1080i vs 1080p - Page 6 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
Old 08-26-2006, 08:38 PM
Vern Dias's Avatar
108024PsF is not an encoding standard. It is purely a transport standard that says that each field is trasmitted separately over the wire by being clocked out of a progressive frame buffer with the odd lines comprising the first field and the even lines comprising the second field.
This is no different from sending a 1080I signal down the wire, except that each pair of fields are guaranteed to be from the same frame, originally captured with no temporal (that means time, it nothing to do with tearing) displacement. (IOW, the entire frame buffer was originally captured from the same film frame).
since it was nothing more than a hack to begin with
I don't agree with this. 24PsF was created to allow progressive frames to be processed by the same cabling and switching infrastructure (HD-SDI, for example)already in place in HD production facilities. Without it we probably wouldn't have 24P encoded on HD discs to begin with, because every telecine bay and production house would have had to rip out every existing piece of gear and cabling and replace it with new 60I / 24P capable gear at a very great expense.
Vern
Vern Dias is offline
Old 08-26-2006, 08:52 PM
gregr's Avatar
Quoted: 12 Post(s)
Originally Posted by dr1394 View Post
The compression codecs (MPEG-2, VC-1 and H.264) don't have a concept of 1080p24sf. The coded sequence is either interlaced or progressive, so there's really no way to make the distinction that 1080p24sf is on disc. In all three codecs, it can only be signaled as 1080p@24. In other words, by just examining the coded bitstream, there's absolutely no way to tell if the original source was fed to the encoder as 1080p24 or 1080p24sf.
Thanks Ron. I was being really sloppy (and incorrect) using the term 1080p24sf in a compression context. I was trying to distinguish between interlaced and progressive sequences while avoiding the confusion that terminology usually produces.
But now that I got your attention ... Is it true that Blu-ray MPEG-2 encoding is still using interlaced sequences of frame pictures for film-sources? Is that still the only way to include top_field_first and repeat_first_field flags in MPEG-2, or has that changed? Is VC-1 similar in that respect?
Edit: Also thanks Vern and Stacey, I didn't see your replies until after I posted this.
Greg Rogers
Video Engineer/Product Designer
gregr is offline
Old 08-27-2006, 01:08 AM
Artwood's Avatar
Quoted: 60 Post(s)
Liked: 244
If all interlacing was against the law for the wole universe this would be a better world.
Artwood is offline
Old 08-27-2006, 04:44 AM
dr1394's Avatar
Quoted: 108 Post(s)
Liked: 57
Actually, it's the other way around. HD-DVD only allows 1080i@29.97 fps sequences while Blu-ray allows 1080p@23.976, 1080p@24 and 1080i@29.97 fps sequences (independent of codecs).
The current scheme for VC-1 encoding on HD-DVD is to code the source at 1080p@23.976 and then run the bitstream through a tool that changes the syntax of the bitstream from 1080p@23.976 to 1080i@29.97 with perfect telecine flags (repeat_first_field, top_field_first and progressive_sequence in MPEG-2 lingo but probably some other names in VC-1 and H.264). Stacey can verify that this is the case.
If you are interested in direct 1080p23.976 or 1080p24 output from the player, then Blu-ray has the advantage. The Blu-ray player knows that the stream is 24p at the beginning of the movie and will not change for the entire movie. It can output 24p without concern. There's still some question as to how the player handles other content on the disc and whether annoying output frame rate changes might occur. We'll see when an actual Blu-ray player ships with 24p output.
HD-DVD players cannot know that the stream is 24p. The stream is always signalled 1080i@29.97. It may have perfect telecine flags (and the VC-1 titles do because of the tool mentioned above), but the player cannot know beforehand that the entire stream has perfect flags. It could be 1080i@29.97 video, 1080i@29.97 with telecine flags dropping to video at times or 1080i@29.97 with perfect flags.
So for HD-DVD, it's a user interface problem. You could provide a 24p output mode, but it's not guaranteed to work properly with all content. Most designers are reluctant to provide an option that possibly doesn't work. It just leads to confusion and lot's of support calls from the field. But never say never.
Bottom line, the 24p output story is yet to be told by either format. I expect Blu-ray to deliver first (and possibly HD-DVD never), but we'll see.
Ron
HD MPEG-2 Test Patterns http://www.w6rz.net
dr1394 is online now
Old 08-27-2006, 05:54 PM
dr1394's Avatar
Quoted: 108 Post(s)
Liked: 57
Originally Posted by Vern Dias View Post
Ron, You have posted this misinformation before, and this statement is flat out WRONG.
Vern
The statement is correct. Your understanding of it is not complete.
Ron
Old 08-27-2006, 07:23 PM
Vern Dias's Avatar
OK, I got it now. Your key statement is that the player detecting and outputting 24FPS from an HD DVD is not bullet proof.
I agree with that.
Since every HD DVD I have played through my CII scaler and Sony Qualia has exibited perfectly smooth pans and scrolls with no sign of 3:2 induced studder, I'm thinking it's not a big deal if we don't get 24PsF or 24P out of the player anyhow.
Deleted previous post as it clearly doesn't apply here.
Vern
Old 08-27-2006, 07:53 PM
AuDiOBoY529's Avatar
Here a web site guys that compared 1080i vs. 1080p. Very interesting.
http://blog.hometheatermag.com/geoff...061080iv1080p/
By the way if the new blue laser content (HD-DVD and Blu-Ray) disc is store at 1080p/24 then what is DVD? 480p/60?
AuDiOBoY529 is offline
Old 08-28-2006, 02:22 AM
pteittinen's Avatar
I've got a CII and Sony Ruby, and at 1080p60 I'm seeing plenty of stuttering pans. Going in via DVI at 1080p48 fixed that, luckily.
I won't pay a cent for UHD Blu-rays made from 2K masters by upscaling.
pteittinen is offline
Old 08-28-2006, 08:13 AM
Vern Dias's Avatar
Well, I am going into my Qualia with 60I since it doesn't support 60P without an upgrade. The Qualia also has film pulldown detection logic.
Vern
Old 08-28-2006, 12:42 PM
RedSox04's Avatar
Originally Posted by toke View Post
There's lots of plans to broadcast 1080p in Europe.
If somebody wants to watch brd/hd-dvd with 1080i display there has to be filtering somewhere along the line.
And that's why it is much easier to output 1080p to 1080p displays, like many players will do.
Then there's no need for filtering 1080p and 1080i output can be filtered.
Continue discussion!!!
UGH....Always a step a head you guys!!!
RedSox04 is offline
Old 08-28-2006, 01:10 PM
RedSox04's Avatar
Originally Posted by mkaz527 View Post
Can you contribute something other than being a shmuck?
that's not very kind and supportive!!!
RedSox04 is offline
Old 08-28-2006, 01:34 PM
SuperPickle's Avatar
i guess time will tell huh?
SuperPickle is offline
Old 08-28-2006, 06:23 PM
Artwood's Avatar
Quoted: 60 Post(s)
Liked: 244
So let me ask this--say Blue-Ray conmes out with a player that outputs 1080p/24 and say you send that to a set that accepts 1080p/24 and has a REFRESH of 72.
In THAT case and IF the Blue Ray Player did a GREAT job of ouputting 1080p/24 and SINCE the set would REFRESH at 72 instead of 60 wouldn't you have the best picture possible as far as a film would go?
And since video is shot Not at 24 like film but at 30 or 60 why don't they just make PROGRESSIVE sets that ACCEPT 1080p/24 and REFRESH EVERYTHING Video and Film at 120 so there never is freakin Judder!
What's so hard about having Blue-Ray output 1080p/24--having sets that accept it and having everything refreshed to 120 so everything in the video universe--film and video would look great?!
Artwood is offline
Old 08-28-2006, 11:54 PM
Artwood -
I'm pretty it would look better because of the 3:3 pulldown. The real diiference is if we ever get 1080p/60 content on disc which probably won't happen anytime soon. 1080p is marketing guys.
Hieu
Old 08-29-2006, 01:06 AM
Artwood's Avatar
Quoted: 60 Post(s)
Liked: 244
Why is it that the Japanese can broadcast 1080p but we can't? Are we just retarded?
What if they had only 1 channel of 1080p and charged anybody who wanted to put prgraming on it? Who would PAY to use it?
If someone recorded it would the universe end?
Artwood is offline
Old 08-29-2006, 10:13 AM
sspears's Avatar
Quoted: 155 Post(s)
Liked: 237
A 1080p feed was setup a couple of years ago at CES. A group went around every booth who offered an ASTC tuner and asked them to tune to the channel. Less than 10% of the ATSC tuners were able to decode it. It was decided at this time that 1080p was not an option for ATSC in the US due to lack of support from the box makers.
sspears is offline
Old 08-29-2006, 03:24 PM
Artwood's Avatar
Quoted: 60 Post(s)
Liked: 244
Did the box makers take their marching orders from the MPAA?
Artwood is offline
Old 08-30-2006, 11:28 AM
koach's Avatar
Originally Posted by HorrorScope View Post
Right so stations that transmit 1080i HD really are transmitting 1080P to us for all intensive purposes.
I don't mean to be a spelling/grammar nazi, but the term you're looking for is "all intents and purposes", not "intensive purposes."
koach is offline
Old 08-30-2006, 01:09 PM
T-Bone's Avatar
Quoted: 13 Post(s)
But you just became one by posting
I hear people all the time say irregardless, and supposebly, but I stay mum even though these "words" do not exist. So for all intensive purposes, I am considerate.
-T
T-Bone is offline
Old 08-30-2006, 01:48 PM
gosawx's Avatar
-T
You are considerate, but can you tell us the heighth of the new blu ray palyers
gosawx is offline
Old 09-22-2006, 12:42 PM
tgable's Avatar
Quoted: 17 Post(s)
Liked: 78
Originally Posted by PeterS View Post
Clarification:
First you MUST differentiate between TRANSMISSION and DISPLAY.
Second, if your display is DIGITAL (DLP, LCD, DiLA, SXRD, Plasma, etc.) then it is PROGRESSIVE in its display regardless of the signal it receives.
Now:
PROGRESSIVE SOURCE --------->Native 1080p------------->Native 1080p DISPLAY (Perfect 1080p Image)
PROGRESSIVE SOURCE --------->Interlaced 1080i---------->Deinterlaced 1080p DISPLAY (Perfect 1080p Image)
INTERLACED SOURCE ----------->Native 1080i------------->Deinterlaced and Processed to 1080p
The difference is only in that the job in going from a PROGRESSIVE SOURCE to final 1080p DISPLAY is in putting the image back together simply by recombining the fields.
If the source is INTERLACED then you also have to account for the fact that the fields are offset in time. This is where the quality of the processing is important as this is not trivial (though well-established on how to do well).
This cannot hold for games correct? A 60fps 1080P game cannot be transmitted in 1080i and displayed in 1080P without a loss in IQ or a drop to 30fps or am I missing something?
Now playing: Bloodborne
Recently Finished: The Order: 1886, Dying Light
PSN & XBL: Scuzzlebutt33
tgable is offline
Old 10-05-2006, 11:04 PM
Sam S's Avatar
Quoted: 212 Post(s)
Liked: 106
Hi guys,
I'm hoping Ron (or someone) can help me understand this better. Let's use an example of an HD-DVD player outputing 1080i HDMI to a 1080p display. I understand that a movie will be encoded at 1080p/24. Are you saying that inside the player, this must be decoded at 1080i/29.97? If so, how is this accomplished? I undersand 2:3 pulldown, but can't make the connection here.
And, if the player has a 1080i/29.97 signal, does it simply double each field to ouput the final 1080i/60?
Finally, what is the frame pattern of 1080i/60 that is reconstructed to 1080p/60?
Sam S is offline
Old 10-05-2006, 11:34 PM
rantanamo's Avatar
Who and what exactly is being broadcast in 1080p?
Are all of us suckers who just wanted to get into HDTV watching obsolete sets just 1-year into the purchase?
rantanamo is offline
Old 10-06-2006, 12:52 AM
bfdtv's Avatar
Much of the series / sitcom programming on CBS and NBC is a 1080p24 sourced and delivered at 1080i60. If your TV does a decent job at deinterlace, it can reconstruct the original 1080p image.
bfdtv is offline
Old 10-06-2006, 04:49 AM
dr1394's Avatar
Quoted: 108 Post(s)
Liked: 57
Originally Posted by Sam S View Post
Hi guys,
The bitstream describes a 1080i@29.97 output from 1080p@23.976 frames. Here's how it's done:
Code:
RFF  TFF
0     1   film frame 1,  2 fields,  2 fields total, 1 frame total
1     1   film frame 2,  3 fields,  5 fields total
0     0   film frame 3,  2 fields,  7 fields total
1     0   film frame 4,  3 fields, 10 fields total, 5 frames total
0     1   film frame 5,  2 fields, 12 fields total, 6 frames total
1     1   film frame 6,  3 fields, 15 fields total
0     0   film frame 7,  2 fields, 17 fields total
1     0   film frame 8,  3 fields, 20 fields total, 10 frames total
0     1   film frame 9,  2 fields, 22 fields total, 11 frames total
1     1   film frame 10, 3 fields, 25 fields total
0     0   film frame 11, 2 fields, 27 fields total
1     0   film frame 12, 3 fields, 30 fields total, 15 frames total
0     1   film frame 13, 2 fields, 32 fields total, 16 frames total
1     1   film frame 14, 3 fields, 35 fields total
0     0   film frame 15, 2 fields, 37 fields total
1     0   film frame 16, 3 fields, 40 fields total, 20 frames total
0     1   film frame 17, 2 fields, 42 fields total, 21 frames total
1     1   film frame 18, 3 fields, 45 fields total
0     0   film frame 19, 2 fields, 47 fields total
1     0   film frame 20, 3 fields, 50 fields total, 25 frames total
0     1   film frame 21, 2 fields, 52 fields total, 26 frames total
1     1   film frame 22, 3 fields, 55 fields total
0     0   film frame 23, 2 fields, 57 fields total
1     0   film frame 24, 3 fields, 60 fields total, 30 frames total
TFF alternates after every time RFF is 1. That is, if you repeat the first field (top or bottom), the next frame must start on the opposite parity (bottom or top).
I use the term 1080i@29.97 to mean 29.97 interlaced frames per second. That's how it's signalled in the bitstream. Everything is normalized to frames. However, lots of folks call this 1080i59.94 (or 1080i60 for short), or 59.94 interlaced fields per second.
If the output rate after a deinterlacer is 1080p@59.94, then the repeated fields are tossed, and the original 1080p@23.976 frames are repeated either 2 or 3 (in a 2:3 cadence) times to get to 1080p@59.94.
Ron
Old 10-06-2006, 06:30 AM
DanielTS's Avatar
It's somehow contradictory.
Blu-ray has to deal with 1080i@29.97 fps sequences as well.
DanielTS is offline
Old 10-06-2006, 10:53 PM
Sam S's Avatar
Quoted: 212 Post(s)
Liked: 106
Thank you for the explaination, Ron.
Sam S is offline
Old 10-07-2006, 09:11 AM
rambo2300's Avatar
MOst LCD/Plasma TVs today take the 1080 60i signal, and use only half of that information because it is unable to deinterlace properly. Every other frame is skipped, and your resolution essentially becomes 1920x540 @ 30p. That means that about 50% of the transmitted information is used.
The TV uses that converted 540p signal and scales it to the native display resolution.
If the TV has a 1366x768 resolution, even more pixels are lost because it cannot display the 1920 horizontal pixels that are available from the converted 540p signal. The TV has to scale the picture down to 1366 horizaontal pixels, which is about 71% of the 1920x540 pixels.
I may be worng with these calculations, but it seems to me that most HDTV screens sold today use about 35% of the pixel information sent by the broadcasters.
It is still better than standard TV though.
Pleae correct me if I made some incorrect assumptions.
rambo2300 is offline
Old 10-07-2006, 09:12 AM
Grammar Police's Avatar
Okay now. We don't want anyone to loose there heads over this apparently sensitive issue.
Grammar Police is offline
Old 10-07-2006, 11:45 AM
Vern Dias's Avatar
rambo, I believe this information was based on the previous generation of TV sets. In the newest generation, I believe that there are far fewer sets that do this. More sets today properly handle deinterlacing 1080I. The sets that still do not are typically not 1080 resolution sets, so some loss of resolution is guaranteed, regardless of how the deinterlacing is performed.
Vern
