One-and-Only PS3 as Blu-Ray Player Thread - Page 1051 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #31501 of 32118 Old 01-19-2012, 10:12 AM
Wryker's Avatar
Quoted: 134 Post(s)
Liked: 52
Originally Posted by Milez28 View Post
So I do NOT need to update to 4.0 to receive the lossless audio formats as someone replied in an earlier post.
Correct however it does not support HD audio from 3DBDs for True-HD audio discs.
"..where you will never find a more wretched hive of scum and villainy."
Wryker is offline
post #31502 of 32118 Old 01-19-2012, 11:02 AM
PTAaron's Avatar
Quoted: 243 Post(s)
Liked: 256
I don't know why your AVR says that - I'm pretty sure it is a fact of the design of the cables that you cannot send the lossless audio through anything other than HDMI.
You can bitstream it via HDMI on a PS3 slim and your AVR will decode the lossless, or you can set it to LPCM and the PS3 will decode the lossless formats for you and send it out over HDMI.
-Aaron
English Way Cinema and Bar - moving on to v3.0... projector time in 2017!
PTAaron is offline
post #31503 of 32118 Old 01-19-2012, 11:09 AM
drhankz's Avatar
Quoted: 77 Post(s)
Liked: 64
JOIN the 21st Century - It is the HDMI protocol and not the Cable.
drhankz is offline
post #31504 of 32118 Old 01-19-2012, 11:40 AM
drhankz's Avatar
Quoted: 77 Post(s)
Liked: 64
That was helpful.
It was more helpful than your VIOLENTLY WRONG Answer.
drhankz is offline
post #31505 of 32118 Old 01-19-2012, 11:47 AM
PTAaron's Avatar
Quoted: 243 Post(s)
Liked: 256
A more helpful response would have been to explain what the difference is, but hey - whatever makes you feel more superior to those of us that are still learning.
-Aaron
PTAaron is offline
post #31506 of 32118 Old 01-19-2012, 02:39 PM
Milez28's Avatar
Originally Posted by Wryker View Post
There is more than one place to change from Bitstream to PCM. There's the XMB settings and then there's using the 'triangle' pop-up while watching a BD.
Are your audio settings in the XMB set to output bitstream? Check that setting.
Yes I'm changing it in the main menu. Didnt know you could change it in the menu from the triangle button
Milez28 is offline
post #31507 of 32118 Old 01-20-2012, 09:18 AM
cuzed2's Avatar
Quoted: 187 Post(s)
Liked: 237
When I have it set at Bitstream(Direct) the "HD light" displays on my Marantz receiver but if I switch it to PCM it doesnt display. FYI I'm using a Marantz sr8002 receiver which does not support 1.4
I have a Marantz 7002 (little brother to the 8002, but very similar), the following is normal:
If you feed the Marantz a bit-stream signal, means the Marantz will be doing the decoding >> you will get the fancy decoder indicator lights on the Marantz panel.
If you do the decoding in the upstream device (PCM to the Marantz) - The Marantz decoding indicators become inactive.
Hope that helps out a bit.
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #31508 of 32118 Old 01-20-2012, 10:49 AM
Milez28's Avatar
Oh ok well I'd rather have the Marantz doing the decoding anyways unless there's really no difference? I guess it would make sense to let my ps3 focus on the video and let my receiver do the work on the audio... Can you tell a difference in sound with yours from HDMI to Optical?
Milez28 is offline
post #31509 of 32118 Old 01-20-2012, 01:02 PM
TheGigaShadow's Avatar
Liked: 24
The difference is, if you use HDMI you'll be able to use DTS-HD MA and Dolby TrueHD (uncompressed, lossless tracks). If you use optical you won't. Optical does not have the bandwidth to accommodate those uncompressed tracks.
If you want your receiver to do the decoding, connect with HDMI and set the PS3 to bitstream.
If you connect using optical you will only get standard Dolby Digital and DTS.
This is not speculation. It is fact.
TheGigaShadow is offline
post #31510 of 32118 Old 01-20-2012, 01:16 PM
drhankz's Avatar
Quoted: 77 Post(s)
Liked: 64
That is ONLY TRUE for the SLIM PS3.
The Fat PS3 is the other way around - decode to LPCM in the PS3.
DO NOT BITSTREAM
drhankz is offline
post #31511 of 32118 Old 01-20-2012, 02:02 PM
KtrainHurricane's Avatar
Quoted: 38 Post(s)
So does this mean that you can still get Dolby TrueHD when using a PS3, as long as your receiver supports it?...since the receiver is the one doing the decoding, and not the PS3?
KtrainHurricane is offline
post #31512 of 32118 Old 01-20-2012, 02:30 PM
Liked: 24
The PS3 can send both DTS-HD MA and Dolby TrueHD on standard Blu-ray discs only.
If you are referring to 3D discs, the answer is no.
As it currently stands the PS3 can only send DTS-HD MA where 3D Blu-rays are concerned. If the 3D movie happens to have a TrueHD track, it will default to standard Dolby Digital. There is speculation that this may be addressed in a future firmware update. After all, there was a time the PS3 couldn't do DTS-HD MA and 3D at the same time and that was fixed with a firmware update. As far as I know, the 3D movies with DTS-HD MA tracks outnumber the 3D discs with TrueHD tracks so the issue is not as big as it seems. Still, it'll be nice if they can fix it.
Now, back to standard (non 3D) discs...
Even if your receiver does not support DTS-HD MA or TrueHD you can still get uncompressed audio IF the receiver has HDMI in. If it does, all you need to do is have the PS3 do the audio decoding internally, by setting it to output PCM (instead of bitstream). That way the PS3 will send the decoded, uncompressed audio to the receiver. The end result will be the same.
NOTE
Though this has been said many times before I'll mention it again. ONLY the slim PS3 can output bitstream audio. If you have the fat (or phat as people like to call it) PS3 you'll have no choice but to have the PS3 do the decoding internally. Again, the end result is the same.
post #31513 of 32118 Old 01-20-2012, 07:53 PM
Quoted: 38 Post(s)
NOTE
Though this has been said many times before I'll mention it again. ONLY the slim PS3 can output bitstream audio. If you have the fat (or phat as people like to call it) PS3 you'll have no choice but to to have the PS3 do the decoding internally. Again, the end result is the same.
That was kick-ass post man...very easy to understand, and informative. Thanks a ton for answering!! ::thumbsup::
post #31514 of 32118 Old 01-20-2012, 08:39 PM
Liked: 24
I'm glad you approve. And glad that it helped.
post #31515 of 32118 Old 01-25-2012, 08:27 AM
Arialis's Avatar
Originally Posted by oqvist View Post
Has anyone hear used the PS3 with the spears and munsil contrast pattern. I can´t get anything decent out of my PS3 using this disc. This pattern in particular either totally crush the upper row of bars or the lower row.
Love to see a reply to this post, sort of having the same issues.
Arialis is offline
post #31516 of 32118 Old 01-25-2012, 08:41 AM
oleus's Avatar
Quoted: 33 Post(s)
i am suddenly having issues with my PS3 outputting DTS HD Master Audio bitstreamed to my receiver (receiver will only show it as DTS now). All of the codecs are checked in the audio options, and i am not playing 3d discs when it happens (i have a samsung BD player and confirmed that the same discs i am just seeing "DTS" on my receiver via the PS3 are DTS HD from the other player).
anyone have any ideas about what might have happened?
oleus is offline
post #31517 of 32118 Old 01-25-2012, 09:59 AM
cpcat's Avatar
Check to be sure you are utilizing YCbCr with super white "on" and
at video levels. The ps3 has a long time bug with
RGB that clips below black and if you are set for
PC levels (so called "expanded" rather than "video" or
"limited") it will also clip above white info.
Assuming all of that is corrected, then I'd say adjust
the brightness/contrast settings on the display. Overly done
contrast will crush whites while setting the brightness
setting too low will crush black.
cpcat is offline
post #31518 of 32118 Old 01-25-2012, 04:02 PM
Devil98's Avatar
Replacing the blu ray laser
I have an 80gb MGS bundle unit. I got the laser replaced a year ago after it progressively failed over the course of a few months. It failed again after about 9 months of use. I spent $70 on a cheap br player rather than sink more money into the ps3 or buy a new slim.
Now im missing the ps3. I prefer the interface for BR and netflix, and i'd like the option to play games.
So, has anyone replaced the blu laser more than once, or does anyone see the value of replacing the laser again over saving up for a slim?
I have a newborn stealing my sleep and could use some clear thought, untainted by sleep deprivation.
Devil98 is offline
post #31519 of 32118 Old 01-25-2012, 04:07 PM
drhankz's Avatar
Quoted: 77 Post(s)
Liked: 64
I own (3) Fat PS3s. Thank GOD - they are all fine..
Replacing the laser is pretty easy and there are
instructions all over the net.
With that said - I would op for the SLIM option.
drhankz is offline
post #31520 of 32118 Old 01-25-2012, 04:21 PM
Devil98's Avatar
Found a guy on ebay and watched him replace it last time, so i think im good with the procedure.
I covet the quiet fan and hopeful reliability of the slim, though.
Devil98 is offline
post #31521 of 32118 Old 01-25-2012, 04:23 PM
drhankz's Avatar
Quoted: 77 Post(s)
Liked: 64
My Point Exactly
drhankz is offline
post #31522 of 32118 Old 01-25-2012, 04:27 PM
Devil98's Avatar
My Point Exactly
Alright. Time to start preparing my ppt for the finance committee.
Devil98 is offline
post #31523 of 32118 Old 01-25-2012, 07:45 PM
King_David's Avatar
Hi,
I have PS3 hooked up to my newly purchased 3D HDTV, but since I am yet to purchase a 3D AV reciever I have it connected via OPTICAL.
Question: Is it possible to BITSTREAM DTS-HD MA and TrueHD audio from the PS3 via optical connection???
If so, how?
Thanks for your response.
King_David is offline
post #31524 of 32118 Old 01-25-2012, 07:50 PM
Ocielz's Avatar
Quoted: 22 Post(s)
Originally Posted by King_David View Post
Hi,
If so, how?
It's only possible thru HDMI and on Uncompressed for the Fat Ps3. Slim ps3 can do Bitstream and Uncompressed thru HDMI, that way you can get HD audio.
Onkyo 1030 7.2.2 Set up.Klipsch VF-35 front left/rightKlipsch VC-25 center speakerOnkyo SKH-410 Atmos SpeakersOnkyo SKF-560F back surround speakers.Klipsch Synergy S1 surround.Onkyo 12in. sub.Polk Audio PSW505OPPO BDP-103 PS3PS4
Ocielz is offline
post #31525 of 32118 Old 01-26-2012, 11:16 AM
Liked: 24
Hi,
If so, how?
No. It's not possible. Optical does not have the bandwidth to carry the HD audio tracks. It has to be HDMI.
I posted more about this a few days ago. See posts :
http://www.avsforum.com/avs-vb/showt...7#post21522927
http://www.avsforum.com/avs-vb/showt...6#post21523436
post #31526 of 32118 Old 01-26-2012, 11:18 AM
Wryker's Avatar
Quoted: 134 Post(s)
Liked: 52
No. It's not possible. Optical does not have the bandwidth to carry the HD audio tracks. It has to be HDMI. See posts #31515 and #31518 on this page.
umm - if i remember, the Slim PS3 CAN bitstream all the HD Audio codecs but no TrueHD audio for 3D BDs.
Wryker is offline
post #31527 of 32118 Old 01-26-2012, 11:24 AM
PTAaron's Avatar
Quoted: 243 Post(s)
Liked: 256
Not over OPTICAL only over HDMI.
-Aaron
PTAaron is offline
post #31528 of 32118 Old 01-26-2012, 11:33 AM
Wryker's Avatar
Quoted: 134 Post(s)
Liked: 52
Got it. I've confused myself too many times due to the question being posed so many times!
Wryker is offline
post #31529 of 32118 Old 01-26-2012, 11:50 AM
Liked: 24
That's not what he asked. He asked if it can bitstream DTS-HD and TrueHD over OPTICAL and it can't.
EDIT:
Thanks Aaron. You beat me to it.
post #31530 of 32118 Old 01-26-2012, 09:10 PM
mdavej's Avatar
Quoted: 2129 Post(s)
Liked: 940
... also worth noting that no device can bitstream HD audio over optical, not just the PS3.
mdavej is offline
Reply Blu-ray Players
Blu Ray Movies , Blu Ray Players , Lcd Hdtv , Playstation 3 160gb System , Sony , Toshiba
