One-and-Only PS3 as Blu-Ray Player Thread - Page 1059 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #31741 of 32120 Old 04-10-2012, 08:32 AM
drhankz's Avatar
Quoted: 88 Post(s)
Liked: 72
Originally Posted by dtbreen76 View Post
So in making the comment that you felt the panny player blows away the PS3, you are referring to some of the features that it offers, rather than the actual picture quality? Not trying to hold you to your words, just trying to understand better. Thank you for your time and input.
Yes - PQ - Should be the same for Blu-Ray MOVIES.
drhankz is offline
post #31742 of 32120 Old 04-10-2012, 08:51 AM
dtbreen76's Avatar
I have a Marantz 7002 (little brother to the 8002, but very similar), the following is normal:
If you feed the Marantz a bit-stream signal, means the Marantz will be doing the decoding >> you will get the fancy decoder indicator lights on the Marantz panel.
If you do the decoding in the upstream device (PCM to the Marantz) - The Marantz decoding indicators become inactive.
Hope that helps out a bit.
Cuzed,
I am wondering if you can share your experience with whether or not Bitstreaming to your reciever or letting PS3 decode and send out PCM has resulted in better audio quality? I am making the assumption that your ears are better than mine simply because I see you have a Marantz
I am no audiophile, as my speakers are Bose Accoustimass and my reciever is a low to mid end Yamaha. They sound great to me, but I don't want to miss out on anything, just in case my average hearing might detect it....lol.
Your impression/thoughts?
dtbreen76 is offline
post #31743 of 32120 Old 04-10-2012, 09:02 AM
dtbreen76's Avatar
Thanks Dr, you have been helpful and I appreciate it. One last question for you. When I turn on my tv, but have not yet turned on any sources, it displays a perfectly black screen. When I turn on my reciever and ps3, and a blu ray is loading, for example, I get a black that contains some "noise."
It is kind of like watching "channel fuzz" only much much more mild and the picture is still black. You have to be pretty close to the tv to see it. It also seems to be present when the movie is playing and the scene is really dark. I believe this may be what is called "dithering," and normal for a plasma tv. I thought you might be able to shed some light on this for me.
I am not overly concerned as it is not too visible from a normal viewing distance. i just want to know if this is what they call dithering, or if it is normal. I can't remember whether or not my Bravia LED did this or not.
post #31744 of 32120 Old 04-10-2012, 09:03 AM
Count Blah's Avatar
Figured I'd add helpful tip based on my recent experience.
I turned on the PS3, which is connected to the HDTV with an HDMI connection, and there was no video/audio. I looking in various places an the 1st step was to hold down the on button to restart. That did not resolve my issue. I swapped out the HDMI cable and still was a no-go. Advice varied greatly on how to proceed from there.
I solved the issue by getting out the old RCA type audio/video connector and hooked up the PS3 using that IN ADDITION to HDMI cable. I switched the TV to the RCA type input and I was prompted with a message that stated "The PS3 also has an HDMI connection, do you want to use HDMI instead". If you select that, you can then switch the TV to the HDMI input and you are then prompted with a count down screen(to reset back to RCA) which requires you to accept that you in fact do want to use this HDMI input.
Boom, problem solved. It does not makes sense to me why you have to do that, considering the HDMI was the only active connection. But that is what I have to do to fix my PS3 HDMI connection. I've had to do this twice now in the last three months. I'm not sure if this is an indication that my machine is on it's way out. But I'll keep on doing this when the issue comes up.
Hopefully this was helpful to someone else who faced the dearth of info I found out there when researching the problem.
Count Blah is offline
post #31745 of 32120 Old 04-10-2012, 09:08 AM
drhankz's Avatar
Quoted: 88 Post(s)
Liked: 72
I am SORRY - I do not know the answer for you.
drhankz is offline
post #31746 of 32120 Old 04-10-2012, 12:08 PM
KtrainHurricane's Avatar
Quoted: 38 Post(s)
I still don't understand what you meant by your original post - saying that the Panasonic will "BLOW AWAY" the PS3 in "all" aspects...is picture and audio quality not the most sought-after characteristics of a "good" Blu-ray player? Would you statement that "will blow away in ALL aspects" not include picture quality?
I have heard comparisons between the PS3 and Oppo 93/95 in this regard, and people who owned both said there is not much of a visual difference at all, if any. That is saying something...
KtrainHurricane is offline
post #31747 of 32120 Old 04-10-2012, 02:01 PM
PTAaron's Avatar
Quoted: 315 Post(s)
Liked: 357
Cuzed,
I'm not cuzed - but I can comment that I hear no difference between having the ps3 decode it and send it PCM and having my Sony 580 send it bitstream to my receiver.
Everything I've read also states that there should be absolutely no deference as either way.
Hope that helps.
-Aaron
English Way Cinema and Bar - moving on to v3.0... projector time in 2017!
PTAaron is offline
post #31748 of 32120 Old 04-10-2012, 02:09 PM
drhankz's Avatar
Quoted: 88 Post(s)
Liked: 72
Originally Posted by PTAaron View Post
I'm not cuzed - but I can comment that I hear. I difference between having the ps3 decode it and send it PCM and having my Sony 580 send it bitstream to my receiver.
Hope that helps.
What you hearing is LOUDNESS - Bitstream is either +3db or +6db Louder.
I forget the exact number - turn it down 3db and it will be the same.
drhankz is offline
post #31749 of 32120 Old 04-10-2012, 02:16 PM
PTAaron's Avatar
Quoted: 315 Post(s)
Liked: 357
I said It sounded the same, maybe you meant to quote someone else.
Edit: I see, my iPhone changed the word "no" into something else. Nevertheless the rest of my post does indicate that there is no difference.
-Aaron
PTAaron is offline
post #31750 of 32120 Old 04-12-2012, 04:44 AM
dtbreen76's Avatar
Thanks. I tried bitstream yesterday and for some reason my reciever wouldn't play the sound. Strange....I guess I am stuck with PCM. I only cared because I wanted to make sure I was getting the lossless format and not the standard 5.1.
Is this a common problem with the slim PS3? Maybe something I am overlooking? When I cycled through the audio options during the movie (using triangle button,) I was able to get a spanish version of DTS, but not sure if it was HD. My reciever is a yamaha and has HDMI pass through. It even handles 3D, so I can't imagine it has problem decoding DTS Master 5.1
post #31751 of 32120 Old 04-12-2012, 06:06 AM
dtbreen76's Avatar
Ok, so I just learned why I don't get sound when using Bitstream. My Yamaha RX-V367 does not list the losless formats on its feature set on their website. Obviously, this means that it will not decode them, so i need to use PCM.
My question is this: If it won't decode them, does this mean it will not play them? I am wondering if I am getting the lossless audio track out of my speakers or if the PS3 detects that the AVR cannot process those tracks and then sends out only the standard version of 5.1 PCM. Please help.
Dave
post #31752 of 32120 Old 04-12-2012, 06:18 AM
drhankz's Avatar
Quoted: 88 Post(s)
Liked: 72
Dave
Having the PS3 Decode them to LPCM is 100% The Same as Bitstream.
Your PS3 knew your AVR would not handle bitstream - it is part of the
HDMI handshake protocol.
drhankz is offline
post #31753 of 32120 Old 04-12-2012, 06:22 AM
dtbreen76's Avatar
Well that is cool. So what you are saying is that what is being delivered to my speakers is the lossless track?
I know it was a budget reciever, but I find it strange that it will handle the 3D passthrough, but not decode a lossless track. Pretty funny actually. Who the heck has a 3D tv and blu ray player but doesn't want the lossless audio?
post #31754 of 32120 Old 04-12-2012, 06:33 AM
drhankz's Avatar
Quoted: 88 Post(s)
Liked: 72
For FUTURE reference all PS3 Questions & Answers are HERE - Click On Link
drhankz is offline
post #31755 of 32120 Old 04-12-2012, 08:08 AM
dtbreen76's Avatar
Dr. Hanks, I appreciate it. however, I have already read the FAQ thread (which was very informative and well written.)
My question still remains: Is my reciever actually playing the pcm lossless track? I understand the PS3 is doing the decoding, but because of the handshake protocol, is it actually only putting out the standard 5.1 in pcm form?
Another way of asking the question would be: Is my reciever automatically putting out exactly what it is being given, even though it would have been unable to decode it on its own?
post #31756 of 32120 Old 04-12-2012, 01:55 PM
willieconway's Avatar
Quoted: 148 Post(s)
Liked: 148
Your receiver can't tell - and doesn't care - which compression format was used BEFORE the signal was decoded and turned into PCM (i.e. if it was lossy (standard DD or DTS) or lossless (DTS HD MA or D TrueHD)). It'll just use whatever PCM signal it gets. In other words you're fine.
Adjusting settings according to personal preference is not calibration.
Epson 5030UB, 100" Carada Criterion with Classic Cinema White, Onkyo TX-NR818, NHT Classic 3s, Classic ThreeC, SuperZero 2.1s, Mirage Omni S10, Oppo 103D. Currently boxed up: Denon 1713, Klipsch SW-450,
NHT Absolute Center, Energy Veritas 5.1s, 5.2C, V-Mini-C.
willieconway is offline
post #31757 of 32120 Old 04-12-2012, 03:20 PM
Pugnax555's Avatar
To find out the original audio format that the PS3 is decoding, simply press the Select button on the controller while the movie is playing.
Pugnax555 is offline
post #31758 of 32120 Old 04-12-2012, 06:26 PM
joepags's Avatar
Passthrough and decoding are two totally different things. Hdmi 1.4 will passthrough 3D but it has nothing to do with the chip that decodes lossless audio.
joepags is offline
post #31759 of 32120 Old 04-13-2012, 10:17 AM
dtbreen76's Avatar
Thanks, that is what I wanted to know.
post #31760 of 32120 Old 04-13-2012, 12:41 PM
mnc
mnc's Avatar
Quoted: 751 Post(s)
Liked: 564
My PS3 won't play certain test patterns from my Spears & Munsil disc. Any ideas??? Everything else plays fine and all but a few patterns play fine. Is it possibly a defective disc? I don't own another blu-ray player to test.
NHT speakers, Denon 4520, Panasonic 65VT50, DUAL PSA XS30SE's
mnc is offline
post #31761 of 32120 Old 04-17-2012, 06:48 AM
dtbreen76's Avatar
I don't have that disc, so I can't say for sure. However, you could try to turn on the "superwhite" option in the PS3 settings. This is supposed to try to get the tv to display the "below black and above white" portions. Perhaps that will help.
post #31762 of 32120 Old 04-17-2012, 05:01 PM
Electric_Haggis's Avatar
Quoted: 24 Post(s)
Anyone have any playback issues after the latest firmware update?
I just tried the 1978 Superman I blu-ray, and it now fails to load up.
Since the firmware's the only thing that's changed, I can't help but wonder...
Electric_Haggis is offline
post #31763 of 32120 Old 04-17-2012, 06:33 PM
Jacob305's Avatar
Quoted: 84 Post(s)
Liked: 48
was the SUperman blu ray from australia or us? was it the single disc or from the boxset?
Jacob
Jacob305 is offline
post #31764 of 32120 Old 04-19-2012, 11:58 AM
Wryker's Avatar
Quoted: 134 Post(s)
Liked: 52
Looks like I'm in the same boat as the prior poster: last night while playing Resistance 3 the screen froze. After rebooting it wont play BDs or PS3 games. Sometimes it gets to the load/main screen then it does nothing or goes to a black screen. I trust this must be the laser? I have the original fatty w/the sd card readers, 4 usb ports and PS2 backwards compatibility and don't want to lose all that. I'm going to try playing a game off the HD to make sure it's not the HD. I already went to the service screen to do a 'reset' and thought that worked but it didn't. Any other suggestions?
"..where you will never find a more wretched hive of scum and villainy."
Wryker is offline
post #31765 of 32120 Old 04-19-2012, 02:06 PM
Quoted: 24 Post(s)
Jacob
Australia, just the first-release single disc.
post #31766 of 32120 Old 04-19-2012, 07:44 PM
joepags's Avatar
Hi All-
I've got a fat ps3 question: sometimes when playing a game (goldeneye for example) there are scenes in the game where the dialog just drops out. Actually, it doesn't drop out, it's more like it was never there in the first place. The ps3 is hdmi straight to my tv, using the tv speakers. Any ideas what the issue is?
joepags is offline
post #31767 of 32120 Old 04-23-2012, 03:12 PM
Talk2Me's Avatar
Quoted: 28 Post(s)
A friend of mine gave me his fat PS3. I just finished downloading the customary Netflix and Vudu so far. I am blown away by the quality of the Netflix streaming. It is better than from my Oppo 93 and Sony S590. A very pleasant surprise. I have a lot of exploring to do. Can I down load any car racing apps?
Talk2Me is offline
post #31768 of 32120 Old 04-23-2012, 03:27 PM
mdavej's Avatar
Quoted: 2212 Post(s)
Liked: 969
It should be better than your Oppo, but how can it be better than your S590? Both are 1080p and essentially the same app.
mdavej is offline
post #31769 of 32120 Old 04-23-2012, 03:49 PM
drhankz's Avatar
Quoted: 88 Post(s)
Liked: 72
Of Course - they are in the Sony Store.
I prefer GT5.
drhankz is offline
post #31770 of 32120 Old 04-23-2012, 05:35 PM
Talk2Me's Avatar
Quoted: 28 Post(s)
Actually, I spoke too soon, and sorry to disappoint the PS3 fan club, but I tired several other Netflix movie downloads, and the fat PS3 was not better, and in some cases, somewhat less quality. It depends on the content i suppose. I quess it is a hit or miss thing, weird. So, not to piss of the Oppo club and the Sony club, both have their advantages. It does not make sense, but I can only report what I see. And I don't have a ego that does not allow me to say I am wrong sometimes. I guess in every system there are many different variables at different times to change the pq, the aq and overall perception one sees. At least I am blessed to compare and discuss.
Talk2Me is offline
Reply Blu-ray Players
Blu Ray Movies , Blu Ray Players , Lcd Hdtv , Playstation 3 160gb System , Sony , Toshiba
