Blu-Ray DVD drives for PCs by March - Page 4 - AVS Forum | Home Theater Discussions And Reviews
Closed Thread
post #91 of 94 Old 10-17-2005, 03:11 PM
archibael's Avatar
Um... they already are. Next year's ATI and Nvidia models start shipping with HDMI.
I do not speak officially in any sense for
Intel Corp., Technology Manufacturing Group
but I do work there.
archibael is offline
post #92 of 94 Old 10-17-2005, 03:58 PM
donotremove's Avatar
oh. :( :mad:
donotremove is offline
post #93 of 94 Old 10-18-2005, 10:29 AM
archibael's Avatar
Why is that sad? You don't have to use it. It's just going to be present on hardware if you want it. The cards will likely still cost the same. Give or take a couple bucks.
post #94 of 94 Old 10-20-2005, 12:48 PM
mikemorel's Avatar
Originally Posted by nataraj
The DRM etc would, I guess, be implemented in players. Yes, its not simple ... but not rocket science ;)
from Amir on the humungo thread...
Originally Posted by lymzy
From NEC PR, the AACS chip is indeed in their first HD DVD ROM.
Originally Posted by amirm
That is not correct. AACS requires certain things to be in the drive to work (i.e. to handshake with it). That is what NEC is talking about. The actual engine for AACS is in the host. For the same reason, I don't see anyone implementing a BD+ VM in an optical drive.
Amir
Just expanding on above, both AACS and BD+ require file system level access to the drive (both formats use UDF). So if you want to put AACS/BD+ in the drive, you then have to put the file system there too which makes this super messy. Hence the reason it is not in the cards.
Amir
Sure sounds ugly. Maybe March is not in the cards?
mikemorel is offline
Closed Thread Blu-ray Players
