Reality check: reading the blu-ray spec. - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Closed Thread
post #31 of 52 Old 03-16-2005, 09:51 AM
CardiacArrest's Avatar
Actually, there are Blu-ray units shipping, just not to America. Also, mpeg-2 was the first decoder to be used. Remember Blu-ray has been available and in-use in Japan for some time now (over a year, I believe), as a recording/timeshifting unit.
I have not heard of a single HD-DVD unit shipping in any country.
CardiacArrest is offline
post #32 of 52 Old 03-16-2005, 11:57 AM
hongcho's Avatar
AVC is Part 10, IIRC. ITU (H.264) and MPEG (MPEG-4 AVC) jointly worked together to bring this video codec.
When people talk about MPEG-4, nowadays, it usually means MPEG-4 AVC HP.
Hong.
i have great faith in fools -- self confidence my friends call it. -- edgar allan poe
hongcho is offline
post #33 of 52 Old 03-16-2005, 12:54 PM
psycho's Avatar
Originally posted by Richard Paul
Where does it say that MPEG-2 will be the first decoder to be used? Also once again I would recommend reading the BD-ROM specs which may answer many of your questions. BD-ROM can use MPEG-2, MPEG-4 AVC HP, and VC-1 for video along with Dolby Digital, Dolby Digital Plus, Doby Digital Lossless (formerly called MLP), DTS, DTS-HD Lossy, DTS-HD Lossless, and PCM for audio. Both Blu-ray and HD-DVD have the exact same video/audio codecs.
BluRay does not support Dolby Digital Plus or MLP. And MLP is not now know as Dolby Digital Lossless, you need to find reliable sources and carefully read them.
psycho is offline
post #34 of 52 Old 03-16-2005, 01:05 PM - Thread Starter
samiam95124's Avatar
Q. Where did you see "all three codecs are required" ?
A. for the players. It was mentioned all over the place try http://www.blu-raydisc.com/assets/d..._0305-12955.pdf in section 3.3
The spec mentioned does not use the word "required", it says:
BDROM provides an easy-to-author framework for creation of
High Definition movie experiences known as "HDMV",
(High Definition Movie) mode.
Here are some of the key features offered by HDMV:
MPEG-2, MPEG-4 AVC.....
Sorry I cannot cut and paste from this document, I encourage reading the
original.
The format "offers" MPEG-4, thats a long way from saying "the first discs
will be in MPEG-4 format".
Now read what the blu-ray site says here:
http://www.blu-raydisc.com/general_i...564/Index.html
"Also on the application layer, the HD-DVD format incorporates many compromises. As the capacity is not likely to be sufficient to encode a full-length feature plus additional bonus materials using the MPEG-2 format, different and stronger encoding formats need to be used. Although Blu-ray Disc offers these advanced codecs as well, the disc has such high capacity that publishers can still use the MPEG-2 encoding format at bitrates up to 54 Mbit/sec. As MPEG-2 is the de-facto standard used in almost any industry involved in digital video (DVD, HDTV, digital broadcast), many authoring solutions are available. Chances are high that a full line MPEG-2 encoding suite is already available, which can be used with no or minor adaptations to encode High Definition content for Blu-ray Disc."
Note that again, the word used is "offers".
This is not new, the Blu-ray group has touted from day one that their big advantage is
allowing the use of the present mpeg-2 format.
So, at the risk of beating this dead horse into the ground, again, there is every reason
to expect that the first discs out in BD format will be mpeg-2, and single layer.
Again, I encourage anyone wanting the facts to read this information for him/herself
at:
I want HDTV 'cause I'm nearsighted !
samiam95124 is offline
post #35 of 52 Old 03-16-2005, 01:25 PM
WriteSimple's Avatar
Okay, try downloading this PDF and go to page 18. We just heard it first in one of the threads around here about DD Plus finally being included in BD.
What's interesting is the difference between DD Plus Lossless and DTS HD Lossless - 6.86 Mbps. It's still all good!
fuad
"DonÂt let them tell you who you are is not enough, that itÂs wrong and that you wonÂt find love. DonÂt let them use my life to put your future down, or tell you that happiness canÂt be found."
WriteSimple is offline
post #36 of 52 Old 03-16-2005, 01:54 PM
Richard Paul's Avatar
Quoted: 32 Post(s)
Liked: 36
Dolby Lossless (also called Dolby Digital Lossless) was announced about a week ago. Don't ask me why they changed the name of MLP, but it is now called Dolby Lossless. Just posted some information on it in relation to Blu-ray.
Found that a bit strange to but since both codecs are limited to 96kHz for 7/8 channel audio it shouldn't make to much of a difference.
Richard Paul is offline
post #37 of 52 Old 03-16-2005, 02:02 PM
psycho's Avatar
Thanks for the up-to date specs, not like the one in the other post.
Why is Sony calling MLP Dolby Lossless, when Dolby calls it MLP? They just license it, they don't own it, Meridian does.
psycho is offline
post #38 of 52 Old 03-16-2005, 02:23 PM
Quoted: 32 Post(s)
Liked: 36
Originally posted by samiam95124
This is not new, the Blu-ray group has touted from day one that their big advantage is allowing the use of the present mpeg-2 format.
So, at the risk of beating this dead horse into the ground, again, there is every reason to expect that the first discs out in BD format will be mpeg-2, and single layer.
Sam, both formats can decode MPEG-2 so this isn't that big of a deal. In fact if the studios wanted they could use MPEG-2 for HD-DVD. Also Blu-ray will offer dual layer discs next spring which is also when pre-recorded Blu-ray launches. I do not know what the studios will use but that will be an option. You seem to be trying to say the worst about Blu-ray and there is no need for that. If you want to argue for HD-DVD then I would recommend doing that.
When I posted that link two days ago it was up to date :).
I believe Dolby has bought the rights to the MLP codec and will now market it as Dolby Lossless. Also out of curiosity who said anything about Sony?
post #39 of 52 Old 03-16-2005, 02:43 PM
Not quite correct.
Dolby Lossless has a Dolby Digital stream and a MLP stream.
kjack is offline
post #40 of 52 Old 03-16-2005, 02:45 PM
psycho's Avatar
I was talking about this whitepaper mentioned here
It seems only sony (and people here) is refering to as Dolby Lossless
Originally posted by kjack
Not quite correct.
ok, that makes sence.
psycho is offline
post #41 of 52 Old 03-16-2005, 04:19 PM
Quoted: 32 Post(s)
Liked: 36
Interesting, does Dolby Lossless also include Dolby Digital Plus with MLP?
I know that was the one I was referring to. I guess I should have said in my original post that Dolby Digital Plus and Dolby Lossless were only recently added.
post #42 of 52 Old 03-16-2005, 04:26 PM
No -- I remember looking for that because it would have been really neat. DD is there for backwards compatibility, DD+ can't be output over SPDIF currently.
kjack is offline
post #43 of 52 Old 03-16-2005, 04:36 PM
psycho's Avatar
I'm shocked that dolby has no info in any of this though.
psycho is offline
post #44 of 52 Old 03-16-2005, 04:51 PM
Quoted: 32 Post(s)
Liked: 36
Dolby takes a while to update its website and they should be putting up a press release in a week or two.
post #45 of 52 Old 03-16-2005, 05:00 PM - Thread Starter
What seems to occur here is that if you are even slightly cirtical of Blu-Ray (or
preceived as being), then you are labeled as AGAINST IT.
What I have done, and I think impartial readers will agree I have done
SCRUPULOUSLY, is simply to point out what is actually written on the blu-ray
site, by the people who are doing the work.
Frankly I find yours and at least one other person heres attempt to paint me as
a "bad man" by simply pointing out facts as patently offensive.
post #46 of 52 Old 03-16-2005, 07:11 PM
AnthonyP's Avatar
it is not the facts we are questioning or that you are a bad man. it is your interpretation of the facts. The fact that AVC HP and VC-1 is there you don't care, but because they say MPEG-2 and using it to compare to DVD you think it means that BR will only use MPEG-2
It is like the argument I saw some time ago from some others
"If the studio uses MPEG-2 at 12 Mbps it will look worst then MPEG-4 at 15 Mbps on HD-DVD."
even though factually true, it is 100% missleading because there is nothing stopping the studio from producing MPEG-4 at 15 Mbps on the BR disk
AnthonyP is offline
post #47 of 52 Old 03-16-2005, 09:58 PM
Quoted: 32 Post(s)
Liked: 36
What seems to occur here is that if you are even slightly cirtical of Blu-Ray (or preceived as being), then you are labeled as AGAINST IT.
SCRUPULOUSLY, is simply to point out what is actually written on the blu-ray site, by the people who are doing the work.
Frankly I find yours and at least one other person heres attempt to paint me as a "bad man" by simply pointing out facts as patently offensive.
You take the negative aspects you can find on Blu-ray's website and then try to prove that Blu-ray will be worse than HD-DVD. That is no different than taking a HD-DVD example on the HD-DVD Promotion Group website and then accusing HD-DVD of doing something wrong. As an example I will take a quote form this HD-DVD page and put it right here:
A 30GB disc can deliver three 150-minute movies, offering the perfect way to store movies and their sequels on a single disc—with all the vibrancy of HD image quality.
Now the real fun begins as I warp there innocent bit of advertising into something proving the real intentions of the HD-DVD group ;) . Example: "This quote clearly shows that the HD-DVD group is thinking of releasing three movies on every HD-DVD disc." Now granted that is not what they meant at all but I have just shown what is being done to the Blu-ray website. Sam, you take the bits of advertising on Blu-ray's website and try to prove that Blu-ray will be worse than HD-DVD. That is not exactly fair and is basically just nit-picking small details that have nothing to do with the capabilities of the two formats. So to sum it up I would like to say that advertising information can be deceiving when put into the context of facts.
Sam, I am not trying to attack you but I know what you are doing and will defend Blu-ray because many of the facts you mention aren't really facts. You claim that being critical of Blu-ray will get you labeled as being "against it", but in your this thread's initial post you praised HD-DVD while critizing Blu-ray. Because of that I believe we all have good reason to believe that you are for HD-DVD and are against Blu-ray. Sam, I have no problem with debating the formats on their merits and if you wish to do that then I would be happy to.
post #48 of 52 Old 03-17-2005, 04:21 PM
HiDefRentals's Avatar
Originally posted by Health Nut
Anything mentioned about 1080p30? That would be reasonable and it is an ATSC format.
Health Nut: the petition you're proposing is very out of date and misleading. it doesn't mention Blu-Ray at all and uses the term HD-DVD incorrectly. it should say "next generation DVD" and use HD-DVD to mean one of the proposed standards. Also, CEMA has not been CEMA for quite awhile - it's now CEA. There are also quite a few technical details that are wrong or outdated.
Overall, it's a great idea, but in its current form would do more harm than good by confusing people and spreading misinformation. i know that's not the point, so i'm wondering if there is a planned update to the petition.
Jason
HiDefRentals is offline
post #49 of 52 Old 03-18-2005, 10:55 AM
rezzy's Avatar
Quoted: 991 Post(s)
Liked: 745
I dunno, they were saying the same thing about (SD) DVD: "Imagine all three (now 4) Lethal Weapon movies on one disc". I can't remember which rag I read that quote in. But in the end, it's the publishing studio who actually decides how many flicks per individual disc. They'll likely realease trilogies and quadrilogies seperately or as a boxed set. Selling each film individually (as opposed to one disc) puts more cash in the studios' pockets.
"I knew you'd say that"...*BLAM!*
rezzy is offline
post #50 of 52 Old 03-19-2005, 08:55 AM
Mr Griffiths's Avatar
This isnt really connected to the above debate but i thought this might be of interest.Will Panasonic blu-ray be able to read DVD-RAM? see here (i'm a new member so cant post links so put www before it)
panasonic.com/industrial...ure/future5.htm
Mr Griffiths is offline
post #51 of 52 Old 03-19-2005, 11:05 AM
dialog_gvf's Avatar
The Panasonic DMR-E700BD, a consumer Blu-Ray deck which was launched in Japan last June, is capable of read/write to Blu-Ray, DVD-R, and DVD-RAM.
It is likely Panasonic will continue to release this capability in the next generation units.
- Don't trust sigs
dialog_gvf is offline
post #52 of 52 Old 03-20-2005, 07:12 AM
Health Nut's Avatar
Jason,
I couldn't agree more. Perhaps I should delete it from my sig file, since everything in the sig file has been granted for the most part. In fact, I'll do this now.
The petition is about 4 years old and outdated. Going to delete...
Health Nut is offline
Closed Thread Blu-ray Players
