Samsung BDP1200 Master/Owner's Thread - Page 157 - AVS Forum | Home Theater Discussions And Reviews
post #4681 of 6049 Old 04-20-2008, 02:42 PM
gatorman's Avatar
Originally Posted by Tarheel72 View Post
it is physically impossibe to send Dolby TrueHD or DTS-HD MA out of the 1200 via any means what so ever. The only uncompressed audio is uncompressed lossless PCM. So the receiver is not decoding anything and is doing nothing more that a digital to analog conversion of that signal. If the disc does not have a lossless PCM track then the receiver is only getting a compressed PCM track, most likely 2.0, and converting it to a multichannel analog signal and then sending it to the speakers.
I don't disagree, I probably wasn't as clear as I should have been. My bad. You can send an uncompressed lossless PCM signal to the 3808 from the 1200 if the disc has it, digitally through an HDMI connection. The receiver then sends the unaltered signals to the speakers. As an alternative, you can send 5.1 analog signals through the coax 5.1 analog connections or 5.1 digital through the fiber optic or coax connections. Correct me if I'm wrong, but I don't think there is any real difference between an uncompressed lossless PCM signal and one of the newer codecs unless you have a disc that has a 7.1 track instead of 5.1.
BTW, what happened to the Heels in the tournament? I was so disappointed.
gatorman is offline
post #4682 of 6049 Old 04-20-2008, 07:46 PM
Ungermann's Avatar
Quoted: 517 Post(s)
Liked: 68
Just checked again, "Blu-ray on DVD" disks that I made with either MPEG-2 (from HDV camcorder) or with AVC (from two different AVCHD camcorders) play with rev. 2.2, do not play with rev. 2.3 -- "This disk cannot be played". Samsung, you suck. On a positive note, rev. 2.2 plays 1440x1080@13Mbps and 1920x1080x17Mbps AVC clips without hiccups.
Ungermann is offline
post #4683 of 6049 Old 04-21-2008, 11:13 AM
Tarheel72's Avatar
It is my understanding that if you send any signal, analog or digital, to the receiver via a digital source (HDMI, coaxial or optical) then you can apply the receiver's DSP to it if you so desire. So the signal is unaltered only if DSP is turned off for those inputs when receiving the LPCM. Most receivers do not apply any processing to signals received via direct analog inputs,whether that is the LPCM or a digital track, such as DD or DTS. My receiver does not have HDMI inputs but does have analog 5.1, which I use for all BRD audio, LPCM or digital tracks.
And you are correct. there is no difference between LPCM and TrueHd/DTS HD MA.
As for the Tarheels, what can I say? They took the first half off and it showed. The only good news is that as a result we may be Tyler back for another year. At Carolina getting to the final four is not a goal, nor does it fulfill our expectations. We plan on winning it all every year and pretty much anything less is a disappointment for us, but this year it was more so.
Tarheel72 is offline
post #4684 of 6049 Old 04-21-2008, 12:04 PM
jandron's Avatar
Quoted: 21 Post(s)
Liked: 74
Regarding Rapid Scrolling Menus from Hell on Across the Universe (and, I take it, other titles as well)...
I discovered one can actually access the special feature items with some quick work with the select button. During the rapid scroll, if you anticipate the feature you want just right, you can select it. You have to hit the button BEFORE the menu item shows up on screen, otherwise it's too late. I got to select the special features this way, and they played. It's a real PITA though.
jandron is offline
post #4685 of 6049 Old 04-25-2008, 08:37 PM
Gardo's Avatar
Trying to watch SD of Abyss SE--weird behavior because of branching in special edition--stuttering (fixed by pause-and-play) and now a freeze at about 1:01:30 in. So many workarounds with this player.... Great picture, though.
Gardo is offline
post #4686 of 6049 Old 04-25-2008, 09:58 PM
snavem's Avatar
I am going to throw something in here. I know a good number of us were sold on the Reon HQV chip as an incentive to purchase this particular Bluray machine. I know I was impressed by the ability to upconvert standard discs to a new level. But, and I am speaking on a personal basis, I have basically given up on using the 1200 for SD use. I have encountered so many problems with playback from the frame skip glitch at chapter points to picture freeze to audio dropouts. I have found I have a problem with 1 of every 2 SD discs I play. Each time I have to move the disc to my Toshiba A-2 for an inferior upconvert but play without problems. So I have finally just decided to use my A-2 and given up on my 1200. I know not all of us have the ability to do what I do. But, for me, enough was enough. As far as BD's are concerned. My 1200 works fine and looks great.
snavem is offline
post #4687 of 6049 Old 04-26-2008, 07:07 AM
LRS3's Avatar
Quoted: 50 Post(s)
Liked: 43
I watched the SD version of American Gangster from Netflix last night. Still lots of lockups, even though I chose the theatrical version of the film from the disc menu, which is supposed to be less troublesome than the extended version. So, even with firmware 2.3, Samsung hasn't really done anything to resolve the problems with branching on many SD discs.
LRS3 is offline
post #4688 of 6049 Old 04-26-2008, 09:09 AM
philnort's Avatar
I've been following these comments on problems with St. def. discs and the 1200 with interest. Either I've been blessed or I'm using a workaround. I purchased two "like new" 1200's from Ebay approximately 3 mos. ago..primarily for Blu-Ray playback of course, but I was also very interested to see how the Reon chip did cf. to my Lumagen processor.
Having played probably in excess of 4 dozen Std. def discs I can report not one hiccup ! Similar success with Blu-Ray. With both players, I upgraded their firmware to 2.2...and left it there! A caviat though...I rarely play back the original Std def disc...they're all ripped "backups" (100 % video resolution) using (always) Verbatim DVD-R single layer and DVD+R dual layers....thus..not a lot of 'branching', menu selections, etc. just pure movie playback. But..that said...not one audio or video problem....and I REALLY enjoy that Reon chip's prowess!
philnort is offline
post #4689 of 6049 Old 04-26-2008, 11:30 AM
LRS3's Avatar
Quoted: 50 Post(s)
Liked: 43
It's the branching that seems to routinely trip this player up. Doesn't seem like rocket science for Samsung to fix, but who knows whether that will ever happen.
LRS3 is offline
post #4690 of 6049 Old 04-26-2008, 03:03 PM
Gardo's Avatar
Hmmm, interesting idea. I'd be happy to skip all the menu folderol anyway, so it'd be worth it to process my troubled SDs this way.
Would love to know what you use for your 100% res. ripped backups--PM if you'd rather.
Gardo is offline
post #4691 of 6049 Old 04-26-2008, 08:43 PM
project86's Avatar
Call me crazy, but I'm about to jump into the wonderful world of 1200 ownership. I'm purchasing a used unit from a trusted source, at a good price. He has never had any playback problems with SD, and only 1 issue with 3:10 to Yuma which was fixed with firmware upgrade. I am hoping that this is one of the elusive units that actually does what it is supposed to do.... at least I hope.
A few questions that I haven't been able to figure out:
I know it doesn't decode TrueHD and DTS-HD/MA.... but what does it do with those instead? I assume it extracts the core at 1.5MB for DTS.... what about the dolby stuff?
Will it work OK to set it to PCM for everything, assuming I connect through HDMI? My HD DVD player sends PCM for HD audio, bitstream for older formats... but PCM all the way around would be fine as well.
Are there many adjustment options for SD DVDs? I know the XA2 has a few.
Thanks, I'll report my experience when I get the unit.
project86 is offline
post #4692 of 6049 Old 04-27-2008, 01:19 AM
shawnmos's Avatar
1.5mb for DTS core and 640kb Dolby Digital Core. Setting it to PCM should work fine. That's what I do.
shawnmos is offline
post #4693 of 6049 Old 04-27-2008, 08:39 AM
millerwill's Avatar
Quoted: 463 Post(s)
Liked: 261
Now I'm confused! From way back in this thread I thought that it was settled that it was best to leave the 1200 on 'Bitstream' all the time. This way you get the legacy DDEx, etc., from sd dvd's, and BR's that only have that, and for BR discs that have 'Uncompressed LPCM', you have to choose this audio in the disc setup, and then it is transmitted over Bitstream and output as such (at least by the Onk 805 that I have). And this is all the hidef audio you can get from the 1200. Is this not correct?
millerwill is offline
post #4694 of 6049 Old 04-27-2008, 09:56 AM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 372 Post(s)
Liked: 243
Yes, bitstream was the consensus recommendation early in this thread and revisited (and confirmed) not all that long ago.....
RUR is offline
post #4695 of 6049 Old 04-27-2008, 10:48 AM
paulsen's Avatar
From the 1200 manual, note on page 39:
If you have selected a LPCM sound track on a disc, the output will automatically be set to PCM.
When playing a Dolby Digital movie make sure the Digital Output is set to Bitstream.
Also from that page:
PCM : Select this when your equipment does not decode Dolby Digital.
That should probably say "only when your equipment does not decode Dolby Digital", and is there any modern receiver that does not?
paulsen is offline
post #4696 of 6049 Old 04-27-2008, 11:17 AM
millerwill's Avatar
Quoted: 463 Post(s)
Liked: 261
I take the first quote, "I you have selected a LPCM sound track on a disc, the output will automatically be set to PCM" to mean that even if you have the 1200 set to 'Bitstream', it will send it output out as PCM; so you never need to set the 1200 to anything other than 'Bitstream'.
post #4697 of 6049 Old 04-27-2008, 11:41 AM
paulsen's Avatar
That's how I read it and it seems to work that way in practice.
I think it's one of the few nice features of the 1200
paulsen is offline
post #4698 of 6049 Old 04-27-2008, 11:55 AM
Tarheel72's Avatar
This is correct. You set the 1200 to bitstream and it sends everything out that way, but will default to PCM if you select LPCM from the disc menu. It does the work for you. The only way to get lossless audio from the 1200 is if the disc has LPCM. It will send it out (automatically changing the output to PCM) or you can send it via the analog 5.1 outputs after doing a DAC.
The analog outputs are always active and it does a DAC on all signals. For instance if you chose TrueHD, it will extract the core, do a DAC and send it out on the analog outputs.
post #4699 of 6049 Old 04-27-2008, 01:55 PM
shawnmos's Avatar
The player can decode DD and DTS internally, so it doesn't really make much difference.
shawnmos is offline
post #4700 of 6049 Old 04-27-2008, 08:42 PM
Tarheel72's Avatar
Has anyone had trouble with Before the Devil Knows You're Dead? I thought I read where it played fine, but I couldn't get it to work. First try it was slow loading and it eventually ejected and gave me the Disc Can Not Be Played message. I put it back in and it got to the FBI warning and then it acted like it wanted to play but it stopped on a blank screen at 00:09. Every other time, it simply fails to load at all and nothing happens. I checked and cleaned the disc, but that did not help. Anyone else have issues with this BluRay?
post #4701 of 6049 Old 04-27-2008, 10:33 PM
silvereyes's Avatar
"the water horse" and "the orphanage" both played fine for me, as far as movie goes, didn't check extras. I'm on firmware 2.3
silvereyes is offline
post #4702 of 6049 Old 04-28-2008, 08:24 AM
LRS3's Avatar
Quoted: 50 Post(s)
Liked: 43
I just received this BD as a rental from Netflix. Put in in the 1200, pressed Play at the menu, and it started fine. I only played it for a minute or so, but it seemed to be OK.
LRS3 is offline
post #4703 of 6049 Old 04-28-2008, 11:54 AM
02fx4dude's Avatar
Not that I doubted you, but I did try 2.3 and had the same "disk cannot be played" message. Bumped down to 2.2 and BD5/9 play fine.
Hope I don't have any BD that require 2.3
02fx4dude is offline
post #4704 of 6049 Old 04-28-2008, 04:37 PM
Tarheel72's Avatar
Washed it four times (it was a NetFlix disc) and finally got it past the intro to the main menu, but it was lots of stutters, etc. I started the movie and it seemed to work but by that time we had watched a different one and it was late so I shut it down. We'll see if I can get it fired up again. Must be something to do with the disc.
update: got another "disc can not be played" guess I will have to play another movie first and try it again. frustrating
post #4705 of 6049 Old 04-28-2008, 07:54 PM
LRS3's Avatar
Quoted: 50 Post(s)
Liked: 43
Must be a bad disc. I watched the whole thing tonight, without any problems (such as stutters or lockups) at all. I'm at firmware version 2.3.
LRS3 is offline
post #4706 of 6049 Old 04-28-2008, 08:28 PM
Bladerunner1959's Avatar
Location: Pittsburgh, PA...Preferably the Virgin Islands....
Quoted: 13 Post(s)
Liked: 67
How did you bump back to 2.2?
Love for all things Hi-def...Losing count; 200 plus bluray, 500 plus dvd, 30 plus HDdvd and a rapidly growing 50 plus in the cloud.
Bladerunner1959 is offline
post #4707 of 6049 Old 04-28-2008, 11:40 PM
Ungermann's Avatar
Quoted: 517 Post(s)
Liked: 68
Reloaded 2.2 over 2.3, at least the 1200 allows downgrading, good heavens.
post #4708 of 6049 Old 04-28-2008, 11:43 PM
Ungermann's Avatar
Quoted: 517 Post(s)
Liked: 68
I submitted a complaint through Samsung website, got a standard canned reply, but I hope that someone at least read it and knows about the issue. Waiting for 2.4 with this issue resolved, along with SD 4:3 playback.
post #4709 of 6049 Old 04-29-2008, 05:51 AM
02fx4dude's Avatar
I might contact Samsung CS or like you did go to the website. I hesitate because I expect some sort of answer such as " how do you know you're burning a properly formatted disc" or something eluding to it being something I did wrong, faulty/cheap media, etc...
I've been fairly tolerant of the issues with the player... like having to wait 2 months to watch POTC 3. Removing functionality is is really hitting below the belt.
Looks like quite a few people in the 71 series thread in the LCD section are talking about a lawsuit against Samsung for the problems with their TVs not performing as advertised. Sucks to be Samsung...
post #4710 of 6049 Old 04-30-2008, 12:08 AM
Ungermann's Avatar
Quoted: 517 Post(s)
Liked: 68
AFAIK, Samsung is also being sued for faulty CCD sensors it its camcorders. I don't think Samsung wants yet another lawsuit.
Reply Blu-ray Players
Samsung Bd P1200 Blu Ray Disc Player
