PS3 Objective Measurements - Page 6 - AVS Forum | Home Theater Discussions And Reviews
post #151 of 166 Old 01-19-2007, 04:57 PM
Gary Murrell's Avatar
thanks Kris, that is one step up on the Panny for sure, I am sure they will get to CUE
after comparing the Sony vs the Sammy in my setup yesterday, I would just about be willing to say that the Sony does NOT have CUE, almost certain of it, I was using Transporter 2 as my demo, with the HD formats one doesn't realize how bad CUE is until you see it without, very different appearance and showing vs SD DVD IMHO
we certainly need CUE free HD and BR players, it's like you take the color palette and up it by 200%, it is that much better
a good example of nice CUE free playback is the JVC 5u DVHS deck, what a HDMI output on that thing
CUE never sucks until you see the problem and see a player that is not affected
-Gary
Gary Murrell is offline
post #152 of 166 Old 01-20-2007, 10:03 AM
plasmabuyer's Avatar
If we are talking here about PS3 not passing BTB and WTW for v1.32, then I can say based on my experiment yesterday that yes, PS3 still clips these signals.
On Sony BD's, the easter egg allows you to launch test patterns to check for pluge patterns as well as resolution, display overscan, color settings etc.
When I used the patterns found on UE, I could not see the 3 distinct shades of black under the RED color bar. I was only able to see a dark gray bar and when I turned the brightness on my 70" SXRD all the way up - it washed away.
According to the info. posted here, am I not supposed to see 3 distinct shades of "BLACK" - SuperBlack, Black, and somewhat Black(the bar I could see)???
plasmabuyer is offline
post #153 of 166 Old 01-20-2007, 11:47 AM
Moderator
Moderator
PooperScooper's Avatar
Quoted: 322 Post(s)
Liked: 6367
Yes, people are hoping the supposed March firmware update will address this. I'm not holding my breath. At least it doesn't appear to be outputting PC RGB.
larry
Eu estou aqui e você é meu sofá
PooperScooper is offline
post #154 of 166 Old 01-20-2007, 01:27 PM
larry
How many things will Sony be fixing with this upgrade???!!?? It seems like every problem discussed here gets a holy grail answer of potential fix in the March fix?
post #155 of 166 Old 01-20-2007, 01:36 PM
dialog_gvf's Avatar
-Gary
It's not an issue until someone points it out, and then it's all you can see.
(Another) Gary
- Don't trust sigs
dialog_gvf is offline
post #156 of 166 Old 01-20-2007, 06:17 PM
Kris Deering's Avatar
Quoted: 2018 Post(s)
Liked: 3151
CUE should be fixable for the Panasonic because it didn't have it with the original firmware. I confirmed this with a player that wasn't upgraded yet compared to a newer updated one. So if firmware can cause it, it can get rid of it.
My Home Theater
Kris Deering is offline
post #157 of 166 Old 01-21-2007, 12:55 AM
DavidHir's Avatar
Quoted: 1944 Post(s)
Liked: 1583
Kris, any idea if the black and white clipping on the PS3 can be fixed via firmware?
DavidHir is offline
post #158 of 166 Old 01-22-2007, 03:26 PM
curlyjive's Avatar
Quoted: 534 Post(s)
Liked: 246
I don't want to answer for anyone else: But my opinion is Yes it CAN be fixed. I see no reason why it can't be. The question is will Sony make that a priority fix for their game console. I am sure they would rather have you buy a new standalone
curlyjive is offline
post #159 of 166 Old 01-23-2007, 07:23 AM
Liked: 3151
No reason it shouldn't be fixable.
My Home Theater
post #160 of 166 Old 01-23-2007, 07:59 AM
TauRus's Avatar
Originally Posted by DaViD Boulet View Post
Back to the original post for a moment...
That measurement was taken with the PS3 in RGB mode. The new 1.3 update allows the PS3 to output Y/Cr/Cb (I'm not sure if 4:2:2 or 4:4:4). That may make a difference. Will a retest be in order?
I have the PS3 and love it. Looking foward to the 1080p24 update and, hopefully, the ability to downscale/upscale all material to any desired setting like 720P, 1080i, or 720P. I'd like to run native 720P into my 720P PJ to avoid bobbing deinterlacing from 1080i signals until I can upgrade to a native 1920 x 1080 projector for 1080p.
Kris or Stacey,
Are you planning to run the tests on PS3 in Y/Cb/Cr mode? It would be interesting to see if those generate any different results.
In Blu-Ray Veritas!
TauRus is offline
post #161 of 166 Old 01-23-2007, 10:50 AM
Liked: 3151
Would love to, but it won't play my test disc (BD-RE). I believe Stacey's is BD-R and it will play that one, so maybe he can do it.
My Home Theater
post #162 of 166 Old 11-18-2007, 06:52 AM
Sam S's Avatar
Quoted: 218 Post(s)
Liked: 107
Sorry to bump up this old thread, but I am very confused by Stacey Spears' first post:
Is the most accurate setting (i.e. Rec.709 colorspace) obtained by setting HDMI output to RGB or YCbCr?
Sam S is offline
post #163 of 166 Old 11-18-2007, 07:26 AM
Moderator
Moderator
Quoted: 322 Post(s)
Liked: 6367
For one, the measurements are very old and some of the issues have been fixed with subsequent firmware. RGB vs YCbCr shouldn't affect the output color space.
larry
post #164 of 166 Old 11-18-2007, 09:59 AM
dc_pilgrim's Avatar
larry
I saw these posts in another thread that suggest that YCbCr is preferable:
Originally Posted by Marc Alexander View Post
Also, if you are PS3 user you will always want to use Y Pb/Cb Pr/Cr for this simple fact:
Y Pb/Cb Pr/Cr Super-White enables the PS3 to pass BTB and WTW with Blu-ray. BTB and WTW are never passed with Blu-ray when set to RGB.
Best PS3 settings for displays that accept Y Pb/Cb Pr/Cr over HDMI:
Output - Y Pb/Cb Pr/Cr
RGB Full Range - Limited
Y Pb/Cb Pr/Cr Super-White - On
dc_pilgrim is offline
post #165 of 166 Old 11-18-2007, 10:13 AM
Sam S's Avatar
Quoted: 218 Post(s)
Liked: 107
Thanks for that info, dc_pilgrim.
Sam S is offline
post #166 of 166 Old 11-18-2007, 02:05 PM
Moderator
Moderator
Quoted: 322 Post(s)
Liked: 6367
Actually, I use RGB on my PS3 and it passes BTB and WTW just fine with limited range and super white on. However, I'm still running the first FW version that fixed the clipping. When newer versions came out I recall discussion about how behavior changed. I never upgraded because "if it ain't broke, don't fix it". If the PS3 is working correctly, it shouldn't matter if you pick RGB or YCbCr. Just 2 different ways to describe the same pixel info.
larry
Reply Blu-ray Players
