Samsung BDP1200 Master/Owner's Thread - Page 52 - AVS Forum
post #1531 of 6049 Old 07-13-2007, 06:44 PM
YouQuein's Avatar
Do anyone had had problems downloading the firmware from Samsung website???
I had tried a lot of times and always download procedure fall and it has been impossible for me to obtain this firmware version.
YouQuein is offline
post #1532 of 6049 Old 07-13-2007, 07:24 PM
Adz523's Avatar
Has anyone had this problem?
Setting the audio to bitstream, I can't get the bitstream signal to transmit over HDMI?
Adz
Adz523 is offline
post #1533 of 6049 Old 07-14-2007, 06:18 AM
bokes's Avatar
Anyone having lip sync problems?
I am sending the HDMI to my television and audio feed via coaxial to my receiver.
I played The Prestige and Kiss Kiss Bang Bang- Both discs gave me lip sync issues.
I had to adjust the delay quite a bit to get it close.
(I am also getting lip sync issues with my Toshiba HDXA2)
What can be done to fix this? HDMI directly into the receiver?
I love HD image- but I never had such issues with SD DVD.
bokes is offline
post #1534 of 6049 Old 07-14-2007, 06:35 AM
Frank D's Avatar
Since you are going direct to your TV you should be getting the quickest video signal path. Using the audio delay in your receiver to correct this is fine. Whatever processing your player or TV are doing is just taking some time. It is not preferred to have lip sync issues but it happens. You can try to run the hdmi via the receiver to see if it makes anything better but it may also make the lip sync issue worse.
Where is your video signal being processed?
Frank D is offline
post #1535 of 6049 Old 07-14-2007, 07:02 AM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 33 Post(s)
Liked: 49
If you're running 1080p/24fps, lip sync issues are a known glitch on the 1200. Folks are hoping a future firmware update will correct this.
RUR is offline
post #1536 of 6049 Old 07-14-2007, 07:08 AM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 33 Post(s)
Liked: 49
If you're having difficulties downloading via the player, try updating the firmware by burning it to disc off of the website and installing it via that disc.
BD-P1200 firmware found here: http://www.samsung.com/us/support/do...ype=FM&vType=R
v1.0 is the latest
RUR is offline
post #1537 of 6049 Old 07-14-2007, 09:38 AM
bokes's Avatar
Yes- I'm sending 1080p/24fps.
How on earth does Samsung release a product without checking this out?
Or did they know about it and shipped units anyway?
Oh well- I suppose I could call Samsung support and voice my 2cents for a firmware fix.
bokes is offline
post #1538 of 6049 Old 07-14-2007, 10:21 AM
davenrino's Avatar
I just watched The Prestige last last night outputing 1080p@60fps with no lip sync issues. I don't even try 24fps anymore as the lip sync is unacceptable and my receiver doesn't have delay adjustments. My gear is connected like yours except with optical audio.
Dave
davenrino is offline
post #1539 of 6049 Old 07-14-2007, 10:53 AM
cpoulos62's Avatar
Got my Blu Ray delivered yesterday. Watched 1 movie and it was just fine. Loved the picture clarity.
BUT today I hit my OPEN/EJECT button to removed my Blu Ray DVD from yesterday and the unit LOCKED UP.
Called Samsung Support and they said to either A. Return to the store I bought it from. B. Send it to them for repair.
But this UNIT is only 16 hours old. How can this happen. Customer care stated that it does happen sometime if you are able to unstick the unit by UNPLUGGING it, leave it like that for an unspecified time and plug it back in. Else, you are SOL!
Anyone know any other ideas on how to solve. My Blu Ray DVD is still stuck in the unit.
cpoulos62 is offline
post #1540 of 6049 Old 07-14-2007, 12:00 PM
motoman's Avatar
Did you try the unplugging solution yet? My 1200 locked up hard one time while watching a BR movie and the only way I got it to reset was unplug it and plug it back in. Unit then powered up ok and worked fine until the next lockup. I ended up returning that 1200 to Amazon.
Good luck.
Jim
motoman is offline
post #1541 of 6049 Old 07-14-2007, 12:33 PM
pal1982's Avatar
I own a high end A/V store and i have been totally neutral in the whole Blu-Ray & HD-DVD deal... but i just went out and got myself a BDP-1200 running it on Parasound HALO seperates ( C2 controller A51 250 X 5 amp, A21 250 X 2 for 7.1 with a Dynaudio speaker setup Contour S 5.4 mains S CX center, SR sides, and S 1.4 rears with 2 Sub 500 in a balanced array) the system is kicking!! i love it, why in the world you would go to HD-DVD i don't know... but the reason i wrote this is i have an affirmative that Denon is producing a Blu-ray player in September. There will be 2 models a standard and then a higher end one, kind of like the 2900 and 5900 series, ya know??? no price or nothing.. but i can't say who told mejust know its legit.
Middle Tennessee & S.W. Florida
www.premieracousticlifestyles.com
see it. hear it. feel it.
Brad Bossman
pal1982 is offline
post #1542 of 6049 Old 07-14-2007, 01:14 PM
cpoulos62's Avatar
Good luck.
Jim
I did the unplug solution and it did not work. Any other ideas??
post #1543 of 6049 Old 07-14-2007, 02:21 PM
jdcerank's Avatar
I just purchased the BD-P1200 this week from Sears (cost of $599.00) and it plays beautifully. The picture on my 720P/1080I Panasonic Plasma was excellent. The BD played using the 1080P setting which my TV accepts. I watched Casino Royale last night for my first BD. I am using the coaxial digital into my AV and it sounded really good. I did one pause w/o any problems and the BD ejected OK after viewing. After buying the 1200, first thing that I did was the firmware update via the internet. That was very easy to do. I noticed that the player version was updated first. Did you do your firmware update? I have read all of the threads on this posting and have found them to be both additive and much informative. Thanks to all, keep up the insight which helps us all. I also own the Toshiba A2 HD-DVD player and have enjoyed watching those HD movies as well. I don't suppose there is a reset button on the outside of this BD player? That would be too easy I suppose.
Good luck.
Jim C.
jdcerank is offline
post #1544 of 6049 Old 07-14-2007, 02:42 PM
Adz523's Avatar
Is anyone familiar with this issue? Its killin' me as its forcing me to run coax for SD DVDs (going into the 1200 and setting it a bitstream) and then HDMI Audio for Hi Def DVDs (going back into the 1200 to set it for PCM).
Adz
Adz523 is offline
post #1545 of 6049 Old 07-14-2007, 03:31 PM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 33 Post(s)
Liked: 49
aaron_hinni was/is having this same problem with a Pio receiver a while back - see post #340 in this thread. I can't recall if others are, as well, but I am not having problems using bitstream/HDMI/Denon 2807. You may wish to PM aaron who's a nice and knowledgable guy. Good luck!
RUR is offline
post #1546 of 6049 Old 07-14-2007, 04:10 PM
Adz523's Avatar
Originally Posted by RUR View Post
aaron_hinni was/is having this same problem with a Pio receiver a while back - see post #340 in this thread. I can't recall if others are, as well, but I am not using bitstream/HDMI/Denon 2807. You may wish to PM aaron who's a nice and knowledgable guy. Good luck!
Thanks. I'll do that. I'll also try another 1200 unit. I had the Sony for awhile and it worked fine with my HDMI processor.
Adz
Adz523 is offline
post #1547 of 6049 Old 07-14-2007, 05:09 PM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 33 Post(s)
Liked: 49
Welcome. After re-reading my post and to be clear, I should have said that I am not having problems sending bitstream via HDMI to my Denon 2807. So we know the Sammy will do it in some circumstances
RUR is offline
post #1548 of 6049 Old 07-14-2007, 05:24 PM
Patrick Bennett's Avatar
Which audio format are you trying to send via bitstream through HDMI?
Regular DD, DTS, Multichannel PCM (<= 5.1) pass fine for me through HDMI.
DTS-ES(!?), TrueHD, Dobly Digital+, DTS-HD MA don't pass through HDMI.
Patrick Bennett is offline
post #1549 of 6049 Old 07-14-2007, 06:07 PM
davenrino's Avatar
Originally Posted by davenrino View Post
So far, my Sammy has performed flawlessly on 6 Blu-ray titles, 1 Superbit DVD and 4 DVDs backed up on Verbatim +R. I haven't experienced any of the problems in this thread and think I may retire my Oppo to my Guam condo.
EDIT: I did have the lip-sync issue at 1080p @24fps.
Add 2 more BD watched. I stopped "The Departed" halfway through and shut everything down for the night. Today I fired everything up and the BD started up where I left off but only for a few frames. It ejected and gave the message - "CANNOT PLAY THIS DISK". I closed the tray again and it started up normally from the beginning of the disk with no further problems. It was a Netflix disk but I thoroughly cleaned it before use as I always do.
Dave
post #1550 of 6049 Old 07-14-2007, 08:09 PM
Adz523's Avatar
Standard DVDs, so DD and DTS. I get no sound over HDMI with bitstream.
Adz
Adz523 is offline
post #1551 of 6049 Old 07-15-2007, 06:34 AM
Scott_NY's Avatar
Originally Posted by axmode View Post
Two freeze overs to report:
- Layer cake, which I had purchased new from Frys. I did not take note of the chapter. I simply rewind it, and it then skipped a whole chapter. Upon fast forwarding to the frozen scene, it worked through it without any further issues.
- Black hawk Down. Same scenario as above but I made a note of the chapter which was chapter 13.
I have the most current FW which I uploaded via a CD. I believe it to be the 05/23 FW. So far, 2 freezing incidents in about 25+ BD viewing occasions.
Hi,
I have two more to add to this same problem. I had a freeze on "Derailed" near the end of chapter 16. I had to unplug the player and plug it back in. Then I had to go to chapter 17 to avoid the freezing. (I had tried several times to continue from where I had the problem without success). Even if there is a problem with a DVD, the system should not reuiqre being unplugged to resolve!
Also had the problem with "The Shooter" with Mark Walhberg. I don't remember where in the movie.
Scott_NY is offline
post #1552 of 6049 Old 07-15-2007, 06:40 AM
cpoulos62's Avatar
Does the Sony BD have locking problems like the 1200? Customer Support stated that it does happen on the Samsung.
I could not un-stick/lock my 1200. I have my BD DVD now stuck in. Menu either says "LOADING" or "OPEN" depending on what button I hit.
post #1553 of 6049 Old 07-15-2007, 06:44 AM
schlitzie's Avatar
I had the same issue with Pioneer 94. Completely locked up even with multiple unpluggings. After I pulled it from the rack to get it boxed up for a return, I plugged it in one more time just in case - and it ejected the disc. I think moving the player jostled something, and it released whatever might have been hung up internally.
schlitzie is offline
post #1554 of 6049 Old 07-15-2007, 07:17 AM
cpoulos62's Avatar
No luck here even after opening it up and trying a few 'love' taps.
post #1555 of 6049 Old 07-15-2007, 07:27 AM
Big J's Avatar
So far, I've tried 2 BDs. One froze and had lip sync issues @1080i, the seond wouldn'r play at all- it just skipped like crazy, sputtering video and audio regardless of where it was in the disc, even after epeated tries. It plays DVds fine.
I'm underwhelmed.
j
Big J is offline
post #1556 of 6049 Old 07-16-2007, 07:38 AM
Adz523's Avatar
I spoke to Customer Service today. The person there told me that since the Samsung 1200 is 1.3, both my HDMI cable and my receiver/processor need to be 1.3 in order to send bitstream over HDMI. That doesn't make sense to me but it wasn't worth arguing. Anyway, my cable is 1.3 compliant (new from Cobalt), but my processor is only 1.1. Almost all receivers and certainly all processors are also either only 1.1 or 1.2, so am I missing something here?
Adz
Adz523 is offline
post #1557 of 6049 Old 07-16-2007, 07:44 AM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 33 Post(s)
Liked: 49
Don't think so. My receiver is not HDMI 1.3, yet I'm able to get audio perfectly fine via bitstream. As indicated, that's not true for everyone, but the reason why some do and some don't is beyond my limited technical expertise, sorry!
RUR is offline
post #1558 of 6049 Old 07-16-2007, 07:55 AM
imperialyoyo's Avatar
Bought the unit and updated to latest firmware. Many thanks to this thread, am very happy with the bdp-1200.
I had a problem with the blu ray version of "Invincible" with Mark Wahlberg, could not get to the disc menu. The back of the box shows clearly that there are some extra features on the disc, wondering if it is player related.
imperialyoyo is offline
post #1559 of 6049 Old 07-16-2007, 07:57 AM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 33 Post(s)
Liked: 49
Sounds like a Mark Wahlberg problem, to me
RUR is offline
post #1560 of 6049 Old 07-16-2007, 09:10 AM
phansson's Avatar
I can't pass anything bitstream via HDMI to my Pioneer 84txsi via HDMI.
phansson is offline
Reply Blu-ray Players
Samsung Bd P1200 Blu Ray Disc Player
