Panasonic DMP-BD10 - 1.4 firmware... - Page 8 - AVS Forum | Home Theater Discussions And Reviews
post #211 of 232 Old 03-10-2007, 11:35 PM
oink's Avatar
Quoted: 5299 Post(s)
Liked: 3035
Originally Posted by sharkshark View Post
Heres an idea - DTS Lossless.
That's too easy...
Stop making sense!!!
oink is offline
post #212 of 232 Old 03-11-2007, 12:25 AM
eightninesuited's Avatar
Quoted: 13 Post(s)
This is something that I was worried about when DTS released their specs and names.
It is an utterly retarded thing to do by naming a lossy and lossless codecs that are so similar! I have to give DTS the double middle finger salute here.
Let's pray that we aren't stuck with 1.5 lossy cores forever on the Fox tracks because DTS might have to overhaul the entire thing.
No animals were harmed in the creation of this sentence.
eightninesuited is online now
post #213 of 232 Old 03-11-2007, 07:20 AM
Schlotkins's Avatar
Originally Posted by kjack View Post
What exactly does their audio codec upgrade note say? Does it say DTS-HD, DTS-HD HR, or DTS-HD MA?
kjack-
Any idea when players with your new chip could be expected on the market?
Chris
Schlotkins is offline
post #214 of 232 Old 03-11-2007, 08:25 AM
SimpleTheater's Avatar
Quoted: 202 Post(s)
Liked: 94
Originally Posted by SimpleTheater View Post
Correct. When I get Crank (hopefully tomorrow - but Saturday the latest) I'll run it using the PCM soundtrack via analog outputs. You and I are both hoping the Panny will split the rear track into two mono rear tracks so that we get sound from both the rear speakers. I'll report back as soon as I find out.
Good news! Watched Crank yesterday and the BD10 does take the one rear channel and splits it into two mono rear channels. You won't hear sound out of only one speaker.
Why is there NO perfect equipment, only compromises?
SimpleTheater is offline
post #215 of 232 Old 03-11-2007, 09:27 AM
sharkshark's Avatar
Quoted: 14 Post(s)
...are you talking with analog or HDMI? I'm about to watch it in an hour (with analogue), so that'll be good to know...
sharkshark is offline
post #216 of 232 Old 03-11-2007, 12:18 PM
Erik van Voorst's Avatar
SimpleTheater can you Simplify this......
Are you trying to say...that the Rear Center on a 6.1 soundtrack is matrixed to your Left and Right Rears....
And if so how do you come to this conclusion in other words how do you know what Rear Center effects gets matrixed...since the Left and Right Rear get there own information probably very often at the same time.....
By choosing DTS 6.1 on the X/men 3 dvdmenu...the Panny menu states
DTS Multichannnel....I rather wish it stated DTS 5.1 cause that is the endresult for the time being until the firmware........now I come to think of it ..there has not been made any promisses concerning 6.1 let alone 7.1......
Erik van Voorst is offline
post #217 of 232 Old 03-11-2007, 02:24 PM
TomsHT's Avatar
The Panny box simply stated DTS-HD and didnt specifically say master but I'm sure it hasnt gone un-noticed that the members here have specifically been posting and expecting the master audio firmware for many months now. I wonder why it took so long for someone to point out that it was incapable of this
TomsHT is offline
post #218 of 232 Old 03-11-2007, 04:17 PM
Quoted: 202 Post(s)
Liked: 94
I'm using analog out on the BD10 - not HDMI or optical. The Panny is not matrixing anything - something you get when a 5.1 track is matrixed to 7.1. What the Panny is doing is on a track where there is a single rear signal (e.g. 6.1 like Crank) it splits the rear channel and outputs two equal MONO signals. Some of us using the analog outputs were concerned that only the LEFT (or maybe only the RIGHT) would get the rear track - making for an annoying rear sound field.
Hope that simplifies it.
post #219 of 232 Old 03-11-2007, 04:40 PM
Yep I get it...I understood you correct only I use the term matrix here incorrect sorry
I do hope that it will be one of the first things they will solve .....
BTW how did you find out that Panny solved the 6.1 flaw in this way....
post #220 of 232 Old 03-11-2007, 06:29 PM
alfbinet's Avatar
I can get it by going to the main unit but remote doesn't list open/close option, manual for basic play tells you to go to main unit. Downloaded codes for my Harmony 880 and "eject" doesn't work from that. What am I missing? Other codes via Harmony seem to work fine.
Chad Billheimer rocks as a ISF Calibrator for Ohio.
Roller Coaster season is upon us. Proud member of American Coaster Enthusiasts (ACE) Woodies Rule!
alfbinet is offline
post #221 of 232 Old 03-11-2007, 07:20 PM
Quoted: 202 Post(s)
Liked: 94
What flaw are you talking about?
post #222 of 232 Old 03-11-2007, 09:30 PM
bferr1's Avatar
Quoted: 87 Post(s)
Liked: 92
You can't eject by remote. It's a safety precaution in case you tried ejecting while the flip-down front panel was still up.
bferr1 is offline
post #223 of 232 Old 03-12-2007, 08:51 AM
alfbinet's Avatar
That explains it. No wonder I coudn't find anything in the manual or my Harmony "eject" didn't work.
Thank you for the heads up!
alfbinet is offline
post #224 of 232 Old 03-31-2007, 12:10 PM
Super Moderator
markrubin's Avatar
Quoted: 1035 Post(s)
Liked: 2273
unstuck
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess
HDCP = Hollywood's Draconian Copy Protection system
markrubin is offline
post #225 of 232 Old 04-01-2007, 05:09 PM
sharkshark's Avatar
Quoted: 14 Post(s)
well, it's April, so we're all expecting expectantly the new FW update for this player... maybe this thread can also house discussion of the new FW as well (meaning it may just yet be "stuck" again...)
post #226 of 232 Old 04-01-2007, 06:12 PM
drbonbi's Avatar
Although I registered my BD10 with Panasonic, I never received an email from them - let alone one that said the BIG firmware update would be available in April. I guess I'll believe it when I see it.
Dana
"If you think you can, or think you can't, you're probably right." Mark Twain
drbonbi is offline
post #227 of 232 Old 04-02-2007, 03:28 PM
I WANT MORE's Avatar
Quoted: 399 Post(s)
Liked: 256
Dana
I sent my card in the day after I purchased my player and I have never received notice of a FW update. In fact when I have called or emailed they deny that one exists. I have had to rely on a fellow AVS menber to send me his disc.
Perhaps I misremembered.
I WANT MORE is offline
post #228 of 232 Old 04-02-2007, 04:01 PM
Coastsider's Avatar
There was a seperate card other than the warranty card included with my BD10 which was specifically for receiving a free FW update CD. Although I've had the BD10 for almost two months now, the card turned up about a week and a half ago and so I mailed it in even though I had already downloaded and installed v. 1.4. Late last week I received a letter, repeat letter, as in hard copy through the U.S. Mail, from Panasonic notifying me that there was to be a firmware update in April and that I should rest assured that I would receive a CD when they became available.
I can scan it an attach an image tomorrow if anyone thinks I'm kidding.
Coastsider is offline
post #229 of 232 Old 04-02-2007, 04:34 PM
thebland's Avatar
Quoted: 1490 Post(s)
Liked: 841
Here is a copy of the email I received after sending in the Panasonic firmware upgrade card:
Dear Customer,
Thank you for your interest in the Blu-ray software upgrade offer for your model number DMP-BD10. This software release is not scheduled until April 2007. We have your address on file and will be sending it to you as soon as it becomes available.
Sincerely,
Panasonic Fulfillment Dept.
It's back!! Wine of the Week! Clos Martinet Tinto, Priorat DOCa, Spain ~$60. If you've not had a good Priorat, you've not truly tried Spain's smallest, yet most unique terroir.
My Home Theater of the Month- Le Petit Trianon
thebland is online now
post #230 of 232 Old 04-02-2007, 05:10 PM
BreakPoint's Avatar
Guys, you don't need no stinkin' notification. Just keep checking this link. The Panny firmware updates appear here first. This is the Panasonic global site in Japan (in English)
http://panasonic.jp/support/global/c...d10/index.html
BreakPoint is offline
post #231 of 232 Old 04-02-2007, 05:35 PM
drbonbi's Avatar
Thanks. The issue I raised is whether Panny ever committed to an April 2007 BIG firmware update. thebland indicates that it did.
Dana
drbonbi is offline
post #232 of 232 Old 04-03-2007, 03:36 PM
alfbinet's Avatar
I had never burned an update disc in my life but had no problem burning the 1.4 update. I was very impressed with Panasonic on this issue.
alfbinet is offline
Reply Blu-ray Players
