IR solution for the PS3, for those of us with learning remotes - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 229 Old 08-16-2007, 11:07 AM
miata's Avatar
Quoted: 65 Post(s)
I was getting frustrated with trying to get my Harmony to learn the BluWave codes. I couldn't remember ever having this much difficulty with the old MX-500. So, for kicks I pulled out the MX-500 and had it learn the BluWave codes. Sure enough -- the MX-500 works perfectly. Harmony really needs to get something posted quickly -- because their learning capabilities plain suck. The Harmony still has all kinds of problems with lags, double signals, etc.
miata is offline
post #182 of 229 Old 08-16-2007, 11:20 AM
trgraphics's Avatar
Have you tried learning the commands from the MX-500 since it works well? That may give you the results you need.
trgraphics is offline
post #183 of 229 Old 08-16-2007, 11:23 AM
miata's Avatar
Quoted: 65 Post(s)
Yup. That was the real purpose of the exercise. No improvement. That is why I'm convinced that the Harmony is absolutely brain dead.
miata is offline
post #184 of 229 Old 08-16-2007, 11:24 AM
PLincoln's Avatar
I had the same issue with my Epson PJ remote. No matter what I did, I could not get the Harmony to learn it...my other universal had no problems. I called Harmony CS and in 10min or so the issue was worked out. Apparently there was some extra garbage being learned by the harmony ... suggest maybe you give them a call and see what they have to say.
PLincoln is offline
post #185 of 229 Old 08-16-2007, 02:59 PM
miata's Avatar
Quoted: 65 Post(s)
Great idea. I submitted an email inquiry. Thanks. I can't remember the last time I had to contact support for anything.
miata is offline
post #186 of 229 Old 08-16-2007, 03:12 PM
pbmpharmacist's Avatar
Quoted: 27 Post(s)
pbmpharmacist is offline
post #187 of 229 Old 08-17-2007, 12:26 AM
miata's Avatar
Quoted: 65 Post(s)
Originally Posted by pbmpharmacist View Post
try this miata
http://forums.logitech.com/logitech/...thread.id=2100
I really appreciate the help. I tried everything -- raw again, different delay times, long button pushes, shorter pushes, using an MX-500 as an intermediary, you name it. I'm still waiting to hear back from support. I'm seriously considering going back to my old MX-500. The family really liked the way the Harmony switches activities, but if the Harmony can't learn, and you can't share and if Logitech doesn't support the Nyko then screw them.
I don't want to send the wrong message. In my opinion, the Nyko/PS3 combo is totally plug and play and performs perfectly as advertised. That is not the issue.
miata is offline
post #188 of 229 Old 08-17-2007, 01:54 AM
miata's Avatar
Quoted: 65 Post(s)
OK. My infinite patience pays off. I finally got my Harmony 670 to work exactly like the BluWave and with the same speed as the the Sony remote. Yes. We are talking rapid fire navigation that you only get with the PS3. That is why you bought it for Blu-ray -- right?
The trick
Set the delay to 0ms
The other thing I did was set the "inter-key delay" to 100 ms. I had a bear of a time with the left direction key and others did as well. Just keep on plugging away and you will eventually reach remote control nirvana.
miata is offline
post #189 of 229 Old 08-17-2007, 05:06 AM
PLincoln's Avatar
The trick
excellent!
I'll be honest with you ... the harmony 1000 was one of the few things that I need to call support for as well...I was having quite a bit of trouble with it early on. But in their defense, CS has been outstanding especially with regards to weird remote codes etc.
PLincoln is offline
post #190 of 229 Old 09-01-2007, 10:43 PM
erikk's Avatar
Props to Rob100 for the clean hex codes for the Logic3 USB dongle but I found some of his labels were wrong and didn't match up with the correct action. Updated:
84 - Up arrow:
0000 0065 0000 0015 0060 0018 0018 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0030 0018 0018 0018 0030 0018 0030 01de
86 - Down arrow:
0000 0065 0000 0015 0060 0018 0018 0018 0030 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0030 0018 0018 0018 0030 0018 0030 01de
87 - Left arrow:
0000 0065 0000 0015 0060 0018 0030 0018 0030 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0030 0018 0018 0018 0030 0018 0030 01de
85 - Right arrow:
0000 0065 0000 0015 0060 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0030 0018 0018 0018 0030 0018 0030 01de
11 - Quit to XMB Home Screen / Stop / Back (circle):
0000 0065 0000 0015 0060 0018 0030 0018 0030 0018 0018 0018 0030 0018 0018 0018 0018 0018 0018 0018 0018 0018 0030 0018 0018 0018 0030 0018 0030 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 01c6
26 - Menu (square):
0000 0065 0000 0015 0060 0018 0018 0018 0030 0018 0018 0018 0030 0018 0030 0018 0018 0018 0018 0018 0018 0018 0030 0018 0018 0018 0030 0018 0030 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 01c6
40 - On-screen Playback Information/Display (select):
0000 0065 0000 0015 0060 0018 0018 0018 0018 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 0018 0030 0018 0030 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 01c6
48 - Previous chapter/track (L1):
0000 0065 0000 0015 0060 0018 0018 0018 0018 0018 0018 0018 0018 0018 0030 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 0018 0030 0018 0030 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 01c6
49 - Next chapter/track (R1):
0000 0065 0000 0015 0060 0018 0030 0018 0018 0018 0018 0018 0018 0018 0030 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 0018 0030 0018 0030 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 01c6
50 - Play / pause (start):
0000 0065 0000 0015 0060 0018 0018 0018 0030 0018 0018 0018 0018 0018 0030 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 0018 0030 0018 0030 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 01c6
51 - Rewind (L2):
0000 0065 0000 0015 0060 0018 0030 0018 0030 0018 0018 0018 0018 0018 0030 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 0018 0030 0018 0030 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 01c6
52 - Forward (R2):
0000 0065 0000 0015 0060 0018 0018 0018 0018 0018 0030 0018 0018 0018 0030 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 0018 0030 0018 0030 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 01c6
56 - Play / Pause / Select (X):
0000 0065 0000 0015 0060 0018 0018 0018 0018 0018 0018 0018 0030 0018 0030 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 0018 0030 0018 0030 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 01c6
84 - Display Control Panel / Options (triangle):
0000 0065 0000 0015 0060 0018 0018 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0030 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 01c6
Erik
erikk is offline
post #191 of 229 Old 09-02-2007, 04:07 AM
Rob100's Avatar
I haven't looked at what you've changed, but I don't think the Logic 3 remote makes sense in the first place, hence why I changed the names to bring them more inline with a the six axis controller and Sony BT remote.
If you use a normal PS3 (six axis) controller, "circle" is "select/play/pause" and "x" is "XMB/Stop/Back".
Anyway, the HEX codes are right just use them / call them as you like
Rob100 is offline
post #192 of 229 Old 09-02-2007, 10:16 AM
erikk's Avatar
What I'm saying is that on the normal sixaxis, circle is NOT select/play/pause. You have that reversed.
From the Playstation 3 manual (http://www.us.playstation.com/SCEARe...are/video.html)
Video Function
System Button Operation
Play
X or START Button
Pause
X or START Button while movie is playing
Circle or PLAYSTATION® Logo Button
Maybe you changed the default controls? Is that even possible?
Erik
erikk is offline
post #193 of 229 Old 09-02-2007, 10:28 AM
erikk's Avatar
BTW since you were able to make such clean codes for the logic3 do you have any idea how to do the same for the Nyko Bluwave (same idea different manufacturer)?
The only problem is that to my understanding the Nyko does NOT use the standard Sony PS2 codes. IE you can't use the Nyko remote with the Logic3 dongle.
Erik
erikk is offline
post #194 of 229 Old 09-02-2007, 01:43 PM
Rob100's Avatar
Video Function
Play
X or START Button
Pause
Don't agree with that.
On my PS3 circle and "x" are reversed from what you've just quoted.
If I play a BD I using the six axis controller, circle will pause/play. If I press "x" I'm prompted if I want to quit playback - press "x" to go back and circle to select yes/no. Same when playing video files in XMB. I haven't changed anything.
Rob100 is offline
post #195 of 229 Old 09-02-2007, 01:55 PM
erikk's Avatar
Well, one of our PS3's either has a different setting (if it can even be changed and I don't know how to, if it can) or isn't working properly. And mine seems to match what the manual says, so...........
Maybe someone else can chime in on how theirs works. If yours isn't doing what it's supposed to by default that might explain why the Logic3 remote made no sense to you.
Either way, the clean hex codes were a godsend and the important thing is both our remotes are doing what we want them to do, so thanks again.
Erik
erikk is offline
post #196 of 229 Old 09-02-2007, 01:59 PM
erikk's Avatar
Rob btw where are you and what PS3 version do you have? Did you import a japanese one or are you outside the US? That might explain the difference.
Erik
erikk is offline
post #197 of 229 Old 09-02-2007, 02:03 PM
larry_s's Avatar
Originally Posted by MUCHO View Post
So far it isn't working at all. I don't think its the Radio Shack I bought this PS2 remote on ebay and I believe it is the problem - but - in truth I have no idea.
item # is 270096123211
You can purchase the remote from Radio Shack as well for $14.99 -- http://www.radioshack.com/product/in...entPage=search.
larry_s is offline
post #198 of 229 Old 09-02-2007, 03:10 PM
Rob100's Avatar
I'm in the UK and my PS3 is a Japanese model. A quick google seems to imply that circle and x are reversed on US and JPN Playstations. I've found references to this for PS2, PSP and PS3.
I wonder how a UK PS3 works... Hmm...
All makes sense now
Rob100 is offline
post #199 of 229 Old 09-02-2007, 03:31 PM
Rob100's Avatar
Here are the manuals...
http://manuals.playstation.net/docum...tions/xmb.html
Can't read the Japanese version myself, but see how x and circle are reversed in the list.
Edit: Babelfish translation confirm this...
http://babelfish.altavista.com/babel...ons%2fxmb.html
Rob100 is offline
post #200 of 229 Old 09-02-2007, 06:56 PM
erikk's Avatar
Well that makes more sense then. I wonder why they did that? Seems like a strange one off thing to change. Since Logic3 is UK based I'd be willing to bet that the UK PS3 uses the same button layout as the US. But who cares, it's not like you're using the sixaxis for movie playback anymore anyway, right?
Erik
erikk is offline
post #201 of 229 Old 09-02-2007, 07:02 PM
erikk's Avatar
BTW if anyone needs it I have the clean Logic3 codes in a URC .MXA file if you want me to email them to you. I uploaded them on remotecentral but I don't see them listed yet so I don't know if there's a delay there or if it was rejected for some strange reason.
Erik
erikk is offline
post #202 of 229 Old 09-02-2007, 11:47 PM
Rob100's Avatar
No idea why it's like that. The PS3 is the first Playstation I've owned or even used so it didn't seem "wrong" to me. Actually I think it's more logical, "x" to say "no" (for quit, back, stop etc) and "o" to select. Anyway...
No definitely not using six axis for move playback.
Rob100 is offline
post #203 of 229 Old 09-22-2007, 08:24 PM
andyd2k's Avatar
Does anyone have issues with sixaxis controllers not connecting to the first position when the bluwave receiver is connected? I have to keep reassigning the controller back to 1 after I boot the system - it's getting annoying
andyd2k is offline
post #204 of 229 Old 10-11-2007, 09:21 AM
simarddominic's Avatar
Anyone of you guys know where I could find the Niko IR remote for the PS3 in Canada ???
Try to find on the net with no success
Thanks !
simarddominic is offline
post #205 of 229 Old 10-11-2007, 10:50 AM
Axel's Avatar
Quoted: 73 Post(s)
Liked: 24
Thanks !
Not to sound like a smarta$$, but did you search for Nyko, rather than Niko?
____
Axel
Axel is offline
post #206 of 229 Old 10-11-2007, 10:58 AM
____
Axel
Yes It's a error on this thread and not in my search !
post #207 of 229 Old 10-31-2007, 11:42 AM
TommyV's Avatar
What is the consensus on the best solution for a Harmony 890? I found the Nyko on amazon but I do not see this Logic 3 listed anywhere.
TommyV is offline
post #208 of 229 Old 10-31-2007, 12:30 PM
erikk's Avatar
Logic3 is only available in Europe but you can buy it direct from stores in the UK. There's not much point in getting the Logic3 for a Harmony versus a Nyko since they both offer the same functionality. There is also another solution created by a forum member that a lot of people like; it's a USB dongle only but since you have a Harmony you don't need the extra remote anyway. You can read more about it in this thread: http://www.avsforum.com/avs-vb/showt...9#post11484259
Erik
erikk is offline
post #209 of 229 Old 10-31-2007, 03:26 PM
TommyV's Avatar
Nice, Thank You! Looks like a good solution.
TommyV is offline
post #210 of 229 Old 11-21-2007, 05:40 PM
Schlotkins's Avatar
OK, I bought something MONTHS ago and now am trying to hook it up... I've totally forgot what the game plan was. In any case, I bought a Pelican Universal Remote off ebay. It has a IR thingie that has a 3 compartment, 9 pin hookup on the back. I assume this is a PSX/PS2 port. My assumption is I have to buy something like this:
Item #280175740304 on e*ay
I then hook up the IR port to that adaptor and hook that into a USB port on my PS3. I can them teach my Harmony remote the codes.
Is that about right?
Chris
Schlotkins is offline
Reply Blu-ray Players
