AV Multi Out to HDMI? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 05-01-2007, 11:00 AM - Thread Starter
Amel's Avatar
I have my PS3 connected over the AV Multi out cable to my HTIB...
my question is, is there an AV Multi Out to HDMI cable available for audio transfer?
the only way I could get the PS3 Audio connected over my HTIB was over the AVMulti Out Cable, are there any other options?
I have the PS3 video over HDMI to my LCD
and the PS3 audio over AV Multi Out to my HTIB Samsung Q85
Blu-Ray Supporter
Amel is offline
post #2 of 23 Old 05-01-2007, 11:54 AM
GotHDTV?'s Avatar
Quoted: 14 Post(s)
Uh, Don't know if you tried this, but how about optical cable straight from your PS3 to your HTIB. The receiver in the HTIB has to have an optical connection.
GotHDTV? is offline
post #3 of 23 Old 05-01-2007, 02:08 PM - Thread Starter
Amel's Avatar
why does it have to have an optical connection?
Blu-Ray Supporter
Amel is offline
post #4 of 23 Old 05-01-2007, 02:50 PM
GotHDTV?'s Avatar
Quoted: 14 Post(s)
You asked if you have any other options and I gave you one.
I believe there is only 3 ways to get sound out of the PS3. 1. The Multi out, which you are using. 2. Optical. 3. HDMI.
You're not going to get 5.1 surround sound with that multi-out, only left and right.
Unless your receiver has HDMI, you're not going to get sound from your receiver, only from your TV. If your receiver does have HDMI, you can hook another HDMI from your TV to your receiver (or receiver to TV if you hook the PS3 to the receiver and not the TV). This will allow you to get 5.1, etc.
Optical will get you 5.1 also. This is a good option for you since you don't have to buy any special cables, just a plain optical.
Hope that helps
GotHDTV? is offline
post #5 of 23 Old 05-01-2007, 02:59 PM
GotHDTV?'s Avatar
Quoted: 14 Post(s)
Opps, I didn't read your 2nd question right. I said that your HTIB has to have an optical connection because I'm assuming is a 5.1 HTIB. Those have been around for at least 5 years, so I'm assuming you have one of those. I have never seen one of those receivers without an optical connection.
If you have optical, then it is your best bet to hook up sound unless your receiver has HDMI.
Hope that helps
GotHDTV? is offline
post #6 of 23 Old 05-01-2007, 04:00 PM - Thread Starter
Amel's Avatar
yes the receiver has an HDMI out and IN....any other options?
I am just looking the get the best out of it
thank you for you answers GotHDTV?
Blu-Ray Supporter
Amel is offline
post #7 of 23 Old 05-01-2007, 04:03 PM - Thread Starter
Amel's Avatar
I read this again
so my best option would be hooking up the PS3 to my TV over HDMI and then connect the TV with the receiver also through HDMI? is that about right?
Blu-Ray Supporter
Amel is offline
post #8 of 23 Old 05-01-2007, 04:06 PM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 370 Post(s)
Liked: 240
I read this again
PS3 to HTIB via HDMI for both audio and video.
HTIB to TV via HDMI for video. Audio will come from the HTIB.
RUR is offline
post #9 of 23 Old 05-01-2007, 04:21 PM - Thread Starter
Amel's Avatar
I think I did that and my TV showed a message saying 'unsupported mode'. I thought it would not be a problem since the receiver has a HDMI out and in?
I will try it again, it looks like the best option would be optical for right now...
Blu-Ray Supporter
Amel is offline
post #10 of 23 Old 05-01-2007, 04:25 PM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 370 Post(s)
Liked: 240
Have you set the PS3 to a resolution which the TV will display i.e. 1080i, 1080p etc? Hold down the PS3 on button until you hear the second beep, then see what you get on the display.
You're better off using HDMI, if we can sort this issue out.
Ken
RUR is offline
post #11 of 23 Old 05-01-2007, 06:22 PM - Thread Starter
Amel's Avatar
yea its set to 1080P on my Samsung 4665F
Blu-Ray Supporter
Amel is offline
post #12 of 23 Old 05-01-2007, 06:53 PM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 370 Post(s)
Liked: 240
OK. To keep this simple to sort out, can you connect the PS3 directly to the TV via HDMI? Do this, then re-select 1080p in the PS3 video output setup. If you get a blank screen, the TV doesn't support that resolution. If all is well, it will test, then give you an OK screen.
Let me know what happens.
Ken
RUR is offline
post #13 of 23 Old 05-01-2007, 08:44 PM
WriteSimple's Avatar
Firstly, it would be helpful if you post the model of your HTiB.
Secondly, not all HTiBs have optical/coaxial digital inputs.
Thirdly, not all HTiBs have HDMI inputs, and not all of them can handle PCM audio via HDMI inputs.
fuad
"DonÂt let them tell you who you are is not enough, that itÂs wrong and that you wonÂt find love. DonÂt let them use my life to put your future down, or tell you that happiness canÂt be found."
WriteSimple is offline
post #14 of 23 Old 05-01-2007, 11:13 PM
GotHDTV?'s Avatar
Quoted: 14 Post(s)
I read this again
Sound right to me. That seems to be the easy way. Or you can do the PS3 to the receiver then to the TV, but it seems that has not worked for you.
Make sure when you set the audio to set it to go through HDMI. If you did not change it from multi-out, then the sound will still be from the multi-out. I had that happen with me when I had my PS3 hooked into my bedroom TV via HDMI, but I took downstairs to my old TV which is only component (and my HTIB has optical). I had to switch not only to multi-out for video but sound to optical also.
Hope that helps.
GotHDTV? is offline
post #15 of 23 Old 05-02-2007, 08:20 AM - Thread Starter
Amel's Avatar
fuad
I did, if you read my first original post
its a Samsung HT-TQ85, it has both
here are the specs http://www.samsung.com/Products/Home...tq85_final.pdf
Blu-Ray Supporter
Amel is offline
post #16 of 23 Old 05-02-2007, 08:23 AM - Thread Starter
Amel's Avatar
Hope that helps.
crap, I don't know what it is, it just doesn't work....
I will order some optical cables and see if the sound improves
don't get me wrong the sound thru the AV output is good, I can't complain, but I might be missing the 5.1 sound and that would suck
Blu-Ray Supporter
Amel is offline
post #17 of 23 Old 05-02-2007, 09:01 AM
Jiffylush's Avatar
HTiB says it is 1080i, it may not support 1080p which is causing your problem with no video.
I bet if you deselect 1080p and only select 1080i and 720p you will clear up your problem.
It doesn't mention audio in over HDMI, or PCM, but it does have optical. So you will at least be able to get 5.1, if not PCM over HDMI.
Jiffylush is offline
post #18 of 23 Old 05-02-2007, 12:19 PM - Thread Starter
Amel's Avatar
so 5.1 over optical or maybe if it works PCM over HDMI?
thanks
Blu-Ray Supporter
Amel is offline
post #19 of 23 Old 05-02-2007, 02:02 PM
GotHDTV?'s Avatar
Quoted: 14 Post(s)
Amel, so did you change the output setting for audio on the PS3 to come out of HDMI? I know it sounds stupid and like I said before, I have encountered that the PS3 only outputs sound (and video) out of one connection. You have the sound coming out of the multiout, so I think you didn't you change it. If you don't do the setting change, you will not even get sound if you buy optical cable.
Come to think of it you may have to not only do the output connector setting, but also how it is outputted (bitstream or PCM, etc). Do the connector setting change first though and see what that does.
I'd also do what Jiffylush said to do about your video problem.
Hope that helps
GotHDTV? is offline
post #20 of 23 Old 05-02-2007, 02:46 PM - Thread Starter
Amel's Avatar
I did, it did not make any difference....as soon as I get the optical cable I will update this thread
thanks guys
Blu-Ray Supporter
Amel is offline
post #21 of 23 Old 05-03-2007, 12:20 AM
GotHDTV?'s Avatar
Quoted: 14 Post(s)
thanks guys
Okay, when you did that, did you get sound out of the TV with just a straight HDMI connection? If you did then, the sound output is fine and the issue is from your TV to your receiver. If that is the case, there has to be a setting in your tv. If that is not the case, then there must be a setting problem on your PS3.
Just to double check, did you save your settings too?
GotHDTV? is offline
post #22 of 23 Old 05-05-2007, 07:36 AM - Thread Starter
Amel's Avatar
hey
great news
got my optical cable yesterday
holy crap, what a freakin difference, I almost peed myself
it's unbelievable, the whole system rocks, thanks guys!
Blu-Ray Supporter
Amel is offline
post #23 of 23 Old 05-05-2007, 12:04 PM
hey
great news
It rocks, until you get the upgrade itch. Glad you finally get the full use of your HTiB.
fuad
Reply Blu-ray Players
