PS3 and DTS-HD MA: is it really planned? - AVS Forum | Home Theater Discussions And Reviews
Old 03-23-2007, 04:49 PM - Thread Starter
TriptonUpman's Avatar
I was looking at my ps3 earlier, and i noticed on the side, it had icons for all of the formats and codecs it supports. there is an icon for DD-TrueHD right on the ps3 case.
does this mean that possibly they have no intent of ever decoding DTS-HD MA? the reason i ask is because, sometimes i wonder if they are even intending on adding it at all. lately it looks like they are leaning towards DD-TrueHD to take over uncompressed PCM on their blu-ray releases.
people always talk about it being in an upcoming update (so much for march), but has sony said anything official whatsoever about future support for DTS-HD MA in the ps3? It would be a shame for those sexy fox DTS-MA tracks to never be decoded without an hdmi 1.3 receiver
wonder if they could maybe add the dts-hd ma icon to the ps3 case with a patch too
Blu-ray discs - 154
HD-DVD - 0
FACT: 90% of the industry is blu-ray, few are hd-dvd.
FACT: Paramount paid 150m, sabotage by MS.
FACT: consumers have spoken, they chose blu-ray over 2-1.
TriptonUpman is offline
Old 03-23-2007, 09:46 PM
Megalith's Avatar
Quoted: 20 Post(s)
DTS-HD?
They can't even give their users custom backgrounds.
Megalith is offline
Old 03-23-2007, 10:25 PM
WriteSimple's Avatar
Originally Posted by Megalith View Post
DTS-HD?
And this comment is helpful because?
DTS HD is what DTS (the company) called its DTS Core, which the PS3 can decode. As far as DTS HDMA update for March, the news got started from a Japanese article from interviews with PS3 engineers/designers. Obviously, the March firmware isn't it.
There is nothing wrong for studios to contemplate using Dolby TrueHD to supplement or replace PCM. With the PS3 you can only get multichannel PCM using HDMI anyway. Since the PS3 can decode TrueHD now with HDMI audio systems, that's considered a big step forward.
Clearly Dolby TrueHD decoding is ready. As for why DTS HDMA decoding is not included in all BD players yet, maybe reference decoding software is not ready. I'm sure once it is ready, Fox would hound SCE and other CEs to add DTS HDMA in the PS3 and BD players.
fuad
"DonÂt let them tell you who you are is not enough, that itÂs wrong and that you wonÂt find love. DonÂt let them use my life to put your future down, or tell you that happiness canÂt be found."
WriteSimple is offline
Old 03-24-2007, 12:37 AM
Dan Hitchman's Avatar
Quoted: 3413 Post(s)
Liked: 1766
Panasonic says they can't add DTS MA to their current player because the chip they used doesn't have the horsepower. The PS3, OTOH, should have plenty.
DTS MA goes through a very complicated process to entwine the core and extension data files together to re-create the original LPCM stream. Dolby TrueHD, on Blu-ray, does the same thing (core + extension), but seemingly has it more streamlined. Therefore, it's less CPU intensive.
The more I ponder it, I think Sony may make DTS MA internal decoding less of a priority on the PS3 because it already has an HDMI 1.3 output, and they're using TrueHD on upcoming releases. Receivers (and soon pre-amps) will have DTS MA as well as Dolby TrueHD on board. With the PS3, you're then set. You can't say the same for other table top BD players currently available.
Dan
Listen up, studios! Just say "NO" to DNR and EE!!
Dan Hitchman is offline
Old 03-24-2007, 06:17 AM
William's Avatar
Quoted: 29 Post(s)
Liked: 50
Originally Posted by WriteSimple View Post
...DTS HD is what DTS (the company) called its DTS Core, which the PS3 can decode....
Actually DTS core is not DTS-HD but the same old (original) DTS full bitrate (1.5Mbps) renamed DTS Encore used on some DVD's and DTS-CD's. DTS-HD is a higher quality lossy (up to 6Mbps on BD) codec. The PS can't decode DTS-HD or DTS-HD Master and only reads the core which is DTS Encore. Now who is it that is confused?
William is offline
Old 03-24-2007, 06:41 AM
kschmit2's Avatar
Paidgeek posted this about the prospect of DTS-HD Master Audio on the PS3:
http://www.avsforum.com/avs-vb/showt...&&#post9827584
kschmit2 is offline
Old 03-24-2007, 06:50 AM
ryoohki's Avatar
They were a mention of DTS HD, but NO DATES it could be in FW5.0... i really think that we are gonna see DTS HD via Bitstream in HDMI before actual decoding... since amp are coming our way really soon...
89+ Blu-ray Disc ;)
ryoohki is offline
Old 03-24-2007, 08:07 AM
William's Avatar
Quoted: 29 Post(s)
Liked: 50
I asked this before but I guess no one can say for sure at this point. Is the PS3 now passing DTS-HD in the bitstream or will this also take a firmware update?
William is offline
Old 03-24-2007, 09:22 AM
Originally Posted by William View Post
confused?
I stand corrected. DTS Core decoding only for the PS3.
The TrueHD and DTS HD/MA bitstream pass through via HDMI should be available already. Unfortunately, nobody can try it but CE insiders.
fuad
Old 03-24-2007, 09:40 AM
bfdtv's Avatar
I don't know if it's changed recently (i.e. with latest firmware), but the PS3 did not output TrueHD or DTS-HD bitstreams over HDMI before. It will require a software update to do that.
bfdtv is offline
Old 03-24-2007, 09:56 AM
cws2882's Avatar
Where did you read this from? I thought they were promising an upgrade for this?
cws2882 is offline
Old 03-24-2007, 12:41 PM
HPforMe's Avatar
Doesn't need any firmware upgrade for this. All DTS HD MA tracks have a core legacy DTS track but it runs at a very nice 1.5 Mbps. Any DTS decoder can handle this and indeed you can even use the optical out as a bitstream of the PS3 and it will be decoded by your receiver with the DTS decoder.
Now as far as TrueHD bitstream - why would we want that if the player does the decoding anyway and sends it out as PCM. Having said that, TrueHD to my knowledge can be sent out of the PS3 as a bitstream.
HPforMe is offline
Old 11-19-2007, 01:28 PM
BrahmaBull's Avatar
Quoted: 36 Post(s)
Liked: 30
TrueHD can only be sent out PCM, if you try to do it bitstream you will get the core DD 5.1 track(448k-6xxk garbage)
And still no DTS-HD-MA, over PCM or bitstream (if you do select a DTS MA track it will just play the DTS core 1.5Mbps track)
- Matt
Samsung KS8000 65"
Onkyo TX-NR747
Polk RTi A7 (Fronts) x2
Polk CSi A6 (Center)
Axiom M2 V3 (Rears) x3
BrahmaBull is online now
Old 11-19-2007, 02:41 PM
jdmac29's Avatar
Just a thought if Sony did do a firmware upgrade to allow DTS MA decoding at a $400 price point would that not just really hurt the other electronic companies making blu ray players? Reading all the threads about dts ma being processor intensive which would mean the other blu ray players probably would have to put more money in their machines to allow this and that would cut into their profit margins looking at the low end PS3. Like most I want that decoding also and would like one machine that can do it all and the PS3 seems to be that machine but I think Sony will not do it for some time to come.
jdmac29 is offline
Old 11-19-2007, 03:42 PM
solo88's Avatar
There is no core to True HD, so it's not doing a core plus extension in a more streamilined way than DTS HD. On BD, there is simply a hidden lossy track strapped on to the lossless track. (HD DVD doesn't need this hidden track because those players can create a lossy track from the lossless track for use over optical.) It could be either 448 or 640. I think SM3's is 640, but I don't remember for sure.
My midis bring all the Force to the yard; my midis are better than yours!
solo88 is offline
Old 11-19-2007, 04:28 PM
cambrian's Avatar
then at least allow bitstream...if they can even do that at all.
cambrian is offline
Old 11-19-2007, 04:46 PM
almostinsane's Avatar
Quoted: 47 Post(s)
Liked: 42
Could they do bitstream? How would they mix in all the menu and game pad sounds if it was just streaming from the disc? I guess this could work if it was a separate setting for movie playback vs a game but all games are on BD's so I'm not sure how it would make the distinction.
I dont think it will ever get bitstream out as the game audio is mixed on the fly, it isn't a track like movies that is 'static' and not changed.
almostinsane is offline
Old 11-20-2007, 12:36 PM
solo88's Avatar
Upcoming titles with player mixing will require internal decoding as well for features to work. Considering Sunshine will employ it and it's a Fox title, meaning DTS-HD MA, the focus will be on internal decoding.
There's really no point to external decoding. People are already getting confused with their Star Trek sets and the new Toshiba. "I get no sound for this feature when using Direct Digital!" Well, yeah; that's because the player has to decode and mix it in.
I guess there is such a thing as too many choices.
solo88 is offline
Old 11-20-2007, 04:16 PM
HumanMedia's Avatar
Pardon my ignorance but for watching movies, does the PS3 pass the newer audio codecs (beyond the cores) via Bitstream? or is it planned?
IMO decoding in the player is a waste of processing and engineering, and I would much rather have lossless compressed audio given straight to the receiver.
HumanMedia is offline
Old 11-20-2007, 04:22 PM
ryoohki's Avatar
Nodody knows if the PS3 HDMI 1.3 chip can or can't. Right now the PS3 decode TrueHD and send it as PCM, if the chip can't do Bitstream, i don't mind having it decoding in PCM since it's mostly the same process...
89+ Blu-ray Disc ;)
ryoohki is offline
Old 11-21-2007, 12:10 AM
miata's Avatar
Quoted: 65 Post(s)
Since Blu-ray has the capacity and bandwidth to handle DTS-HDMA I would think it would be very important to Sony to encourage studios to include DTS-HDMA sound tracks. The best way to encourage studios is to enable DTS-HDMA playback with the most prevalent Blu-ray platform -- the PS3 -- provide internal decoding as well as bit stream pass-through if possible.
miata is offline
Old 11-21-2007, 08:01 AM
HeLLSpiRE's Avatar
FYI you will never see bitstream pass-through on the PS3 because the HDMI chip used in the PS3 does not have this capability but internal decoding will happen eventually
HeLLSpiRE is offline
Old 11-21-2007, 10:13 AM
threefirstnames's Avatar
is this confirmed? is it a hardware limitation of the chip (even though the chip is HDMI 1.3)?
--kevin--
threefirstnames is offline
Old 11-21-2007, 10:25 AM
solo88's Avatar
Here we go again! Nothing's really confirmed, just suspected because the only writeup anyone could ever find doesn't state that capability.
Amazingly no one in all this time has been able to contact the manufacturer.
solo88 is offline
Old 11-21-2007, 10:26 AM
Rich Davenport's Avatar
All that is known is that the HDMI chip in the PS3 is not the one that is advertized on the chip maker's web site. So we don't know what the specs are on it.
Member of AVS FORUM folding@home team, (team #55280)
Rich Davenport is offline
Old 11-21-2007, 12:36 PM
thanks for the info. it sure would be nice if people would stop making definitive statements about it.
--kevin--
Old 11-21-2007, 01:41 PM
Moderator
Moderator
PooperScooper's Avatar
Quoted: 284 Post(s)
Liked: 3917
I just looked and couldn't find the thread here that linked to another thread where it was stated that the rev of the HDMI 1.3 chip used in the PS3 does not support sending DTS-MA bitstreams (and I guess others). The statement was made by somebody who actually works at the hardware/firmware level in the industry. Converting to PCM is all we need.
larry
And the pantaloon duck, white gooseneck quacked: Webcor, Webcor
PooperScooper is offline
Old 11-21-2007, 02:59 PM
if that was true, i wonder if it is still true for the newer PS3 SKUs (such as the 40GB), which possibly has a newer HDMI chip...
--kevin--
Old 11-21-2007, 04:53 PM
Moderator
Moderator
Quoted: 284 Post(s)
Liked: 3917
Yes, I mentioned something like that in a another post; the newer PS3s could have the newer chip. I don't know the answer. Somebody needs to pop open a new one and list some chip part numbers.
larry
Old 11-21-2007, 06:29 PM
Donnie Eldridge's Avatar
Is this really a hardware issue or more of a licensing issue? Or, perhaps a bit of both?
Donnie Eldridge is offline
