this gets old quickly (or at least it did for me)
Setting up the speaker configuration and levels is a bit a pain - the user interface could use improvement. But that is something you do once and forget.
The lack of HDMI inputs is a pain. In my setup (inside a cabinet) I can only use the back port. I hooked up an HDMI switch. Standing up every time I want use the Chromecast or cable or Apple TV gets tiring quickly (and the quality of Netflix on the Oppo105 is poor compared to the Chromecast, by the way - not sure why that is). If you want Amazon VOD you need access to a Roku too, because at this writing the Oppo will not help you there.
Not being able to trigger the the rest of the equipment to turn one when I turn one the Oppo (no trigger out) is a *real* pain (for me).
The absence of composite or component video inputs is a pain. I still watch VHS in my home theater (there is old material that I only have in VHS). And I cannot connect an older camcorder or really anything lacking HDMI.
The volume control/attenuator is ok, but I quickly missed the physical knob on my receiver the first time I had to lower the volume in a hurry. And even hooked up to a Sunfire 400x5, I felt it was not matching the output level the pre produced. Felt like less-than-unity gain.
Not having a way to apply dolby prologic quickly to a source by pressing a button? THAT is a pain. You can, in theory, go back to the main menu and turn on DTS neo 6 for either music or cinema, but it is a slow cumbersome process.
So....
Can it work as pre/pro? Yes if you have only a couple of HDMI connections and make do w/o the conveniences you take for granted in an AV receiver.
Does it sound that much better to warrant doing? Not in my opinion, certainly not with my equipment. I am going back to my receiver as the control center.
PS: Good news are: the DAC kicks butt! Best DAC I have had so far - and that is on lowly 24/96 stuff - I have yet to play the higher def stuff or DSD!! Incredible resolution. And the Darbee processor is worth every penny for video!
Emotiva XMC-1 / Emotiva XPA1-L / Sunfire 405x5 / Behringer iNuke 3000DSP
Oppo BDP-83 / VPI Aries 1 / with JMW 10.5 Memorial Tonearm and Van de Hul Frog cart
Goldenear Triton Ones / Supercenter XXL / Buttkicker LFE /Rythmik FVP15HP
Mistubishi HCD7900 / Elite VMAX2 135" screen / Sharp Aquous 60" LC-60LE450U
Other sources: MacMini / Roku HD / XFINITY / Chromecast / too many tape decks
Namikis is online now
post #21 of 38 Old 03-17-2014, 06:14 PM - Thread Starter
wse
wse's Avatar
Liked: 739
For me it does not because I can go direct so the SSP-800 doesn't mucky up the sound
I didn't think that was a pain the SSP-800 is manual as well, I would rather take my tape measure and my SPL so I know the info is correct the first time
The lack of HDMI inputs is a pain. In my setup (inside a cabinet) I can only use the back port. I hooked up an HDMI switch. Standing up every time I want use the Chromecast or cable or Apple TV gets tiring quickly (and the quality of Netflix on the is very poor compared to teh Chromecast by the way - not sure why that is). If you want Amazon VOD you need access to a Roku too, becasue at this writing the Oppo will not help you there.
I only need one HDMi input so no problem here as well
Yes, that would be nice
I have no old equipment I use with this, so I am glad it does"t have S Video or component or FGS composite
The volume is a non issue I set mine at 0, never use the nob on the SSP-800 the remote :)
And not having a way to apply dolby prologic quickly to a source? THAT is a pain. You can, in theory, go back to the main menu and turn on DTS neo 6 for either music or cinema, but it is a slow cumbersome process.
Agreed I miss Dolby ProLogic IIx
So.... Can it work as pre/pro? Yes if you have only a couple of HDMI connections and make do w/o the conveniences you take for granted in an AV receiver.
Does it sound that much better to warrant doing? Not in my opinion. I am going back to my receiver as the control center.
Good for you
If I didn't have the SSP-800 already I probably would not buy it today; mine is 4.5 years old.
Maybe I will sell the SSP-800
wse is offline
post #22 of 38 Old 03-17-2014, 06:33 PM
Namikis's Avatar
Holly molly wse, just spent 20 minutes pouring over pics of your system. Amazing. Congrats on managing to pull together such a great collection of equipment.
I am keeping the Oppo as the pre/pro for a week - it will take an afternoon to reinstall the receiver and work stands in the middle of that.
P
post #23 of 38 Old 03-17-2014, 06:55 PM - Thread Starter
wse
wse's Avatar
Liked: 739
Originally Posted by Namikis View Post Holly molly wse, just spent 20 minutes pouring over pics of your system. Amazing. Congrats on managing to pull together such a great collection of equipment.  I am keeping the Oppo as the pre/pro for a week - it will take an afternoon to reinstall the receiver and work stands in the middle of that.
smile.gif P
Thank you, I am a music fanatic and love to be surrounded by it  :D
This is my point of reference
wse is offline
post #24 of 38 Old 03-17-2014, 07:15 PM
"If I didn't have the SSP-800 already I probably would not buy it today; mine is 4.5 years old.
Maybe I will sell the SSP-800.
Why? What a beautiful piece of machinery.
post #25 of 38 Old 03-17-2014, 11:13 PM - Thread Starter
wse
wse's Avatar
Liked: 739
If and when OPPO incorporate some of the features I am looking for I might sell the SSP-800 as it will be redundant and that way I can buy more speakers biggrin.gif I am a speaker man wink.gif
wse is offline
post #26 of 38 Old 03-18-2014, 01:47 AM
OmarF's Avatar
Quoted: 22 Post(s)
Liked: 84
Well, I hate to go backwards on what I'd said before...but...
I spent about a week using my 105 as a pre amp, then today switched back to my Ayre preamp. No comparison, using a dedicated preamp is better in my system. The 105 as preamp sounded pretty good, until I compared them head to head again.
Omar
OmarF is offline
post #27 of 38 Old 04-03-2014, 03:03 PM - Thread Starter
wse
wse's Avatar
Liked: 739
Originally Posted by OmarF View PostWell, I hate to go backwards on what I'd said before...but..  I spent about a week using my 105 as a pre amp, then today switched back to my Ayre preamp. No comparison, using a dedicated preamp is better in my system. The 105 as preamp sounded pretty good, until I compared them head to head again. Omar
I sure would hope so with the price of the AYRE !!!!!
wse is offline
post #28 of 38 Old 04-03-2014, 07:34 PM
OmarF's Avatar
Quoted: 22 Post(s)
Liked: 84
Yeah, luckily I was able to get my Ayre pre and amp as dealer demos, or I'd never have been able to afford them. I switched back again this week, to give the OPPO another shot. What I found was, the bass was there, but not as tight, and the highs were slightly muffled, using the 105 as preamp. That having been said, I might not have even thought or noticed that, if I didn't have my Ayre amp to compare with. The 105 certainly didn't sound bad by itself, and I still think it did a better job with sound staging by itself. The Ayre was just so much cleaner and open. I put on a pair of Audio-Technica m50s for validation, and the Ayre sound lined right up with what I was hearing there, too.
I will say this, I wasn't entirely happy with either preamp solution, at first. The Ayre as preamp sounded clean but artificial. Then I turned upsampling off in Audirvana, and the sound cleared right up and became very natural sounding as well as super clean. Anyone using upsampling with their DAC, I recommend disabling it.
Omar
OmarF is offline
post #29 of 38 Old 04-08-2014, 10:16 AM
oneartist's Avatar
Quoted: 17 Post(s)
I'm building a 105/Magnepan theater/multipurpose system. I love the pure sound of the 105 directly to individual amps, but as I'm coming closer to putting everything together and I'm wondering if I shouldn't consider putting a 300wpc integrated between the stereo outs and the front speakers. 300wpc in case I use 3.7 or 3.6 front end. This will provide addional connectivity as well as phono. Or would it be possible to slip a pre amp in line to a large front amp? How are you adding connectivity?
oneartist is offline
post #30 of 38 Old 04-09-2014, 11:00 PM
OmarF's Avatar
Quoted: 22 Post(s)
Liked: 84
Personally, I'm running from the 105 to a pre amp, then to an amp. Separates, in other words. Based on the varied responses people are having to this, I recommend trying both ways, yourself. The variables are too many to make a clear prediction of what will sound better for you. You just have to try and put your ear to it. I was going back and forth between preamp, no preamp, and one thing that swung my vote towards preamp was running a good pair of headphones out of the 105 and listening. The sound of the preamp lined up much more strongly with what I heard from the headphones than without preamp.
Omar
OmarF is offline
Reply Blu-ray Players
Oppo Bdp 105 Blu Ray Player
