Tech specs:
https://www.oppodigital.com/blu-ray-bdt-101CI/
Advanced Features
- Universal disc format support including Blu-ray, Blu-ray 3D1, DVD, DVD-Audio, Super Audio CD, CD, HDCD and more
- Upscaling to Ultra HD (4K) resolution
- VRS® (Video Reference Series) ClearView™ video processing
- Dolby® TrueHD and Dolby Digital Plus decoding
- DTS-HD Master Audio™ decoding
- Bitstream output compatible with Dolby Atmos and DTS-X
- Three USB ports for playback of media files2 (AVCHD, MKV, AVI, MP4, WAV, FLAC, APE, DSD, etc.)
- Ethernet port for BD-Live, firmware upgrade and home network media file playback
- True 24p™ video for Blu-ray encoded in 24Hz frame rate and optional conversion of DVD to 24p
- Multiple zoom modes
- Advanced picture control including video smoothing, detail and edge enhancement
- Premium 32-bit audio DAC by AKM
- Optical and coaxial digital audio outputs
- Rigid steel chassis and center mounted disc loader with motion balance and vibration isolating mechanisms
- Back-lit remote control
Custom Integration Features
- Versatile modular design with many customized options
- One or two HDMI outputs via the additional HDMI output module
- Optional HDBaseT output module for long cable runs
- Stereo or optional 7.1ch analog audio output module
- Optional rack mount kit
- Large front panel buttons with finger guards
- RS232 and IP control for system integration
- Switchable rear IR sensor for a clean IR blaster/emitter installation
- HDMI CEC (Consumer Electronics Control)
- Three customizable picture adjustment presets
- Settings can be locked to prevent inadvertent changes
Notes:
1 Requires proper 3D television and glasses.
2 Compatibility with user-encoded contents or user-created discs is on a best-effort basis with no guarantee due to the variation of media, software and techniques used.
All trademarks are the property of their respective owners.
Specifications
Designs and specifications are subject to change without notice.
Disc Types BD-Video, Blu-ray 3D, DVD-Video, DVD-Audio, AVCHD, SACD, CD, HDCD, Kodak Picture CD, CD-R/RW, DVD±R/RW, DVD±R DL, BD-R/RE BD Profile BD-ROM Version 2.5 Profile 5 (also compatible with Profile 1 Version 1.0 and 1.1) Output Analog Audio: stereo / 5.1ch / 7.1ch
Coaxial/Optical Audio: up to 2ch/192kHz PCM, Dolby Digital, DTS.
HDMI Audio: up to 7.1ch/192kHz PCM, up to 5.1ch DSD, bitstream.
HDMI Video: 480i/480p/576i/576p/720p/1080i/1080p/1080p24/UHD, 3D frame-packing 720p/1080p24. Audio Characteristics
(Nominal specification) Frequency: 20Hz – 20kHz (±0.2dB), 20Hz – 96kHz (-3.5dB ~ +0.05dB)
Signal-to-Noise Ratio: >105dB (A-weighted)
THD+N: < 0.0012% (1kHz at 0dBFS, 20kHz LPF) General Specification Power Supply: ~100V – 240V, 50/60Hz AC
Power Consumption: 40W (Standby: 0.5W in Energy Efficient Mode)
Dimensions: 16.9 x 11.3 x 4.1 inches (430mm x 287mm x 105mm)
Mass: 9.9 lbs (4.5kg) Operating Temperature 41°F - 95°F
5°C - 35°C Operating Humidity 15% - 75%
No condensation Parts & Labor Warranty 2 Years
