Official Samsung UBD-K8500 4K HDR Ultra HD Blu-Ray Player Owner's Thread - Page 391 - AVS Forum | Home Theater Discussions And Reviews
 22906Likes
post #11701 of 13255 Old 01-25-2017, 10:40 AM
Ambush083's Avatar
Quoted: 22 Post(s)
Originally Posted by iang153 View Post
just search this thread for 'remote' - lots of responses - here's one:
Originally Posted by Musician View Post
Crap, you beat me to it.
I was trying to hunt down this post of mine for @Ambush083 which also includes a picture...
Thanks to both of you. Since it's 2017 I thought minimalistic remotes would be a thing. Beggers can't be choosers though. I'll be buying this bad boy soon.
[TV's]
LG OLED55C6P - Current
Samsung UN55HU8550 TH01 - In Rehab
Samsung UN46C7000 - Dead
Ambush083 is offline
post #11702 of 13255 Old 01-25-2017, 10:45 AM
goombatommy's Avatar
Quoted: 33 Post(s)
I think it is a bit of both. Some scenes are lit red so red illumination is going to happen and then there was one particular brief scene where guys were referring to the phenomenon as "smearing". If it was prevalent in every disc then this would have caused an outcry but other than those initial posts dating back to the April 2016 time frame when the disk was first released this is the first post in a long time discussing anything similar.
It appears this issue was isolated and if it was something that Samsung could (or would) fix via firmware it probably would have happened by now.
If you jump to the following posts you will see it was a pretty active topic at the time with the word "smearing" appearing over 30 on that page alone...
...and if you use the Search this Thread feature you will find over 140 posts discussing "smearing". I believe the topic also came up in the UHD Content thread.
That's probably a better word - smearing.
LG 55" B6 OLED | Marantz SR5011 | Outlaw Audio 5000 Model Amplifier | B&W HTM62 S2 - Center | B&W 684 S2 - Fronts | B&W 685 S2 - Surrounds | 2 x SVS SB-2000 Subwoofers | Oppo 203 4K UHD Blu Ray Player
goombatommy is offline
post #11703 of 13255 Old 01-25-2017, 10:58 AM
Musician's Avatar
Quoted: 2383 Post(s)
Liked: 4168
My Wiring Diagram
Based on the amount of interest (or lack of posts) where guys have shared their wiring diagrams, I thought you guys might be interested in taking a look at my revised wiring diagram to reflect the addition of the new Chromecast Ultra which now makes it possible for me to view YouTube HDR videos.
Just in case anyone is wondering, the UBD-K8500 will never be upgraded to play YouTube HDR anymore so than an older TV would (and by that I mean 2014 & 2015 models) because at the time of it's production it contained the VP9 chipset. In order to play YouTube HDR it would require a hardware change to the VP9 Profile 2 chipset which has only begun to appear in some 2016 television models and external devices such as the Chromecast Ultra.
As you can see I am one of "those guys" who prefers to hook up his primary video devices to his One Connect Box for a number of reason which you can view in the following post...
Advantages to Connecting Devices to the One Connect Box
Although the above link includes pictures and scenarios applicable to the 2015 Samsung interface, if you read between the lines many of the advantages might also apply to your particular architecture.
The major change between this and my old schematic is that I have moved the Apple TV to my Receiver and used that input to hook up the Chromecast Ultra. The advantage to this setup is so that anytime I cast from my iPad (or any device for that matter) it automatically selects the input the Chromecast Ultra is plugged into. If my TV is turned off at the time it will even turn it on for me!
My setup is pretty typical of what a guy with an older A/V Receiver without HDMI 2.0a & HDCP 2.2 would do in the case of hooking up the UBD-K8500 using the dual output method along with connecting other gear that requires HDMI 2.0a / HDCP 2.2 ports.
I wouldn't have bothered posting my wiring diagram as a separate post until I realized on my BD Wise Guy post, my old schematic generated over 1,400 views plus at least another 1,000 where I have attached it to other posts on AVS Forum so without further ado please see the attached thumbnail...
Name:	My Wiring Diagram.png
NTC likes this.
Samsung UN78HU9000 - Firmware 1510.3 SEK-3500U
Samsung UN40HU7000 - Firmware 1510.3 SEK-3500U
Samsung UBD-K8500 UHD Blu-ray Player; Apple TV 4K
Arris VIP5662W UHD Whole Home DVR; Chromecast Ultra
Marantz SR7005 Receiver; Magnepan Speakers; Martin Logan Subwoofer
Musician is offline
post #11704 of 13255 Old 01-25-2017, 11:01 AM
mrtickleuk's Avatar
Quoted: 1864 Post(s)
Liked: 3034
My Wiring Diagram
Very nice! Did you use any special software to create it, if so what was it please?
Musician likes this.
____________________
Denon AVR-X4200W + Arcam Alpha 8P. A 5.1.4 setup: Mission 702e, M7C1i, 77DS, 731. Rel T5 Sub. Monitor Audio CT165 4 Tops. | Samsung 55KS7000 TV (EU/UK single-tuner version of KS8000) | Samsung UBD-K8500 UHD Blu-Ray
HDMI-4K modes | 4K chroma test | Samsung 2016 TVs | Dolby & DTS core+outer audio tracks on (UHD) Blu-Rays
mrtickleuk is offline
post #11705 of 13255 Old 01-25-2017, 11:46 AM
Musician's Avatar
Liked: 4168
Nothing real special other than Paint that comes with MS Windows and the Snipping Tool.
I used the pictures in my Marantz manual. If your manual shows a front and back you can just do a bit of a cut and paste into a Paint picture and then go to town.
If you right click on my diagram and save it to your computer you can save a little time creating the little icons for each device and the HDMI cables and then use the select tool (or eraser) to remove my captions and replace them with your own. You can also use the eraser tool to remove whatever else you like.
Also if you search around the internet and pull up some images you may luck out and find something close to use as a starting point. You should at least be able to find the One Connect Box applicable to the 2016 Samsung KS model.
I would suggest opening up two or three instances of Paint so you can switch between them while you create your masterpiece!
Being the nice guy that I am (even though a few testy members of AVS might not agree ) to get you started, here is a ultra high def picture of the back of your Denon X4200W...
http://www.soundgeeks.de/wp-content/...R-X4200W-2.jpg
...along with one of the front with the door open...
http://www.novial.sk/images/denon/av...w-black-op.jpg
You'll notice on my Wiring Diagram I used the right side of the front picture since that is where my HDMI port is. I see yours is on the left so that is the side you would want to use for your cutaway.
Hell, if I made it any easier for you I would have asked for a list of your devices telling me what HDMI port they are plugged into and done it for you.
Rudy1 and mrtickleuk like this.
Musician is offline
post #11706 of 13255 Old 01-25-2017, 08:06 PM
Liked: 0
I just got this player. put in an UHD disc and it is only displaying in 1080p(black bars on top and bottom of the screen, not full screen).
I have LG 60UH7700 TV. All hdmi ports are hdcp 2.2. Have high speed HDMI cable, direct connection from the player to the tv. 4k video from the youtube app displays correctly. Any idea what I'm doing wrong?
Brill00 is offline
post #11707 of 13255 Old 01-25-2017, 08:24 PM
stangflyer's Avatar
Quoted: 49 Post(s)
Liked: 34
4k discs come with black bars also. The aspect ratio 1.85 or 2.39 determines if you have black bars or not. 99% of movies will have bars.
stangflyer is offline
post #11708 of 13255 Old 01-26-2017, 06:11 AM
mrtickleuk's Avatar
Liked: 3034
You are not doing anything wrong. This is the "why isn't my 2.35:1 movie filling the screen" "because it's a different shape to the screen" discussion that we had in 1999 with DVDs. It is nothing whatsoever to do with the format.
(and after 18 years of answering this FAQ, I hope you can appreciate why we're all a little tired of it!)
b0rnarian likes this.
post #11709 of 13255 Old 01-26-2017, 07:09 AM
NorthJersey's Avatar
Quoted: 365 Post(s)
Liked: 160
majority of UHD movies are letterbox, hate to disappoint you. One of the few that isn't is Pacific Rim UHD.
IF you don't see the HDR flag appear, though, when you start the UHD disc, you should verify on the LG TV that the HDMI input has UHD Deep Color enabled.
I've enabled it for all inputs on my 55UH8500 LG set, it won't hurt anything
NorthJersey is offline
post #11710 of 13255 Old 01-27-2017, 01:36 AM
mrtickleuk's Avatar
Liked: 3034
I know by 99% you just meant "most" and it was short-hand. However it's interesting what the actual proportion of movies is. You Definitely used to be able to search IMDb by aspect ratio, but they have removed this feature.
However, a while back when I ran these searches I took the liberty of keeping the results
Code:
Common aspect ratios  IMDb stats (http://uk.imdb.com/Sections/DVDs/AspectRatios/)
10:9 is 1.11:1 |       |
11:9 is 1.22:1 |       |
4 :3 is 1.33:1 | 11395 | 50.7%
        1.37:1 |     8 |  0.0%
13:9 is 1.44:1 |     3 |  0.0%
14:9 is 1.56:1 |     6 |  0.0%
15:9 is 1.66:1 |   628 |  2.8%
        1.75:1 |    21 |  0.1%
16:9 is 1.78:1 |   848 |  3.8%
        1.85:1 |  6408 | 28.5%
17:9 is 1.89:1 |     1 |  0.0%
        2.20:1 |    53 |  0.2%
20:9 is 2.22:1 |     6 |
21:9 is 2.33:1 |     5 |  0.0%
        2.35:1 |  2995 | 13.3%
22:9 is 2.44:1 |   103 |  0.5%
                 22480
NB obviously this is DVDs so contains a lot of TV series at the time, hence the large number of 4:3 titles.
I think it's very sad when a feature is needlessly and ruthlessly removed. It's so unnecessary and seems spiteful. Before I dug my figures out I was trying to find it again on the IMDb, and I found posts on their forums with people asking about it, and others replying as if it had never been there, and suggesting it was put forward for consideration! It used to be there!
galonzo, Terminader and Ted Brogan like this.
post #11711 of 13255 Old 01-28-2017, 08:32 AM
Quoted: 40 Post(s)
Liked: 31
MrT, I've gotten into the habit of having Tim Burton's 1.85:1 'Sleepy Hollow' play on an all day loop for Halloween.
Can't wait to see it on the K8000 this year.
LG4k and mrtickleuk like this.
Samsung UN60KS8000
Samsung UBD-K8500
Ted Brogan is offline
post #11712 of 13255 Old 01-29-2017, 09:14 AM
Quoted: 30 Post(s)
Liked: 1
hi All,
i recently purchased this samsung player and i can't seem to make it work smoothly with my jvc x550r projector. I popped in the Revenant bluray and the sound is choppy, the picture goes in and out, etc. After reading a few pages, on this long thread, i wanted to get clarification as to whether this player still has these issues or have they been address? i tried everything last night and it is just a very disappointing experience to say the least because i can't even watch my first movie yet.
Any help will be greatly appreciated. thanks !
Whitecamaross79 is offline
post #11713 of 13255 Old 01-29-2017, 10:54 AM
as in "O.G." Alonzo
galonzo's Avatar
Quoted: 770 Post(s)
Liked: 877
Originally Posted by Whitecamaross79 View Post
hi All,
"These issues" have only been experienced by those who have HDMI cables that can't handle the demands of the higher data rates possible with an HDMI 2.0a signal; you must use "Certified Premium" HMDI cables to guarantee you will be able to handle anything current players can output. I ended up with these and have had no such issues, but they're only available through 20' lengths. Here's an article, where @Dave Vaughn tested some other options if you require longer than that.
mrtickleuk likes this.
Equipment Details:
Spoiler!
galonzo is offline
post #11714 of 13255 Old 01-29-2017, 11:44 AM
poppagene's Avatar
Quoted: 704 Post(s)
Liked: 522
hi All,
Are you having problems with a blu-ray disk or with a UHD blu-ray disk?
what about streaming apps like netflix or amazon prime?
I don't know what you mean by still has these issues because the player works well for most with few issues.
Most problems relate to bad disks, poor cables or trouble setting up ARC.
UN48JS8500 UN55HU6950 w/SEK-3500U UN40HU6950 w/SEK-3500U UBD-K8500 UN37C5000
poppagene is offline
post #11715 of 13255 Old 01-29-2017, 02:52 PM
Quoted: 30 Post(s)
Liked: 1
i was having problems with a specific bluray. the image was jittery and the sound was skipping. i did a hard reset on the player and it now functions fine with the exception of the apps such as amazon, youtube, netflix. The screen goes black once a video starts streaming. I am guessing it is a cable issue so i have ordered a cable from the ones mentioned above.
post #11716 of 13255 Old 01-30-2017, 06:05 AM
Swolern's Avatar
Quoted: 99 Post(s)
Liked: 25
The K8500 only supports HDR10 correct? Any word that it will receive an update for Dolby Vision HDR?
Swolern is offline
post #11717 of 13255 Old 01-30-2017, 06:14 AM
Rudy1's Avatar
Quoted: 1433 Post(s)
Liked: 2117
This model doesn't have the hardware necessary to decode Dolby Vision, so it cannot be updated.
"I am not IN the business...I AM the business."
Rudy1 is offline
post #11718 of 13255 Old 01-30-2017, 06:58 AM
Swolern's Avatar
Quoted: 99 Post(s)
Liked: 25
Well that sucks. I hate all these format wars!!!
Swolern is offline
post #11719 of 13255 Old 01-30-2017, 07:03 AM
dpippel's Avatar
Quoted: 300 Post(s)
Liked: 438
It's not a format war. DV is an alternative to HDR10, and all DV titles on disc are required to be backwards-compatible with HDR10. What you're complaining about is the price that is usually paid when you're an early adopter. Samsung chose to release the K8500 before DV hardware was readily available, so they didn't incorporate it into the player. It was more important to them to get the K8500 out in the marketplace when they did than wait for DV.
______________
LG OLED65E6P | Denon AVR-X4200W | Oppo UDP-203 | Panasonic DMP-UB900
My Media Collection
dpippel is offline
post #11720 of 13255 Old 01-30-2017, 07:13 AM
Musician's Avatar
Liked: 4168
And just to add to what everyone else is saying, most of the time the questions asked on AVS Forum can be answered with a quick Google search. A search for "UBD-K8500 Dolby Vision" returns the following article...
Samsung UBD-K8500 vs Philips BDP7501 vs Xbox One S
The only HDR format that is supported is HDR10, meaning neither one of the three supports Dolby Vision, nor it’s possible to add suport via a firmware update in the future due to the fact Dolby Vision requires a special chip to be present on-board
And another search for "Oppo Dolby Vision" reveals that Samsung is not the only game in town...
Oppo UDP-203 Ultra HD Blu-ray Player Review: The Return Of The King
In fact, the 203’s processing brain is so open-ended that it’s going to allow Oppo’s deck to become the first to support the Dolby Vision HDR format, following a firmware update due in March.
Terminader likes this.
Musician is offline
post #11721 of 13255 Old 01-30-2017, 07:16 AM
dpippel's Avatar
Quoted: 300 Post(s)
Liked: 438
I believe that the only player available for purchase at this time with Dolby Vision SoC is the Oppo UDP-203, and the feature won't be available until they turn it on with a firmware update sometime this year. Its' also important to remember that your DISPLAY, along with your UHD player, must support Dolby Vision in order for DV discs (still vaporware) to work.
______________
My Media Collection
dpippel is offline
post #11722 of 13255 Old 01-30-2017, 08:22 AM
as in "O.G." Alonzo
galonzo's Avatar
Quoted: 770 Post(s)
Liked: 877
Exactly what I found when I first tried some brand-new, 10' Amazon Basic High-Speed HDMI cables; they worked great for 4K/24 (UHD Blu-ray disks, most, if not all 4K Netflix and Amazon shows and movies), and even had no problems displaying the Home screen, but once I tried to watch some 4K/60 (rather, 1080p/60 from Netflix that automatically gets upscaled to 4k/60 by the player, unless you explicitly set Resolution to 1080p), I started to get an occasional black screen. So, I did a little research, and found that only certified "Premium" HDMI cables will guarantee no issues with current HDMI standards.
Equipment Details:
Spoiler!
galonzo is offline
post #11723 of 13255 Old 01-30-2017, 08:50 AM
fred37's Avatar
Success
Originally Posted by fred37 View Post
Has anyone had an issue outputting a 2160 signal from the Samsung UBD-K8500 through a 20' 2.0a HDMI cable? Connected it directly to a JVC DLA-X550R projector with a Maestro 2.0a HDMI cable, no luck. Connected the player to a 4k LED TV with a 6' cable and it works. Set the player to 1080 and brought it back to the projector and it worked. With the player menu displaying on the projector screen I set it the player back to 2160 and got 10 seconds of black screen and then resets back to 1080p. Feel like I've gone back in time to the early days of HDMI!
An installer told me I may have to use an HDMI extender over fiber, hope not.
This is how i fixed this.
With the UBD-8500 set to output 1080p I went through every setting one by one then tried 2160p. No success until...
Changed to an Ultralink HDMI cable rated at 27Gbs and changed "HDMI color format" to YCbCr(4:4:4) .
fred37 is offline
post #11724 of 13255 Old 01-30-2017, 10:42 AM
mrtickleuk's Avatar
Liked: 3034
Absolutely. And had Samsung waited, it would have been an entire year late!
aaronwt and rickcleveland like this.
post #11725 of 13255 Old 01-30-2017, 10:49 AM
UHD Addict
aaronwt's Avatar
Quoted: 6414 Post(s)
Liked: 3963
Yes, I've been able to enjoy my Samsung K8500 for close to a year now. I got it the week of February 8th, 2016. I'm glad I didn't wait.
mrtickleuk and rickcleveland like this.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Sony UBP-X800--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #11726 of 13255 Old 01-30-2017, 05:18 PM
Liked: 0
Hi guys. I just bought the 8500. Do the apps such as Neflix and Amazon still not support HDR? Thanks.
thinkblue is offline
post #11727 of 13255 Old 01-30-2017, 05:56 PM
kwhite666's Avatar
Quoted: 130 Post(s)
Liked: 89
Amazon yes HDR support
Netflix no
kwhite666 is offline
post #11728 of 13255 Old 01-30-2017, 06:00 PM
Liked: 0
Thanks for the quick answer! I appreciate it. I've confirmed what you said - so I know my 8500 is working as it should. Thanks again.
post #11729 of 13255 Old 01-30-2017, 08:12 PM
mikestr's Avatar
Quoted: 176 Post(s)
Liked: 225
Anybody having issues with the Amazon apps HDR not working tonight. Trying to watch Sneaky Pete and it will only go up to 1080P no HDR. Watched a couple episodes last night no problem. Even tried other show, Grand Tour and MITJ same results.
Samsung 55JS9000
Vizio P65-C1
mikestr is offline
post #11730 of 13255 Old 01-31-2017, 08:01 AM
Tweaver1's Avatar
Quoted: 60 Post(s)
Liked: 48
Amazon HDR is not working for me either..Not from this player or from my Roku ultra..
I WANT MORE and mikestr like this.
Vizio p65c1>- Yamaha a3050>- Emotiva UPA-1 Mono blocks>-Oppo 203>- Samsung K8500>- Roku Ultra>- Apple tv4>- Energy RC70, RC10's, RCLCR
>-SVS PB2000>- Energy S10.3
Tweaver1 is offline
Reply Blu-ray Players
color calibration , hdr player , member , settings
