Blu-ray Disc Marking System Outlined - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-05-2005, 09:28 AM - Thread Starter
Ricko's Avatar
Very Interesting...
http://www.dvd-recordable.org/Article2224.phtml
Recently published patents at the US Patent & Trademark Office could bring some light to the so-called "ROM Mark" protection layer of the Blu-Ray format.
Both HD DVD and Blu-Ray formats use the Advanced Access Contest System (AACS), in order to protect their data from unathorized replication, in an attempt to fight forgery. However, the Blu-Ray format additionally adds a second layer of protection called BD+, and a third layer called ROM Mark.
The Blu-Ray Disc Association has not publically given explanations on how the BD+ adds encryption key renewability to AACS key revocation. In addition, it has not said a word about how the ROM Mark works. The Association has officially said that the ROM Mark 'guards against mass production piracy or the mass duplication and sale of unauthorised copies of pre-recorded media' and also confirms that a digital signature is buried in the recording which can identify whether an individual disc was pressed from an authorised glass master.
Recently published patents from Robert Edmonds and Kevin McDonnell in California and Johann de Meulder in Belgium could give a give a strong clue to how BD Mark works.
Although every machine used to laser-cut a master disc is theoretically the same, the motor that spins the blank disc and moves the laser along a spiral track varies slightly in speed and precision. So if a digital marker is put in the middle of a recording, e.g. after exactly 60 minutes, its physical position on the master disc - and every disc then pressed - will be a unique fingerprint of the cutting machine.
The new system also buries some digital code on the disc which describes where the marker should be for the machine that created the master disc, for instance 25% round the thousandth turn of the spiral track. A modified player used by Customs checks the described position with the actual position. If they match, the disc is genuine. If they don't, the disc is a fake pressing.
To beat the system, pirates would have to reverse engineer the entire marker description and check process - which they are unlikely to have the time, expertise or money to do.
Format war my A$$! I want one, and one only!
Ricko is offline
post #2 of 6 Old 10-05-2005, 09:42 AM
Michael Grant's Avatar
Liked: 24
Very interesting indeed! Thanks for the info.
Michael
Michael Grant is offline
post #3 of 6 Old 10-05-2005, 09:54 AM
dialog_gvf's Avatar
Yes, thanks! Interesting indeed!
Gary
- Don't trust sigs
dialog_gvf is offline
post #4 of 6 Old 10-05-2005, 11:50 AM
lymzy's Avatar
Thank you for the info.
Check process might be the weak link. But you got SPDC to check the environment.
HDPLEX
lymzy is offline
post #5 of 6 Old 10-05-2005, 05:52 PM
AnthonyP's Avatar
thanks
AnthonyP is offline
post #6 of 6 Old 10-10-2005, 02:57 PM
paintit77's Avatar
Pirates won't need to remove the mark or reverse engineer. Once the movie is ripped from the disk, it will be encoded in a totally different format which can be played using D-VHS or a PC. Pirates will just by pass BR drives all together.
They may need to reverse engineer the disks if they want to mass produce BR disks, but the Chinese are using their own disk players and software. Once the movies is removed from the disk, they can do what they want and encode it anyway they want.
paintit77 is offline
Closed Thread Blu-ray Players
