1080i vs 1080p - Page 8 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #211 of 222 Old 01-03-2008, 09:47 AM
jwrabbit's Avatar
New to using forums so not sure if correct procedure to ask a question!
I have ps3, hd plasma (pioneer pdp507xd), AV Amp (yamaha RX-V2600 (HDMI 1.1, support for LPCM5.1)) and I am unsure as to best connection option.
PS3 auto sets max video and audio resolution supported when connected via hdmi, so when I connect ps3 to amp it will output max 5.1 LPCM but only 720p/1080i (amp wont support 1080p).
When connecting ps3 hdmi to tv it outputs 1080p/24fps but DD/dts5.1 via optical.
Tv is HD (720p/1080i) set NOT Full HD (1080p) but with support (?) for 1080/24 (BD movie native resolution).
Questions:
What exactly does it mean to have 1080/24 support on hd tv and would I get most benefit going through amp to take advantage of lpcm5.1 or outputing 1080/24 to plasma directly (which amp doesent support)?
Is it the case that ps3 output of 1080p@24fps (or 1080i for that matter) is accepted by hd plasma and then downscaled to 720p, in which case there is no benefit in outputting 1080p and I would get more advantage by using lpcm5.1?
jwrabbit is offline
post #212 of 222 Old 01-03-2008, 02:27 PM
JonW747's Avatar
There may be an advantage (depending on your TV, it's scaler, and its true native resolution) but it may not be all that noticeable - but that may be the case with the audio as well. Try it both ways and pick what seems to be more noticeable?
I have a pre-HDMI Amp so the choice was simple for me.
JonW747 is offline
post #213 of 222 Old 01-04-2008, 10:15 AM
Jay0001's Avatar
Wow.....
Okay, I have read this from the beginning. I have an optoma hd72 projector projecting on a 92 inch screen via HDMI. If I let me PS3 detect resolution, it shows 1080p.
The projector specs are:
Resolution
Native WXGA (1280 x 768)
Maximum Resolution
PC: UXGA (1600 x 1200)
Video: 1080p(1920 x 1080)
Is my projector displaying the 1080 or the native resolution?
Jay0001 is offline
post #214 of 222 Old 01-04-2008, 10:40 AM
JonW747's Avatar
The native resolution is the only thing your projector can display, anything else you send to it will be scaled.
The point of this thread is that 1080i60 will result in the same image quality as 1080p24 if your TV can reconstruct the signal correctly. In general you want to keep the signal native and digital as long as you can and save scaling until the very last step, but in reality your mileage may vary depending on the quality of the scaler involved.
I have my PS3 configured to output 720p during normal operation, and 1080p24 when watching a Blu-Ray movie, and that may be a good starting point for you, but your mileage may vary. That's why there's no one answer here.
JonW747 is offline
post #215 of 222 Old 01-04-2008, 10:55 AM
superklye's Avatar
Originally Posted by HorrorScope View Post
Right so stations that transmit 1080i HD really are transmitting 1080P to us for all intensive purposes.
ugh...
intents. and. purposes.
"IBTL" isn't cute, funny or original.
Also: you couldn't care less and purposes are NOT intensive. For all intents and purposes if you don't know these things, you probably shouldn't use them.
superklye is offline
post #216 of 222 Old 01-04-2008, 11:39 AM
Jay0001's Avatar
Thanks for the reply. I realize my question was a bit off the main topic of the thread.......sorry for that.
I will try those setting later. I have to admit I was expecting more in image quality from Blu Ray than I was getting on my oppo upconverting. Perhaps it's a limitation of my projector or if I was in fact asking my projector to "scale" the image.
Thanks again.
Jay
Jay0001 is offline
post #217 of 222 Old 10-30-2010, 06:43 AM
dnelms's Avatar
This question is one I need an answer to before moving foward on a Blu-Ray player purchase. When I purchased my HDTV, 1080p was really expensive. The best I can do on my set is 1080i. Is getting a blu-ray player worth it when you do not have 1080p display?
dnelms is offline
post #218 of 222 Old 10-30-2010, 06:54 AM
jjeff's Avatar
Quoted: 588 Post(s)
Liked: 206
Even 1080i is a far site better than 480i, I wouldn't worry about your current TV. With properly mastered BRs you'll see a big difference from 480i SD DVDs.
If you're going to be playing many SD DVDs you'll want to look into one of the better(more expensive) BR players with better scalers.
jjeff is offline
post #219 of 222 Old 10-30-2010, 06:56 AM
rboster's Avatar
Quoted: 657 Post(s)
Liked: 465
If you use "1080i" in the advance search engine, title search only...you'll find others have asked similar/same questions about this type of set up.
FS: SMX curved Scope Screen for $500 + shipping
http://www.avsforum.com/forum/218-di...een-700-a.html
FS: lightbox + 100 plus DS movie posters
http://www.avsforum.com/forum/211-ac...e-posters.html
rboster is online now
post #220 of 222 Old 10-30-2010, 05:39 PM
tjdean's Avatar
I've purchased LG 50PK950 TV which has Netcast. Is there any reason then to purchase a blu-ray player that has wi-fi?
tjdean is offline
post #221 of 222 Unread 06-20-2016, 06:32 AM
MarcMame's Avatar
Cool
Originally Posted by MarcMame View Post
Quote:Originally Posted by toke
I won't hold it, but we can always make a traditional bet of one bottle of good cognac. I'll bet that we will have 1080p50 broadcasts in this decade (before 2009-12-31).
Regular broadcast, right ? Not some crappy test's feed with fishes in an aquarium...
You're on toke !
So here we are, 10 years later (long after the 2009-12-31) !
Where's my bottle of good cognac ?
you can PM me for my adress Toke...
tomdkat and COZisBack like this.
MarcMame is offline
post #222 of 222 Unread Today, 01:06 PM
Hans Gruber's Avatar
Quoted: 32 Post(s)
I have not read many of the posts in this thread. Today you really cannot find a comparison between 1080i and 1080p because all the 1080p native sets upconvert 1080i to 1080p. You would have to see a 1080i TV side by side with a 1080p set to see the difference. Bottom line the "P" progressive all lines broadcast, not every other line helps a great detail with motion. With that said, who uses 24hz, 24P, 24fps film mode when watching Blue Ray? Probably nobody as 60fps looks far better on TV's today. So unless you are using an actual film projector to watch films. Stick with 60hz or higher but that is of course a different argument.
Hans Gruber is online now
Reply Blu-ray Players
taboola here
