Just received PS3 BD Remote - AVS Forum | Home Theater Discussions And Reviews
Old 12-14-2006, 05:06 PM - Thread Starter
Bill0711's Avatar
I received the Japanese version from NCS Inc. for $39. All the labels on the remote are in English (see attached jpg), but the instructions are in Japanese which does me no good. I am using it with a US 20GB PS3 1.31 firmware. The package includes 2 AA batteries and the remote weighs 5 ozs incl the batteries. To install select Settings, Accessory Settings, Register Bluetooth device, Register BD remote control and hold the Start and enter keys on the remote for five seconds. The PS3 is very responsive to the remote. Being bluetooth the range of the remote is very good, I tested from about 50 feet from a different room with the doors closed and had no problems, you could probably hide your PS3 away and still control it. You can also turn the PS3 on and off by pressing the Playstation button on the remote for about 2 seconds. I have no idea if the remote would have any use with games but it looks good for media, if you can accept its lack of IR.
Bill0711 is offline
Old 12-14-2006, 05:20 PM
MRMOTA's Avatar
So how long before you got it? Are you in the states? What shipping did you spring for? Thanks
MRMOTA is offline
Old 12-14-2006, 05:34 PM
joerod's Avatar
Quoted: 607 Post(s)
Liked: 487
Cool. Thanks for the info. I was thinking about getting one if I get a PS3...
My Sony 5000ES Review PART 2 FINISHED:
http://hstrial-jrodriguez996.homeste...=1462841668379
joerod is online now
Old 12-14-2006, 05:45 PM - Thread Starter
Bill0711's Avatar
ordered from http://ncsx.com/ located in Brooklyn, shipped UPS ground for $7, from Brooklyn to Great Neck is about 10 miles so it took one day
Bill0711 is offline
Old 12-14-2006, 05:49 PM
MRMOTA's Avatar
Thanks I'm getting one.
MRMOTA is offline
Old 12-14-2006, 08:47 PM
jayselle's Avatar
Quoted: 26 Post(s)
Is battery life mentioned anywhere? I know infrared remotes can last years with one set of batteries as it doesn't take much power to send out short IR blasts. This remote has to maintain a bluetooth link constantly which would seem to drain the battery quickly. Unless the remote connects the transmits the command in which case it would seem there would be a lag.
jayselle is offline
Old 12-14-2006, 09:59 PM
chokeslam's Avatar
That's weird that they have buttons for L1, L2, L3, R1, R2, R3. I know L1 and R1 are backward chapter skip and forward chapter skip, respectively, but there are already buttons for those functions on the remote... I remember trying the other 4 while watching a BD tonight and they did nothing.
chokeslam is offline
tcpipkim's Avatar
When can purchase PS3 remocon in usa?
tcpipkim is offline
Old 12-15-2006, 01:11 AM
John Haghighi's Avatar
I am hoping someone with a pronto will post the remote codes
John Haghighi is offline
Old 12-15-2006, 05:44 AM
KCWolfPck's Avatar
Is there a Pronto that is Bluetooth compatible? The PS3 doesn't have any IR ports so a programmable remote isn't going to do anything for you. What good would the remote codes be? Just curious.....
KCWolfPck is offline
Old 12-15-2006, 06:19 AM
ArthurL's Avatar
You are correct, it won't work with the Pronto, or Harmony remote, for that matter since those remotes use IR, not Bluetooth.
ArthurL is offline
Old 12-15-2006, 06:27 AM
ihyln's Avatar
just ordered one, hopefully it will arrive quickly!
ihyln is offline
Old 12-15-2006, 06:58 AM
Dave-Blu-Ray's Avatar
Great! 10x for the info
Blu-ray is the way!
Dave-Blu-Ray is offline
Old 12-15-2006, 07:20 AM
inca's Avatar
To tell the truth, I can navigate the DVD functions witht he remote controll as quickly as I can with any DVD Remote. I don't think there is a reason for me to upgrade right now, other then people looking at me funny when I use the PS remote to access DVD stuff
inca is offline
Old 12-15-2006, 07:23 AM
Adam_ME's Avatar
Quoted: 35 Post(s)
Is this available in the states yet? If not, when is it due out and what's the reported list price?
Adam_ME is offline
Old 12-15-2006, 08:19 AM
ckenisell's Avatar
Quoted: 110 Post(s)
Liked: 62
I assume you can do everything with this remote that you can do with the pop-up hover menu that comes up when you press the triangle button on the controller. The only difference is that I can use this remote to never have to see the pop-up hover menu. That would be great!
Chet
ckenisell is offline
Old 12-15-2006, 02:35 PM
jhimmel's Avatar
Brooklyn is "in the states".
jhimmel is offline
Old 12-15-2006, 03:53 PM
Adam_ME's Avatar
Quoted: 35 Post(s)
I meant the US version of the remote.
Adam_ME is offline
Old 12-15-2006, 04:10 PM
bdshort's Avatar
I can't imagine what would be different except it would have an english manual, from what the OP said. I'll think about getting one of these, but I would rather hold out till someone comes out with an IR receiver, and buy something like the Harmony so I can use it with all of my other devices.
PSN: bdshort
bdshort is offline
Old 12-15-2006, 04:13 PM
ArthurL's Avatar
Hmm, IR through the USB ports on the front...something similar to the Saitek DVD remote on the PS2. Let's keep our fingers crossed.
ArthurL is offline
Old 12-16-2006, 03:54 PM
pifemaster's Avatar
Thank to the OP for the info. I just ordered one today (although temp out of stock).
Bob
pifemaster is offline
Old 12-19-2006, 02:27 PM
stepmback's Avatar
If you go to the Harmoney login and search for PS3, you can load the functions to the PS3 to the 880. However thoug it does state on the site that the remote does not work with bluetooth. So why did harmoney even bother offering this device?
stepmback is offline
Old 12-19-2006, 06:17 PM
dauthum's Avatar
Hey guys just looked on the ps forum and they said there is a usb to ps2 controller adapter at radioshack. My guess is if you have the old remote for the ps2 you could always use it's sensor with the harmony(as stated just a guess).
dauthum is offline
Old 12-19-2006, 08:18 PM
playitloud's Avatar
are there any bluetooth compatible universal remotes out right now? That to me seems like the answer to all our problems.
playitloud is offline
Old 12-19-2006, 10:18 PM
jayselle's Avatar
Quoted: 26 Post(s)
I think this is hack. You still have to control the PS3 with the sixxaxis controller until the actual movie is playing.
The remote will need to act like a normal remote such as powering the unit on and off.
jayselle is offline
Old 12-20-2006, 05:05 AM
avshaman's Avatar
Looks great! Even though I can use the PS3 controller as effectively as any DVD player remote I think I will still get one of these.
avshaman is offline
Old 12-20-2006, 05:11 AM
Nike-Air's Avatar
Probably in anticipation of an IR receiver being released to plug into the USB port at some point.
Nike-Air is offline
Old 12-20-2006, 05:36 AM
michael000's Avatar
Not a bad little remote, will probably pick one up depending on the price. Normally price wouldn't be an issue but i'm guessing this one is as thin and that the buttons are as tiny as they were on the official Sony PS2 DVD remote. No way i'm paying over $20 for one given those reasons as well as the fact that it's severely lacking compared to what you get with the X360 universal remote, and that retails for $29.
Still pretty dumbstruck that my TV, DVD player, and PS3 (possibly stereo as well in the near future) are all made by Sony but i can't purchase a single remote that will work them all.
michael000 is offline
Old 12-20-2006, 05:38 AM
cdub998's Avatar
Sony did that with the ps2 remote also. Its because you can technically use the remote to play games. Though I have no idea why you would want to.
Xbox 360 gamertag: Cdub998
PSN: cdub998
cdub998 is offline
Old 12-20-2006, 10:27 AM
WriteSimple's Avatar
Maybe this is SCE's introduction to a Wiimote for the PS3?
Just speculating. Though an eletronic gyroscope built-in to the BD remote would be a far fetched idea.
fuad
"DonÂt let them tell you who you are is not enough, that itÂs wrong and that you wonÂt find love. DonÂt let them use my life to put your future down, or tell you that happiness canÂt be found."
WriteSimple is offline
