Panasonic DMP-BD10, 10A Setup/Tweaks/Settings Thread - Page 135 - AVS Forum | Home Theater Discussions And Reviews
post #4021 of 4042 Old 08-23-2010, 08:56 AM
himey's Avatar
Quoted: 66 Post(s)
Originally Posted by Terminator840 View Post
I installed a new AVR last night and dumped the analogs for HDMI. In the set up menu I turned HDMI audio on, and then set everything to bitstream. I want my new AVR to do the decoding. I am not getting Dolby True HD or DTS Master Audio, I am getting DTS core and legacy DD. What am I missing?
This player outputs Dolby True HD as PCM and does not do DTS-MA. Set your new AVR to PCM...
himey is offline
post #4022 of 4042 Old 08-23-2010, 09:15 AM
Terminator840's Avatar
I knew this player would not decode DTS-MA, but I thought you could send the signal via bitstream in HDMI and let the AVR decode the signal?
Terminator840 is offline
post #4023 of 4042 Old 08-24-2010, 05:40 PM
dbriana's Avatar
The dmp-bd10a only decodes internally, it does not bitstream those formats.
dbriana is offline
post #4024 of 4042 Old 08-25-2010, 01:35 PM
So for advanced codecs over HDMI set everything to PCM? I have a PS3 so I guess I'll use it to play DTS-MA discs.
post #4025 of 4042 Old 11-04-2010, 05:17 PM
JOE.G's Avatar
I am having trouble with Panny's website whats the newest Firm Ware for teh BD 10A
Samsung HL-T6176S 1080P DLP
Panasonic DMP BD55
Onkyo HT-SR800 7.1
Samsung PN50A650 1080P Plasma
Panasonic DMP BD 85 K
Samsung LN32C530F1F
Panasonic DMP BD10 A
JOE.G is offline
post #4026 of 4042 Old 11-04-2010, 05:38 PM
Super Moderator
teachsac's Avatar
Quoted: 651 Post(s)
Liked: 957
2.5 Last update was over 2 years ago.
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #4027 of 4042 Old 11-04-2010, 05:48 PM
JOE.G's Avatar
Yeah Thats the one I have was just checking
Panasonic DMP BD55
Onkyo HT-SR800 7.1
Samsung LN32C530F1F
JOE.G is offline
post #4028 of 4042 Old 11-19-2010, 09:36 AM
mxz600's Avatar
If I buy a new receiver with DTS-MA decoding, will I get DTS-MA out of my BD10A through the 7.1 analog?
mxz600 is offline
post #4029 of 4042 Old 11-19-2010, 10:48 AM
Rachael Bellomy's Avatar
Location: Knocksville TN, capitol por republica de Polezannia
No, you'll get DTS reg-lar but at it's highest bit-rate.
In real life I am Dot Mongur champion of the International Pacman Federation. I don't play the game, I operate it.....no dot is safe from me....
Rachael Bellomy is offline
post #4030 of 4042 Old 02-05-2011, 08:16 PM
JOE.G's Avatar
Ok I have been following this thread since it started, But I am not about to reread it to find my answer again. MY BD10 a used to be hooked up to a DLP and a 7.1 Sound System. I now have it hooked to my Sammsung Plasma HDMI and no Suround system at this time.
1. Can Any one help me to pick what settings wouldbe best in the set up menu,
Ex. Multi channel or 2 ch. Theres also a darker setting and all that kind of stuff. Thanks a lot.
Panasonic DMP BD55
Onkyo HT-SR800 7.1
Samsung LN32C530F1F
JOE.G is offline
post #4031 of 4042 Old 02-15-2011, 11:48 PM
JOE.G's Avatar
Anyone?
Panasonic DMP BD55
Onkyo HT-SR800 7.1
Samsung LN32C530F1F
JOE.G is offline
post #4032 of 4042 Old 03-12-2011, 06:56 AM
JOE.G's Avatar
How should the other settings be set, such as HDMI levels and Black levels and what not? Picture detail normal or fine and so on.
Panasonic DMP BD55
Onkyo HT-SR800 7.1
Samsung LN32C530F1F
JOE.G is offline
post #4033 of 4042 Old 06-29-2011, 03:54 PM
JOE.G's Avatar
When Was the last Firmware Released? Will there be more? My Guess is not which sucks because this has been a great player for me, I have this along with the 55 and the 85 and this is my most used one out of all of them.
Panasonic DMP BD55
Onkyo HT-SR800 7.1
Samsung LN32C530F1F
JOE.G is offline
post #4034 of 4042 Old 10-11-2011, 06:34 PM
rayven's Avatar
I have my BD10A set up to play the high res audio through HDMI using PCM. My receiver is a Yamaha RX3900 and verifies 7:1 as does the Blue Ray player using test tones. I can only get the player to pass 5:1 high res such as Dolby True HD. I do the disc set up for 7:1 and only 5:1 passes via PCM. I should mention the back surround work fine when using Dolby EX. Any suggestions would be greatly appreciated.
Yamaha RX3900
JBL Studio 590 7:1
SVS Ultra PB 13
Sharp LC70LE857U
Sony SACD
rayven is offline
post #4035 of 4042 Old 10-11-2011, 07:59 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 397
Most discs only contain 5.1 sound track. Are you sure you are playing a disc with 7.1 sound tracks. 7.1 TrueHD and DTS-HD are very rare. On some newer Panny players, Panasonic also restrict the decoding capability in software to 5.1 max for low end players so that they can force you to pay more for mid or higher end versions.
But yours is pretty old version. Such limit wasn't imposed back then.
Foxbat121 is offline
post #4036 of 4042 Old 10-12-2011, 06:56 PM
rayven's Avatar
Chris Botti in Boston is Dolby True HD 7:1.
Yamaha RX3900
JBL Studio 590 7:1
SVS Ultra PB 13
Sharp LC70LE857U
Sony SACD
rayven is offline
post #4037 of 4042 Old 11-01-2012, 04:17 PM
robotec's Avatar
I just purchased a used Panasonic DMP-BD10 Blu ray player and the only Blu ray it will play is Pandorum. The rest gets a read disc error. I checked the Panasonic site and the latest firmware is v2.5. The player is already updated to V2.5. Any suggestions? I only paid 10.00 for the player, so if its broken no big lose. Just weird it only plays Pandorum.
I'm not snobbish and uninformed.
robotec is offline
post #4038 of 4042 Old 11-01-2012, 08:49 PM
RichGuy's Avatar
Sounds like it may have been priced so low for a reason, I have a Panasonic DMP-BD10A and have never had a disc it wouldn't play, it's always been a great player.
When I die I want to go peacefully, in my sleep like my grandfather did, not screaming and scared like the other three people in his car!
RichGuy is offline
post #4039 of 4042 Old 11-01-2012, 08:58 PM
My guess would be that either the reader is dirty or dying. A cleaning might yield you a player...???
post #4040 of 4042 Old 11-02-2012, 12:32 PM
JOE.G's Avatar
My BD 10 A is still going strong, I love this play I used it more then any of my others, It's load times aren't the fastest but it does well, the only disc I could not get it to play was Avatar.
Panasonic DMP BD55
Onkyo HT-SR800 7.1
Samsung LN32C530F1F
JOE.G is offline
post #4041 of 4042 Old 12-29-2015, 07:02 AM
sdlehman's Avatar
I watched Minions on my BD10 yesterday with my grand daughter. Amazing this player can play the newest discs while all over this forum you hear about players less than half its age needing firmware updates or to be replaced altogether. I'm sure I have discs this player would be unable to play but I was pleased we were able to watch this movie without incident. Load times were sluggish but I can live with that.
Stace
sdlehman is offline
post #4042 of 4042 Old 12-29-2015, 04:09 PM
JOE.G's Avatar
Still to this day my most used player, I run into a disc here or there that it can't play but not often.
Panasonic DMP BD55
Onkyo HT-SR800 7.1
Samsung LN32C530F1F
JOE.G is offline
Reply Blu-ray Players
Panasonic Dmp Bd10 Blu Ray Disc Player Upscaling
