One-and-Only PS3 as Blu-Ray Player Thread - Page 1052 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #31531 of 32120 Old 01-26-2012, 09:02 PM
TheGigaShadow's Avatar
Liked: 24
Originally Posted by mdavej View Post
... also worth noting that no device can bitstream HD audio over optical, not just the PS3.
Which is exactly why I said:
"Optical does not have the bandwidth to carry the HD audio tracks."
TheGigaShadow is offline
post #31532 of 32120 Old 01-26-2012, 09:13 PM
jd213's Avatar
It's not so much the bandwidth, since optical can do 24bit/-192kHz LPCM 2.0. The S/PDIF standard was just never updated to handle DTS-MA or TrueHD.
jd213 is offline
post #31533 of 32120 Old 01-27-2012, 05:12 PM
Liked: 24
True enough. A poor choice of words on my part. For anyone who wants a bit more detail, this is a pretty good article:
http://solidlystated.com/hardware/hd...s3-or-blu-ray/
post #31534 of 32120 Old 01-31-2012, 12:41 PM
justin987's Avatar
Thanks for the link.
justin987 is offline
post #31535 of 32120 Old 02-01-2012, 02:33 PM
swarm87's Avatar
Quoted: 135 Post(s)
Liked: 104
just lost my 60gb to the red blinking light; is it a better idea just to get a replacement unit for $99 and restore a backup from the old system? the only ps2 games i play are MGS, legacy of kain and FF-X. i use it as my primary bluray player(samsung bdp-1400 is my backup) is it worth getting a slim referb.
pcm=potato
bitstream=patato
swarm87 is offline
post #31536 of 32120 Old 02-01-2012, 03:54 PM
Ferdy's Avatar
When my A01 60GB gave up the ghost, it was overdue---it was of the batch of very first released---and never really worked exactly right. It had trouble holding an internet connection, trouble downloading updates (usually had to download them from the PS3 website to a flash drive and do it manually), and then after updates, the auto reboot would hang and I would have to start it in safe mode just to get it to run again. The final straw was when it wouldn't load regular DVDs and PS2 games.
So I called Sony and got the $99 trade in. Although they say the replacements (Slim 160GB 2401's) are refurbs, the one I got appeared to be brand spanking new with all of the protective sticky plastic stuff that you have to peel off still in place. I have to say, it's the best deal around for 99 bucks---it works perfectly and has done away with all my frustrations with the old one--the turnaround was only about a week, though they say 2 weeks. The rep almost shed a tear to offer to take the A01 back---he seemed genuinely upset and said he hates to see the grandaddy of them all crash and burn, because they (the first 2 models) had EVERYTHING in one package. But anyway, I just went on eBay and bought a used PS2 SCPH-50001 complete with DVD remote, network adapter, 64MB memory card, 2 wired controllers and 1 wireless controller for 60 bucks shipped for my huge library of PS2 games. The 50001 was the last of the "fat" models, and is the only fat model that has the progressive scan option for DVDs. Gotta say for $60, it's just as good as any upscaling DVD player I've seen. Usually if you can get a 480p signal through component cables to any worthwhile HDTV, the TV can upscale to signal to HD if it has any kind of decent scaler built into it.
So, I'd say go for it. Well worth the $160 total it cost me to trade it in---
Let us know what you decide to do----
Ferdy is offline
post #31537 of 32120 Old 02-02-2012, 06:25 PM
hansol89's Avatar
Not getting dts all the time on blu-rays. I have a new ps3 slim with audio connected to an older receiver that supports dts, i set output to optical and check all the formats and set the ps3 to bitsream the audio. while some movies downmix the audio automatically to dts some only output in 5.1 dolby. when that happens i have to go to the optical settings and uncheck 5.1 and then i get a dts downmix. Is this normal?
hansol89 is offline
post #31538 of 32120 Old 02-02-2012, 10:56 PM
King_David's Avatar
How do I set my PS3 Slim to do uncompressed pcm and send to my pioneer VSX-921-K??
The darn thing will not display TrueHD tracks via bitstream...
I probably should have stuck with an Onkyo.
Please help.
King_David is offline
post #31539 of 32120 Old 02-03-2012, 05:22 AM
WannaKnowTech's Avatar
Quoted: 12 Post(s)
Please help.
Wait are you using HDMI? Because thats the only way it will bitstream. If it's hooked up using HDMI then it should be bitstreaming. Or are we talking 3D? Right now the PS3 slim only can bitstream DTS-HD-MA during 3D play. Im sure one day in the future that will be fixed too. I have that same receiver and im not having any problems.
WannaKnowTech is offline
post #31540 of 32120 Old 02-03-2012, 05:43 AM
King_David's Avatar
The PS3 can send both DTS-HD MA and Dolby TrueHD on standard Blu-ray discs only.
If you are referring to 3D discs, the answer is no.
As it currently stands the PS3 can only send DTS-HD MA where 3D Blu-rays are concerned. If the 3D movie happens to have a TrueHD track, it will default to standard Dolby Digital. There is speculation that this may be addressed in a future firmware update. After all, there was a time the PS3 couldn't do DTS-HD MA and 3D at the same time and that was fixed with a firmware update. As far as I know, the 3D movies with DTS-HD MA tracks outnumber the 3D discs with TrueHD tracks so the issue is not as big as it seems. Still, it'll be nice if they can fix it.
Now, back to standard (non 3D) discs...
Even if your receiver does not support DTS-HD MA or TrueHD you can still get uncompressed audio IF the receiver has HDMI in. If it does, all you need to do is have the PS3 do the audio decoding internally, by setting it to output PCM (instead of bitstream). That way the PS3 will send the decoded, uncompressed audio to the receiver. The end result will be the same.
NOTE
Though this has been said many times before I'll mention it again. ONLY the slim PS3 can output bitstream audio. If you have the fat (or phat as people like to call it) PS3 you'll have no choice but to have the PS3 do the decoding internally. Again, the end result is the same.
You are the dude!
Thanks for this post, I am very grateful.
post #31541 of 32120 Old 02-03-2012, 05:54 AM
King_David's Avatar
Yes I am using HDMI, and yes I am playing 3D BDs.
As I read in another post, if I set my output to PCM that should fix my problem.
post #31542 of 32120 Old 02-03-2012, 03:32 PM
Bcfoy's Avatar
Hi, I have a rather dumb question:
I went to delete the Blu-Ray Data Utility folder and it would say it deleted but it would still be there. It emptied The folder though which is pretty much all I wanted. Anyway, I'm just concerned that by "deleting" it, my PS3 may be adversely effected. I have had issues with settings before so I'm just wondering if "deleting" it would mess up some of my settings or hurt the PS3. I probably sound crazy, but I'd really like to have my mind put to ease or fix something if need be.
Bcfoy is offline
post #31543 of 32120 Old 02-04-2012, 04:26 PM
sagecounsel's Avatar
Bit streaming on ps3 slim The Dark Knight Bluray to yamaha a3000 firmware 4.0
Hit info to show decoder and shows Dolby Digital NOT TrueHD
Hit select on the ps3 to get the pop up menu and shows multi channel
Was watching Stones BluRay and display showed DTSHD 5.1
What gives?
sagecounsel is offline
post #31544 of 32120 Old 02-04-2012, 04:31 PM
Ocielz's Avatar
Quoted: 31 Post(s)
What gives?
Some Warner releases you have to go into the Blu ray Menu and put it to DD HD. They come already set to Dolby Digital you just have to switch it.
Onkyo 1030 7.2.2 Set up.Klipsch VF-35 front left/rightKlipsch VC-25 center speakerOnkyo SKH-410 Atmos SpeakersOnkyo SKF-560F back surround speakers.Klipsch Synergy S1 surround.Onkyo 12in. sub.Polk Audio PSW505OPPO BDP-103 PS3PS4
Ocielz is offline
post #31545 of 32120 Old 02-04-2012, 04:45 PM
Ferdy's Avatar
I'm sure a lot of you guys have your whole house networked together like I do through a router with media sharing enabled.
My PS3 picks up my DirecTV receiver DVR recordings on the shared network media server---but when I try to play them through the PS3, the console gives me an error message that a special codec is needed to play them.
Does anyone know what this codec is and how it can be found, loaded and enabled?
Ferdy is offline
post #31546 of 32120 Old 02-04-2012, 06:12 PM
slimoli's Avatar
Quoted: 647 Post(s)
Liked: 299
Directv proprietary stuff. Has never been broken as far as I know.
I was so happy without HDR...
slimoli is offline
post #31547 of 32120 Old 02-04-2012, 06:17 PM
Ferdy's Avatar
Thanks Slim---sure was hoping there was a way---
Ferdy is offline
post #31548 of 32120 Old 02-05-2012, 02:03 PM
Liked: 24
What gives?
Ocielz is right. Dark Knight is definitely one of the Warner titles in which the default audio track is standard Dolby Digital. For TrueHD, go to the discs pop up menu and choose the TrueHD option. Off the top of my head I know the same applies for Batman Begins and all of the Matrix movies.
post #31549 of 32120 Old 02-05-2012, 02:04 PM
Liked: 24
You are the dude!
Happy to help if I can.
post #31550 of 32120 Old 02-05-2012, 02:18 PM
Liked: 24
If it's my post you are referring to, I have to say, I don't know how that will work with 3D. In the other post I talked about setting the output to PCM rather than bitstream if you:
A. have a receiver that doesn't decode HD tracks but does have HDMI in.
or
B. if you have a fat PS3 in which you have no other choice.
Both options were in reference to playback of standard 2D discs only.
No matter what PS3 you have (fat or slim) if you playback a 3D disc with a TrueHD track and you set the PS3 to output PCM I don't know for sure what the results will be. If I had to guess, I would think that you would get the 3D video but that the audio would end up PCM 2.0 not 5.1 uncompressed since the PS3 can't do TrueHD and 3D at the same time.
If you tried it I guess you'll have to let us know what happened.
post #31551 of 32120 Old 02-05-2012, 02:37 PM
Liked: 24
There's no reason that I know of to delete the folder. If there's stuff in it you don't need or want on your PS3, just delete those items and empty the folder, but leave the folder where it is.
post #31552 of 32120 Old 02-05-2012, 05:40 PM
zoro's Avatar
Quoted: 225 Post(s)
Liked: 41
Old fatty sounded better due to SACD circuitry built in imho
zoro is offline
post #31553 of 32120 Old 02-06-2012, 12:58 PM
mg777's Avatar
I am running a PS3 Fat to a Sony soundbar (HTCT550) and then a Bravia (52' LCD). SHould I upgrade all my hdmi cables to high speed? Btw is it worth it for my cable box as well?
mg777 is offline
post #31554 of 32120 Old 02-06-2012, 01:38 PM
Rob67's Avatar
Liked: 26
What are you trying to accomplish that you are not currently getting?
Rob67 is offline
post #31555 of 32120 Old 02-06-2012, 01:46 PM
PTAaron's Avatar
Quoted: 320 Post(s)
Liked: 378
Unless you are not able to pass 3D, there probably isn't any reason to do so... but if you did it isn't that expensive to do since you can get High Speed cables up to 10 ft long for under $5 each.
If you are getting an image and sound, there isn't really any good reason to spend the money though.
-Aaron
English Way Cinema and Bar - moving on to v3.0... projector time in 2017!
PTAaron is online now
post #31556 of 32120 Old 02-06-2012, 01:52 PM
mg777's Avatar
Everything is really looking and sounding good. I was thinking high speed hdmi cables would enhance pq and sound quality? Is this true? I heard that fat Ps3 has older hdmi ports , so not sure if this will make a difference or not. I just got my sony soundbar and am totally blown away with bd video and audio
mg777 is offline
post #31557 of 32120 Old 02-06-2012, 02:00 PM
Rob67's Avatar
Liked: 26
No, no quality increase with current BluRay specs. Unless your cable runs are over 20', don't worry about it.
Rob67 is offline
post #31558 of 32120 Old 02-06-2012, 02:56 PM
mg777's Avatar
Really appreciate the feedback.
Another quick question, with my current set-up(see above) do you think it would be worth upgrading to a Pioneer 52fd for increased PQ and sound quality. (got it open box at bb for 315)? It seems like the more i read online, the PS3 is really a good BD player after all. I had originally thought about getting a stand-alone, but it seems like to really notice a difference you need to get in the $500 or more category. I think would wait till I can get a whole new home theater set up for this
mg777 is offline
post #31559 of 32120 Old 02-06-2012, 03:03 PM
Rob67's Avatar
Liked: 26
For all intents and purposes, Blu Ray PQ is indistinguishable between players. Most people don't even calibrate their TVs so it is even more indistinguishable. That being said, in terms of cost + versatility + features, the PS3 is the best Blu Ray player deal on the market.
Now, quality with upscaled DVDs CAN vary between players.
I would pay the extra money towards getting your TV calibrated by an ISF pro instead of spending $500 on a blu ray player.
Rob67 is offline
post #31560 of 32120 Old 02-06-2012, 04:41 PM
rdclark's Avatar
Quoted: 328 Post(s)
Liked: 606
For all intensive purposes,
"Intents and purposes."
Forgive me. It's a pet peeve, a hot button, an itch I have to scratch. The phrase is "For all intents and purposes."
http://www.word-detective.com/2009/0...sive-purposes/
Wide Awake
on the Edge
of the World
rdclark is online now
Reply Blu-ray Players
Blu Ray Movies , Blu Ray Players , Lcd Hdtv , Playstation 3 160gb System , Sony , Toshiba
