PS3 update question - AVS Forum | Home Theater Discussions And Reviews
Old 01-04-2007, 11:09 AM - Thread Starter
jbug's Avatar
Quoted: 248 Post(s)
Liked: 127
Mine is version 1.31. I hear there is a 1.32. I don't have broadband so is Sony providing a update disc like Toshiba?
jbug is offline
Old 01-04-2007, 11:42 AM
brad31's Avatar
You can download updates onto a flash USB drive and use that to upgrade the PS3. Instructions can be found in the Playstation area of the gaming forum. It is very easy to do and only takes a couple of minutes for a PC to download the update.
brad31 is offline
Old 01-04-2007, 11:57 AM
dsg2003gt's Avatar
I have update # 1.32.
dsg2003gt is offline
Old 01-04-2007, 12:49 PM - Thread Starter
jbug's Avatar
Quoted: 248 Post(s)
Liked: 127
Thanks, the manual was not as clear as your responses.
jbug is offline
Old 01-04-2007, 02:12 PM
dsg2003gt's Avatar
if you have it connected to the internet go to settings and then update firmware, it will check and see if you have the most current version and then will update if you dont.
