One-and-Only PS3 as Blu-Ray Player Thread - Page 1002 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #30031 of 32120 Old 11-08-2010, 03:28 AM
caper_1's Avatar
Liked: 26
curious as to how 1080p is "crappy"
HT: Yamaha RX-V565 | 3 X Energy Take FPS, 2 X VS Surround, 2 X Take LCR | DIY Subs: SDX12 APR15 & TRIO12 Dual APR 12's | 47" LCD
Music: Yamaha RX-V863 | 2 X Energy RC-70 | MA RXw12 Sub
Bathroom: 2 X Energy Take LCR
Car: Sony Xplod HU, Xplod 6X9s, Kenwood 4"s, Alpine 12" Type-S, Rockford Amp,...
caper_1 is offline
post #30032 of 32120 Old 11-08-2010, 03:47 AM
Paul Clancy's Avatar
Compression. 1080p blue ray is far less compressed than 1080p streams.
Paul Clancy is offline
post #30033 of 32120 Old 11-08-2010, 06:13 AM
rlb
rlb's Avatar
Quoted: 1794 Post(s)
Liked: 1464
[quote=Alex solomon;19449161 I just can't seem to find the PS button in harmony one database. [/QUOTE]
It's in my harmony one database. Follows "previous" in the PS3 command drop down box.
Samsung 65JS9500 and 65F9000 w/SEK-3500U, Denon AVR X3300 & Outlaw 755
Samsung K8500, OPPO 103-D, PS3, HR44, HR24, and Roku Ultra
rlb is offline
post #30034 of 32120 Old 11-08-2010, 06:16 AM
StuJac's Avatar
Originally Posted by Alex solomon View Post
Can you please post here or PM me a detail step by step instruction on how to do it. I just can't seem to find the PS button in harmony one database. I currently use the Nyko Blu-wave USB adapter and Harmony to control the PS3. Except for the power toggle and PS button, I can control all of the PS3 function using this combo.
Alex-it doesn't matter that the code for the PS3 button is in the Harmony data base; you still need a Harmony adapter to use it. Again, there is no support for the PS3 (or power button) with the ir2tb (Nyko). Just keep the PS3 remote handy or, pay about 50-70 for the Harmony version.
Pan 46PZ85U, Marantz SR5003, TiVo Premier, TiVoHd + 1tb, A2 (fs), PS3, Pan DMR E-95 (fs), JVC DVD-A, Polk & Infinity, Harmony One
StuJac is offline
post #30035 of 32120 Old 11-08-2010, 06:32 AM
rlb
rlb's Avatar
Liked: 1464
Originally Posted by kiko1 View Post
what do i need to set the ps3 to so my receiver can do the upscaling of dvd's
I do the following:
(1) Video Settings/BD/DVD Upscaler is set to off
(2) Display Settings/Video Output settings is set to 480p as the highest resolution your set can display. (PS3 will not output 480i)
Number (1) above may be only one required for DVDs. But (2) also required for streaming Netflix (I set the highest resolution the set will receive as 480p for SD and 720p for HD and use a VP to upconvert to 1080p).
rlb is offline
post #30036 of 32120 Old 11-08-2010, 07:12 AM
Keenan's Avatar
Quoted: 2523 Post(s)
Liked: 2376
You can find them for cheaper, under $45 at Buy.com today in fact.
Code:
http://www.buy.com/prod/logitech-harmony-adapter-for-playstation-3/q/loc/108/211082833.html
Keenan is offline
post #30037 of 32120 Old 11-08-2010, 09:21 AM
raylock's Avatar
From others who have posted, it sounds like the PS3 button does not work with the Nyko. I upgraded to the Harmony adapter for about $46 from Amazon at the same time I downloaded the new Netflix app so I didn't try the PS button with the Nyko. Sorry if I led you in a false direction.
Ray
raylock is offline
post #30038 of 32120 Old 11-08-2010, 12:14 PM
PTAaron's Avatar
Quoted: 349 Post(s)
Liked: 403
Code:
I believe some ebay sellers have it for under $45 shipped as well...
I got mine from this seller: http://myworld.ebay.com/outletmp3/
-Aaron
English Way Cinema and Bar - moving on to v3.0... projector time in 2017!
PTAaron is offline
post #30039 of 32120 Old 11-08-2010, 01:51 PM
John Megadeth's Avatar
I got mine from the same seller. Great price and quick shipping.
John Megadeth is offline
post #30040 of 32120 Old 11-08-2010, 02:02 PM
Alex solomon's Avatar
Quoted: 36 Post(s)
Alex solomon is offline
post #30041 of 32120 Old 11-09-2010, 01:14 AM
Doug Blackburn's Avatar
Quoted: 188 Post(s)
Liked: 353
Because when they compress the holy crap out of the signal, you lose everything that makes HD. Including resolution, sound quality, and image quality. Just because they say it's 1080p doesn't mean you'll get Blu-ray quality. In fact streamed 1080p probably AVERAGES less than half the resolution of a 1920x1080 image for many reasons... this applies to both color accuracy and clarity, block artifacts from over-compressing scenes with a lot of motion (or pixel-to-pixel change).
When you see something like an explosion via streamed video, the resolution you get during the explosion is probably something like 200x110 because the block compression artifacts are SO LARGE you can only get maybe 200 of them across the screen - I might be over estimating... it could be as few as 120x70
"Movies is magic..." Van Dyke Parks
THX -- ISF -- HAA
Doug Blackburn is offline
post #30042 of 32120 Old 11-09-2010, 01:22 AM
As a videophile it is my greatest fear that bd will go away in favor of compressed streaming and downloads much like happened in the music world with mp3. A sad thing to contemplate for me.
post #30043 of 32120 Old 11-09-2010, 02:12 AM
EJ
EJ's Avatar
Something else along that thought. I am a commentary junkie, and I don't see streaming offering anything like that.
Former USSB uplink operator.
EJ is offline
post #30044 of 32120 Old 11-09-2010, 07:39 AM
caper_1's Avatar
Liked: 26
I thought the sound was a little tinny in a streamed TV show via netflix when I first heard it....same principle for sound as explained above for video??
caper_1 is offline
post #30045 of 32120 Old 11-09-2010, 10:17 AM
moodyman's Avatar
Originally Posted by mjvmec View Post
is there any REAL difference between the blu-ray player that comes in a PS3 and a stand alone player?
nope
moodyman is offline
post #30046 of 32120 Old 11-09-2010, 11:14 AM
PTAaron's Avatar
Quoted: 349 Post(s)
Liked: 403
You can play games on a PS3, and not on a stand alone player...
-Aaron
PTAaron is offline
post #30047 of 32120 Old 11-09-2010, 04:58 PM
TheGigaShadow's Avatar
Liked: 24
You can still by CDs for every major release. Every minor release too. You don't even have to seek them out. They are available everywhere. Despite great exaggeration, they have not been discontinued in favor of MP3. They likely never will be. 28 years strong and no real end in sight. You don't have to worry about BD being replaced by compressed streaming or downloads. Much like the CD, BD isn't going anywhere.
TheGigaShadow is offline
post #30048 of 32120 Old 11-09-2010, 05:03 PM
Keenan's Avatar
Liked: 2376
Many small independent artists have already made the jump to download/digital only. Granted, these are rather obscure artists, but the future is there for them already.
Don't be so sure about optical disc not disappearing, they will disappear, it's just a matter of when, not if.
Keenan is offline
post #30049 of 32120 Old 11-09-2010, 06:27 PM
slimoli's Avatar
Quoted: 654 Post(s)
Liked: 299
I'm getting "We're unable to connect you to Netflix" msg. Anybody else ?
I was so happy without HDR...
slimoli is offline
post #30050 of 32120 Old 11-09-2010, 10:49 PM
allredp's Avatar
Newb to PS3 - trying to figure out why my Onkyo 808 only receives PCM Multi-Ch via HDMI from the PS3 slim (black little model). I've looked through the menu on the PS3 and can't see anywhere to switch between PCM or Bitstream. Much appreciated for any help!
creative>energy
allredp is offline
post #30051 of 32120 Old 11-10-2010, 05:37 AM
seggers's Avatar
Quoted: 112 Post(s)
Liked: 59
Without wishing to pick on poor slimoli here, this is another reason why BD, or optical media in general, isn't going away any time soon.
Netflix, and its ilk, are slowing, or not so slowly as it seems, bringing the Internet to its knees. There wil come a point soon when you'll request a film on Monday and it'll be ready to watch on Friday.
And I wonder which ISP is going to break ranks and put the choke on the Netflix traffic, in order to save their own streaming crap?
I'll stick to my more imediate download called BD and CDs thanks muchly.
Seggers
Vizio M80-C3, Denon X6300H, Emotiva UPA5 (triggered), Wharfedale Pacific Evo 40s, CS, 10s, PC DX12 sub, Def Tech A60 Atmos tops, the internet, an ASUS ChromeBox running Kodi, a TiVo Series 3 and a Philips BDP7501 UHD . There's also a Wii, but we don't talk about that...
seggers is offline
post #30052 of 32120 Old 11-10-2010, 06:31 AM
JChin's Avatar
Quoted: 377 Post(s)
Liked: 210
Hi allredp, go to "BD/DVD Audio Output Format (HDMI)" under "Video Settings".
JChin is offline
post #30053 of 32120 Old 11-10-2010, 06:59 AM
allredp's Avatar
Wow, under "video settings" eh?!
Fantastic - thanks a ton!
creative>energy
allredp is offline
post #30054 of 32120 Old 11-10-2010, 10:51 AM
Buckeye911's Avatar
Yes, it was horrible. I changed all my settings, cold booted the PS3, deleted Netflix and reinstalled, I tried everything. I could not connect from about 4:30 PM (East Coast) until about 11 PM. It suddenly just started working again. I sure hope it doesn't happen again.
The measure of a man's character is what he would do if he knew he never would be found out.
Buckeye911 is offline
post #30055 of 32120 Old 11-10-2010, 11:49 PM
Dorn's Avatar
Has anyone had any problems on the PS3 watching Blu-rays where you get what I would best describe as a "heat haze" around things sometimes? By "heat haze" I'm meaning how on a hot day, you have that hazy part above the street/sidewalk/concrete. I can't think of the proper term.
I'm not sure if it's my TV, or the PS3. Sometimes I'll see it on a panning motion of the camera, other times it's surrounding a person simply on the screen talking with things moving behind him/her.
Dorn is offline
post #30056 of 32120 Old 11-11-2010, 04:07 AM
Talon884's Avatar
No problems like that here...
Talon884
Sarasota, FL
HT - LG OLED 65E6P | Marantz AV7703 | Marantz M7055 | OPPO UHDP 203 | Technics SL-D303 TT | PS3 | Nintendo NES | Atari 2600 | Roku Premiere + | Klipsch | Monster Power HD 2550
Den of Solitude - Marantz 6300 TT | Marantz 125 Tuner | Marantz 3800 Pre Amp | Marantz 250 Amp | Sansui SP-5500X Speakers
Talon884 is offline
post #30057 of 32120 Old 11-11-2010, 08:58 AM
04rex's Avatar
Quoted: 138 Post(s)
Hello, I have a question about my PS3. I have it connected via HDMI to my Yamaha Receiver. Whenever I play a game, the receiver says PSM instead of dolby digital or DTS or whatever. But when I play a Blu Ray, it says Dolby Digital or DTS.
Can anybody help me out with this?
FAMILY ROOM - Totem Tribe II LCR, JL Audio E-112, Anthem MRX 300, Apple TV Gen 3, WD HDTV, Panasonic 55" Plasma
BASEMENT THEATRE - Paradigm Studio 100 v.5 L/R, CC-690 v.5 C, Studio 10 v.5 x4 Surround Side and Backs, 4x DIY 15" Ultimax Subwoofers in 3.0 Cu Ft sealed boxes, Cerwin Vega CV-5000 for Subs, Anthem MRX 720, Outlaw Audio 7700, HTPC, Apple TV Gen 4, X-Box One, Harmony Ultimate Remote, Ben-Q W1070, 92" screen
04rex is offline
post #30058 of 32120 Old 11-11-2010, 09:34 AM
Ken Beck's Avatar
That's because those games are creating PCM, not DD or DTS. Some Blu-Rays also have PCM tracks so when you select the PCM track on a Blu-Ray, your receiver will show PCM for that.
Ken Beck is offline
post #30059 of 32120 Old 11-11-2010, 01:34 PM
petrovy's Avatar
Turn OFF the "smoothmotion" or "motionflow" or "whatever " special effect your new set has.
all is good....LNT4671 1005/1001 SQ01 w/old PS3 80G,Oppo 83 & 2400ES into Mirage OS3FS
petrovy is offline
post #30060 of 32120 Old 11-11-2010, 01:44 PM
Pugnax555's Avatar
It could also be that the sharpness setting on the TV is cranked up. Either way, the problem is almost definitely not the PS3 (unless it's defective).
Pugnax555 is offline
Reply Blu-ray Players
Blu Ray Movies , Blu Ray Players , Lcd Hdtv , Playstation 3 160gb System , Sony , Toshiba
