Panasonic DMP-BD10 - 1.4 firmware... - AVS Forum | Home Theater Discussions And Reviews
Old 01-16-2007, 12:32 PM - Thread Starter
pixel_'s Avatar
- Picture Quality via HDMI
- Playability and stability
- Response of skipping operations
- Support of the dics recorded with Panasonic AVCHD Camcorders
check:
http://panasonic.jp/support/global/c...d10/index.html
pixel_ is offline
Old 01-16-2007, 12:47 PM
Gary Murrell's Avatar
sweet! I got get a look at a Panny
-Gary
Gary Murrell is offline
Old 01-16-2007, 01:40 PM
shamus's Avatar
Quoted: 23 Post(s)
Im confused.... This is not showing up on their regular site. It also looks like this firmware is older than the original. Anyone?
shamus is offline
Old 01-16-2007, 01:42 PM - Thread Starter
pixel_'s Avatar
The update site is the official pansonic site (firmware form 1/16/07... what firmware do you have?
pixel_ is offline
Old 01-16-2007, 01:45 PM
shamus's Avatar
Quoted: 23 Post(s)
Ive got the original firmware, but when I download this, my computer asks me if I want to replace with this, which shows a date of 12/05???? Im not very computer savy so....
shamus is offline
Old 01-16-2007, 01:55 PM
shamus's Avatar
Quoted: 23 Post(s)
Originally Posted by joshd2012 View Post
12/05/06 is later than the November release of the last update.
No... December2005.
shamus is offline
Old 01-16-2007, 02:11 PM
shamus's Avatar
Quoted: 23 Post(s)
Well, that should have been clue enough that the date was corrupted somewhere, or was replaced with info not pertaining to a date. When you stick the disc in your machine, it will know immediately if it is a new update or not.
Ok!!! I just had to purchase winrar... waiting for my order to go through!
shamus is offline
Old 01-16-2007, 02:53 PM
bferr1's Avatar
Quoted: 87 Post(s)
Liked: 92
When they say "Picture Quality via HDMI," I hope they're referring to the CUE on SDs.
bferr1 is offline
Old 01-16-2007, 03:04 PM
shamus's Avatar
Quoted: 23 Post(s)
You don't need WINRAR!
What do I need?
shamus is offline
Old 01-16-2007, 04:37 PM
dvdguru's Avatar
Can I download to a dvd or is it to cd only?
Elite PRO-70X5FD!
dvdguru
Xbox Live Gamertag: AVS Steve
dvdguru is offline
Old 01-16-2007, 05:26 PM
ottscay's Avatar
I just updated my player without a hitch (burned using default Windows software to a cd-r). I can also confirm while using the THX Optimizer that blacker than black is passed through, and the drop-shawod is very visible with black levels turned up. I haven't had time to check cue, but I'm already thrilled.
Hurray to Panasonic!!!!
ottscay is offline
Old 01-16-2007, 05:58 PM
Frank Stein's Avatar
Panasonic specifically states CD. Will it work with a DVD? Who knows. Will it screw anything up if you put in on a DVD? Who knows. You could try. Or you could just use a CD-r and not take any chances. If I didn't have a CDr around, I would go buy some before taking any chances with a DVD. You'll need more CDr's anyway for subsequent updates.
P.S. My Panasonic updated to 1.4 without a hitch from CDR.
Frank Stein is offline
Old 01-16-2007, 06:10 PM
dvdguru's Avatar
Thanks Frank, I won't take the chance on messing it up using a dvd.
Elite PRO-70X5FD!
dvdguru
dvdguru is offline
Old 01-16-2007, 06:22 PM
thebland's Avatar
Quoted: 1496 Post(s)
Liked: 847
Good news.
FWIW: I used a CD-R for the last update w/o a hitch.
It's back!! Wine of the Week! Clos Martinet Tinto, Priorat DOCa, Spain ~$60. If you've not had a good Priorat, you've not truly tried Spain's smallest, yet most unique terroir.
My Home Theater of the Month- Le Petit Trianon
thebland is online now
Old 01-16-2007, 06:30 PM
thebland's Avatar
Liked: 847
Any True HD / DTS HD on this release?
Old 01-16-2007, 06:43 PM
BreakPoint's Avatar
Updated to 1.4 with no problems.
The menus on "Descent" are as slow as always. However, pressing the chapter skip button responds very fast. The picture, which was already great, looks better with even more contrast and "pop". However, its hard to tell. Maybe it's just my expectations. We need someone with 2 Pannys to do an A/B compare.
BreakPoint is offline
Old 01-16-2007, 06:50 PM
rboster's Avatar
Quoted: 900 Post(s)
Liked: 750
Curious how to verify latest software installed on the Panny? I got the unsupported message when I inserted the burned CD. But, I just recently purchased this unit from VE, so it could be that mine was shipped with 1.4
Retired Moderator
FS: APC J10 Home Theater Conditioner/UPS back up $100: http://www.avsforum.com/forum/211-ac...y-back-up.html
rboster is online now
Old 01-16-2007, 06:56 PM
BreakPoint's Avatar
To see the FW version: Go to the Setup Menu. Select Display. Move the highlight into the Display Menu. Press "STATUS" button. You will see a small 1.4 (or whatever version) appear for a few seconds in the lower right.
Also when I update firmware I always burn my CD at the SLOWEST possible rate (around 8x) as this gives a better chance of working.
Old 01-16-2007, 07:33 PM
ottscay's Avatar
Ok, I've played with a number of disks, and BTB is showing on all of the callibration ones (I didn't check any early Sony-release easter egg callibration, since they clipped BTB anyways). No question about it. Subjectively, the color looks even better to me, but I wil wait for Sspears or Kris Dearing or someone who can do objectivce chroma measurements before I believe it.
Interactivity is marginally faster, especially FF and RW. Most important to me (and almost unbelievable to me) it fixed my problem with the SW out. The subwoofer out is very quiet (as is well documented) but before this firmware my SW audio out did not output anything. Now it does, and I am stoked. had to test a dozen BD's with uncompressed audio...I love it. When the Panny gets DTS-MA and TrueHD decoding it'll be the perfect player.
Awesome!
ottscay is offline
Old 01-16-2007, 08:14 PM
Alan Gouger's Avatar
Quoted: 31 Post(s)
Liked: 57
For some reason this is not downloading properly for me. It could be the time of day. Anyone else having trouble right now. Its downloading ok but wrong file size and its a dead format when I open it. File size before decompression is 32mb after 20mb.
I tried this on 3 different PCs thinking one of the machines was choking during download but got the same thing on all three.
Last update went very smooth. Ill give it another try in a hour.
Alan Gouger is offline
Old 01-16-2007, 08:21 PM
Video Engineer's Avatar
check:
Just updated to 1.4. Everything seems to work fine on initial assesment.
Video Engineer is offline
Old 01-16-2007, 08:22 PM
I just downloaded about the same time Alan and worked OK for me. The server did seem to be slow and overloaded though.
Old 01-16-2007, 08:30 PM
divedude's Avatar
I just downloaded it within the last hour with no problem. The install went with no problems. Getting ready to watch a movie
Dive deep, play with sharks.
So long and thanks for all the fish . . .
divedude is offline
Old 01-16-2007, 09:03 PM
thebland's Avatar
Liked: 847
Awesome!
HDMI bass?
Old 01-16-2007, 09:53 PM
Quoted: 31 Post(s)
Liked: 57
Guys Im ending up with 32.5KB after de compression FRM type file. What the he%# is this
Old 01-16-2007, 10:08 PM
TWD
TWD's Avatar
Quoted: 46 Post(s)
Liked: 36
My .FRM file is 31.6 MB (33,239,040 bytes) after decompress. It loaded just fine.
I noticed the the color space is 422. I could be wrong, but I think it was 444 prior to the upgrade.
TWD
TWD is offline
Old 01-16-2007, 10:24 PM
ottscay's Avatar
Alan, pm me and I'll upload it for you to get if you keep having problems.
No Bland, I can't get HDMI audio into my Arcam. it was the analog (i.e. SW) out that wasn't outputting anything. And I mean anything. Tier 2 (or 3, I don't remember) customer support concluded it was a hardware problem, which I'd guessed too, as the circuit was just not "turning on". Anyways, I didn't send it in for repairs last week because I have guests in town and a Blu Ray player with optical sound is better than none; imagine my suprise tonight when I did nothing but laod the new firmware and suddenly there was SW output through the analogs.
ottscay is offline
Old 01-17-2007, 09:22 AM
shamus's Avatar
Quoted: 23 Post(s)
Any luck Alan??????
shamus is offline
Old 01-17-2007, 10:36 AM
Quoted: 31 Post(s)
Liked: 57
Guys I am sure I am OK. I am so use to updating the HD DVD players I was trying to burn this as an image file
By the way does anyone know if this patch will allow the Panny to play back BDAV discs...that would be sweat if it does!!
Old 01-17-2007, 11:57 AM - Thread Starter
pixel_'s Avatar
No it does not play BDAV, have tried it. BDMV is ok...
pixel_ is offline
