Panasonic DMP-BD10, 10A Setup/Tweaks/Settings Thread - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 4042 Old 12-29-2006, 12:04 AM
michaelffm75's Avatar
Hello,
at first - sorry for my bad english - i hope i can explain my problem with
the Panasonic BD Player...
My combination is BD->Yamaha 2600->HC3100
When i set up the Panasonic to 720p and turn it off
then next day - the settings will be at "automatic"
Pani will not remember these settings - why?
can anyone test this with another Panasonic?
thanks and greetings from germany
Michael
michaelffm75 is offline
post #182 of 4042 Old 12-29-2006, 10:21 AM
ThomasW's Avatar
Hi all,
I have read and searched this thread and some of the reviews of this player, and come to the following conclusions about some matters:
1. The included remote leaves a lot to be desired, but can be substituted for a backlit and more handy remote like the Harmony 880 for example.
2. The component output will give 1080p, but NOT when upconverting a SD DVD.
3. The built in fan does not have a disturbing or intruding noise level.
True?
Thomas
ThomasW is offline
post #183 of 4042 Old 12-29-2006, 10:23 AM
bferr1's Avatar
Quoted: 87 Post(s)
Liked: 92
Originally Posted by ThomasW View Post
Hi all,
True?
Thomas
1. True on both counts. I have an 880 and it works perfectly with the Panny. I had to program it myself, though, as the Panny model number somehow corresponds to a DVD recorder profile in Logitech's database.
2. Not sure about component 1080p output, but SD DVD limitation is correct.
3. True.
bferr1 is offline
post #184 of 4042 Old 12-29-2006, 10:29 AM
ThomasW's Avatar
Thanks bferr1,
I still have to make my mind up about what format to choose, but if BD the Panny will be the player of choise.
Thomas
ThomasW is offline
post #185 of 4042 Old 12-29-2006, 10:31 AM
bferr1's Avatar
Quoted: 87 Post(s)
Liked: 92
Thanks bferr1,
Thomas
You bet. If you have any questions, just shoot. An informed choice is the best choice you can make.
bferr1 is offline
post #186 of 4042 Old 12-29-2006, 10:39 AM
ThomasW's Avatar
Available movie titles in the future will be important to me, currently BD seems to have an advantage there with larger studio support.
I am curious to what a distributor like Criterion Collection will choose for their HD format, that will be an important factor for me.
Thomas
ThomasW is offline
post #187 of 4042 Old 12-29-2006, 02:06 PM
m1fuller68's Avatar
I have the panny blu-ray player. To the other owners, when you put in a movie do you get a loud accessing sound before the movie starts. I had the toshiba HD DVD and don't remember a sound like this. It almost sounds like a computer harddrive accessing data. Any thoughts?
m1fuller68 is offline
post #188 of 4042 Old 12-29-2006, 02:55 PM
avbiae's Avatar
Hello, i am from Spain, and yesterday bought a DMP-BD10. I have connected to a TV with DVI-HDMI Cable. And I cant change the resolution in HDMI menu, it was selected always in Auto. I want to compare the image from 720p to 1080i.
Also, in the movie Fantastic 4 (the only one that i have), the image goes slow sometimes.
What can I do, is it normal all this?
avbiae is offline
post #189 of 4042 Old 12-29-2006, 03:39 PM - Thread Starter
jacksonian's Avatar
Yes, it does make an access noise on initial read, but I never hear it after that. I have the Toshiba A2 and although it makes a little access noise, not as loud as the Panny. It's normal.
jacksonian is offline
post #190 of 4042 Old 12-29-2006, 10:14 PM
CraigN's Avatar
I am hoping that Panasonic will release a firmware update to enable its otherwise excellent Ist generation Blu Ray player to output 1080p-24 directly.
This is in order to eliminate the 3:2 pulldown steps inherent in a 60Hz signal. The first Blu-ray and HD DVD players output 60Hz signals. The very latest (Pioneer and Sony) also have "source direct outputs at 1080p-24Hz).
Are there others keen for this?
How could we best inform Panasonic that we want this feature?
CraigN is offline
post #191 of 4042 Old 12-30-2006, 10:07 AM
m1fuller68's Avatar
Thought so...Thanks
post #192 of 4042 Old 12-30-2006, 10:54 AM
GoldenBoy's Avatar
Quoted: 34 Post(s)
Liked: 26
Originally Posted by Franchot View Post
I also haven't had all the audio problems using analog inputs mentioned in the article except the subwoofer level is too low and needs to be boosted.
I agree. The LFE is a bit anemic on the Panny out of the analogue outs.
Also this:
I have no problem bring up the test patterns on the Sony discs I've tried.
Neither do I, but I don't use the Panny remote, I use a Sony RM-AX4000. I can't recall if I ever tried using the supplied remote to bring up the test patterns.
I also have some suggestions for features I'd like them to add in the next FW update: I'd like to be able to see the current video bitrate and codec, and also the audio codec/bitrate.
Brandon A. DuHamel
Founder & Editor-in-Chief
TheaterByte
GoldenBoy is offline
post #193 of 4042 Old 12-30-2006, 01:49 PM
bferr1's Avatar
Quoted: 87 Post(s)
Liked: 92
Some receivers can compensate for this by boosting the analog SW signal by 10dB. My Pioneer receiver can do it, and the analog audio sound unbelievable!
bferr1 is offline
post #194 of 4042 Old 12-31-2006, 10:26 AM
ndjr's Avatar
I hope that to, but do anyone know if it`s even technical possible to do it? or is there some hardware limitation???
ndjr is offline
post #195 of 4042 Old 12-31-2006, 11:54 AM
GoldenBoy's Avatar
Quoted: 34 Post(s)
Liked: 26
I have the 10db boost turned on in my receiver, and the Panasonic is still thin, that's the problem. I'm not really complaining, mind you, I think the Panasonic sounds great, it's just that its LFE sounds a little weak in comparison to all my other components when using the analogue outs or when going through the digital outs and letting my A/V receiver decode. Unfortunately, the DMP-BD10 offers no way to boost the sub's output in the multichannel setup, only to lower it.
Brandon A. DuHamel
TheaterByte
post #196 of 4042 Old 12-31-2006, 02:21 PM
CraigN's Avatar
re: 1080p-24 output upgrade to Panasonic
I thought that I read somewhere that it should be technically possible. Any experts out there?
CraigN is offline
post #197 of 4042 Old 12-31-2006, 04:54 PM
divedude's Avatar
Can anyone tell me if the fan on the player comes on when they turn the unit on or does it wait to come on after the unit heats up?
Dive deep, play with sharks.
So long and thanks for all the fish . . .
divedude is offline
post #198 of 4042 Old 01-01-2007, 07:58 AM
steviec's Avatar
the fan will only come on if the unit gets too warm.
steviec is offline
post #199 of 4042 Old 01-01-2007, 11:18 AM
Franchot's Avatar
Quoted: 210 Post(s)
Liked: 165
Yes, that would be the perfect solution if the Panasonic Blu-ray player allowed you to boost the SW signal.
I have a later model Pioneer and I approached the problem by turning up the signal on my subwoofer which is the now my "default" setting. The Blu-ray discs using analog sound wonderful this way. Then, I went into the receiver's set-up menu and lowered the subwoofer signal for all my digital connections which I use for my music/HD DVD/DVD media.
Franchot is offline
post #200 of 4042 Old 01-01-2007, 12:39 PM
bferr1's Avatar
Quoted: 87 Post(s)
Liked: 92
My experience with the analogs happily has been very different. There's only one other thing I could suggest doing if you're not already doing it. Make sure that HDMI Audio Output is turned off under the HDMI tab in the Setup menu, as leaving it on negatively affects analog output.
bferr1 is offline
post #201 of 4042 Old 01-01-2007, 01:47 PM
GoldenBoy's Avatar
Quoted: 34 Post(s)
Liked: 26
Unfortunately, not only is my Panasonic sharing the 7.1 analogue inputs on my receiver with my Denon DVD-2200 universal via a Zektor 5.1 multichannel switch (the two surround back channels from the Panny go directly to the receiver) but my receiver also has a set of 5.1 analogue inputs into which I have a Sony SCD-XA9000ES SACD/CD player connected. Boosting the sub solely for the Panasonic is not an option. I'm thinking what I may do is lower the other channels in the Panasonic by 3db, that way, on playback the LFE will be 3db louder than everything else, but I would just have to turn the A/V receiver up louder by 3db when using the Panasonic's analogue output.
Brandon A. DuHamel
TheaterByte
post #202 of 4042 Old 01-01-2007, 01:47 PM
GoldenBoy's Avatar
Quoted: 34 Post(s)
Liked: 26
This is how I have it set.
Brandon A. DuHamel
TheaterByte
post #203 of 4042 Old 01-01-2007, 01:58 PM
GoldenBoy's Avatar
Quoted: 34 Post(s)
Liked: 26
I've also noticed that when setting the speaker sizes in a 7.1 setup, the Panasonic will not allow me to set the surround and surround back speakers to different sizes. This is a problem for me, as I use two satellites for my surround back L/R speakers and need them to be set as 'small', but set everything else as large. Has anyone else noticed this?
Brandon A. DuHamel
TheaterByte
post #204 of 4042 Old 01-01-2007, 02:13 PM
divedude's Avatar
Thanks for the confirmation
divedude is offline
post #205 of 4042 Old 01-01-2007, 10:34 PM
bferr1's Avatar
Quoted: 87 Post(s)
Liked: 92
Hmm. Still trying to find ways to resolve your LFE problem, because I am having totally different results with the same player. You've probably done this already, but Dynamic Compression and BD Button Sound are off? These also impact audio negatively.
Beyond that, I'm out of ideas.
bferr1 is offline
post #206 of 4042 Old 01-02-2007, 07:45 AM
GoldenBoy's Avatar
Quoted: 34 Post(s)
Liked: 26
Yep, I've done all of that. Don't get me wrong, I'm not saying that the Panasonic sounds bad, just that the LFE sounds a bit weak. I'm thinking the solution may be the last option I posted - to lower all the other channels thereby leaving the LFE a bit higher than everything else.
Now, the other problem I have, for which I see no solution, is the fact that it will not allow me to set the surround and surround back channels as different sizes. Now, this is one setting that really makes no sense to me whatsoever. I suppose I have no option but to set them both to 'small', as my surround back L/R are both micro- satellites and setting them as 'large' is not an option whatsoever.
Really, the BM an time alignment in the DMP-BD10 is some of the worst I've ever seen, IMO. There's no ability to set the delay/distance for the sub, no ability to boost the LFE; you can't set the surround and surround back speakers to different sizes - who thinks these things through?
On another note, does anyone know what the crossover is in the Panny when all speakers are set to large?
Brandon A. DuHamel
TheaterByte
post #207 of 4042 Old 01-02-2007, 07:49 AM
bferr1's Avatar
Quoted: 87 Post(s)
Liked: 92
I think it's set at 100, with no ability to raise or lower it.
bferr1 is offline
post #208 of 4042 Old 01-02-2007, 08:16 AM
GoldenBoy's Avatar
Quoted: 34 Post(s)
Liked: 26
The crossover is 100 when all speakers are set to large? Isn't that sort of high? I thought it was around 160 or something when set to small, 100 when set to large seems odd.
Brandon A. DuHamel
TheaterByte
post #209 of 4042 Old 01-02-2007, 09:03 AM
Wendell R. Breland's Avatar
Quoted: 288 Post(s)
Liked: 158
If all speakers are set to large (as in full range) then there should no crossover.
Wendell R. Breland is offline
post #210 of 4042 Old 01-02-2007, 12:36 PM
GoldenBoy's Avatar
Quoted: 34 Post(s)
Liked: 26
Doh! That's true. Dumb question on my part.
Brandon A. DuHamel
TheaterByte
Reply Blu-ray Players
Panasonic Dmp Bd10 Blu Ray Disc Player Upscaling
